Rossliew
- Jul 23, 2012
Those VU meters set my tongue wagging lol
Was purchased from Glenn. Custom headphone amp.
https://www.head-fi.org/threads/2359glenn-studio.600110/
Like @leftside I run my HE-6 from a 300b amp. My amp is the Woo WA5-LE though. 8 - 10 watts per channel, many attenuation, impedance matching, and signal matching options. Sounds fantastic. It bests my Musical Fidelity M6si. I've tried other pre / power amp combos and you may get a little more plankton but they can't match the musicality of the Woo.
These are the specs on my amp, Primare Pre32
Power
2 x 250W into 8Ω, 400W into 4Ω
I n p u t s
Unbalanced inputs
2 x RCA, 15kΩ impedance.
Balanced inputs
2 x XLR, 15kΩ impedance.
P e r f o r m a n c e
Gain
26dB unbalanced,
20dB balanced
Could someone please tell me the measurements of how my amp would power the HE-6 (6 screw) like how many W @ 8 ohms & 4 ohms? Sorry, but I'm not savvy enough in this area to figure it out.
I'm running the Genalex Golden Lion 300b, Tungsol 6F8G, and Brimar 5Z4G. Make a very good pairing with the HE-6.What tubes do you like the best on your WA5 for the HE-6?
I use my 220 Watt per channel Musical Fidelity M6si with my HE-6 with no problems.32 ohm 62.5 watt
50 ohm 40 watt
300 ohm 6.666667 watt
That's a lot of power.. I would not use that for the he-6.
you are looking at 35watt at 50ohm with that amp which is wildly overkill, not saying it will sound bad, just overkill since you only need 1/7 of that power(Hifiman EF-6 has 5 watts at 50ohm)I use my 220 Watt per channel Musical Fidelity M6si with my HE-6 with no problems.
I have a banana to XLR adapter cable that I plug directly into the speaker terminals on the amp, then I plug the HE-6 into the XLR on the other end of the cable. There are not boxes or resistors that I use with the setup. The M6si is an integrated amp so I use the integrated preamp that comes with it. I can turn the volume pot normally like I do with my speakers. 12 o'clock on the dial is loud but it is on my speakers too.you are looking at 35watt at 50ohm with that amp which is wildly overkill, not saying it will sound bad, just overkill since you only need 1/7 of that power(Hifiman EF-6 has 5 watts at 50ohm)
just out of curiosity.
what percentage of max do you keep your amp when using HE-6?.
balanced or unbalanced DAC?
did you use any gain settings on the amp?
any preamps?
post amp magic box?
Thanks for figuring that out for me! But why shouldn't I use the amp? What might happen? I have no pets or youngsters and I always turn my pre amp to zero before connecting the HE-6 and disconnect them when I'm done listening.32 ohm 62.5 watt
50 ohm 40 watt
Let me rephrase.Thanks for figuring that out for me! But why shouldn't I use the amp? What might happen? I have no pets or youngsters and I always turn my pre amp to zero before connecting the HE-6 and disconnect them when I'm done listening.
