apatN
- Mar 28, 2007
Great work!
Wow, nice one.Olive wood?
After a long waiting and 13 euro custom duties the jumbo pads finally arrived!
So i was able to finish the ms1000, and i'm very happy with them!
Thanks to all those who shared their experience here, i had not the time to read all the 150 pages but i read a lot of them with pleasure.
Special thanks go to nickchen for the instructions and for the kindly advice.
Due to olive wood's oily consistence, it's hardly to be covered with (high gloss) resin lacquering though, you're bound to eco stuff like non glossing waxes & oil treatments. That's why I never touched that wood, I always preffered the high gloss bling effect with my woodies...
Very beautiful set Jonas. Amazing wood. Did you replace the plastic rod block with wood?
Nickchen you are a hell of a guy! Knowledge everywhere!
You are right i try to use to eco staff where it's possible, the good thing by waxes and oil treatments is that is a very easy and fast process, and in case of scratches it's easy to remedy! But of course with oil and waxes you will never get that high gloss bling.
Yes i replace the plastic with wood, but by doing so i completely destroy the plastic ones.
And after a while the rods became a little lose, probably due to humidity changes or/and usage.
The plastic ones had 2 rubber donuts on each side to avoid that.
So i bend the rods little bit and now it is ok, but for sure that's not the best solution...
Very clever. You can always use small metal collet like I did on my MS-Pro
http://cdn.head-fi.org/2/2e/2efe50d9_MS-Ultimate_4.jpeg
