ZMF AUTEUR IMPRESSIONS
Thanks for sending me these to check out Zach!!
- BASS: I find the bass of the Auteur to be tight and controlled. The sub bass is not as prominent as the mid bass but the hump in the midbass doesn't sound to have as high of an arch as the Atticus or the Eikon. It has good speed and is pretty punchy.
- ATTACK/TRANSIENTS: Very snappy and decently fast. The tones are solid and dense enough that it makes the Auteur sound nimble and defined. Though it is not as heavy handed and rich as my Blackwood Eikon, it sounds more crisp and a little more clean cut with quicker decay.
- MIDRANGE: The upper mids sound very much there with the Auteur pads without going into shoutiness. There are no dips in the upper midrange. The Auteur pads sound just a little zingy to me at times closer to the lower treble and around the upper mids but I actually like that as opposed to the Eikon Perforated pads. It gives it a bit more character and sizzle without becoming fatiguing. Very very very good midrange on the Autuer. The Eikon pads don't sound as forward in the upper mids but still don't dip like the Atticus.
- TREBLE: The treble has decent extension and sounds very balanced. Again the Auteur may or may not have a little/tiny bit of sizzly/zing (not sure if there is any ringing or anything there) with the Autuer pads but nothing unpleasant to my ears. The Eikon pads are smooth as butter and really smooth over any irritations the drivers may be putting out.
- OVERALL TONALITY: Very very well balanced. Perhaps one of the most balanced sounding headphones coming out now. The Eikon had good balance already and this one pretty much nails it. The only other headphone I have heard that hits sweet spots like this is the Code-X and the HD650. Very cohesive transitions from one range to the next
- SOUNDSTAGE/SEPARATION/OPPENNESS: The area that I feel the Auteur improves the most over the Eikon is in soundstage width and separation. There is less reverberation from he cups and it sounds much better separated. The Eikon already has good separation. The soundstage is wider but not much deeper (as far as I can hear yet). The Eikon pads hold back the openess to me making them sound semi-open but the Auteur pads make them sound more open and airy to my ears. For this reason, despite me liking warm headphones, I actually much prefer the Auteur pads with this new release.
- DETAILS: Just a bit of a step up from the Eikon. The resolution seems to be very good the microdynamics are great as is to be expected. It has good low level details especially since the decay is cleaner and the there is also less distortion around the details than the Eikon and Atticus.
- BACKGROUND/CLARITY/TRANSPARENCY: The Auteur is a step up here from the Eikon and Atticus. In fact switching from the HD800 when I have the Auteur pads on doesn't leave me wanting more transparency or even separation. Perhaps a little more openness and of course the soundstage is not nearly as big as the 800 but the clarity is there. I would say this headphone really does have a blackground and sounds grainless and clean with my Aficionado.
I would say the only cons to my ears is that I just find that the EIkon pads limit the openness of the headphone making it sound semi-open. Other than that the Auteur sounds VERY good. It sounds like Zach took his time. Well actually I know he took his time because this has been in the works for some while now. Also in terms of technicalities, it is not giant killer but the tonality and adequate technicalities make it special in the market. It is an easy headphone to get a long with.
Someone mentioned they wanted to see what I thought about it with the Milo. I like the Milo actually a lot but I don't find it ideal with the Autuer. I actually found it to hinder its openness and sounded just a little slow. It layered really well and provided good tonality. It is the closest to a tube amp I have heard in terms of timbre. The Pro iCan can't grip the Auteurs bass as well as the Milo but it sounds faster and more open and resolving, just not as layered. I need to do more comparisons to check on the resolution part but the Milo does not strike me as super resolving. I am gonna ruffle feathers here and just say that I prefer these ZMF headphones on tubes still overall and feel that I rarely, if ever, am able to hear the same snap, taughtness, solidity,
microdynamics, and timbre that a good tube amp can deliver to these. Biased you say? sure. Does the Auteur sound good enough from a solid state for me to be happy? Yup. Ideal, nope.
Actually, now that I think about it, the only other high impedance high end headphone out there is the HD800. This headphone is begging to scale up with gear. VERY scalable and it is very unique. I think Zach killed it with this headphone. I got some more listening on them now compared to my first impressions and this is pretty much how I feel my impressions will stay.
