PowerfulRen
The paired ones have a capacitance of 680pF (Total 8), and the single ones have 2.2nF (Total 4)? That's what it says, and I also asked another person, he also said such a capacity.0603
Looks like You have right. After all this problems with Zishan Z4 or Zishans on general I couldn't recommend it as all round devices.All kinds of formats. FLAC, WAV, DSD and some mp3. It stucks always after the same period. It seems to me that it has to do with a limited amount of files in the buffer.
I faced with this problem. But I have music in flac album ISO + CUE playlist format, and if I enable random playback, then when I catch a song from the cue playlist, at the end the player hangs, and starts playing the first song since the power on. In this case the only thing left to do is to restart. To avoid problems like this, I cut the album into individual tracks and that was it. There was also a problem where I couldn't play individual tracks, as it turned out it was because of the album artwork, I just changed the display to a frequency/spectrum graph and the problem disappeared.I have a problem with the last firmware update 0.3. I use a 200 GB card and play my music through shuffle over the entire card with now 5744 files. After about 3,5 hours use the Z4 stucks in the same file. Skipping is no use. It stays in the same file. Only shutting down and restart will solve the problem for an other period of about 3,5 hours. Do others recognise the problem?
Hows this EQ looks like just take a picture.new here
got z4, updated to 0.3
if i use equalizer, sound becomes jittery, grained, kinda falling apart
especially with lossy like mp3
anybody knows why this happens?
you think it clamps for some reason?Hows this EQ looks like just take a picture.
Maybe try negative values? Looks like software problem.you think it clamps for some reason?
nothing special actually, just tried to make hybrid iems more tolerable)
tried different eq presets
basically the more eq is changed the more jittery the sound becomes
this happens with 3.5 po and lo jacks
haven't tried balanced outputs
(hope the picture will stay)
yeah, that works, thanx!Maybe try negative values? Looks like software problem.
Just form 0 on basa to -9 on highs, just drop all frequency by -5
Z4 have better audio relay design from factor than Z3yeah, that works, thanx!
overall like z4
i have a slightly modded z3
stock z4 sounds less detailed, but more balanced and comfortable
still waiting for balanced cable though
i've read through this topic but still struggling to figure out what mods will have most effect for less effort
maybe changing op275 with surrounding caps?
i dont have noiseI noticed such a thing, that if you turn on the player and do not connect headphones, holding it to the ear you can hear the noise of the current. If you plug in headphones, the noise becomes noticeably quieter, but still present. Is this normal?
