Back with an update. I had a chance to try out authentic G cush and SR80x from a friend.
First, I was completely wrong about the aftermarket G cush vs genuine Grado brand. I had done some research and very unscientific hearing comparison between the two, both with MS1000 mod and stock (my distancer is detachable, see earlier post). The former added bass and muddies the sound while the latter decreased bass and brought the highs forward slightly, relative to L cush. The sound signature was much better after switching to genuine Grado G cush. All accounts of the sound characteristics from the thread were roughly inline with mine experience. From my personal preference, the bass was too strong with 13mm spacer and in turns made the treble too shrill. I tried putting a thin felt layer over the driver. It resolves the treble issue but it also muffles the sound. MS1i is not particularly resolving in today's standard. I haven't tried putting cloth on the bowl as it's hard to manage and, I hate to say it, quite unsightly.
For version 2, I natural tried the recommended modification without going too far off the beaten path. I printed a 11.5mm version detachable now all in one piece (will upload to the same thingiverse shortly). Because of the lowered distance between the driver and my ear, both bass and treble shrills were decreased. The treble still bothers me a little bit and this is the area I need to work on next. All in all, I am ashamed that I doubted the mod and went with aftermarket pads against everyone recommendations. I will be purchasing my set of authentic G cush shortly. Sadly I don't have a way to measure the frequency response but someone else who did a very similar mod did and experience roughly echoes what's documented. The variant of the mod used is 12mm distancer.
http://www.changstar.com/www.changstar.com/index.php/topic,1458.0.html
Now onto the interesting part. I read in the thread that SR series were not a good candidate for this mod. I imagine this is mainly because of the frequency high frequency peaks of the older SR80s. I put v2 of the distancer onto SR80x, which has an updated driver with higher resolution, better bass extension, and less peaky highs; generally considered more neutral compared to classic Grados (from my hearing only, can't find FR curves online atm to confirm). The results were really good! Compared to the MS1000, everything sounded more detailed and full. Bass and sound stage had even a greater impact from the mod. The 11.5mm distancer helped it not becoming too bassy and overpowering. But because the higher are not as peaky, the shrilling issue I had with MS1000 was lessened. Mids are great as usual. To my ears, SR80(00)x sounded better than MS1000. This could be mainly due to SR80x stock sounded way better than MS1i in every respect. However, something still feels a bit off. This could be an interesting direction for the mod to continue onto X series drivers. From my limited experience, something still feels "off" about the SR80(00)x. I don't have a lot of time to further investigate.
