May 26, 2024 at 1:46 PM Post #6,196 of 6,409
Hi everyone,
I'm wondering if the Albums tab is using using folders instead of tags to to list albums.
I don't see any other reason the same albums are being listed multiple times.
May 26, 2024 at 3:31 PM Post #6,197 of 6,409
Hi everyone,
Did you check the files metadata with MP3Tag? Are the individual files divided into disk 1-2-3-4 for instance?
May 26, 2024 at 3:56 PM Post #6,198 of 6,409
Hi everyone,
I think you must have same artist (or album artist) AND same album name.
But as the album is from several artists, you may have it considered as different albums.
May 26, 2024 at 3:58 PM Post #6,199 of 6,409
Hi everyone,
Have you enabled this?
If songs are in a directory such as Artist->Album->Disc1, Disc 2, Disc 3, Disc 4, etc. they will appear separate unless that option is enabled.
May 26, 2024 at 3:59 PM Post #6,200 of 6,409
It appears they have Various Artists as the album artist for all the tracks (guessing just a little bit here).
May 26, 2024 at 4:03 PM Post #6,201 of 6,409
Yes. Apparently the issue was caused by having the track files in different folders. Enabling this setting solved most of the repeated listings (I still have some tracks with different album artist for the same album).
Thanks everyone!
May 30, 2024 at 8:25 PM Post #6,202 of 6,409
Hey guys, new to the audiophile rabbit hole. I'm currently running UAPP on a S24, with a L&P W4. Everytime I plug in my dac, play/pause or skip a track i get a pop. On a 3.5mm connection it's worse compared to 4.4MM. I messed around with every setting in UAPP I could think off. Any recommendations would be appreciated.
May 31, 2024 at 1:44 AM Post #6,203 of 6,409
I've been using UAPP for several years with many different devices without problems. I recently purchased a Questyle M15i dac/amp dongle and the sound is terrific. However I'm finding it extremely fickle to use with my Android as a source. Everything happens in slow motion. I connect it and it will take 15 seconds or so to work. Usually a pop-up occurs telling me it's not working but it gives me the option to select wait, which I do. Even then it constantly disconnects and sometimes even causes the android to restart itself. I'd send it back if it didn't sound so darned good. Is it possible there are settings in UAPP that need to be adjusted? Any advice would be appreciated. Thanks
Jun 4, 2024 at 4:22 AM Post #6,205 of 6,409
UAPP has taken away the ability to add the qobuz subscription? is no longer in the settings. Now there's only Tidal.
Erm, I don't have that issue?
What's your version number on the app?
Here's my UAPP, v7.0.2.8, on my Samsung Galaxy Z Fold5 (SM-F946B):
Jun 4, 2024 at 7:16 AM Post #6,207 of 6,409
Have you unchecked it in settings - user interface - panel items ?
Jun 4, 2024 at 8:18 AM Post #6,208 of 6,409
I also have the 7.0.2.8 version, the latest available from the playtore. How can I solve it? Do I try to uninstall and reinstall the app?
Well, that's weird...🤔
Ah, @jsk ksj might be on to something!
Following their instructions, can you tell us @damians if Qobuz is deselected on the Panel Items?
Jun 10, 2024 at 2:40 AM Post #6,209 of 6,409
Tried to add & save a new eq today, entry worked fine, entered name in save as dialog, but eq not showing in list of eqs.
I am running the up to date "paid for" app & have force stopped / restarted app.
Was working fine the last time I used the eq, a few weeks ago.
I only have 3 other eqs saved.
No joy.
Any solutions?
ps same on 10 band & 6 band eq
Jun 10, 2024 at 8:13 AM Post #6,210 of 6,409
No joy.
Any solutions?
Cleared all data / uninstall / reinstall.
golden.
