Mar 4, 2019 at 5:10 AM Post #2,506 of 6,408
Davy, I'm a little puzzled by the Play Next Album/Folder feature and was hoping you could help clarify my doubts.
I have my music organised in the following structure (on a MicroSD card):
Artist 1
- Album A
--- Disc i
--- Disc ii
- Album B
--- Disc i
--- Disc ii
Artist 2... and so on
In UAPP's Library, there are 4 entries under Artist 1:
Album A Disc i
Album A Disc ii
Album B Disc i
Album B Disc ii
I play Album A Disc i. At the end of the album, instead of proceeding to Album A Disc ii, UAPP skips to Album B Disc i.
Is this the intended behaviour?
This is with UAPP 5.1.1?
Mar 4, 2019 at 5:11 AM Post #2,507 of 6,408
Hi Davy,
On Cayin N5iiS, UAPP can't detect SD card. only Internal storage... is it an issued of my own DAP or else ?
It probably is not configured right. If you go using folder to /storage or /mnt, do you see any subfolder that could be the external SD card, like a number 0000-0000? Please note that /mnt/sdcard is the internal storage.
Mar 4, 2019 at 6:30 AM Post #2,508 of 6,408
every subfolder file that I try to click, ends back to the internal storage..
Yes, I can used UAPP, but it doesn't read my music on my external SD Card or from USB if thats info helps
Mar 4, 2019 at 6:35 AM Post #2,509 of 6,408
Ok, is there any other app on your device that lists the external SD card (without using the Storage Access Framework preferably)?
Mar 4, 2019 at 7:01 AM Post #2,512 of 6,408
And what path does it display when showing the track information for a file from external SD?
sorry, the temporary solution for now. I copy the music from SDcard to internal SDCard..
answering ur question, I can not find path to external SDCard...
Answering other question... I install spotify in N5iiS. It shows tha path to storage to SDCard... I hope it helps
Mar 4, 2019 at 7:06 AM Post #2,513 of 6,408
Ok, then you can add those folders manually by going to /mnt/external_sd1 or /mnt/external_sd2 and add them for scanning into the Library.
Mar 4, 2019 at 7:39 AM Post #2,514 of 6,408
Solved. . Great Support....
now, the next one. Cayin can support DSD 256... how come, only read 176 kHZ.... need help and direction....
Mar 4, 2019 at 7:44 AM Post #2,515 of 6,408
I can only add support if you can send ADB logs of other apps playing native DSD. If you have experience with that or good PC knowledge, let me know.
Mar 4, 2019 at 8:05 AM Post #2,516 of 6,408
noted.. will asked my it fellows about this
will get back to you ASAP
edit : using Native Apps, Hiby Music. playing DSD256...
Mar 5, 2019 at 7:29 AM Post #2,520 of 6,408
@Davy Wentzler, DSD512 files sound really good on UAPP, but I'm trying to get gapless playback to work and there is always a click and a pause between tracks. Is this just a limitation of UAPP with DSD512 or is there a setting I can adjust? Thanks!
No, it will always stop and start between dsf/dff tracks because we cannot get it to work otherwise. SACD .iso's can play gapless though.
