MrScratch
- Sep 5, 2012
Anyone know if this thing works with a Galaxy S3 phone pumping USB audio over otg cable?
It's not made to be run from a mobile device, but iv read it has worked on some android phones, maybe with audio recorder pro app from play store can drive it. Also phone probably can't give it enough juice to run. Maybe with something like this, that can pull additional power from portable usb charger: http://www.ebay.com/itm/Micro-USB-Host-OTG-Cable-w-USB-power-Male-Female-Samsung-S2-i9100-S3-i9300-9220-/281145913835?pt=US_Cell_Phone_PDA_Cables_Adapters&hash=item41759a31eb
Also, have a look at this thread: http://www.head-fi.org/t/595071/android-phones-and-usb-dacs
And: http://www.head-fi.org/t/628667/has-anyone-tried-aq-dragonfly-with-s3-using-otg
To be honest, I've stopped trying to run my DF with my Windows 8 Ultrabook, which I use with my desktop rig.
With my MacBook Retina and my 2009 Mac Mini, it works great and that's that
Ah he did say that, DF seems to default to 96khz (magenta) when you plug it in on a windows pc, did you test it with 44.1 (green) on the other pc? Mine had problems with 44.1/88.2, and worked okey with 48/96 for a while, untill i started hearing little clicking on that too every now and then.
I've been thinking about getting one of these. I have a Macbook Pro and LCD3's, and while I don't take them on the road often, I'd like something a step up from my Fiio E17 for when I do. While someone said this will drive the LCD3, has anyone tried it? Is this a step you would recommend for me?
Thanks!
