irjoe
- Dec 4, 2007
will putting felt pads on the insides make hte bass more prominent? or just tame the highs?
Originally Posted by irjoe /img/forum/go_quote.gif will putting felt pads on the insides make hte bass more prominent? or just tame the highs? |
Originally Posted by cosmopragma /img/forum/go_quote.gif How do you manage to drive an Alessandro by utilizing a T-amp? ..... I mean, those bridged Tripath amps are fried by combined ground and are not suited for the relatively high impedance/ high sensitivity either. Maybe you are listening way louder than most listeners. I can't remember the MS-Ultimate distorting noticeably (similar to clipping) at my normal listening level unless the recording itself is crappy, and I do listen quite loud at an average of 80-85 dB (measured some time ago with an SPL meter calibrated to +- 1dB). Regarding electrostats : My Stax SR-4070 definitely starts to distort heavily only beyond ear bleeding volume.I estimate beyond 110 dB.I can't stand such volume for more than a few seconds anyway. My other electrostats can't be cranked that far but certainly to levels above 100dB and that's more than enough for most music except some extreme crescendos in classical music but those are too extreme for most headphones and loudspeakers and aren't often mastered that way anyway (given that your average listening level isn't above 85 dB).Even classical music is often slightly compressed in order to avoid such extreme SPL differences within one movement.Vinyl isn't even technically capable of such a dynamic range and the recording has to be compressed or the needle would jump like a kangaroo. Are you sure what you perceive as distortion similar to clipping isn't actually your hurted ears that clip? ![]() |
Originally Posted by nickchen /img/forum/go_quote.gif Actually DIY, ApatN or me. |
Originally Posted by kintsaki /img/forum/go_quote.gif 1) My friend Yanni a seasoned tube amp designer one day told me that I can drive dynamic phones with power amps in fact one day he donated me a tube amp he had made from spare part leftovers along with an adapter cable and when I tried it I was pleasantly surprised. After that i used the adapter cable to try my Trends Audio and I was surprised again. Then I tried a number of various power amps with various power ratings including 1.5, 10, 30, 80 and 180 Watt and they all worked nicely. However depending on the headphone set and the amp I would some time get some humming noise which I could get rid off by using a series resistor. |
Originally Posted by Amarphael /img/forum/go_quote.gif It's defenitly in another league than a regular RS-1 in all the aspects of resolution, sounstage, bass etc. that were mentioned BUT... I feel there's somewhat drop in treble sparkle making them a bit darker. Also strangly distortion with electric guitatrs sounds somewhat compressed... i can't figure why is that so 'cuz the upper mids are as marvalous as ever except for that. is that similiar to the 'sssh-boom' effect? ![]() So i don't like them that much with Metal currently but other than that i'm really intrigued by thier new enlarged status. |
Originally Posted by cosmopragma /img/forum/go_quote.gif Please be careful with loudspeaker amps in combination with headphones. I guess by "adapter cable" you mean a 6,3 mm (~1/4") jack at the headphones side and 4 bare wires or bananas at the loudspeaker side. In this case there are two problems: 1) Whenever you plug the headphones in while the loudspeaker amp is running there is a short for a fraction of a second.There's no way to avoid this (except you are utilizing a rare special Neutrik jack) due to the flawed concept of the TRS connector. Designers of headphone amps have to take that into account and therefor almost all headphone amps are robust regarding shorts.Many loudspeaker amps are not.A fuse might blow or in case of a fuseless ultraaudiophile minimalistic amp a whole circuit is fried ...... At least you should plug the headphones into the the jeck before you turn the loudspeaker amp on and turn the amp off before you unplug the headphones. 2) Some amps, especially bridged or symmetric/balanced amps, don't like the ground of both channels to be combined, and combined ground is another design flaw of the stereo TRS connector headphones are usually equipped with. It was sheer luck you didn't damage your Tripath chip based amp when you did drive your headphones this way, with an emphasis at not yet. Please don't do it again. I know, Greeks don't want to take advice from Germans these days, but honestly, it's not a malign conspiracy to prevent you from having fun, we just want to save your amps .......... ![]() |
Originally Posted by Amarphael /img/forum/go_quote.gif Wow are those DIY GS1000 cups you put on there? ![]() Anyways here are my 1000'ned RS-1's: ![]() It's defenitly in another league than a regular RS-1 in all the aspects of resolution, sounstage, bass etc. that were mentioned BUT... I feel there's somewhat drop in treble sparkle making them a bit darker. Also strangly distortion with electric guitatrs sounds somewhat compressed... i can't figure why is that so 'cuz the upper mids are as marvalous as ever except for that. is that similiar to the 'sssh-boom' effect? ![]() So i don't like them that much with Metal currently but other than that i'm really intrigued by thier new enlarged status. |
Originally Posted by nickchen /img/forum/go_quote.gif That works. ![]() No, the velours pad is much bigger, you get a fullsized circumaural that way. Wait, I search NoXter's pics in the german thread... ![]() ![]() Huh, looks like we didn't use 414s then, that looks rather like the stock pads of the MS1...how were they called? I always mix up flats and comfies... ![]() |
Originally Posted by kintsaki /img/forum/go_quote.gif Can someone please explain what the three holes drilled on the distancer are for and how they affect the sound? |
