notamethlab
- Feb 23, 2014
Are there any Chinese competitors for Comply tips? They're the only tips I've found that give me a consistently good seal on my Dunu 2000Js but I think they're pretty overpriced for what they are.
Yeah there actually is and they're pretty good I'll link you an example of them. Just a suggestion if you're going to order make sure you specify the nozzle wize 3mm or 5mm
4Pairs(8pcs) KZ Noise Isolating Memory Foam C sets 3mm 5mm
http://s.aliexpress.com/f6jEfAVf
(from AliExpress Android)
