- Jan 30, 2009
Quote:1964 have posted that the reason and the main difference between the livewires is that they don't use damping filters.
Drivers are the same but who knows about the configuration/tuning.
Think you might have misunderstood the response from 1964 Ears. They only claimed that the bass between 1964-D and LiveWire Duals is about the same but the Duals may have more mid-high because LW does not use damping filters. The physical drivers are not the same.
How would you know the physical drivers aren't the same?
Unless you have taken apart the t1 and compared.
1964 uses sonion and knowles interchangeably and there is no major difference between the high drivers of the duals vs the livewires t1 which uses the knowles for the high as well.
Despite the slightly smoother response on the 1964-D.
