AP80 - Hidizs next portable Hi-Res music player
Aug 31, 2018 at 7:06 PM Post #646 of 4,614
Well it's probably the same design as modern smartphones - glass sandwich with metal frame. It's not that hard to open up, any smartphone service shop could do it and there are a bunch of guides on youtube as well, most use a heatgun.
The bigger issue could be finding the specific battery, unless you could buy a direct replacement part.
There is an electric hot plate you can buy that heats to the correct temperature to soften the glue. Once glue is soft after a few minutes, you pry open the device and access the battery. Get the measurements and specs for it, 3.7 volts and the mAh. Then order a battery from eBay or somewhere else and install with solder iron.
Sep 1, 2018 at 3:44 AM Post #648 of 4,614
Completed testing standby time.
Given:
FW version 0.08beta
Bluetooth -> OFF
Standby mode -> ON
Play on PAUSE
IEMs connected
23:40 -> 68% batt - start of the test
10:40 -> 65% batt - end of the test
Equals:
3% -> 11 hours = 0.27% / hour
100 / 0.27 = 370 / 24 = 15 days
So, AP80 with FW 0.08beta consume 0.27% of battery per hour in standby mode + play put on pause and can stay as long as 15 days until full discharge.
I think that the problem of headphonics is that they haven't turned on Standby mode.
Sep 1, 2018 at 4:00 AM Post #649 of 4,614
Hello @kenloveme
You promised to update this thread thread about the AP60Pro firmware. Do you have any news?
The AP200 seems to be stuck in a 0.XX beta software at the moment too.
Would be appreciated!!
Cheers.
Sep 1, 2018 at 9:21 AM Post #653 of 4,614
Given:
FW version 0.08beta
Bluetooth -> OFF
Standby mode -> ON
Play on PAUSE
IEMs connected
Equals:
Thanks a lot for the test! Appreciate it! It really clears everything. Thanks,
Sep 1, 2018 at 9:35 AM Post #654 of 4,614
Given:
FW version 0.08beta
Bluetooth -> OFF
Standby mode -> ON
Play on PAUSE
IEMs connected
Equals:
Snap! Me too :)
Well done!
I also did a test today.
I did intend to do it for 24 or 48 hours but I think I will take it with me tomorrow. So its now on recharge.
Excuse me as I copy and paste so we have the same testing format.
_________________________
Given:
FW version 0.08beta
Bluetooth -> OFF
Standby mode -> ON
Play on PAUSE
IEMs (NOT) connected
Start: 21:29 today
Finish: 09:55 today
*Real time 9:45am to 10:10pm = 12 & a 1/2 hours - my AP80 clock is set improperly. But my ipod touch photos have the correct time stamp. Same, same.
(Clock has been set properly now- I am used to wifi daps automatic time settings). :wink:
(Rough estimate 12 hours - see clocks).
12 hours a loss of 2%. On Sleep mode.
I changed the theme color so you could see more easily.
Needs more full testing from 100% and watching it tick over to 95% exactly.
But we get a rough idea.
(I also didnt see I had to turn on the stand by until this morning - usually I shut down my daps anyways).
__________________________
Already charged back up to 91% whilst I have been typing this. Photos taken 10:11pm, now 10:41pm.
Sep 1, 2018 at 9:57 AM Post #655 of 4,614
Snap! Me too :)
Well done!
Given:
FW version 0.08beta
Bluetooth -> OFF
Standby mode -> ON
Play on PAUSE
Start: 21:29 today
Finish: 09:55 today
*Real time 9:45am to 10:10pm = 12 & a 1/2 hours - myclock is set properly to local time. But my ipod touch photos have the correct time. Same, same.
(Clcok has been set properly now- I am used to wifi daps automatic time settings). :wink:
Thanks you guys for the tests now headp about that M0 comparison:wink: I’m just curious if your results concur with others.
Sep 1, 2018 at 9:58 AM Post #656 of 4,614
Given:
FW version 0.08beta
Bluetooth -> OFF
Standby mode -> ON
Play on PAUSE
IEMs connected
Equals:
Thanks for all your hard work Bro!
Sep 1, 2018 at 10:56 AM Post #657 of 4,614
It's amazing what people expect at this price point. There are DAPs that cost 5 times as much that don't have these options. I backed the AP80 to replace my ageing plenue d. I am excited for what I'm getting at this price. November can't get here soon enough.
Couldn't have said it any better. Thanks
Sep 1, 2018 at 11:40 AM Post #659 of 4,614
Given:
FW version 0.08beta
Bluetooth -> OFF
Standby mode -> ON
Play on PAUSE
IEMs connected
Equals:
This is great to know thanks!
I might have missed it but can somebody point me to the link where there is a comparo between the ap80 and the r3.
Thanks.
I don't have the link at the moment, but Bad Guy Good Audio Reviews has a comparison between the two on his youtube channel, not watched it myself either yet but looking forward to it!
Sep 1, 2018 at 11:44 AM Post #660 of 4,614
Thanks.
there's a bit of a rant at the end that hasn't much to do with the topic but the first part gives you some ideas of the differences
