Bought this year following asian IEMs and would rank them:
ATH IM02 > Tenore > TTPOD T1E > Havi B3 Pro1
wondering if I should try to get my hands on the Ostry or Sony MH1 as a Tenore replacement, I sadly have 2 broken sets of them.
Hmm, I would think the T1-E is somewhat similar to MH1 but better and an upgrade while being a little different signature wise. Tenore is supposed to be even more similar to MH1, but again, an upgrade sq wise... tho it won't do you any good if your Tenores are broken... :/ So MH1 might be a similar but more reliable slight downgrade with an annoying cable from what I've gathered.
B3 is more similar to Ostry, but better when properly driven so no point in getting the Ostrys unless you like a little brightness, more fatigue potential, & more thinness over naturalness, a hair of warmth, neutrality, and big deep soundstage.
Also, I like the T1-E and B3 better than the Tenore personally.
Cool, many thanks for the info.
I have read comments about volume being low, I would be driving them with a cell phone - un amped - do you think they would be too quiet?
essentially I am looking for a pair of over ears for when I am travelling and for occasional use at home
Np. It would be good for traveling and home. Comfortable minus a little heat/stuffy after long periods, isolating,
really durable. They are only pretty quiet at low to moderate volumes(better at high), but the isolation is good & the music seal is even better. And if you turn the volume slider up and make sure the ears sound balanced then don't touch it again. Then only ever control it with your source.
I could turn them all the way up for a while and listen for a while no problem. I think I listened to them at 12-14/15 most of the time on Droid 2 Global back in the day. I wouldn't say they are power hungry at all, just not too sensitive. Also, if you use an app like PowerAmp music player you could use the pre-amp for a little extra volume if need be. What kind of phone do you have? Because some are louder than others...
