Chinese / Asian Brand Info Thread (Headphones, IEMs, Amps, DACs)
Status
Not open for further replies.
Jul 22, 2016 at 9:39 PM Post #31,711 of 35,472
most important is that they use wm8740 chip
Jul 23, 2016 at 3:05 AM Post #31,717 of 35,472
how is the battery life looking on that AGPTEK? tempted to go for one
manufacturer says it's 12 hour. I'm sick with a cold right now (3am local) so I'm collecting 1st impressions. It's got the heft and polish of quality kit. Screen is large, boots to AGPtEK logo. All the buttons are solid. The volume wheel knob is much more ergo friendly than I had anticipated. Sound is big, fun, and detailed.
Jul 23, 2016 at 3:23 AM Post #31,720 of 35,472
Been using westones 4r for a few years now, thinking maybe its time for a upgrade. How does zhiyin qt5 compare against w4r, or are there other options that I should look at?
Def not that IEM. Haven't heard it but it's not positive. SW3, possibly the Delta Master 4/6 which should be released soon. The NiceHCK DZ7 has i believe one purchase but it's positive
Jul 23, 2016 at 4:21 AM Post #31,722 of 35,472
  Which is better, Awei Q5 or Q9? I am less concerned with build quality at this price point
 than sound quality.
Both are utter cr¤p! Steer away from them! Tell us Your price limit and we share better recommendations.
Jul 23, 2016 at 5:58 AM Post #31,724 of 35,472
I appreciate the honest reply. I'm looking to spend $20 USD max on a pair of IEMs. There are an intimidating number of options on Aliexpress.
I would suggest going thru the KZ thread. KZ's are all under $20 and more often than not pretty shockingly good for the money.
One of their $10 models (ATE) is my favorite IEM under $70.
(disclaimer: I have 3 different KZ models I've never heard as well as lg quadbeat 3's on the way, all of which are hopefully good)
Jul 23, 2016 at 6:20 AM Post #31,725 of 35,472
Although I have not received my Sendiy M2 yet, mine has another diaphragm against carbon fiber diaphragm version.
According to the product page of the direct shop, the diaphragm is platinum alloy liquid metal.
platinum alloy liquid metal diaphragm???
However, the diaphgram image of the product page different  from carbon version but  its frequency response curve is same
Perhaps mine might sound different from other M2s.
(from http://www.head-fi.org/t/684159/chinese-asian-brand-info-thread-headphones-iems-amps-dacs/22470#post_12341183 of @1clearhead )
(from the product page of the directshop on Aliexpress )
Status
