wenyuanalive
- Aug 10, 2013
kryten123 - I have the same issue as you with windows xp only. Audioquest was no help either. They said it was a driver issue, but I used a few different ones and all had the same issue. Mine shoots to full output and does the crazy freakout thing once I come back up from zero. Windows 7 and OSX have no issues at all. Yes, with IEM's, volume can get high quickly and I did not like that. I also felt it did a better job as a DAC only and not as a headphone amplifier.
Anyone know if this thing works with a Galaxy S3 phone pumping USB audio over otg cable?
Anyone following the GEEK Kickstarter project? It looks very interesting.
I sure am - and backing it. I'll compare it to the Dragonfly when the time comes.
Hi,
Is it possible to use a Music Fidelity V-Link with the Audioquest DragonFly? If so, I don't understand what the order of connections would be and how one would connect the output of V-link to the Dragonfly and in turn how the DF would be connected?
Perhaps the idea is nonsensical; if so please advise.
Thanks
Ian
I thing you want to add an amp to that equation to get better performance out of the HD650.
