I wasn't thinking about Vamp until I saw it on Amazon for about $450 and I have a 10% Amazon coupon, so I could buy Vamp new for $400 and am giving this serious consideration.
Are the differences between the sonic performance of the GoDap 4/Vamp and GoDap X/Verza subtle or significant based on published stats?
What differences do some of you who own Vamp hear through Vamp vs. Iphone 4?
How does Vamp compare as a portable amp to the JDS Labs C421 or Headstage Arrow?
Is there a cable that could connect Vamp to Iphone 5 in the future (understanding they won't fit together) ?
I own M-100s and have Velodyne VTrue on the way. I may also be using with AKG Tiesto K267 and Ultrasone Signature DJs in the future. (Wouldn't keep all of those, just M-100s plus one of the other three, but this provides an idea of my ideal sound signature)
1) Are the differences between the sonic performance of the GoDap 4/Vamp and GoDap X/Verza subtle or significant based on published stats?
Until the Verza comes out, there probably won't be any published stats. As for sonic differences between the Go-DAP 4.0 and VAmp, it'll depend whether the Go-DAP 4.0 was customised or not. I had the base Go-DAP 4.0 (both Muses 8820E and OPA2134 versions) and comparing to the VAmp, of course there were differences.
I had them customised with the RK73 gain, Muses F95 capacitor added to the DAC, 2200mAh battery, OpAmp upgrades. Now I have Go-DAPs with AD8397, and OPA1612 with those aforementioned upgrades.
For my Go-DAP with OPA1612, I didn't hear any difference in comparison to my VAmp. Note that this is no Go-DAP ASR or VAmp VQ enabled. Once enabled then of course each will have their own "custom tuning" which I personally don't like. The only other difference was that the VAmp could go louder due to it's 150mW/ch. But actual sound-wise, they're effectively the same. In fact, because of that I passed my VAmp to my friend back in Perth last week. I don't need 2xdevices with OPA1612.
2) What differences do some of you who own Vamp hear through Vamp vs. Iphone 4?
As for what the VAmp does for the iPhone 4, others have written reviews of the VAmp, I had written a review for the Go-DAP 4.0 last year/early this year :-
http://www.head-fi.org/products/venturecraft-go-dap-4-0
I didn't write one for the VAmp in the end 'cos it effectively sounded the same as the Go-DAP 4.0 with OPA1612 and all the the other RK73 gain, and DAC cap upgrades.
3) How does Vamp compare as a portable amp to the JDS Labs C421 or Headstage Arrow?
Sorry, don't have those items. But note both those devices are amps only. Not DAC/Amps. The VAmp is a DAC/Amp.
4) Is there a cable that could connect Vamp to Iphone 5 in the future (understanding they won't fit together) ?
As for using the VAmp with the iPhone 5, I just want to clarify you mean VAmp, not Verza? The answer is No. You cannot use the iPhone 5 with the VAmp. The reason is that the Lightning -> 30-pin cable DrSheep is suggesting has got a Wolfson DAC inside. This mean you're attempting to use the VAmp as an "amp-only" and that's a no-go. The VAmp is used as a combined DAC/Amp or transport to external DAC/Amp via the optical out.You cannot use the VAmp as an "amp only" or a "DAC only".
If your question meant the iPhone 5 & Verza, then a cable something like this will work :-
http://www.e-earphone.jp/shopdetail/003082000015/
