Apex Glacier amp/dac review and appreciation thread
post-8923574
Post #166 of 863
turokrocks
post-8924078
Post #167 of 863
ObeyurMaster
Originally Posted by turokrocks
Is that the venture craft cable that you've modified? The whole thing looks very neat!
The only reason stopping me from getting the Glacier is the availability of such a cable. I suck at soldering.
post-8924091
Post #168 of 863
turokrocks
Yeah, to be honest I am also novice in soldering, and if you never try (even if you fail) you will never learn.
It was relatively simple to modify, and it looks neat.
I have the Hak5 shop cable, but its long and this looks neat.
I will try to help anyone who needs to modify it.
post-8924096
Post #169 of 863
turokrocks
...Ah..one more thing, it sounds amazing.
The Glacier has one of the best refined micro details I ever heard from a portable amp.
post-8924110
Post #170 of 863
turokrocks
@ObeyurMaster
You can ask Frank , from Toxixcable (http://www.head-fi.org/u/279519/toxic-cables) to make you one.
I will ask him to do one for me in the near future.
It will look miles better....
post-8924345
Post #172 of 863
ObeyurMaster
@ObeyurMaster
Thanks turokrocks.
I know there are two different inputs for charging and usb in. Does the Glacier charge through the DAC usb input? I prefer it doesn't or can be disabled. I don't my galaxy S3s battery to drain out.
post-8924382
Post #173 of 863
turokrocks
post-8924386
Post #174 of 863
turokrocks
Thanks turokrocks.
By default, yes it will charge from both, but pushing the gain and reset, will turn it off (even after a shut down, as to charging from the DAC).
post-8924724
Post #176 of 863
turokrocks
Even with my Dx100 , I did not get such clarity and sound-stage.
I am happier with this setup, than the DX100, alas, no 96/24 capability (android limitation...for now)
Neutron with the Glacier, are giving me the chills............................
post-8925365
Post #177 of 863
zachchen1996
any comparisons between the glacier and the uha-6s mkii yet? They are both DAC/AMP, would be interesting how they comapre.
post-8926608
Post #178 of 863
Kazenagi
I was planning on saving up for a DX100 to pair with my 8A but it seems getting the Glacier and using it with my Note2 looks even more attractive now..
post-8926620
Post #179 of 863
cooperpwc
...you should hear it.
...thanks.
I do want to hear it!
It sounds like you are really happy with the DAC.  That is the factor that is starting to intrigue me about the Glacier. Having heard the TTVJ Slim, I am confident that the amp section is good.
post-8926659
Post #180 of 863
daniel_hokkaido
just turned off dac input recharging. can i expect to hear a cleaner signal?
