catspaw
- Mar 31, 2011
Soloist is the Soloist SL bigger brother. Mind if I ask how you're getting the Soloist for $600? Doesn't retail for $1000?
I can give you a small advice but it is based on an estimation, so take it with a grain of salt:
I have: Asgard 1 (1W).
I listened to Burston soloist (4W edition, not sure what version it is).
Source was: Cowon i9 directly to the burston.
When I was listening to the LCD 2-Soloist this way, I would not go over 80% volume (it would be sinply put, painfull).
When I would listen from my Asgard and my HE-400 at home from the cowon i9, I could max the amp and be within crazy but listenable levels.
When I Hooked my HE-400 to the asgard one BUT with the Bifrost multibit, I would not go over 50% of the volume on the asgard (most of the time stayin at 30%).
http://www.audiobot9000.com/match/audeze/lcd-2/with/schiit/asgard-2
As you can see, it seems that you can get 128 db from the asgard on the Audeze, so in terms of volume it should be far more than enough.
In terms of quality.... Cant say... most of these amps sound very similar to me.
