What I'm using is in my signature.
I also previously used the WA22 (with the Tung-Sol 7236/Shugang Treasure CV181Z, and EML 5U4G). Both instances the soundstaging of the LCD-3 equaled my HE-6s (now sold) and beyer T1s. Is that to say that they can compete with the HD800s? Sorry, as I'm in Canada, shipping anything over the boarder usually incurs duty (not to mention the shipping costs and $ I've got tied up in the gear).
I have heard the Grace M903 with the LCD-2s and wasn't overly impressed. I found the amp section with more than sufficient gain, but lacked power to properly drive orthos fully. That said, I did like it very much with dynamic headphones (through the amp) and the DAC section was quite good too.
The HE-400 driven by my m903 sounds slightly tinny and had issues with distortion with music that has a large dynamic range like the Tron soundtrack. This is supported by the charts:
http://www.innerfidelity.com/images/HiFiMANHE400.pdf
Look at the distortion charts and the impulse response. Any time I see that kind of ringing on the impulse response I can almost always if not always hear a tinny nature to the sound signature.
The HE-300 sounds better to me than the HE-400 in regards to being more pleasant to listen to with more of my music. I heard less distortion and no tinny nature to the sound signature. Do not get me wrong the HE-300 has its own set of issues with distortion, but it was more pleasing overall to listen to than the HE-400.
http://www.innerfidelity.com/images/HiFiMANHE300.pdf
The HE-500 proved the most reliable and pleasing to listen to compared to the HE-300 and HE-400. It could not get the HE-500 to distort at normal listening levels and the clarity and neutrality was stunning. The mids were less harsh than the HE-300 and did not fatigue nearly as much over long listening sessions.
In regards to MacedonianHero what source are you using, what tracks are you listening to, and what amp do you use? I will try to replicate this wide sound stage scenario, but I find it pretty hard to see why my m903 would not drive the LCD-2/3 well. Please elaborate on your LCD-2/3 testing in regards to soundstage. I am using soundstage as in how wide and from where I can detect a sound. The wider the soundstage the more directionality it has. I found both the LCD-2 and LCD-3 very singular as far as directionality with little openness.
I think you hear a great many things that I have yet to hear in the LCD-2/3. Would you be willing to loan your setup to Tyll or myself so we can see if we can hear it too? Perhaps I am missing something, but in regards to soundstage I remain unimpressed by the LCD-2/3.
For me it is difficult to see why changing between quality amplifiers would drastically change the sound stage characteristic of a headphone. I admit that impedance, driver damping, and power delivered to the driver varies from amp to amp, but as long as each quality amp does the job well enough the soundstage should not suddenly become enhanced. Perhaps someone out there can give a details explanation of why the soundtage would increase simply by flipping between quality amps. By quality here I mean an amp designed to deliver a high enough damping factor for the driver, has a low output impedance ( below 5 Ohms ), and can deliver adequate power to the drivers to give 70dB of loudness.
I can see how adding in higher order harmonics may contribute the the soundstage and soundstaging is often a factor of the Fourier transform of the signal and how the ear interprets the higher order harmonics. I can also see how a poor amp would introduce a time delay between higher order harmonics and thus introduce the effects of distance and directionality, but are we really saying that the m903 or even Ultra Desktop Amp is not driving the LCD-2/3 properly?
I require further explanation before I believe that the LCD-2/3 is capable or even competent at delivering an immense soundstage or even a great sense of space. As a scientist I admit it is completely possible, but with the m903 or Ultra Desktop Amp I have not heard it.
