Rob80b
I share your skepticism.
Balanced was designed for pro situations, like mics with very low level signals and high output impedance traveling along a 50' cord. That's a worst case scenario begging for hum/noise which balanced eliminates or at least reduces........
Balanced headphone connections and balanced interconnect connections should not be confused as they do not serve the same purpose, balanced interconnects as you've noted are used mainly to reduce noise though cancellation by incorporating a + a - and a common ground. Headphones being a passive devise are more or less immune to noise due to grounding or RF signals and even very long runs of single ended headphone cables will not be inherent to induced noise, resistance and a change in impedance possibly and balanced headphones are powered with a left + and - and a right + and - signal and do not share a common ground and therefore totally discrete, no cross-talk.
If I'm not mistaken, push/pull implies balanced by default. So what you're saying is the balanced output makes the balanced output shine.
Possibly….the Bryston BHA-1 in discussion does supply a discrete + & - signal in balanced mode to the headphone which could be beneficial to some headphone drivers.
I’ve only had my LCD2.2s for a short while but being planar magnetics they do appear to benefit the most from the balanced connection more than all my other previous dynamic headphones with added stage width and depth and possibly better base over the single ended connection.
