My thoughts are the same Anj. I've had these cans for some months now and never considered upgrading once. These are my endgame for sure, i just hope these 2.2 prefazor drivers don't give out any time soon!
Audeze LCD-2 Impressions Thread
- Thread starter DefectiveAudioComponent
Anjolie
- Oct 24, 2013
You know what's the worst? Going through the other threads on Head-Fi! I've had the LCD-2F for a few weeks and now I'm being tempted to upgrade to the LCD-X because I want a little more in the treble which describes the X perfectlyMy thoughts are the same Anj. I've had these cans for some months now and never considered upgrading once. These are my endgame for sure, i just hope these 2.2 prefazor drivers don't give out any time soon!
I'm going to have to check out the Schiitr. They have a pair of LCD-XC over there and it'll give me a better idea
I hope your 2.2 prefazors live long and prosper. Happy listening!
-Anj
- Jul 7, 2014
Don't forget that synergy is everything!You know what's the worst? Going through the other threads on Head-Fi! I've had the LCD-2F for a few weeks and now I'm being tempted to upgrade to the LCD-X because I want a little more in the treble which describes the X perfectly
-Anj
Anjolie
- Oct 24, 2013
Thanks for reminding meDon't forget that synergy is everything!
areek
So, finally an update on my headphones-
after waiting for 1 month and 2 days, I finally got back my lcd-2s from rma. Right driver was losing connection (connector issue). I had to send em to audeze and they shipped it back within 10 days after receiving it. BD customs held it for a week more. Good news is, I had zero hassle with customs and auduze paid for all the customs fee as well as the c&f charge. I just had to pay a warehouse charge of 206tk. And the biggest thing is, I requested for a replacement vegan pad if they had to replace the pads and they did replace it (wow). so overall not a losing venture. Excellent service from audeze.
Anyways, time for a review. I had ordered a VE Zunkosha silver wire (4 wire) mini xlr to 6.35mm single ended cable for my Audeze LCD-2. The wire is nicely built, sleeved according to my specifications. cable looks thin but is quite strong. The mini xlr connectors are a bit stiff when trying to remove and is my only complaint regarding this cable. However, the sound is what matters. These have a clearly audible difference from the original cable. these have a much wider soundstage and the instrument separation is better with improved imaging. the overall sound is laid back in comparison to the in your face sound of the originals which is a welcome change considering it is less fatiguing and more relaxed. These also reduce the mid bass slightly. however, if you are a lcd2 user who would prefer a slightly more relaxing sound, it is a great option for just 35 bucks. although if u can, get the 8 wire option which would cost you around 60$.
Sound Eq
- Nov 9, 2013
On the LCD4 thread, the guys were using carnuba wax with excellent results.
the wood became dull and lost its gloss, can you link me to the right thing to buy from ebay
and how to use it
Anjolie
- Oct 24, 2013
Very nice! How do you like the vegan pads versus the regular lamb skinSo, finally an update on my headphones-
areek
lighter, less stiff, exert less lateral pressure on my ears so more comfortable. vegan is the way to go.Very nice! How do you like the vegan pads versus the regular lamb skin
Anjolie
- Oct 24, 2013
I'm all for more comfort! How do you feel it affects the sound quality if anylighter, less stiff, exert less lateral pressure on my ears so more comfortable. vegan is the way to go.
areek
I did not get the leather pads back so gotta say from memory that it sounds pretty much the same to meI'm all for more comfort! How do you feel it affects the sound quality if any
Anjolie
- Oct 24, 2013
I just had a revelatory moment. I was having problems with getting my liquid carbon to work for an A/B comparison with my Hifiman EF-6. At first I thought it was my power cable. I know. Terrible logic. So I changed out my "audiophile" cable for a "regular" no-name power cable. Still nothing. So I went about playing with the buttons again and viola! I got sound!
I wish Alex Cavalli would label his buttons better because I don't know what they are with his cryptic symbols
However, something was amiss when I plugged my EF-6 back in. The sound seemed veiled. Constipated. In a word, "yucky". I then went back to the "audiophile" cable and that "yucky" word changed to "WOW"
The EF-6 was transformed and what I heard was something more spacious. Everything had authority. Everything had more everything. It was crazy. It's making me love my amp and the LCD-2F even more....and this is playing AAC files ripped from CD's through iTunes. I can't vouch if this power cable change will transmorgify your mini-buck amp to sound like a mega-buck TOTL amp. But if you've got access to some better cables, it's worth a try to see if it will help your system
Forgive my noobiness. I'm still learning here. I'm just very excited
PS: I'm not a plant for "audiophile" cable
MRC001
- Mar 20, 2014
Ergonomic tip: adjusting so the ear cups ride a bit high, or at least not too low, often reduces jaw pressure and increases comfort with headphones. Put differently, low-riding ear cups can increase jaw pressure. Also, a good all-around seal is important for ideal frequency response, especially noticeable in bass extension.... Although, the clamping force isn't excessive, I still feel it putting pressure on my cheeks and jaw ...
George Taylor
Seconding for as far as the comfort issue goes. Had the same problem when I first got my LCD2s, and since then don't wear the as low on my head. No problems since adjusting.Ergonomic tip: adjusting so the ear cups ride a bit high, or at least not too low, often reduces jaw pressure and increases comfort with headphones. Put differently, low-riding ear cups can increase jaw pressure. Also, a good all-around seal is important for ideal frequency response, especially noticeable in bass extension.
Anjolie
- Oct 24, 2013
Thank you for the tip! Much more comfortable nowErgonomic tip: adjusting so the ear cups ride a bit high, or at least not too low, often reduces jaw pressure and increases comfort with headphones. Put differently, low-riding ear cups can increase jaw pressure. Also, a good all-around seal is important for ideal frequency response, especially noticeable in bass extension.
johnzz4
Check out this post and read the page or so after:the wood became dull and lost its gloss, can you link me to the right thing to buy from ebay
and how to use it
https://www.head-fi.org/threads/audeze-lcd-4.782442/page-388#post-13470925
Total: 11 (members: 0, guests: 11)
