Rob Watts or John Franks said, for sure, Hugo is powered by the batters inside, even when the charger/power supply is plugged, so upgrading the power supply won't have a positive influence on the SQ.
I used to think that the Mojo was always powered from the battery, but then last month Rob said:
To understand it better, let's assume Mojo is off and charging.
Now the charger has two modes of normal operation - constant current, which is set to 330 mA, and constant voltage which is set to 8.200 V. Now when the non charging battery battery voltage is less than 8.200 V, then the charger supplies a constant current. But when the non charging battery voltage gets close to 8.200 V, then the charger switches mode to constant voltage at 8.200 V. The current that is charging the battery then slowly falls from the initial 330mA, to zero - its in the trickle charge mode now. Eventually, the non charging battery voltage hits exactly 8.200 V, the charger is in constant voltage mode of 8.200 V, no current now flows into the battery, and the charger switches off automatically. When the battery voltage falls to 8.0 volts, then the charger will return to charging. Tip - if you want to force the charger to top up Mojo's battery to 8.200 V then removing the charge USB, wait 5 seconds, reattach, and the charger will top it up to 8.200 V.
Now imagine that Mojo is on at the same time as it is charging.
In this case, the battery will continue to charge until it gets to 8.200 V, and the charger is set to voltage mode and gives 8.200 V too; so no current flows into or out of the battery; but Mojo itself is drawing 180 mA of DC current, and this will simply come from the charger - so the charger will supply the needed 180 mA for Mojo. It will do this for ever, and it won't switch off. This is intended, as it means that the battery is effectively not being used to supply the bulk of the current, won't charge or discharge, is held at a safe level, and will operate like this for a very long time.
Now we have been talking about DC currents, and this is indeed the vast bulk of the current. But what about dynamic currents and noise? Because the output impedance of the battery is much lower than the charger, then the noise of the charger is reduced; also dynamic currents still comes from the battery. So running in this mode ensures the best of both worlds - low RF and audio band noise from the battery, large dynamic currents available, and low PSU impedance too - but without the worry of the battery wearing out from charge and discharge cycles.
I hope this clarifies.
Rob
I wonder if the same principle applies to the Hugo?
