m-i-c-k-e-y
Its 8 years running Bud. But welcome!
Hi David and Merry Christmas!
What I have right now is a Bee-link GT-King. It has now a newer version GT-King II. Yes it has Hdmi, USB(OTG) Spdif(Toslink), Headphone Out. And yes you could sideload apps.
Other interesting boxes from Bee-link are:
GT-King Pro
GS-King
It's been less than a year that I am not using my Android TV Box as player/streamer(UPnP) since I bought myself an Audiobyte Hydra.Hub to complete my stack.
Michael
I was able to check today: The problems are ONLY when using RU6 with UAPP. Not if I use RU6 with any other music app, nor if I use UAPP with just my phone. And the delay is quite long. Do you know Peter Gabriel's Big Time? It starts with a voice saying Hi there! 4 out if 5 times I don't hear that when using RU6 with UAPP, while when using UAPP on my phone I heard it 10 out of 10 times. Same when using RU6 with Poweramp.With UAPP -
Is the error only with USB connection to RU6 ,
or even without USB connection , at direct connection ( with Headphone , Inear , )
at the source device ?
Is this happening when selecting a new track/album or when transitioning naturally from one to another?I was able to check today: The problems are ONLY when using RU6 with UAPP. Not if I use RU6 with any other music app, nor if I use UAPP with just my phone. And the delay is quite long. Do you know Peter Gabriel's Big Time? It starts with a voice saying Hi there! 4 out if 5 times I don't hear that when using RU6 with UAPP, while when using UAPP on my phone I heard it 10 out of 10 times. Same when using RU6 with Poweramp.
Wondering whether I should contact Davey for thoughts? Or does he chime in here every now and then?
Tnx...
drftr
It happens with every first track of an album, any track I manually click on, and when using a playing list.Is this happening when selecting a new track/album or when transitioning naturally from one to another?
I've noticed that when skipping/selecting a new track on Qobuz through UAPP with the Cayin RU6, there can be a slight delay. I've tested pausing the current track before selecting a new track and this seems to eliminate the delay. I don't know if this helps?
Have the same issue with my Fiio M11 Plus when using UAPPIt happens with every first track of an album, any track I manually click on, and when using a playing list.
drftr
While playing music from your phone? Or do you use UAPP on the M11 Plus? I'm asking because today I tried a Sony DAP while playing from my phone and it didn't have this problem at all. So that made me think it only happens when playing music from a phone, using UAPP, in combination with RU6. But if you have a very different situation with your FiiO...Have the same issue with my Fiio M11 Plus when using UAPP
Direct from the M11 PlusWhile playing music from your phone? Or do you use UAPP on the M11 Plus? I'm asking because today I tried a Sony DAP while playing from my phone and it didn't have this problem at all. So that made me think it only happens when playing music from a phone, using UAPP, in combination with RU6. But if you have a very different situation with your FiiO...
drftr
Have you tried playing with the recently introduced start-up delay option?Direct from the M11 Plus
Yes, I can navigate to it. Tried context, double click and single click. Every time the dialog "Allow to create UAPP...for faster ..." (along those lines) pops up. Regardless of my yes/no on that dialog, UAPP creates a XML file with the same Playlist name, but fails to create any data. The file contains the header and the container XML commands, but not a single row of data. I even tried a Playlist which contains just two songs with plain ASCII title, album etc. to make sure that UAPP does not trip over 'foreign' characters.Can you access the Playlists using the Folder browsing mode in UAPP?
If you can access them that way, it should give you the option of opening / converting them as UAPP Playlists.
