Fixcinater
- Apr 6, 2008
Look at my sig. Sounds verra verra nice!
Originally Posted by jmanlp /img/forum/go_quote.gif Maybe this is why is sounds so good, this thing is an old beast. If you have the electrical schematic for your amp you can likely check this. For instance I think I was looking at a new NAD integrated schematic the other day and saw that the headphone jack came right of the main amplifier section. |
Originally Posted by tfarney /img/forum/go_quote.gif Could be that your Rotel pre is set-up similarly, that it draws its power from the amp it is hooked up to and sends it to the headphone jack through a resistor or two instead of using a cheap op amp. |
Originally Posted by tfarney /img/forum/go_quote.gif Where did you get your DIY instructions, by the way? |
Originally Posted by braddo /img/forum/go_quote.gif NAVYBLUE, the Rotel IS very good. my RA-05 integrated was cheaper than my headphone amp, and almost as good. My guess would be your pre-amp is better than the RA-05. |
Originally Posted by ccfoodog /img/forum/go_quote.gif Other than the danger of accidentally bumping the volume too high, what are the dangers/problems with using the speaker outputs? What are the potential strategies for volume correction? Resistors? -john |
Originally Posted by Penchum /img/forum/go_quote.gif I also use a Pioneer SA-9500II integrated amp. ![]() ![]() |
Originally Posted by PITTM /img/forum/go_quote.gif I actually returned an amp I paid $785 for because my Rotels HP out sounded like 2-3% worse. I preferred having the money. I think the Rotel HP out sounds very very good. |
Originally Posted by Navyblue /img/forum/go_quote.gif I am wondering if I should get the Little Dot Mk V. Would be it a significant upgrade to my Rotel pre amp? Upgraditis made me undecided between using my preamp headphone jack, power amp with adapter or either of the Little Dot Mk IV/V. Or should I just put the money in a better source. |
Originally Posted by PITTM /img/forum/go_quote.gif Spend the money ona nice vacation or something. thats what im doing. |
Originally Posted by Penchum /img/forum/go_quote.gif To me, it just makes sense to have a dedicated headphone amp. With the MKV, you have two selectable inputs, so you could listen to another source without turning on your main system. Having that flexibility is very nice indeed. ![]() Do you think your source is lacking? I have no idea. ![]() |
Originally Posted by Penchum /img/forum/go_quote.gif To me, it just makes sense to have a dedicated headphone amp. With the MKV, you have two selectable inputs, so you could listen to another source without turning on your main system. Having that flexibility is very nice indeed. ![]() |
