My pair has been stuck in San Francisco for the last three days. It must be at a music festival, or riding a trolly, or at a boy's club or something...
Uehdbdldpwpabwyyofpcnebwjwoe!!!
I had the same issue. It's easily fixable. TThere's a band petruding out too far. Take a pliers and squeeze enough to compromise the black plastic band, and turn the plug. You're basically using force to reshape the ring.Just received my 'thick' cable from Aliexpress. Unfortunately, one of the connectors is defective..
The part circled on the right is the main issue. The black piece isn't flush with the rest of the connector, so I can't get it into any device. I'm not sure what the left part is. It's not just a visual marking, when I run my nail in that area it feels as if there is a small recess. I'm not sure if it has any effect on the cable, but I can't test it anyways as the protruding black piece is preventing me from doing anything.
Going to contact the seller and see what can be done about this.
Hope this helps
The materials this seller uses is top notch. However, his qc is suspectHaha yea, that was the first thing I thought of doing. I just wanted to post here and contact the seller before potentially damaging the connector even more Thanks though! Good to know you were able to fix it successfully.
Everyone , i just came across this thread very recently and it is mind bogglingly long. Obviously i read thread as i could but i hit ceiling and couldn't further than that. So, I apparently get the sense that some chinese manufacturers produce high quality headphones that are very similar in quality and performance to popula brand name headphones like sony. I did get the sense that there are a lot of hit and misses sometimes like the takstar pro 80 where the headphone cups are not properly aligned. But i did here there were good ones too. I am right now looking for a great full size headphone and am a novice by the way. Can anyone recommend me a good one that i can get on amazon. Thank you very much!!!
I put the comfort padding back on the hd681 evo, it's the thick sound dampening felt over the driver that I removed. They really do sound 1000 times better this way. I'm really happy with them with this mod.
