Dan S
- Feb 23, 2011
The Continental v3 just appeared on ALO's site. I wonder how different it sounds...
http://www.aloaudio.com/the-continental-v3
Here's the new knob. It's a Kilo ML from Digikey, diameter .625 inch, in the matte finish.
The skirt on the knob fits perfectly in the recess in the amps faceplate.
I don't suppose you'd have an actual part number or web link for that part would you?
- Meoow
- offline
******* it...I just got the V2 not long ago =.=, but I guess i just use it until it dies then I will replace it
I would be really careful replacing the battery, lipoly are not known for their stability (they are much less stable than lifepo4 and this chemistry is the reason we now have all these shipping restrictions and issues with flying wit laptops etc) and the charge circuit will be tuned for this particular battery. provided the charge circuit is internal and not in the wall wart, which you could change instead, changing to a larger capacity or different voltage could make for an .....'interesting' listening experiencesame with the tube, bias will be set up for this tube in combination with this output stage and this supply voltage, its not like rolling opamps (which themselves imo should not be rolled blind)
