USB Audio Player PRO (UAPP): 24- and 32-bit playback, ubiquitous USB audio support for Android
Mar 11, 2019 at 12:16 AM Post #2,536 of 6,156
ive been trying to deal with a playback issue with Tidal for several months now... Everytime im listening to an album, on every song end there is a little loopback from the song, before the next song starts playing, without any adjusment the loop last about 2 and half seconds... ive tried several settings with buffers sizes, forced packages, etc.... ive managed to reduced the loop to about 1 second, this is with the higest buffer sizes and bit perfect playback enable. ive run out of ideas. any help? ive endlessly read the thread for something similiar, and havent found anything that resemblance my problem.
im running uapp through Nokia 8 to fiio q1.
This happens to me sometimes as well. Except it might loop the last minute or 2 over and over until I manually change tracks. Seems to happen most often if I skip around on a playlist... I have a V30+
Mar 11, 2019 at 1:22 AM Post #2,537 of 6,156
An earlier version of UAPP didnt play well with the Q1mk2 but have since got rid of the fiio.
Mar 11, 2019 at 5:59 AM Post #2,538 of 6,156
Please go into the app's System settings, HTTP client and if it's at HTTPUrlConnection, choose OkHttp.
Mar 11, 2019 at 2:09 PM Post #2,539 of 6,156
Hi Davy I need a clarification about system licensing. Playstore said that in my family group I may use the app for 5 accounts, but on my himedia q10 tv box, that had a different account from my phone, it appears a pop up for the mqa purchase
Thanks in advance
Mar 11, 2019 at 3:07 PM Post #2,540 of 6,156
Thanks in advance
I'm afraid that's out of my reach. Just make sure your account is in the family group and in Android settings, Accounts, select your Google account and choose 'Sync now'. If that does not work, please contact Google.
Mar 12, 2019 at 6:03 AM Post #2,542 of 6,156
@Davy Wentzler already try for 1 week to install any kind of apps to get catLog or adb or else, but somehow not manage to recognize my Cayin N5iis device... Even try to install Android APK. but somehow, it can't save the log...
Seems I need to make peace to myself that Cayin N5iiS with UAPP can't play DSD, only force to play in PCM at 176.4 kHz... :triportsad:
The rest, like 192/24 bit flac or MQA works perfectly..
Mar 12, 2019 at 6:07 AM Post #2,543 of 6,156
You need to do it from a PC. Do you have a PC and some PC skills?
Mar 12, 2019 at 7:17 AM Post #2,545 of 6,156
Mar 12, 2019 at 8:05 AM Post #2,546 of 6,156
Yes, you don't have to install any app on your Android device. Just follow the instructions in the bottom section here:
http://www.extreamsd.com/index.php/hires-audio-driver
I only manage to extract this
Clients:
pid: 660
pid: 962
Notification Clients:
pid: 100
pid: 371
pid: 660
pid: 962
Global session refs:
session pid count
9 660 1
43 962 1
Hardware status: 0
Standby Time mSec: 3000
Output thread 0x414be000:
Normal frame count: 16384
Last write occurred (msecs): 118
Total writes: 62800
Delayed writes: 0
Blocked in write: yes
Suspend count: 0
Sink buffer : 0x414ff000
Mixer buffer: 0x4150f000
Effect buffer: 0x4152f000
Fast track availMask=0xfe
I/O handle: 2
TID: 408
Standby: no
Sample rate: 44100
HAL frame count: 16384
HAL buffer size: 65536 bytes
Channel Count: 2
Channel Mask: 0x00000003 (front-left, front-right)
Format: 0x1 (pcm16)
Frame size: 4
Pending config events: none
AudioMixer tracks: 0x00000003
FastMixer not initialized
Stream volumes in dB: 0:0, 1:-6, 2:0, 3:0, 4:0, 5:0, 6:0, 7:-6, 8:-6, 9:0, 10:0, 11:0, 12:0
Normal mixer raw underrun counters: partial=0 empty=0
2 Tracks of which 1 are active
Name Active Client Type Fmt Chn mask Session fCount S F SRate L dB R dB Server Main buf Aux Buf Flags UndFrmCnt
0 no 660 3 00000001 00000003 9 32768 A 1 44100 0 0 00000000 0x414ff000 0x0 0x008 819200
1 yes 962 3 00000006 00000003 43 70560 A 3 176400 0 0 00700000 0x414ff000 0x0 0x000 3801204
0 Effect Chains
Reroute submix audio module:
route[0] rate in=0 out=0, addr=[]
route[1] rate in=0 out=0, addr=[]
route[2] rate in=0 out=0, addr=[]
route[3] rate in=0 out=0, addr=[]
route[4] rate in=0 out=0, addr=[]
route[5] rate in=0 out=0, addr=[]
route[6] rate in=0 out=0, addr=[]
route[7] rate in=0 out=0, addr=[]
route[8] rate in=0 out=0, addr=[]
route[9] rate in=48000 out=48000, addr=[]
shell@N5MK2SS:/ $
This was playing UAPP DSD 256...
Mar 12, 2019 at 8:12 AM Post #2,547 of 6,156
Hold on, there is no HiRes direct support at the moment at all for the Cayin, let alone DSD. Please slide out the left panel in UAPP, select About and press the top-right button to send us the audio config file of your device.
Mar 12, 2019 at 8:50 AM Post #2,548 of 6,156
alrd scanning, and connect to wifi, but always pop up this message...
Edit
I think the audio config file is not listed.. so I can't send anything.... just my guess
Mar 14, 2019 at 6:25 PM Post #2,549 of 6,156
I'm using APP on Nokia 7 plus and when I leave phone untouched, after 40 minutes android kill AUPP (I think it caused by adoptive battery). I try everything, clearing cache of health of device, restricted all apps then turn off adaptive battery/restricted some apps then turn off adaptive battery even turn off adaptive brightness:smile_phones:. Davy please if you can in this upcoming updates do something, it not only kills app, it kill joy of long music essions :triportsad:
thanks
Mar 14, 2019 at 6:32 PM Post #2,550 of 6,156
thanks
I happen to have a Nokia 7 Plus here on my desktop by coincidence. Is this with USB DAC or without?
