Same with DSDs model nothing to worry about. It's a last picture from GPU freeze in LCD with backlight off.
Zishan Z4 - DAP with Dual DAC ES9038Q2M | Dual AMP OPA1622 | USB 32-bit + DSD | Bluetooth LDAC 24-bit | Balanced 2,5/4,4 | LO/PO 3,5mm
Hello and thanks for all the info about the z4, but I have a question before buying it.
When connecting it to the pc in dac mode does it use the battery or the power of the pc?
I would like to use it as a desktop dac without degrading its battery.
You need to connect 2 cables one for DAC connection and second for charge from PC USB or external charger.Hello and thanks for all the info about the z4, but I have a question before buying it.
Z4 goes crazy.
I had bad feelings about buttons and this happen and I can't fix it in every way.
Micro chip who is working as decoder of buttons randomly "pressing" (sending message) to CPU to voume UP with no reason.
Can't fix it
Looks like PCB crack or cold solder on chip.
Any ideas?
Can't fix it
Any ideas?
There's no IC that decode the buttons, it's the GPIO of the FC microprocessor, check any short on the modded phases (such as amps , power IC, etc.) also check the firmware versions, finally check cold joints on the microprocessor and the buttons. If they are like the digital board on DSDs they are a shi* (from my point of view) replace them.Z4 goes crazy.
Can't fix it
Any ideas?
-deleted-
Rafinnnnnn15
Hello friend, I hope you are well
I am interested in the Sizhan Z4
but I want to know what daps is equivalent in sound for the 4.4m?
is its sound better than that of the Fiio M11, equal to 4.4m?
What dap does the Z4's 4.4m stock output equate to?
CarlosBryant
BANNED - AKA audiophileeee, audiophileeeeeMember of the Trade
recently listened to z4
of the same akm sound that was previously in DSD
there is no longer (
Hello @Rafinnnnnn15 I want to tell you about the Zishan devices are meant for DIY and optimizations by your self, currently I didn't own the Z4, but I own the DSD's (AK4499 and Dual 4497 by GAD) and they sound amazing but as I did tell you are meant for modding. If you own an M11 will have a better sound than z4 since FIIO fine tune the components and PCB tracks and z4 does not (this is an assumption). Zishan idea for those devices are we have the proposed implementations from the manufacturer (aka. ESS, AKM, CS, TI, AD) lets wrap all of this and get a simple device, if the customer wants to do it by himself. You can go and see the mods on the dedicated posts like The Zishan DSD or see it here. @Setmagic @Mr.HiAudio @PiR2 and myself could help you with the mods.Hello friend, I hope you are well
Translation to spanish: Hola, @ Rafinnnnnn15 Quiero comentarte sobre los dispositivos Zishan están diseñados para las modificaciones y las optimizaciones hechas por ti. Actualmente, no soy tengo el Z4, pero tengo los DSD (AK4499 y Dual 4497 by GAD) y suenan increíbles, pero como dije, están hechos para modding. Si tienes un M11, tendrá un sonido mejor que el z4, ya que FIIO ajusta los componentes y las pistas de PCB y el z4 no (esto es una teoria). La idea de Zishan para esos dispositivos es que utilizan las implementaciones propuestas por el fabricante (como ESS, AKM, CS, TI, AD), unimos todo y obtenemos un dispositivo simple, si el cliente quiere modificarlo lo puede hacer por sí mismo. Puedes ir y ver las modificaciones en las publicaciones dedicadas como The Zishan DSD o aquí. @Setmagic @ Mr.HiAudio @ PiR2 y yo podríamos ayudarte con las modificaciones.
XTF1
- Nov 9, 2014
Adding a few comments: the Z4 audio qualities are excellent out of the box, which is great… but is also taking some of the moding fun away: it is too far beyond the point of diminishing returns, and I am not sure the potential for great DIY mods is there, at least not as it was for, say a DSD, or Z2-Z3. But I may be proved wrong!!!Hello @Rafinnnnnn15 I want to tell you about the Zishan devices are meant for DIY and optimizations by your self, currently I didn't own the Z4, but I own the DSD's (AK4499 and Dual 4497 by GAD) and they sound amazing but as I did tell you are meant for modding. If you own an M11 will have a better sound than z4 since FIIO fine tune the components and PCB tracks and z4 does not (this is an assumption). Zishan idea for those devices are we have the proposed implementations from the manufacturer (aka. ESS, AKM, CS, TI, AD) lets wrap all of this and get a simple device, if the customer wants to do it by himself. You can go and see the mods on the dedicated posts like The Zishan DSD or see it here. @Setmagic @Mr.HiAudio @PiR2 and myself could help you with the mods.
Where the Z4 is clearly far behind DAPs like the Fiio M11 is software/firmware and unfortunately, there is no DIY mod available. This is a real missed opportunity for Zishan IMO: as the HW gets almost perfect, they should have opened the firmware DIY/mod gate to keep that ‘Zishan spirit’ alive.
That being said, the very fact that the Z4 is being put against the Fiio M11 still says a lot about the great basic sound qualities of the Zishan products… at a fraction of the cost!
buzzbuzz
- Dec 21, 2016
11-11 sales + sitting at home = purchase of Zishan Z4.
buzzbuzz
- Dec 21, 2016
This thread is idle since Nov 23.
Just received my Z4 from KRHIFI Audio. 0.2 firmware. Still have the misspelled "floder" plus some funny characters in front of "floder" when I scroll through. Oh well.
Q: How can I find out whether I have the "5" or "6" version without opening this baby up?
buzzbuzz
- Dec 21, 2016
Upgraded to 0.3. UI is much faster. Like 0.2, 0.3 has "ticking" sound when playing DSD256 11Mbits/s files. (My DSD AK4977 and DSD dual AK4977s have no problem with these files).
The buttons are not hard to push. Does this mean I have a version 6?
Will test BT and other sound quality before opening up this baby.
LaughMoreDaily
Just open it up... that's what Zishan is best for giving you the ability to do!
But wear a mask (if you want), you never know what could be floating in the air after... and vaccum.
[paranoia over] Lol.
buzzbuzz
- Dec 21, 2016
Seriously dumb question. How to open this baby up?Just open it up... that's what Zishan is best for giving you the ability to do!
Also I have yet be able to connect Z4 BT to anything.
Wait. Which direction does the Z4 BT go to?
I can "pair" my phone to Z4 via BT and listen (Phone) music from Z4. What about the other direction, sending Z4 music to a BT headphone? Am I the only one think this way?
