Jan 29, 2019 at 11:56 PM Post #2,386 of 6,408
I have to say I am also getting occasional pops and clicks when streaming Tidal in UAPP on my V30 (Internal HiRes driver, only MQA flag set). Usually it gets better after rebooting the phone, but seems to come back after awhile.
Bingo - same here. VS996 V30 verizon variant. Happens a lot with the internal DAC, maybe once a minute or so. I usually get 10 minutes or so if using an external DAC before it glitch/pops.
I've tried different Network chunk sizes (System menu) but doesn't seem to affect it - or at least it doesn't solve it. Network buffer size is 15 seconds (System menu). I'll try raising Buffer size (Internal HiRes menu) as you suggested. It's been at 600ms so far.
I've tried just about every setting and it still happens :(
If you experience it with WiFi turned off and playing local files, then we can exclude WiFi.
It doesn't happen with local files that I've noticed.
Guess I'm hanging on to my Hiby R6 and tidal offline files. (it also pops softly every couple minutes when using UAPP tidal streaming - but it's much softer and hard to pick out). Shame because the UAPP is the best sounding solution on both the Hiby and V30. Why that is, when the Hiby promises bit perfect playback even for 3rd party apps, I can't say.
Jan 30, 2019 at 3:31 AM Post #2,387 of 6,408
I am also still getting the glitches despite maximising buffer etc.
Jan 30, 2019 at 6:00 AM Post #2,388 of 6,408
I've tried just about every setting and it still happens :frowning2:
Ok, so the questions are:
* Does it glitch when playing from WiFi, but not from Tidal (like UPnP)?
* Does it glitch when playing non-MQA tracks from Tidal?
* Does it glitch when playing tracks from Tidal using a stable 4G connection?
Jan 30, 2019 at 7:17 AM Post #2,389 of 6,408
Mine glitches on wifi although its ok with tidal.
Only MQA tracks glitch.
4g glitches on uapp not on tidal app
Thanks Gary.
Jan 30, 2019 at 8:10 AM Post #2,390 of 6,408
* NO glitches EVER on local files, tested up to DSD256 and PCM 352kHz.
* Streaming Tidal on WiFi glitches consistently on both MQA and 16/44 tracks, usually more often on higher bandwidth tracks.
* Very, very occasionally do I hear glitches when streaming in Tidal app on WiFi. NEVER when playing offline in Tidal app.
* I do not stream on my cheap mobile data plan, so cannot speak to that. Have not tried Network (uPnP etc) streaming either.
I did some more testing yesterday. Things that affect this:
* Switching back and forth between UAPP and other apps that use the DAC, such as Tidal app or LG Music app. Rebooting solves this particular aspect. (I've reported this before.)
* Apps that run in background, such as ones with persistent notifications. I uninstalled Notification History app (helped), Deactivated Blokada (didn't help), Disabled Blokada Keep-alive persistent notification (helped), Settings->General-Developer options->Inactive apps->Made all apps Inactive that I could (helped). Even with all of those, I'd still get a pop in UAPP every 10 mins or so.
That's still in Battery Saver mode, deliberately, because I want to see if I can make that work (and it does work in Tidal app 99.9% of the time). Tomorrow I'll try excluding UAPP from Battery Saver and see if that helps.
I finally enabled logging in UAPP Settings->Logging->Log to file. I forgot to delete UAPP.txt first, so there was bunch of older log entries. I deleted everything before 2019-01-29, which is when all these tests were done. UAPP.txt attached.
I should add I have a T-Mobile H932 with Oreo.
Edit: Attaching UAPP.txt didn't work. ZIP didn't work either. Pasted into spoiler instead.
Code:
2019-01-29 19:08:08.254: App: loading 3rd party libs
2019-01-29 19:08:08.329: Loaded
2019-01-29 19:08:08.359: SSPA oncreate
2019-01-29 19:08:08.427: MediaService onCreate com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:08.433: Start LG-H932
lge
joan
26
com.extreamsd.usbaudioplayerpro 5.0.7
2019-01-29 19:08:08.462: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b582019:01:29 19:08:08.487 CTOR AS
2019-01-29 19:08:08.566: Android driver = 12019:01:29 19:08:08.567 setOutputType 2
2019:01:29 19:08:08.568 new ATN
2019:01:29 19:08:08.569 CTOR ATN 0xe83cf540
2019-01-29 19:08:08.587: Logmethod = 0
2019-01-29 19:08:08.713: logFileName = /storage/emulated/0/UAPP/UAPP.txt, log to file = false
2019-01-29 19:08:08.720: Calling getUSBAudioDevices()
2019-01-29 19:08:08.764: loadPlayQueueInfo
2019-01-29 19:08:08.784: loadPlayQueueInfo done, diff = 16, counter = 44, i_queue.size = 44
2019-01-29 19:08:08.792: After reloadQueue
2019-01-29 19:08:08.805: #devices 4
2019-01-29 19:08:08.810: Output 0
2019-01-29 19:08:08.815:     ID = 1
2019-01-29 19:08:08.819:     Type = 1
2019-01-29 19:08:08.824:     Name = LG-H932
2019-01-29 19:08:08.828: #rates = 1
2019-01-29 19:08:08.832:     Rate = 48000
2019-01-29 19:08:08.836: Output 1
2019-01-29 19:08:08.840:     ID = 2
2019-01-29 19:08:08.844:     Type = 2
2019-01-29 19:08:08.848:     Name = LG-H932
2019-01-29 19:08:08.852: #rates = 1
2019-01-29 19:08:08.855:     Rate = 48000
2019-01-29 19:08:08.860: Output 2
2019-01-29 19:08:08.864:     ID = 22
2019-01-29 19:08:08.868:     Type = 4
2019-01-29 19:08:08.872:     Name = LG-H932
2019-01-29 19:08:08.876: #rates = 1
2019-01-29 19:08:08.880:     Rate = 48000
2019-01-29 19:08:08.884: Output 3
2019-01-29 19:08:08.889:     ID = 5
2019-01-29 19:08:08.893:     Type = 18
2019-01-29 19:08:08.897:     Name = LG-H932
2019-01-29 19:08:08.900: #rates = 2
2019-01-29 19:08:08.904:     Rate = 8000
2019-01-29 19:08:08.908:     Rate = 16000
2019-01-29 19:08:08.918: Service created
2019-01-29 19:08:08.922: onStartCommand
2019-01-29 19:08:08.930: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:08.990: Connectivity change, state = CONNECTED, type = WIFI
2019-01-29 19:08:09.028: CT 772195341009, 949194403724, 2679720
2019-01-29 19:08:09.032: DT
2019-01-29 19:08:09.260: onStartCommand
2019-01-29 19:08:09.274: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:09.290: onStartCommand
2019-01-29 19:08:09.298: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:09.375: postReloadQueue, i_currentPos = 103762
2019-01-29 19:08:13.181: onStartCommand
2019-01-29 19:08:13.194: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:13.224: onStartCommand
2019-01-29 19:08:13.246: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:18.317: onStartCommand
2019-01-29 19:08:18.329: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:36.477: onStartCommand
2019-01-29 19:08:36.499: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:36.551: onStartCommand
2019-01-29 19:08:36.569: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:43.722: linkSpeed = 866 Mbps
2019-01-29 19:08:43.732: Restrict bg status = 32019:01:29 19:08:43.746 setOutputType 2
2019:01:29 19:08:44.582 prep ATN i_sampleRate = 44100, i_flags = 400000, i_format = 0, bufferSize = 131072
2019-01-29 19:08:44.639: Play Android, HiRes = true
2019-01-29 19:09:18.730: onStartCommand
2019-01-29 19:09:18.801: MediaService: onDestroy
2019-01-29 19:09:18.816: MediaService: onDestroy, player stop
2019-01-29 19:09:18.832: Remove media session
2019-01-29 19:09:18.839: MediaService: onDestroy, send exit
2019-01-29 19:09:18.847: T: delete AS2019:01:29 19:09:18.848 DTOR AS
2019:01:29 19:09:18.848 Deleting old device
2019:01:29 19:09:18.849 Deleted old device
2019:01:29 19:09:18.852 DTOR OD 0xe83cf540
2019:01:29 19:09:18.852 Send exit message to decode thread
2019-01-29 19:09:18.853: Closing DB
2019-01-29 19:09:18.856: T: AS deleted
2019-01-29 19:09:18.859: MediaService: END onDestroy
2019-01-29 19:09:18.937: onDestroy SSPA
2019-01-29 19:11:24.764: App: loading 3rd party libs
2019-01-29 19:11:24.799: Loaded
2019-01-29 19:11:24.812: SSPA oncreate
2019-01-29 19:11:24.865: MediaService onCreate com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:24.870: Start LG-H932
lge
joan
26
2019-01-29 19:11:24.887: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b582019:01:29 19:11:24.916 CTOR AS
2019-01-29 19:11:24.975: Android driver = 12019:01:29 19:11:24.977 setOutputType 2
2019:01:29 19:11:24.977 new ATN
2019:01:29 19:11:24.978 CTOR ATN 0xe83ceb40
2019-01-29 19:11:24.989: Logmethod = 0
2019-01-29 19:11:25.101: logFileName = /storage/emulated/0/UAPP/UAPP.txt, log to file = false
2019-01-29 19:11:25.107: Calling getUSBAudioDevices()
2019-01-29 19:11:25.147: loadPlayQueueInfo
2019-01-29 19:11:25.160: loadPlayQueueInfo done, diff = 8, counter = 19, i_queue.size = 19
2019-01-29 19:11:25.166: After reloadQueue
2019-01-29 19:11:25.174: #devices 4
2019-01-29 19:11:25.178: Output 0
2019-01-29 19:11:25.182:     ID = 1
2019-01-29 19:11:25.186:     Type = 1
2019-01-29 19:11:25.190:     Name = LG-H932
2019-01-29 19:11:25.194: #rates = 1
2019-01-29 19:11:25.198:     Rate = 48000
2019-01-29 19:11:25.203: Output 1
2019-01-29 19:11:25.207:     ID = 2
2019-01-29 19:11:25.211:     Type = 2
2019-01-29 19:11:25.216:     Name = LG-H932
2019-01-29 19:11:25.220: #rates = 1
2019-01-29 19:11:25.224:     Rate = 48000
2019-01-29 19:11:25.228: Output 2
2019-01-29 19:11:25.232:     ID = 22
2019-01-29 19:11:25.236:     Type = 4
2019-01-29 19:11:25.240:     Name = LG-H932
2019-01-29 19:11:25.244: #rates = 1
2019-01-29 19:11:25.248:     Rate = 48000
2019-01-29 19:11:25.252: Output 3
2019-01-29 19:11:25.255:     ID = 5
2019-01-29 19:11:25.259:     Type = 18
2019-01-29 19:11:25.263:     Name = LG-H932
2019-01-29 19:11:25.267: #rates = 2
2019-01-29 19:11:25.271:     Rate = 8000
2019-01-29 19:11:25.275:     Rate = 16000
2019-01-29 19:11:25.281: Service created
2019-01-29 19:11:25.286: onStartCommand
2019-01-29 19:11:25.294: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:25.362: Connectivity change, state = CONNECTED, type = WIFI
2019-01-29 19:11:25.401: CT 772195341009, 949194403724, 2679720
2019-01-29 19:11:25.404: DT
2019-01-29 19:11:25.583: onStartCommand
2019-01-29 19:11:25.591: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:25.602: onStartCommand
2019-01-29 19:11:25.615: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:25.663: postReloadQueue, i_currentPos = 34179
2019-01-29 19:11:27.412: onStartCommand
2019-01-29 19:11:27.438: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:27.453: onStartCommand
2019-01-29 19:11:27.471: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:29.972: onStartCommand
2019-01-29 19:11:29.991: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:35.024: onStartCommand
2019-01-29 19:11:35.037: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:35.077: onStartCommand
2019-01-29 19:11:35.096: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:37.601: linkSpeed = 866 Mbps
2019-01-29 19:11:37.613: Restrict bg status = 32019:01:29 19:11:37.622 setOutputType 2
2019:01:29 19:11:38.497 prep ATN i_sampleRate = 44100, i_flags = 400000, i_format = 0, bufferSize = 131072
2019-01-29 19:11:38.557: Play Android, HiRes = true
2019-01-29 19:12:29.980: onStartCommand
2019-01-29 19:12:30.000: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:18:34.371: onStartCommand
2019-01-29 19:18:42.674: onStartCommand
2019-01-29 19:18:42.742: MediaService: onDestroy
2019-01-29 19:18:42.752: MediaService: onDestroy, player stop
2019-01-29 19:18:42.759: Remove media session
2019-01-29 19:18:42.766: MediaService: onDestroy, send exit
2019-01-29 19:18:42.774: T: delete AS2019:01:29 19:18:42.777 DTOR AS
2019:01:29 19:18:42.777 Deleting old device
2019:01:29 19:18:42.777 Deleted old device
2019-01-29 19:18:42.777: Closing DB
2019-01-29 19:18:42.784: MediaService: END onDestroy
2019-01-29 19:18:42.784: T: AS deleted2019:01:29 19:18:42.787 DTOR OD 0xe83ceb40
2019:01:29 19:18:42.787 Send exit message to decode thread
2019-01-29 19:18:42.885: onDestroy SSPA
2019-01-29 19:19:36.039: App: loading 3rd party libs
2019-01-29 19:19:36.085: Loaded
2019-01-29 19:19:36.108: SSPA oncreate
2019-01-29 19:19:36.160: MediaService onCreate com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:19:36.165: Start LG-H932
lge
joan
26
2019-01-29 19:19:36.181: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c2019:01:29 19:19:36.196 CTOR AS
2019-01-29 19:19:36.253: Android driver = 12019:01:29 19:19:36.254 setOutputType 2
2019:01:29 19:19:36.255 new ATN
2019:01:29 19:19:36.255 CTOR ATN 0xe83cf400
2019-01-29 19:19:36.267: Logmethod = 0
2019-01-29 19:19:36.381: logFileName = /storage/emulated/0/UAPP/UAPP.txt, log to file = false
2019-01-29 19:19:36.386: Calling getUSBAudioDevices()
2019-01-29 19:19:36.426: loadPlayQueueInfo
2019-01-29 19:19:36.438: loadPlayQueueInfo done, diff = 7, counter = 19, i_queue.size = 19
2019-01-29 19:19:36.444: After reloadQueue
2019-01-29 19:19:36.452: #devices 4
2019-01-29 19:19:36.456: Output 0
2019-01-29 19:19:36.461:     ID = 1
2019-01-29 19:19:36.465:     Type = 1
2019-01-29 19:19:36.469:     Name = LG-H932
2019-01-29 19:19:36.473: #rates = 1
2019-01-29 19:19:36.477:     Rate = 48000
2019-01-29 19:19:36.481: Output 1
2019-01-29 19:19:36.485:     ID = 2
2019-01-29 19:19:36.490:     Type = 2
2019-01-29 19:19:36.494:     Name = LG-H932
2019-01-29 19:19:36.499: #rates = 1
2019-01-29 19:19:36.503:     Rate = 48000
2019-01-29 19:19:36.507: Output 2
2019-01-29 19:19:36.511:     ID = 22
2019-01-29 19:19:36.515:     Type = 4
2019-01-29 19:19:36.519:     Name = LG-H932
2019-01-29 19:19:36.523: #rates = 1
2019-01-29 19:19:36.526:     Rate = 48000
2019-01-29 19:19:36.530: Output 3
2019-01-29 19:19:36.534:     ID = 5
2019-01-29 19:19:36.538:     Type = 18
2019-01-29 19:19:36.542:     Name = LG-H932
2019-01-29 19:19:36.546: #rates = 2
2019-01-29 19:19:36.550:     Rate = 8000
2019-01-29 19:19:36.555:     Rate = 16000
2019-01-29 19:19:36.563: Service created
2019-01-29 19:19:36.568: onStartCommand
2019-01-29 19:19:36.576: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:19:36.629: Connectivity change, state = CONNECTED, type = WIFI
2019-01-29 19:19:36.666: CT 772195341009, 949194403724, 2679720
2019-01-29 19:19:36.670: DT
2019-01-29 19:19:36.844: onStartCommand
2019-01-29 19:19:36.852: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:19:36.866: onStartCommand
2019-01-29 19:19:36.877: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:19:36.929: postReloadQueue, i_currentPos = 419073
2019-01-29 19:19:40.027: onStartCommand
2019-01-29 19:19:40.047: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:19:41.587: onStartCommand
2019-01-29 19:19:41.597: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:19:41.612: onStartCommand
2019-01-29 19:19:41.628: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:19:42.959: linkSpeed = 866 Mbps
2019-01-29 19:19:42.968: Restrict bg status = 32019:01:29 19:19:42.973 setOutputType 2
2019:01:29 19:19:44.080 prep ATN i_sampleRate = 44100, i_flags = 400000, i_format = 0, bufferSize = 131072
2019-01-29 19:19:44.176: Play Android, HiRes = true2019:01:29 19:34:33.644 Decoding took too long!  totalMilliSeconds = 620, milliSecondsAllowed = 185, framesToRead = 8192
2019-01-29 19:38:44.427: onStartCommand
2019-01-29 19:38:44.486: MediaService: onDestroy
2019-01-29 19:38:44.492: MediaService: onDestroy, player stop
2019-01-29 19:38:44.501: Remove media session
2019-01-29 19:38:44.508: MediaService: onDestroy, send exit
2019-01-29 19:38:44.514: T: delete AS2019:01:29 19:38:44.515 DTOR AS
2019:01:29 19:38:44.515 Deleting old device
2019:01:29 19:38:44.515 Deleted old device
2019:01:29 19:38:44.519 DTOR OD 0xe83cf400
2019:01:29 19:38:44.519 Send exit message to decode thread
2019-01-29 19:38:44.521: Closing DB
2019-01-29 19:38:44.522: T: AS deleted
2019-01-29 19:38:44.527: MediaService: END onDestroy
2019-01-29 19:38:44.623: onDestroy SSPA
2019-01-29 19:41:21.781: App: loading 3rd party libs
2019-01-29 19:41:21.823: Loaded
2019-01-29 19:41:21.838: SSPA oncreate
2019-01-29 19:41:21.886: MediaService onCreate com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:41:21.890: Start LG-H932
lge
joan
26
2019-01-29 19:41:21.906: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c2019:01:29 19:41:21.920 CTOR AS
2019-01-29 19:41:21.977: Android driver = 12019:01:29 19:41:21.978 setOutputType 2
2019:01:29 19:41:21.979 new ATN
2019:01:29 19:41:21.979 CTOR ATN 0xe83cf400
2019-01-29 19:41:21.991: Logmethod = 0
2019-01-29 19:41:22.103: logFileName = /storage/emulated/0/UAPP/UAPP.txt, log to file = false
2019-01-29 19:41:22.109: Calling getUSBAudioDevices()
2019-01-29 19:41:22.147: loadPlayQueueInfo
2019-01-29 19:41:22.159: loadPlayQueueInfo done, diff = 8, counter = 19, i_queue.size = 19
2019-01-29 19:41:22.165: After reloadQueue
2019-01-29 19:41:22.179: #devices 4
2019-01-29 19:41:22.184: Output 0
2019-01-29 19:41:22.188:     ID = 1
2019-01-29 19:41:22.192:     Type = 1
2019-01-29 19:41:22.197:     Name = LG-H932
2019-01-29 19:41:22.201: #rates = 1
2019-01-29 19:41:22.205:     Rate = 48000
2019-01-29 19:41:22.209: Output 1
2019-01-29 19:41:22.213:     ID = 2
2019-01-29 19:41:22.217:     Type = 2
2019-01-29 19:41:22.221:     Name = LG-H932
2019-01-29 19:41:22.225: #rates = 1
2019-01-29 19:41:22.229:     Rate = 48000
2019-01-29 19:41:22.233: Output 2
2019-01-29 19:41:22.237:     ID = 22
2019-01-29 19:41:22.240:     Type = 4
2019-01-29 19:41:22.244:     Name = LG-H932
2019-01-29 19:41:22.248: #rates = 1
2019-01-29 19:41:22.252:     Rate = 48000
2019-01-29 19:41:22.255: Output 3
2019-01-29 19:41:22.259:     ID = 5
2019-01-29 19:41:22.263:     Type = 18
2019-01-29 19:41:22.267:     Name = LG-H932
2019-01-29 19:41:22.270: #rates = 2
2019-01-29 19:41:22.274:     Rate = 8000
2019-01-29 19:41:22.278:     Rate = 16000
2019-01-29 19:41:22.284: Service created
2019-01-29 19:41:22.288: onStartCommand
2019-01-29 19:41:22.296: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:41:22.347: Connectivity change, state = CONNECTED, type = WIFI
2019-01-29 19:41:22.387: CT 772195341009, 949194403724, 2679720
2019-01-29 19:41:22.391: DT
2019-01-29 19:41:22.559: onStartCommand
2019-01-29 19:41:22.567: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:41:22.579: onStartCommand
2019-01-29 19:41:22.586: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:41:22.632: postReloadQueue, i_currentPos = 96589
2019-01-29 19:41:24.800: onStartCommand
2019-01-29 19:41:24.810: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:41:24.829: onStartCommand
2019-01-29 19:41:24.841: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:41:26.590: onStartCommand
2019-01-29 19:41:26.631: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:41:26.665: onStartCommand
2019-01-29 19:41:26.681: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:41:30.393: linkSpeed = 866 Mbps
2019-01-29 19:41:30.403: Restrict bg status = 32019:01:29 19:41:30.407 setOutputType 2
2019:01:29 19:41:31.417 prep ATN i_sampleRate = 44100, i_flags = 400000, i_format = 0, bufferSize = 131072
2019-01-29 19:41:31.439: Play Android, HiRes = true
2019-01-29 19:41:56.560: Stop
2019-01-29 19:41:56.862: Return because isAsyncInProgress, pos = 4, i_play = true
2019-01-29 19:41:57.236: linkSpeed = 866 Mbps
2019-01-29 19:41:57.250: Restrict bg status = 32019:01:29 19:41:57.254 setOutputType 2
2019-01-29 19:41:58.037: Play Android, HiRes = true
2019-01-29 19:42:26.706: MediaService: onDestroy
2019-01-29 19:42:26.713: MediaService: onDestroy, player stop
2019-01-29 19:42:26.725: Remove media session
2019-01-29 19:42:26.734: MediaService: onDestroy, send exit
2019-01-29 19:42:26.742: T: delete AS2019:01:29 19:42:26.743 DTOR AS
2019:01:29 19:42:26.743 Deleting old device
2019:01:29 19:42:26.743 Deleted old device
2019:01:29 19:42:26.750 DTOR OD 0xe83cf400
2019:01:29 19:42:26.750 Send exit message to decode thread
2019-01-29 19:42:26.756: T: AS deleted
2019-01-29 19:42:26.759: Closing DB
2019-01-29 19:42:26.771: MediaService: END onDestroy
2019-01-29 19:42:26.923: onDestroy SSPA
2019-01-29 19:43:57.563: App: loading 3rd party libs
2019-01-29 19:43:57.597: Loaded
2019-01-29 19:43:57.613: SSPA oncreate
2019-01-29 19:43:57.660: MediaService onCreate com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:43:57.665: Start LG-H932
lge
joan
26
2019-01-29 19:43:57.679: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c2019:01:29 19:43:57.698 CTOR AS
2019-01-29 19:43:57.756: Android driver = 12019:01:29 19:43:57.758 setOutputType 2
2019:01:29 19:43:57.758 new ATN
2019:01:29 19:43:57.758 CTOR ATN 0xe83cf540
2019-01-29 19:43:57.770: Logmethod = 0
2019-01-29 19:43:57.881: logFileName = /storage/emulated/0/UAPP/UAPP.txt, log to file = false
2019-01-29 19:43:57.886: Calling getUSBAudioDevices()
2019-01-29 19:43:57.925: loadPlayQueueInfo
2019-01-29 19:43:57.937: loadPlayQueueInfo done, diff = 8, counter = 19, i_queue.size = 19
2019-01-29 19:43:57.949: After reloadQueue
2019-01-29 19:43:57.966: #devices 4
2019-01-29 19:43:57.972: Output 0
2019-01-29 19:43:57.977:     ID = 1
2019-01-29 19:43:57.983:     Type = 1
2019-01-29 19:43:57.987:     Name = LG-H932
2019-01-29 19:43:57.993: #rates = 1
2019-01-29 19:43:57.997:     Rate = 48000
2019-01-29 19:43:58.002: Output 1
2019-01-29 19:43:58.007:     ID = 2
2019-01-29 19:43:58.011:     Type = 2
2019-01-29 19:43:58.015:     Name = LG-H932
2019-01-29 19:43:58.020: #rates = 1
2019-01-29 19:43:58.025:     Rate = 48000
2019-01-29 19:43:58.030: Output 2
2019-01-29 19:43:58.036:     ID = 22
2019-01-29 19:43:58.041:     Type = 4
2019-01-29 19:43:58.045:     Name = LG-H932
2019-01-29 19:43:58.050: #rates = 1
2019-01-29 19:43:58.054:     Rate = 48000
2019-01-29 19:43:58.059: Output 3
2019-01-29 19:43:58.063:     ID = 5
2019-01-29 19:43:58.068:     Type = 18
2019-01-29 19:43:58.074:     Name = LG-H932
2019-01-29 19:43:58.081: #rates = 2
2019-01-29 19:43:58.087:     Rate = 8000
2019-01-29 19:43:58.092:     Rate = 16000
2019-01-29 19:43:58.100: Service created
2019-01-29 19:43:58.104: onStartCommand
2019-01-29 19:43:58.114: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:43:58.161: Connectivity change, state = CONNECTED, type = WIFI
2019-01-29 19:43:58.198: CT 772195341009, 949194403724, 2679720
2019-01-29 19:43:58.201: DT
2019-01-29 19:43:58.380: onStartCommand
2019-01-29 19:43:58.388: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:43:58.399: onStartCommand
2019-01-29 19:43:58.407: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:43:58.458: postReloadQueue, i_currentPos = 26743
2019-01-29 19:44:00.221: onStartCommand
2019-01-29 19:44:00.240: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:44:00.257: onStartCommand
2019-01-29 19:44:00.281: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:44:07.752: onStartCommand
2019-01-29 19:44:07.783: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:44:09.443: onStartCommand
2019-01-29 19:44:09.459: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:44:09.477: onStartCommand
2019-01-29 19:44:09.493: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:44:11.130: linkSpeed = 780 Mbps
2019-01-29 19:44:11.138: Restrict bg status = 32019:01:29 19:44:11.142 setOutputType 2
2019:01:29 19:44:12.390 prep ATN i_sampleRate = 44100, i_flags = 400000, i_format = 0, bufferSize = 131072
2019-01-29 19:44:12.432: Play Android, HiRes = true
2019-01-29 19:51:47.294: onStartCommand
2019-01-29 19:51:47.314: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:52:07.577: MediaService: onDestroy
2019-01-29 19:52:07.582: MediaService: onDestroy, player stop
2019-01-29 19:52:07.595: Remove media session
2019-01-29 19:52:07.605: MediaService: onDestroy, send exit
2019-01-29 19:52:07.615: T: delete AS2019:01:29 19:52:07.616 DTOR AS
2019:01:29 19:52:07.618 Deleting old device
2019:01:29 19:52:07.618 Deleted old device
2019:01:29 19:52:07.626 DTOR OD 0xe83cf540
2019:01:29 19:52:07.626 Send exit message to decode thread
2019-01-29 19:52:07.634: T: AS deleted
2019-01-29 19:52:07.637: Closing DB
2019-01-29 19:52:07.653: MediaService: END onDestroy
2019-01-29 19:52:07.796: onDestroy SSPA
2019-01-29 19:55:36.365: App: loading 3rd party libs
2019-01-29 19:55:36.398: Loaded
2019-01-29 19:55:36.413: SSPA oncreate
2019-01-29 19:55:36.459: MediaService onCreate com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:55:36.463: Start LG-H932
lge
joan
26
2019-01-29 19:55:36.479: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c2019:01:29 19:55:36.493 CTOR AS
2019-01-29 19:55:36.549: Android driver = 12019:01:29 19:55:36.551 setOutputType 2
2019:01:29 19:55:36.551 new ATN
2019:01:29 19:55:36.551 CTOR ATN 0xe83cf540
2019-01-29 19:55:36.563: Logmethod = 0
2019-01-29 19:55:36.674: logFileName = /storage/emulated/0/UAPP/UAPP.txt, log to file = false
2019-01-29 19:55:36.680: Calling getUSBAudioDevices()
2019-01-29 19:55:36.720: loadPlayQueueInfo
2019-01-29 19:55:36.732: loadPlayQueueInfo done, diff = 8, counter = 19, i_queue.size = 19
2019-01-29 19:55:36.739: After reloadQueue
2019-01-29 19:55:36.747: #devices 4
2019-01-29 19:55:36.758: Output 0
2019-01-29 19:55:36.763:     ID = 1
2019-01-29 19:55:36.767:     Type = 1
2019-01-29 19:55:36.771:     Name = LG-H932
2019-01-29 19:55:36.775: #rates = 1
2019-01-29 19:55:36.779:     Rate = 48000
2019-01-29 19:55:36.783: Output 1
2019-01-29 19:55:36.788:     ID = 2
2019-01-29 19:55:36.793:     Type = 2
2019-01-29 19:55:36.797:     Name = LG-H932
2019-01-29 19:55:36.802: #rates = 1
2019-01-29 19:55:36.805:     Rate = 48000
2019-01-29 19:55:36.809: Output 2
2019-01-29 19:55:36.813:     ID = 22
2019-01-29 19:55:36.817:     Type = 4
2019-01-29 19:55:36.820:     Name = LG-H932
2019-01-29 19:55:36.824: #rates = 1
2019-01-29 19:55:36.828:     Rate = 48000
2019-01-29 19:55:36.832: Output 3
2019-01-29 19:55:36.835:     ID = 5
2019-01-29 19:55:36.839:     Type = 18
2019-01-29 19:55:36.843:     Name = LG-H932
2019-01-29 19:55:36.847: #rates = 2
2019-01-29 19:55:36.852:     Rate = 8000
2019-01-29 19:55:36.856:     Rate = 16000
2019-01-29 19:55:36.863: Service created
2019-01-29 19:55:36.868: onStartCommand
2019-01-29 19:55:36.876: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:55:36.926: Connectivity change, state = CONNECTED, type = WIFI
2019-01-29 19:55:36.964: CT 772195341009, 949194403724, 2679720
2019-01-29 19:55:36.969: DT
2019-01-29 19:55:37.131: onStartCommand
2019-01-29 19:55:37.149: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:55:37.161: onStartCommand
2019-01-29 19:55:37.170: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:55:37.218: postReloadQueue, i_currentPos = 170910
2019-01-29 19:55:40.123: onStartCommand
2019-01-29 19:55:40.147: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:55:41.757: onStartCommand
2019-01-29 19:55:41.770: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:55:44.364: onStartCommand
2019-01-29 19:55:44.412: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:55:44.446: onStartCommand
2019-01-29 19:55:44.470: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:55:47.138: linkSpeed = 866 Mbps
2019-01-29 19:55:47.144: Restrict bg status = 32019:01:29 19:55:47.149 setOutputType 2
2019-01-29 19:55:50.628: onStartCommand
2019-01-29 19:55:50.651: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c2019:01:29 19:55:52.023 prep ATN i_sampleRate = 44100, i_flags = 400000, i_format = 0, bufferSize = 131072
2019-01-29 19:55:52.062: Play Android, HiRes = true
2019-01-29 20:02:27.153: Message MESSAGE_TYPE_START
2019-01-29 20:02:27.163: linkSpeed = 866 Mbps
2019-01-29 20:02:27.170: Restrict bg status = 32019:01:29 20:02:27.174 setOutputType 2
2019-01-29 20:02:27:184  OutputDevice::preparePlayback, i_singleBufferSize = 131072, i_offsetMilliSeconds = 282539, i_isWiredHeadsetOn = 1, i_upsampleMethod = 0
2019-01-29 20:02:27.196: HttpURLConnection: Opening connection for Tidal, i_offset = 22587681
2019-01-29 20:02:27.448: Fetch 65536
2019-01-29 20:02:27.476: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22653217, m_contentLength = 22588706
2019-01-29 20:02:27.594: Diff: bytesRead 1025 of (1025) in 93 msec
2019-01-29 20:02:27.605: Fetch 65536
2019-01-29 20:02:27.615: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:02:27.629: HttpURLConnection: Returning -1 (end of file)!
2019-01-29 20:02:27.641: HttpURLConnection: Opening connection for Tidal, i_offset = 22585633
2019-01-29 20:02:27.736: Fetch 65536
2019-01-29 20:02:27.761: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22651169, m_contentLength = 22588706
2019-01-29 20:02:27.787: Fetch 65536
2019-01-29 20:02:27.816: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:02:27.844: HttpURLConnection: Returning -1 (end of file)!
2019-01-29 20:02:27.871: HttpURLConnection: Opening connection for Tidal, i_offset = 22581537
2019-01-29 20:02:28.008: Fetch 65536
2019-01-29 20:02:28.030: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22647073, m_contentLength = 22588706
2019-01-29 20:02:28.052: Fetch 65536
2019-01-29 20:02:28.062: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:02:28.070: HttpURLConnection: Returning -1 (end of file)!
2019-01-29 20:02:28.078: HttpURLConnection: Opening connection for Tidal, i_offset = 22573345
2019-01-29 20:02:28.161: Fetch 65536
2019-01-29 20:02:28.184: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22638881, m_contentLength = 22588706
2019-01-29 20:02:28.223: Fetch 65536
2019-01-29 20:02:28.235: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:02:28.244: HttpURLConnection: Returning -1 (end of file)!
2019-01-29 20:02:28.253: HttpURLConnection: Opening connection for Tidal, i_offset = 22556961
2019-01-29 20:02:28.367: Fetch 65536
2019-01-29 20:02:28.380: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22622497, m_contentLength = 22588706
2019-01-29 20:02:28.396: Fetch 65536
2019-01-29 20:02:28.410: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22640754, m_contentLength = 22588706
2019-01-29 20:02:28.434: Fetch 65536
2019-01-29 20:02:28.452: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:02:28.462: HttpURLConnection: Returning -1 (end of file)!
2019-01-29 20:02:28.474: HttpURLConnection: Opening connection for Tidal, i_offset = 22524193
2019-01-29 20:02:28.638: Fetch 65536
2019-01-29 20:02:28.665: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22589729, m_contentLength = 22588706
2019-01-29 20:02:28.697: Fetch 65536
2019-01-29 20:02:28.729: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22629079, m_contentLength = 22588706
2019-01-29 20:02:28.760: Fetch 65536
2019-01-29 20:02:28.788: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22646050, m_contentLength = 22588706
2019-01-29 20:02:28.829: Fetch 65536
2019-01-29 20:02:28.858: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:02:28.868: HttpURLConnection: Returning -1 (end of file)!
2019-01-29 20:02:28.878: HttpURLConnection: Opening connection for Tidal, i_offset = 22458657
2019-01-29 20:02:29.147: Fetch 65536
2019-01-29 20:02:29.194: Fetch 65536
2019-01-29 20:02:29.205: Fetch 65536
2019-01-29 20:02:29.218: Fetch 65536
2019-01-29 20:02:29.227: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22589353, m_contentLength = 22588706
2019-01-29 20:02:29.248: Fetch 65536
2019-01-29 20:02:29.259: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22619570, m_contentLength = 22588706
2019-01-29 20:02:29.272: Fetch 65536
2019-01-29 20:02:29.288: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22637858, m_contentLength = 22588706
2019-01-29 20:02:29.301: Fetch 65536
2019-01-29 20:02:29.313: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22638394, m_contentLength = 22588706
2019-01-29 20:02:29.326: HttpURLConnection: Opening connection for Tidal, i_offset = 22462821
2019-01-29 20:02:29.480: Fetch 65536
2019-01-29 20:02:29.511: Fetch 65536
2019-01-29 20:02:29.535: Fetch 65536
2019-01-29 20:02:29.545: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22593305, m_contentLength = 22588706
2019-01-29 20:02:29.557: Fetch 65536
2019-01-29 20:02:29.568: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22629666, m_contentLength = 22588706
2019-01-29 20:02:29.580: Fetch 65536
2019-01-29 20:02:29.590: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22646050, m_contentLength = 22588706
2019-01-29 20:02:29.601: HttpURLConnection: Opening connection for Tidal, i_offset = 22474470
2019-01-29 20:02:29.743: Fetch 65536
2019-01-29 20:02:29.758: Fetch 65536
2019-01-29 20:02:29.769: Fetch 65536
2019-01-29 20:02:29.780: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22602554, m_contentLength = 22588706
2019-01-29 20:02:29.789: Fetch 65536
2019-01-29 20:02:29.798: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22629666, m_contentLength = 22588706
2019-01-29 20:02:29.806: Fetch 65536
2019-01-29 20:02:29.815: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22643514, m_contentLength = 22588706
2019-01-29 20:02:29.824: Fetch 65536
2019-01-29 20:02:29.832: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:02:29.841: HttpURLConnection: Returning -1 (end of file)!
2019-01-29 20:02:29.850: HttpURLConnection: Opening connection for Tidal, i_offset = 224744692019-01-29 20:02:29:969  setActualDeviceSampleRate: decoder rate = 44100
2019-01-29 20:02:29:970  setActualDeviceSampleRate: getNearestDeviceSampleRate = 44100
2019-01-29 20:02:29:970  Device rate becomes 44100
2019-01-29 20:02:29:970  m_diskBufferSizeFrames = 524288
2019-01-29 20:02:29.993: Fetch 65536
2019-01-29 20:02:30.002: Fetch 65536
2019-01-29 20:02:30.023: Fetch 65536
2019-01-29 20:02:30.050: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22595029, m_contentLength = 22588706
2019-01-29 20:02:30.067: Fetch 65536
2019-01-29 20:02:30.077: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22629666, m_contentLength = 22588706
2019-01-29 20:02:30.086: Fetch 65536
2019-01-29 20:02:30.095: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22646050, m_contentLength = 22588706
2019-01-29 20:02:30.106: Fetch 65536
2019-01-29 20:02:30.115: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:02:30.126: HttpURLConnection: Returning -1 (end of file)!2019-01-29 20:02:30:133  not enough data, calling setNextToCurrent, framesToRead = 487424
2019-01-29 20:02:30:133  after setNextToCurrent: current = 0x0, m_next = 0x0
2019-01-29 20:02:30:133  Clearing double buffer area due to stop and go
2019-01-29 20:02:30:136  Error decoding or not enough frames in first block!
2019-01-29 20:02:30:136  bufferFrames = 131072 for sr 44100
2019-01-29 20:02:30.145: preparePlayback failed!
2019-01-29 20:02:48.106: onStartCommand
2019-01-29 20:02:48.124: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:02:52.230: onStartCommand
2019-01-29 20:02:52.247: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:02:52.264: onStartCommand
2019-01-29 20:02:52.293: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:02:56.455: setting async in prog because setting two songs
2019-01-29 20:02:56.464: Open ASYNC: Islandsmoen: Requiem - Lacrymosa
2019-01-29 20:02:56.831: onPositiveResult, i_isNextPosition = false
2019-01-29 20:02:56.846: Message MESSAGE_TYPE_QUEUE_SONG2019-01-29 20:02:56:847  Current was NULL, so current becomes Islandsmoen: Requiem - Lacrymosa = Tidal
2019-01-29 20:02:56:847  after setNextDataSource: current = 0xd187dd00, m_next = 0x0
2019-01-29 20:02:56.863: Message MESSAGE_TYPE_START
2019-01-29 20:02:56.863: Open ASYNC: Islandsmoen: Requiem - Confutatis
2019-01-29 20:02:56.882: linkSpeed = 866 Mbps
2019-01-29 20:02:56.894: Restrict bg status = 32019:01:29 20:02:56.900 setOutputType 2
2019-01-29 20:02:56.910: HttpURLConnection: fetchDataForReal: m_HttpURLConnection == null, creating request, this = com.extreamsd.usbaudioplayershared.ESDHTTPClient@85392a8
2019-01-29 20:02:56.918: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:02:57.100: HttpURLConnection: contentLength = 48607266 for Tidal
2019-01-29 20:02:57.121: Fetch 65536
2019-01-29 20:02:57.137: Fetch 335249
2019-01-29 20:02:57.168: Fetch 214529
2019-01-29 20:02:57.181: Fetch 126201
2019-01-29 20:02:57.198: Fetch 105929
2019-01-29 20:02:57.210: Fetch 65536
2019-01-29 20:02:57.220: Fetch 40393
2019-01-29 20:02:57.232: Fetch 65536
2019-01-29 20:02:57.274: onPositiveResult, i_isNextPosition = true
2019-01-29 20:02:57.285: Fetch 65536
2019-01-29 20:02:57.291: Fetch 65536
2019-01-29 20:02:57.297: Fetch 65536
2019-01-29 20:02:57.303: Fetch 65536
2019-01-29 20:02:57.311: Fetch 65536
2019-01-29 20:02:57.320: Fetch 65536
2019-01-29 20:02:57.328: Fetch 65536
2019-01-29 20:02:57.344: Fetch 65536
2019-01-29 20:02:57.363: Fetch 65536
2019-01-29 20:02:57.394: Fetch 65536
2019-01-29 20:02:57.411: Fetch 65536
2019-01-29 20:02:57.421: Fetch 65536
2019-01-29 20:02:57.433: Fetch 65536
2019-01-29 20:02:57.443: Fetch 65536
2019-01-29 20:02:57.453: Fetch 65536
2019-01-29 20:02:57.468: Fetch 65536
2019-01-29 20:02:57.484: Fetch 65536
2019-01-29 20:02:57.495: Fetch 65536
2019-01-29 20:02:57.511: Fetch 65536
2019-01-29 20:02:57.534: Fetch 65536
2019-01-29 20:02:57.544: Fetch 65536
2019-01-29 20:02:57.558: Fetch 65536
2019-01-29 20:02:57.576: Fetch 65536
2019-01-29 20:02:57.587: Fetch 65536
2019-01-29 20:02:57.599: Fetch 655362019-01-29 20:02:57:613  OutputDevice::preparePlayback, i_singleBufferSize = 131072, i_offsetMilliSeconds = 0, i_isWiredHeadsetOn = 1, i_upsampleMethod = 0
2019-01-29 20:02:57:613  setActualDeviceSampleRate: decoder rate = 44100
2019-01-29 20:02:57:613  setActualDeviceSampleRate: getNearestDeviceSampleRate = 44100
2019-01-29 20:02:57:614  Device rate becomes 44100
2019-01-29 20:02:57:614  m_diskBufferSizeFrames = 524288
2019-01-29 20:02:57.665: Fetch 65536
2019-01-29 20:02:57.683: Fetch 65536
2019-01-29 20:02:57.698: Fetch 65536
2019-01-29 20:02:57.705: Fetch 65536
2019-01-29 20:02:57.716: Fetch 65536
2019-01-29 20:02:57.727: Fetch 65536
2019-01-29 20:02:57.746: Fetch 65536
2019-01-29 20:02:57.791: Fetch 65536
2019-01-29 20:02:57.815: Fetch 65536
2019-01-29 20:02:57.828: Fetch 65536
2019-01-29 20:02:57.843: Fetch 65536
2019-01-29 20:02:57.856: Fetch 65536
2019-01-29 20:02:57.871: Fetch 65536
2019-01-29 20:02:57.883: Fetch 65536
2019-01-29 20:02:57.895: Fetch 65536
2019-01-29 20:02:57.908: Fetch 65536
2019-01-29 20:02:57.925: Fetch 65536
2019-01-29 20:02:57.938: Fetch 65536
2019-01-29 20:02:57.957: Fetch 65536
2019-01-29 20:02:57.973: Fetch 65536
2019-01-29 20:02:57.988: Fetch 65536
2019-01-29 20:02:58.005: Fetch 65536
2019-01-29 20:02:58.018: Fetch 65536
2019-01-29 20:02:58.031: Fetch 65536
2019-01-29 20:02:58.044: Fetch 65536
2019-01-29 20:02:58.057: Fetch 65536
2019-01-29 20:02:58.069: Fetch 65536
2019-01-29 20:02:58.086: Fetch 65536
2019-01-29 20:02:58.100: Fetch 65536
2019-01-29 20:02:58.113: Fetch 65536
2019-01-29 20:02:58.127: Fetch 65536
2019-01-29 20:02:58.141: Fetch 65536
2019-01-29 20:02:58.155: Fetch 65536
2019-01-29 20:02:58.175: Fetch 65536
2019-01-29 20:02:58.189: Fetch 65536
2019-01-29 20:02:58.205: Fetch 65536
2019-01-29 20:02:58.219: Fetch 65536
2019-01-29 20:02:58.231: Fetch 65536
2019-01-29 20:02:58.245: Fetch 65536
2019-01-29 20:02:58.256: Fetch 65536
2019-01-29 20:02:58.267: Fetch 65536
2019-01-29 20:02:58.279: Fetch 65536
2019-01-29 20:02:58.294: Fetch 65536
2019-01-29 20:02:58.305: Fetch 65536
2019-01-29 20:02:58.321: Fetch 65536
2019-01-29 20:02:58.334: Fetch 65536
2019-01-29 20:02:58.345: Fetch 65536
2019-01-29 20:02:58.359: Fetch 65536
2019-01-29 20:02:58.370: Fetch 65536
2019-01-29 20:02:58.384: Fetch 65536
2019-01-29 20:02:58.397: Fetch 65536
2019-01-29 20:02:58.413: Fetch 65536
2019-01-29 20:02:58.436: Fetch 65536
2019-01-29 20:02:58.453: Fetch 65536
2019-01-29 20:02:58.472: Fetch 65536
2019-01-29 20:02:58.484: Fetch 65536
2019-01-29 20:02:58.501: Fetch 65536
2019-01-29 20:02:58.515: Fetch 65536
2019-01-29 20:02:58.525: Fetch 65536
2019-01-29 20:02:58.541: Fetch 65536
2019-01-29 20:02:58.554: Fetch 65536
2019-01-29 20:02:58.580: Fetch 65536
2019-01-29 20:02:58.600: Fetch 65536
2019-01-29 20:02:58.616: Fetch 65536
2019-01-29 20:02:58.630: Fetch 65536
2019-01-29 20:02:58.645: Fetch 65536
2019-01-29 20:02:58.664: Fetch 65536
2019-01-29 20:02:58.678: Fetch 65536
2019-01-29 20:02:58.701: Fetch 65536
2019-01-29 20:02:58.722: Fetch 65536
2019-01-29 20:02:58.743: Fetch 65536
2019-01-29 20:02:58.765: Fetch 65536
2019-01-29 20:02:58.784: Fetch 65536
2019-01-29 20:02:58.797: Fetch 65536
2019-01-29 20:02:58.808: Fetch 65536
2019-01-29 20:02:58.826: Fetch 65536
2019-01-29 20:02:58.838: Fetch 65536
2019-01-29 20:02:58.853: Fetch 65536
2019-01-29 20:02:58.870: Fetch 65536
2019-01-29 20:02:58.884: Fetch 65536
2019-01-29 20:02:58.899: Fetch 65536
2019-01-29 20:02:58.915: Fetch 65536
2019-01-29 20:02:58.928: Fetch 65536
2019-01-29 20:02:58.949: Fetch 65536
2019-01-29 20:02:58.963: Fetch 65536
2019-01-29 20:02:58.976: Fetch 655362019-01-29 20:02:58:980  Reusing audiotrack
2019-01-29 20:02:58:983  bufferFrames = 131072 for sr 44100
2019-01-29 20:02:58.997: Play Android, HiRes = true2019-01-29 20:02:58:997  ATN start
2019-01-29 20:02:59.057: Message MESSAGE_TYPE_QUEUE_SONG2019-01-29 20:02:59:59  Current wasn't NULL, so setting next to Islandsmoen: Requiem - Confutatis = Tidal
2019-01-29 20:02:59:59  after setNextDataSource: current = 0xd187dd00, m_next = 0xd0349100
2019-01-29 20:02:59.080: Setting m_asyncInProgress to false in A
2019-01-29 20:03:07.872: Fetch 65536
2019-01-29 20:03:07.918: Fetch 65536
2019-01-29 20:03:07.932: Fetch 65536
2019-01-29 20:03:07.945: Fetch 65536
2019-01-29 20:03:07.958: Fetch 65536
2019-01-29 20:03:07.972: Fetch 65536
2019-01-29 20:03:07.986: Fetch 65536
2019-01-29 20:03:08.002: Fetch 65536
2019-01-29 20:03:08.022: Fetch 65536
2019-01-29 20:03:08.043: Fetch 65536
2019-01-29 20:03:08.061: Fetch 65536
2019-01-29 20:03:08.076: Fetch 65536
2019-01-29 20:03:08.089: Fetch 65536
2019-01-29 20:03:08.101: Fetch 65536
2019-01-29 20:03:08.113: Fetch 65536
2019-01-29 20:03:08.132: Fetch 65536
2019-01-29 20:03:08.146: Fetch 65536
2019-01-29 20:03:08.162: Fetch 65536
2019-01-29 20:03:08.180: Fetch 65536
2019-01-29 20:03:08.195: Fetch 65536
2019-01-29 20:03:08.211: Fetch 65536
2019-01-29 20:03:08.222: Fetch 65536
2019-01-29 20:03:08.233: Fetch 65536
2019-01-29 20:03:08.243: Fetch 65536
2019-01-29 20:03:08.253: Fetch 65536
2019-01-29 20:03:08.264: Fetch 65536
2019-01-29 20:03:08.281: Fetch 65536
2019-01-29 20:03:08.295: Fetch 65536
2019-01-29 20:03:08.310: Fetch 65536
2019-01-29 20:03:08.325: Fetch 65536
2019-01-29 20:03:08.338: Fetch 65536
2019-01-29 20:03:08.356: Fetch 65536
2019-01-29 20:03:08.379: Fetch 65536
2019-01-29 20:03:08.404: Fetch 65536
2019-01-29 20:03:08.417: Fetch 65536
2019-01-29 20:03:08.430: Fetch 65536
2019-01-29 20:03:08.444: Fetch 65536
2019-01-29 20:03:08.460: Fetch 65536
2019-01-29 20:03:08.474: Fetch 65536
2019-01-29 20:03:08.488: Fetch 65536
2019-01-29 20:03:08.501: Fetch 65536
2019-01-29 20:03:08.518: Fetch 65536
2019-01-29 20:03:08.533: Fetch 65536
2019-01-29 20:03:08.545: Fetch 65536
2019-01-29 20:03:08.557: Fetch 65536
2019-01-29 20:03:08.571: Fetch 65536
2019-01-29 20:03:08.582: Fetch 65536
2019-01-29 20:03:08.594: Fetch 65536
2019-01-29 20:03:08.612: Fetch 65536
2019-01-29 20:03:08.624: Fetch 65536
2019-01-29 20:03:08.640: Fetch 65536
2019-01-29 20:03:08.658: Fetch 65536
2019-01-29 20:03:08.675: Fetch 65536
2019-01-29 20:03:08.691: Fetch 65536
2019-01-29 20:03:08.705: Fetch 65536
2019-01-29 20:03:08.719: Fetch 65536
2019-01-29 20:03:08.735: Fetch 65536
2019-01-29 20:03:19.746: Fetch 65536
2019-01-29 20:03:19.773: Fetch 65536
2019-01-29 20:03:19.786: Fetch 65536
2019-01-29 20:03:19.799: Fetch 65536
2019-01-29 20:03:19.813: Fetch 65536
2019-01-29 20:03:19.826: Fetch 65536
2019-01-29 20:03:19.838: Fetch 65536
2019-01-29 20:03:19.856: Fetch 65536
2019-01-29 20:03:19.874: Fetch 65536
2019-01-29 20:03:19.892: Fetch 65536
2019-01-29 20:03:19.906: Fetch 65536
2019-01-29 20:03:19.919: Fetch 65536
2019-01-29 20:03:19.938: Fetch 65536
2019-01-29 20:03:19.951: Fetch 65536
2019-01-29 20:03:19.965: Fetch 65536
2019-01-29 20:03:19.984: Fetch 65536
2019-01-29 20:03:19.996: Fetch 65536
2019-01-29 20:03:20.008: Fetch 65536
2019-01-29 20:03:20.018: Fetch 65536
2019-01-29 20:03:20.028: Fetch 65536
2019-01-29 20:03:20.038: Fetch 65536
2019-01-29 20:03:20.050: Fetch 65536
2019-01-29 20:03:20.066: Fetch 65536
2019-01-29 20:03:20.079: Fetch 65536
2019-01-29 20:03:20.092: Fetch 65536
2019-01-29 20:03:20.110: Fetch 65536
2019-01-29 20:03:20.123: Fetch 65536
2019-01-29 20:03:20.137: Fetch 65536
2019-01-29 20:03:20.154: Fetch 65536
2019-01-29 20:03:20.169: Fetch 65536
2019-01-29 20:03:20.184: Fetch 65536
2019-01-29 20:03:20.200: Fetch 65536
2019-01-29 20:03:20.217: Fetch 65536
2019-01-29 20:03:20.231: Fetch 65536
2019-01-29 20:03:20.244: Fetch 65536
2019-01-29 20:03:20.269: Fetch 65536
2019-01-29 20:03:20.282: Fetch 65536
2019-01-29 20:03:20.293: Fetch 65536
2019-01-29 20:03:20.304: Fetch 65536
2019-01-29 20:03:20.314: Fetch 65536
2019-01-29 20:03:20.322: Fetch 65536
2019-01-29 20:03:20.333: Fetch 65536
2019-01-29 20:03:20.348: Fetch 65536
2019-01-29 20:03:20.366: Fetch 65536
2019-01-29 20:03:20.395: Fetch 65536
2019-01-29 20:03:20.436: Fetch 65536
2019-01-29 20:03:20.456: Fetch 65536
2019-01-29 20:03:20.468: Fetch 65536
2019-01-29 20:03:20.480: Fetch 65536
2019-01-29 20:03:20.494: Fetch 65536
2019-01-29 20:03:20.505: Fetch 65536
2019-01-29 20:03:20.518: Fetch 65536
2019-01-29 20:03:20.536: Fetch 65536
2019-01-29 20:03:20.549: Fetch 65536
2019-01-29 20:03:20.564: Fetch 65536
2019-01-29 20:03:20.581: Fetch 65536
2019-01-29 20:03:20.597: Fetch 65536
2019-01-29 20:03:20.614: Fetch 65536
2019-01-29 20:03:20.630: Fetch 65536
2019-01-29 20:03:20.640: Fetch 65536
2019-01-29 20:03:31.669: Fetch 65536
2019-01-29 20:03:31.699: Fetch 65536
2019-01-29 20:03:31.712: Fetch 65536
2019-01-29 20:03:31.725: Fetch 65536
2019-01-29 20:03:31.740: Fetch 65536
2019-01-29 20:03:31.756: Fetch 65536
2019-01-29 20:03:31.774: Fetch 65536
2019-01-29 20:03:31.815: Fetch 65536
2019-01-29 20:03:31.833: Fetch 65536
2019-01-29 20:03:31.847: Fetch 65536
2019-01-29 20:03:31.863: Fetch 65536
2019-01-29 20:03:31.876: Fetch 65536
2019-01-29 20:03:31.889: Fetch 65536
2019-01-29 20:03:31.903: Fetch 65536
2019-01-29 20:03:31.920: Fetch 65536
2019-01-29 20:03:31.938: Fetch 65536
2019-01-29 20:03:31.958: Fetch 65536
2019-01-29 20:03:31.975: Fetch 65536
2019-01-29 20:03:31.989: Fetch 65536
2019-01-29 20:03:32.006: Fetch 65536
2019-01-29 20:03:32.016: Fetch 65536
2019-01-29 20:03:32.025: Fetch 65536
2019-01-29 20:03:32.035: Fetch 65536
2019-01-29 20:03:32.046: Fetch 65536
2019-01-29 20:03:32.059: Fetch 65536
2019-01-29 20:03:32.069: Fetch 65536
2019-01-29 20:03:32.083: Fetch 65536
2019-01-29 20:03:32.106: Fetch 65536
2019-01-29 20:03:32.119: Fetch 65536
2019-01-29 20:03:32.130: Fetch 65536
2019-01-29 20:03:32.143: Fetch 65536
2019-01-29 20:03:32.157: Fetch 65536
2019-01-29 20:03:32.174: Fetch 65536
2019-01-29 20:03:32.191: Fetch 65536
2019-01-29 20:03:32.203: Fetch 65536
2019-01-29 20:03:32.217: Fetch 65536
2019-01-29 20:03:32.234: Fetch 65536
2019-01-29 20:03:32.245: Fetch 65536
2019-01-29 20:03:32.258: Fetch 65536
2019-01-29 20:03:32.273: Fetch 65536
2019-01-29 20:03:32.286: Fetch 65536
2019-01-29 20:03:32.302: Fetch 65536
2019-01-29 20:03:32.324: Fetch 65536
2019-01-29 20:03:32.339: Fetch 65536
2019-01-29 20:03:32.356: Fetch 65536
2019-01-29 20:03:32.370: Fetch 65536
2019-01-29 20:03:32.384: Fetch 65536
2019-01-29 20:03:32.397: Fetch 65536
2019-01-29 20:03:32.408: Fetch 65536
2019-01-29 20:03:32.426: Fetch 65536
2019-01-29 20:03:32.443: Fetch 65536
2019-01-29 20:03:32.466: Fetch 65536
2019-01-29 20:03:32.488: Fetch 65536
2019-01-29 20:03:32.500: Fetch 65536
2019-01-29 20:03:32.511: Fetch 65536
2019-01-29 20:03:32.530: Fetch 65536
2019-01-29 20:03:32.556: Fetch 65536
2019-01-29 20:03:32.570: Fetch 65536
2019-01-29 20:03:32.583: Fetch 65536
2019-01-29 20:03:32.594: Fetch 65536
2019-01-29 20:03:32.607: Fetch 65536
2019-01-29 20:03:45.021: Fetch 65536
2019-01-29 20:03:45.045: Fetch 65536
2019-01-29 20:03:45.058: Fetch 65536
2019-01-29 20:03:45.071: Fetch 65536
2019-01-29 20:03:45.084: Fetch 65536
2019-01-29 20:03:45.101: Fetch 65536
2019-01-29 20:03:45.124: Fetch 65536
2019-01-29 20:03:45.149: Fetch 65536
2019-01-29 20:03:45.174: Fetch 65536
2019-01-29 20:03:45.185: Fetch 65536
2019-01-29 20:03:45.196: Fetch 65536
2019-01-29 20:03:45.208: Fetch 65536
2019-01-29 20:03:45.219: Fetch 65536
2019-01-29 20:03:45.230: Fetch 65536
2019-01-29 20:03:45.243: Fetch 65536
2019-01-29 20:03:45.257: Fetch 65536
2019-01-29 20:03:45.281: Fetch 65536
2019-01-29 20:03:45.296: Fetch 65536
2019-01-29 20:03:45.313: Fetch 65536
2019-01-29 20:03:45.335: Fetch 65536
2019-01-29 20:03:45.353: Fetch 65536
2019-01-29 20:03:45.364: Fetch 65536
2019-01-29 20:03:45.378: Fetch 65536
2019-01-29 20:03:45.391: Fetch 65536
2019-01-29 20:03:45.404: Fetch 65536
2019-01-29 20:03:45.418: Fetch 65536
2019-01-29 20:03:45.432: Fetch 65536
2019-01-29 20:03:45.443: Fetch 65536
2019-01-29 20:03:45.457: Fetch 65536
2019-01-29 20:03:45.470: Fetch 65536
2019-01-29 20:03:45.485: Fetch 65536
2019-01-29 20:03:45.501: Fetch 65536
2019-01-29 20:03:45.532: Fetch 65536
2019-01-29 20:03:45.554: Fetch 65536
2019-01-29 20:03:45.568: Fetch 65536
2019-01-29 20:03:45.584: Fetch 65536
2019-01-29 20:03:45.597: Fetch 65536
2019-01-29 20:03:45.615: Fetch 65536
2019-01-29 20:03:45.628: Fetch 65536
2019-01-29 20:03:45.641: Fetch 65536
2019-01-29 20:03:45.654: Fetch 65536
2019-01-29 20:03:45.667: Fetch 65536
2019-01-29 20:03:45.682: Fetch 65536
2019-01-29 20:03:45.701: Fetch 65536
2019-01-29 20:03:45.715: Fetch 65536
2019-01-29 20:03:45.749: Fetch 65536
2019-01-29 20:03:45.763: Fetch 65536
2019-01-29 20:03:45.778: Fetch 65536
2019-01-29 20:03:45.796: Fetch 65536
2019-01-29 20:03:45.811: Fetch 65536
2019-01-29 20:03:45.823: Fetch 65536
2019-01-29 20:03:45.836: Fetch 65536
2019-01-29 20:03:45.851: Fetch 65536
2019-01-29 20:03:45.874: Fetch 65536
2019-01-29 20:03:45.889: Fetch 65536
2019-01-29 20:03:45.905: Fetch 65536
2019-01-29 20:03:45.918: Fetch 65536
2019-01-29 20:03:45.930: Fetch 65536
2019-01-29 20:03:45.944: Fetch 65536
2019-01-29 20:03:45.959: Fetch 65536
2019-01-29 20:03:45.980: Fetch 65536
2019-01-29 20:03:46.000: Fetch 65536
2019-01-29 20:03:55.431: Fetch 65536
2019-01-29 20:03:55.472: Fetch 65536
2019-01-29 20:03:55.485: Fetch 65536
2019-01-29 20:03:55.498: Fetch 65536
2019-01-29 20:03:55.513: Fetch 65536
2019-01-29 20:03:55.527: Fetch 65536
2019-01-29 20:03:55.552: Fetch 65536
2019-01-29 20:03:55.563: Fetch 65536
2019-01-29 20:03:55.574: Fetch 65536
2019-01-29 20:03:55.588: Fetch 65536
2019-01-29 20:03:55.603: Fetch 65536
2019-01-29 20:03:55.618: Fetch 65536
2019-01-29 20:03:55.636: Fetch 65536
2019-01-29 20:03:55.659: Fetch 65536
2019-01-29 20:03:55.675: Fetch 65536
2019-01-29 20:03:55.692: Fetch 65536
2019-01-29 20:03:55.706: Fetch 65536
2019-01-29 20:03:55.720: Fetch 65536
2019-01-29 20:03:55.734: Fetch 65536
2019-01-29 20:03:55.748: Fetch 65536
2019-01-29 20:03:55.772: Fetch 65536
2019-01-29 20:03:55.791: Fetch 65536
2019-01-29 20:03:55.803: Fetch 65536
2019-01-29 20:03:55.819: Fetch 65536
2019-01-29 20:03:55.833: Fetch 65536
2019-01-29 20:03:55.854: Fetch 65536
2019-01-29 20:03:55.866: Fetch 65536
2019-01-29 20:03:55.880: Fetch 65536
2019-01-29 20:03:55.895: Fetch 65536
2019-01-29 20:03:55.911: Fetch 65536
2019-01-29 20:03:55.935: Fetch 65536
2019-01-29 20:03:55.948: Fetch 65536
2019-01-29 20:03:55.960: Fetch 65536
2019-01-29 20:03:55.973: Fetch 65536
2019-01-29 20:03:55.993: Fetch 65536
2019-01-29 20:03:56.005: Fetch 65536
2019-01-29 20:03:56.018: Fetch 65536
2019-01-29 20:03:56.030: Fetch 65536
2019-01-29 20:03:56.044: Fetch 65536
2019-01-29 20:03:56.059: Fetch 65536
2019-01-29 20:03:56.078: Fetch 65536
2019-01-29 20:03:56.098: Fetch 65536
2019-01-29 20:03:56.120: Fetch 65536
2019-01-29 20:03:56.138: Fetch 65536
2019-01-29 20:03:56.156: Fetch 65536
2019-01-29 20:03:56.174: Fetch 65536
2019-01-29 20:03:56.185: Fetch 65536
2019-01-29 20:03:56.198: Fetch 65536
2019-01-29 20:03:56.210: Fetch 65536
2019-01-29 20:03:56.223: Fetch 65536
2019-01-29 20:03:56.246: Fetch 65536
2019-01-29 20:03:56.265: Fetch 65536
2019-01-29 20:03:56.278: Fetch 65536
2019-01-29 20:03:56.293: Fetch 65536
2019-01-29 20:03:56.316: Fetch 65536
2019-01-29 20:03:56.331: Fetch 65536
2019-01-29 20:03:56.342: Fetch 65536
2019-01-29 20:03:56.365: Fetch 65536
2019-01-29 20:03:56.380: Fetch 65536
2019-01-29 20:03:56.395: Fetch 65536
2019-01-29 20:03:56.407: Fetch 65536
2019-01-29 20:03:56.422: Fetch 65536
2019-01-29 20:03:56.439: Fetch 65536
2019-01-29 20:03:56.461: Fetch 65536
2019-01-29 20:04:08.791: Fetch 65536
2019-01-29 20:04:08.831: Fetch 65536
2019-01-29 20:04:08.845: Fetch 65536
2019-01-29 20:04:08.858: Fetch 65536
2019-01-29 20:04:08.871: Fetch 65536
2019-01-29 20:04:08.885: Fetch 65536
2019-01-29 20:04:08.902: Fetch 65536
2019-01-29 20:04:08.923: Fetch 65536
2019-01-29 20:04:08.951: Fetch 65536
2019-01-29 20:04:08.971: Fetch 65536
2019-01-29 20:04:08.982: Fetch 65536
2019-01-29 20:04:08.995: Fetch 65536
2019-01-29 20:04:09.006: Fetch 65536
2019-01-29 20:04:09.022: Fetch 65536
2019-01-29 20:04:09.044: Fetch 65536
2019-01-29 20:04:09.059: Fetch 65536
2019-01-29 20:04:09.080: Fetch 65536
2019-01-29 20:04:09.093: Fetch 65536
2019-01-29 20:04:09.107: Fetch 65536
2019-01-29 20:04:09.125: Fetch 65536
2019-01-29 20:04:09.138: Fetch 65536
2019-01-29 20:04:09.155: Fetch 65536
2019-01-29 20:04:09.169: Fetch 65536
2019-01-29 20:04:09.185: Fetch 65536
2019-01-29 20:04:09.201: Fetch 65536
2019-01-29 20:04:09.220: Fetch 65536
2019-01-29 20:04:09.236: Fetch 65536
2019-01-29 20:04:09.250: Fetch 65536
2019-01-29 20:04:09.262: Fetch 65536
2019-01-29 20:04:09.281: Fetch 65536
2019-01-29 20:04:09.294: Fetch 65536
2019-01-29 20:04:09.308: Fetch 65536
2019-01-29 20:04:09.331: Fetch 65536
2019-01-29 20:04:09.344: Fetch 65536
2019-01-29 20:04:09.358: Fetch 65536
2019-01-29 20:04:09.371: Fetch 65536
2019-01-29 20:04:09.384: Fetch 65536
2019-01-29 20:04:09.399: Fetch 65536
2019-01-29 20:04:09.414: Fetch 65536
2019-01-29 20:04:09.435: Fetch 65536
2019-01-29 20:04:09.458: Fetch 65536
2019-01-29 20:04:09.476: Fetch 65536
2019-01-29 20:04:09.487: Fetch 65536
2019-01-29 20:04:09.500: Fetch 65536
2019-01-29 20:04:09.517: Fetch 65536
2019-01-29 20:04:09.538: Fetch 65536
2019-01-29 20:04:09.554: Fetch 65536
2019-01-29 20:04:09.571: Fetch 65536
2019-01-29 20:04:09.587: Fetch 65536
2019-01-29 20:04:09.604: Fetch 65536
2019-01-29 20:04:09.618: Fetch 65536
2019-01-29 20:04:09.630: Fetch 65536
2019-01-29 20:04:09.644: Fetch 65536
2019-01-29 20:04:09.662: Fetch 65536
2019-01-29 20:04:09.680: Fetch 65536
2019-01-29 20:04:09.700: Fetch 65536
2019-01-29 20:04:09.714: Fetch 65536
2019-01-29 20:04:09.726: Fetch 65536
2019-01-29 20:04:09.746: Fetch 65536
2019-01-29 20:04:09.759: Fetch 65536
2019-01-29 20:04:09.772: Fetch 65536
2019-01-29 20:04:09.785: Fetch 65536
2019-01-29 20:04:09.796: Fetch 65536
2019-01-29 20:04:09.806: Fetch 65536
2019-01-29 20:04:09.817: Fetch 65536
2019-01-29 20:04:19.203: Fetch 65536
2019-01-29 20:04:19.224: Fetch 65536
2019-01-29 20:04:19.237: Fetch 65536
2019-01-29 20:04:19.248: Fetch 65536
2019-01-29 20:04:19.264: Fetch 65536
2019-01-29 20:04:19.279: Fetch 65536
2019-01-29 20:04:19.303: Fetch 65536
2019-01-29 20:04:19.326: Fetch 65536
2019-01-29 20:04:19.339: Fetch 65536
2019-01-29 20:04:19.353: Fetch 65536
2019-01-29 20:04:19.366: Fetch 65536
2019-01-29 20:04:19.378: Fetch 65536
2019-01-29 20:04:19.392: Fetch 65536
2019-01-29 20:04:19.407: Fetch 65536
2019-01-29 20:04:19.423: Fetch 65536
2019-01-29 20:04:19.440: Fetch 65536
2019-01-29 20:04:19.461: Fetch 65536
2019-01-29 20:04:19.479: Fetch 65536
2019-01-29 20:04:19.509: Fetch 65536
2019-01-29 20:04:19.536: Fetch 65536
2019-01-29 20:04:19.552: Fetch 65536
2019-01-29 20:04:19.564: Fetch 65536
2019-01-29 20:04:19.581: Fetch 65536
2019-01-29 20:04:19.596: Fetch 65536
2019-01-29 20:04:19.608: Fetch 65536
2019-01-29 20:04:19.624: Fetch 65536
2019-01-29 20:04:19.639: Fetch 65536
2019-01-29 20:04:19.655: Fetch 65536
2019-01-29 20:04:19.668: Fetch 65536
2019-01-29 20:04:19.681: Fetch 65536
2019-01-29 20:04:19.697: Fetch 65536
2019-01-29 20:04:19.711: Fetch 65536
2019-01-29 20:04:19.737: Fetch 65536
2019-01-29 20:04:19.754: Fetch 65536
2019-01-29 20:04:19.765: Fetch 65536
2019-01-29 20:04:19.781: Fetch 65536
2019-01-29 20:04:19.795: Fetch 65536
2019-01-29 20:04:19.810: Fetch 65536
2019-01-29 20:04:19.828: Fetch 65536
2019-01-29 20:04:19.843: Fetch 65536
2019-01-29 20:04:19.859: Fetch 65536
2019-01-29 20:04:19.871: Fetch 65536
2019-01-29 20:04:19.887: Fetch 65536
2019-01-29 20:04:19.904: Fetch 65536
2019-01-29 20:04:19.922: Fetch 65536
2019-01-29 20:04:19.942: Fetch 65536
2019-01-29 20:04:19.961: Fetch 65536
2019-01-29 20:04:19.977: Fetch 65536
2019-01-29 20:04:19.992: Fetch 65536
2019-01-29 20:04:20.004: Fetch 65536
2019-01-29 20:04:20.016: Fetch 65536
2019-01-29 20:04:20.028: Fetch 65536
2019-01-29 20:04:20.041: Fetch 65536
2019-01-29 20:04:20.058: Fetch 65536
2019-01-29 20:04:20.071: Fetch 65536
2019-01-29 20:04:20.086: Fetch 65536
2019-01-29 20:04:20.105: Fetch 65536
2019-01-29 20:04:20.120: Fetch 65536
2019-01-29 20:04:20.134: Fetch 65536
2019-01-29 20:04:20.147: Fetch 65536
2019-01-29 20:04:20.163: Fetch 65536
2019-01-29 20:04:31.097: Fetch 65536
2019-01-29 20:04:31.131: Fetch 65536
2019-01-29 20:04:31.147: Fetch 65536
2019-01-29 20:04:31.161: Fetch 65536
2019-01-29 20:04:31.175: Fetch 65536
2019-01-29 20:04:31.186: Fetch 65536
2019-01-29 20:04:31.198: Fetch 65536
2019-01-29 20:04:31.215: Fetch 65536
2019-01-29 20:04:31.238: Fetch 65536
2019-01-29 20:04:31.254: Fetch 65536
2019-01-29 20:04:31.273: Fetch 65536
2019-01-29 20:04:31.286: Fetch 65536
2019-01-29 20:04:31.297: Fetch 65536
2019-01-29 20:04:31.307: Fetch 65536
2019-01-29 20:04:31.328: Fetch 65536
2019-01-29 20:04:31.348: Fetch 65536
2019-01-29 20:04:31.365: Fetch 65536
2019-01-29 20:04:31.381: Fetch 65536
2019-01-29 20:04:31.393: Fetch 65536
2019-01-29 20:04:31.407: Fetch 65536
2019-01-29 20:04:31.433: Fetch 65536
2019-01-29 20:04:31.445: Fetch 65536
2019-01-29 20:04:31.457: Fetch 65536
2019-01-29 20:04:31.471: Fetch 65536
2019-01-29 20:04:31.485: Fetch 65536
2019-01-29 20:04:31.498: Fetch 65536
2019-01-29 20:04:31.512: Fetch 65536
2019-01-29 20:04:31.528: Fetch 65536
2019-01-29 20:04:31.541: Fetch 65536
2019-01-29 20:04:31.553: Fetch 65536
2019-01-29 20:04:31.567: Fetch 65536
2019-01-29 20:04:31.583: Fetch 65536
2019-01-29 20:04:31.607: Fetch 65536
2019-01-29 20:04:31.628: Fetch 65536
2019-01-29 20:04:31.647: Fetch 65536
2019-01-29 20:04:31.659: Fetch 65536
2019-01-29 20:04:31.670: Fetch 65536
2019-01-29 20:04:31.682: Fetch 65536
2019-01-29 20:04:31.694: Fetch 65536
2019-01-29 20:04:31.707: Fetch 65536
2019-01-29 20:04:31.728: Fetch 65536
2019-01-29 20:04:31.744: Fetch 65536
2019-01-29 20:04:31.764: Fetch 65536
2019-01-29 20:04:31.783: Fetch 65536
2019-01-29 20:04:31.798: Fetch 65536
2019-01-29 20:04:31.808: Fetch 65536
2019-01-29 20:04:31.822: Fetch 65536
2019-01-29 20:04:31.834: Fetch 65536
2019-01-29 20:04:31.846: Fetch 65536
2019-01-29 20:04:31.859: Fetch 65536
2019-01-29 20:04:31.884: Fetch 65536
2019-01-29 20:04:31.898: Fetch 65536
2019-01-29 20:04:31.918: Fetch 65536
2019-01-29 20:04:31.933: Fetch 65536
2019-01-29 20:04:31.946: Fetch 65536
2019-01-29 20:04:31.959: Fetch 65536
2019-01-29 20:04:31.975: Fetch 65536
2019-01-29 20:04:31.994: Fetch 65536
2019-01-29 20:04:32.015: Fetch 65536
2019-01-29 20:04:32.038: Fetch 65536
2019-01-29 20:04:32.050: Fetch 65536
2019-01-29 20:04:32.065: Fetch 65536
2019-01-29 20:04:32.084: Fetch 65536
2019-01-29 20:04:42.974: Fetch 65536
2019-01-29 20:04:43.004: Fetch 65536
2019-01-29 20:04:43.017: Fetch 65536
2019-01-29 20:04:43.030: Fetch 65536
2019-01-29 20:04:43.040: Fetch 65536
2019-01-29 20:04:43.052: Fetch 65536
2019-01-29 20:04:43.065: Fetch 65536
2019-01-29 20:04:43.084: Fetch 65536
2019-01-29 20:04:43.103: Fetch 65536
2019-01-29 20:04:43.133: Fetch 65536
2019-01-29 20:04:43.148: Fetch 65536
2019-01-29 20:04:43.161: Fetch 65536
2019-01-29 20:04:43.179: Fetch 65536
2019-01-29 20:04:43.196: Fetch 65536
2019-01-29 20:04:43.216: Fetch 65536
2019-01-29 20:04:43.231: Fetch 65536
2019-01-29 20:04:43.244: Fetch 65536
2019-01-29 20:04:43.261: Fetch 65536
2019-01-29 20:04:43.282: Fetch 65536
2019-01-29 20:04:43.312: Fetch 65536
2019-01-29 20:04:43.346: Fetch 65536
2019-01-29 20:04:43.366: Fetch 65536
2019-01-29 20:04:43.382: Fetch 65536
2019-01-29 20:04:43.396: Fetch 65536
2019-01-29 20:04:43.409: Fetch 65536
2019-01-29 20:04:43.423: Fetch 65536
2019-01-29 20:04:43.445: Fetch 65536
2019-01-29 20:04:43.459: Fetch 65536
2019-01-29 20:04:43.472: Fetch 65536
2019-01-29 20:04:43.495: Fetch 65536
2019-01-29 20:04:43.512: Fetch 65536
2019-01-29 20:04:43.533: Fetch 65536
2019-01-29 20:04:43.545: Fetch 65536
2019-01-29 20:04:43.556: Fetch 65536
2019-01-29 20:04:43.567: Fetch 65536
2019-01-29 20:04:43.588: Fetch 65536
2019-01-29 20:04:43.607: Fetch 65536
2019-01-29 20:04:43.633: Fetch 65536
2019-01-29 20:04:43.646: Fetch 65536
2019-01-29 20:04:43.658: Fetch 65536
2019-01-29 20:04:43.674: Fetch 65536
2019-01-29 20:04:43.686: Fetch 65536
2019-01-29 20:04:43.699: Fetch 65536
2019-01-29 20:04:43.716: Fetch 65536
2019-01-29 20:04:43.734: Fetch 65536
2019-01-29 20:04:43.757: Fetch 65536
2019-01-29 20:04:43.776: Fetch 65536
2019-01-29 20:04:43.794: Fetch 65536
2019-01-29 20:04:43.805: Fetch 65536
2019-01-29 20:04:43.819: Fetch 65536
2019-01-29 20:04:43.834: Fetch 65536
2019-01-29 20:04:43.856: Fetch 65536
2019-01-29 20:04:43.868: Fetch 65536
2019-01-29 20:04:43.880: Fetch 65536
2019-01-29 20:04:43.898: Fetch 65536
2019-01-29 20:04:43.914: Fetch 65536
2019-01-29 20:04:43.934: Fetch 65536
2019-01-29 20:04:43.951: Fetch 65536
2019-01-29 20:04:43.968: Fetch 65536
2019-01-29 20:04:43.983: Fetch 65536
2019-01-29 20:04:43.996: Fetch 65536
2019-01-29 20:04:44.007: Fetch 65536
2019-01-29 20:04:44.025: Fetch 65536
2019-01-29 20:04:44.037: Fetch 65536
2019-01-29 20:04:44.053: Fetch 65536
2019-01-29 20:04:44.070: Fetch 65536
2019-01-29 20:04:44.082: Fetch 65536
2019-01-29 20:04:44.097: Fetch 65536
2019-01-29 20:04:54.877: Fetch 65536
2019-01-29 20:04:54.911: Fetch 65536
2019-01-29 20:04:54.923: Fetch 65536
2019-01-29 20:04:54.935: Fetch 65536
2019-01-29 20:04:54.949: Fetch 65536
2019-01-29 20:04:54.963: Fetch 65536
2019-01-29 20:04:54.991: Fetch 65536
2019-01-29 20:04:55.007: Fetch 65536
2019-01-29 20:04:55.035: Fetch 65536
2019-01-29 20:04:55.047: Fetch 65536
2019-01-29 20:04:55.058: Fetch 65536
2019-01-29 20:04:55.080: Fetch 65536
2019-01-29 20:04:55.100: Fetch 65536
2019-01-29 20:04:55.114: Fetch 65536
2019-01-29 20:04:55.129: Fetch 65536
2019-01-29 20:04:55.147: Fetch 65536
2019-01-29 20:04:55.165: Fetch 65536
2019-01-29 20:04:55.182: Fetch 65536
2019-01-29 20:04:55.210: Fetch 65536
2019-01-29 20:04:55.228: Fetch 65536
2019-01-29 20:04:55.243: Fetch 65536
2019-01-29 20:04:55.259: Fetch 65536
2019-01-29 20:04:55.276: Fetch 65536
2019-01-29 20:04:55.288: Fetch 65536
2019-01-29 20:04:55.302: Fetch 65536
2019-01-29 20:04:55.319: Fetch 65536
2019-01-29 20:04:55.335: Fetch 65536
2019-01-29 20:04:55.360: Fetch 65536
2019-01-29 20:04:55.380: Fetch 65536
2019-01-29 20:04:55.400: Fetch 65536
2019-01-29 20:04:55.413: Fetch 65536
2019-01-29 20:04:55.426: Fetch 65536
2019-01-29 20:04:55.440: Fetch 65536
2019-01-29 20:04:55.454: Fetch 65536
2019-01-29 20:04:55.467: Fetch 65536
2019-01-29 20:04:55.480: Fetch 65536
2019-01-29 20:04:55.500: Fetch 65536
2019-01-29 20:04:55.520: Fetch 65536
2019-01-29 20:04:55.539: Fetch 65536
2019-01-29 20:04:55.558: Fetch 65536
2019-01-29 20:04:55.575: Fetch 65536
2019-01-29 20:04:55.588: Fetch 65536
2019-01-29 20:04:55.602: Fetch 65536
2019-01-29 20:04:55.615: Fetch 65536
2019-01-29 20:04:55.626: Fetch 65536
2019-01-29 20:04:55.645: Fetch 65536
2019-01-29 20:04:55.662: Fetch 65536
2019-01-29 20:04:55.679: Fetch 65536
2019-01-29 20:04:55.698: Fetch 65536
2019-01-29 20:04:55.722: Fetch 65536
2019-01-29 20:04:55.737: Fetch 65536
2019-01-29 20:04:55.751: Fetch 65536
2019-01-29 20:04:55.764: Fetch 65536
2019-01-29 20:04:55.778: Fetch 65536
2019-01-29 20:04:55.796: Fetch 65536
2019-01-29 20:04:55.812: Fetch 65536
2019-01-29 20:04:55.831: Fetch 65536
2019-01-29 20:04:55.852: Fetch 65536
2019-01-29 20:04:55.865: Fetch 65536
2019-01-29 20:04:55.880: Fetch 65536
2019-01-29 20:05:08.247: Fetch 65536
2019-01-29 20:05:08.294: Fetch 65536
2019-01-29 20:05:08.308: Fetch 65536
2019-01-29 20:05:08.321: Fetch 65536
2019-01-29 20:05:08.335: Fetch 65536
2019-01-29 20:05:08.353: Fetch 65536
2019-01-29 20:05:08.376: Fetch 65536
2019-01-29 20:05:08.394: Fetch 65536
2019-01-29 20:05:08.408: Fetch 65536
2019-01-29 20:05:08.422: Fetch 65536
2019-01-29 20:05:08.442: Fetch 65536
2019-01-29 20:05:08.456: Fetch 65536
2019-01-29 20:05:08.468: Fetch 65536
2019-01-29 20:05:08.488: Fetch 65536
2019-01-29 20:05:08.501: Fetch 65536
2019-01-29 20:05:08.513: Fetch 65536
2019-01-29 20:05:08.528: Fetch 65536
2019-01-29 20:05:08.542: Fetch 65536
2019-01-29 20:05:08.564: Fetch 65536
2019-01-29 20:05:08.579: Fetch 65536
2019-01-29 20:05:08.596: Fetch 65536
2019-01-29 20:05:08.613: Fetch 65536
2019-01-29 20:05:08.625: Fetch 65536
2019-01-29 20:05:08.640: Fetch 65536
2019-01-29 20:05:08.657: Fetch 65536
2019-01-29 20:05:08.675: Fetch 65536
2019-01-29 20:05:08.689: Fetch 65536
2019-01-29 20:05:08.704: Fetch 65536
2019-01-29 20:05:08.723: Fetch 65536
2019-01-29 20:05:08.736: Fetch 65536
2019-01-29 20:05:08.751: Fetch 65536
2019-01-29 20:05:08.764: Fetch 65536
2019-01-29 20:05:08.778: Fetch 65536
2019-01-29 20:05:08.791: Fetch 65536
2019-01-29 20:05:08.808: Fetch 65536
2019-01-29 20:05:08.829: Fetch 65536
2019-01-29 20:05:08.844: Fetch 65536
2019-01-29 20:05:08.857: Fetch 65536
2019-01-29 20:05:08.874: Fetch 65536
2019-01-29 20:05:08.892: Fetch 65536
2019-01-29 20:05:08.908: Fetch 65536
2019-01-29 20:05:08.923: Fetch 65536
2019-01-29 20:05:08.938: Fetch 65536
2019-01-29 20:05:08.950: Fetch 65536
2019-01-29 20:05:08.966: Fetch 65536
2019-01-29 20:05:08.979: Fetch 65536
2019-01-29 20:05:08.999: Fetch 65536
2019-01-29 20:05:09.015: Fetch 65536
2019-01-29 20:05:09.031: Fetch 65536
2019-01-29 20:05:09.047: Fetch 65536
2019-01-29 20:05:09.062: Fetch 65536
2019-01-29 20:05:09.080: Fetch 65536
2019-01-29 20:05:09.096: Fetch 65536
2019-01-29 20:05:09.113: Fetch 65536
2019-01-29 20:05:09.130: Fetch 65536
2019-01-29 20:05:09.144: Fetch 65536
2019-01-29 20:05:09.162: Fetch 65536
2019-01-29 20:05:09.178: Fetch 65536
2019-01-29 20:05:09.195: Fetch 65536
2019-01-29 20:05:09.215: Fetch 65536
2019-01-29 20:05:09.229: Fetch 65536
2019-01-29 20:05:09.244: Fetch 65536
2019-01-29 20:05:18.646: Fetch 65536
2019-01-29 20:05:18.660: Fetch 65536
2019-01-29 20:05:18.673: Fetch 65536
2019-01-29 20:05:18.684: Fetch 65536
2019-01-29 20:05:18.697: Fetch 65536
2019-01-29 20:05:18.712: Fetch 65536
2019-01-29 20:05:18.733: Fetch 65536
2019-01-29 20:05:18.752: Fetch 65536
2019-01-29 20:05:18.768: Fetch 65536
2019-01-29 20:05:18.784: Fetch 65536
2019-01-29 20:05:18.798: Fetch 65536
2019-01-29 20:05:18.811: Fetch 65536
2019-01-29 20:05:18.822: Fetch 65536
2019-01-29 20:05:18.834: Fetch 65536
2019-01-29 20:05:18.846: Fetch 65536
2019-01-29 20:05:18.863: Fetch 65536
2019-01-29 20:05:18.881: Fetch 65536
2019-01-29 20:05:18.898: Fetch 65536
2019-01-29 20:05:18.915: Fetch 65536
2019-01-29 20:05:18.930: Fetch 65536
2019-01-29 20:05:18.943: Fetch 65536
2019-01-29 20:05:18.958: Fetch 65536
2019-01-29 20:05:18.975: Fetch 65536
2019-01-29 20:05:18.994: Fetch 65536
2019-01-29 20:05:19.018: Fetch 65536
2019-01-29 20:05:19.034: Fetch 65536
2019-01-29 20:05:19.047: Fetch 65536
2019-01-29 20:05:19.063: Fetch 65536
2019-01-29 20:05:19.079: Fetch 65536
2019-01-29 20:05:19.093: Fetch 65536
2019-01-29 20:05:19.105: Fetch 65536
2019-01-29 20:05:19.117: Fetch 65536
2019-01-29 20:05:19.128: Fetch 65536
2019-01-29 20:05:19.144: Fetch 65536
2019-01-29 20:05:19.165: Fetch 65536
2019-01-29 20:05:19.180: Fetch 65536
2019-01-29 20:05:19.193: Fetch 65536
2019-01-29 20:05:19.209: Fetch 65536
2019-01-29 20:05:19.221: Fetch 65536
2019-01-29 20:05:19.233: Fetch 65536
2019-01-29 20:05:19.247: Fetch 65536
2019-01-29 20:05:19.260: Fetch 65536
2019-01-29 20:05:19.274: Fetch 65536
2019-01-29 20:05:19.294: Fetch 65536
2019-01-29 20:05:19.311: Fetch 65536
2019-01-29 20:05:19.326: Fetch 65536
2019-01-29 20:05:19.343: Fetch 65536
2019-01-29 20:05:19.358: Fetch 65536
2019-01-29 20:05:19.377: Fetch 65536
2019-01-29 20:05:19.395: Fetch 65536
2019-01-29 20:05:19.407: Fetch 65536
2019-01-29 20:05:19.422: Fetch 65536
2019-01-29 20:05:19.440: Fetch 65536
2019-01-29 20:05:19.460: Fetch 65536
2019-01-29 20:05:19.480: Fetch 65536
2019-01-29 20:05:19.500: Fetch 65536
2019-01-29 20:05:19.515: Fetch 65536
2019-01-29 20:05:19.535: Fetch 65536
2019-01-29 20:05:19.549: Fetch 65536
2019-01-29 20:05:19.563: Fetch 65536
2019-01-29 20:05:19.581: Fetch 65536
2019-01-29 20:05:30.538: Fetch 65536
2019-01-29 20:05:30.575: Fetch 65536
2019-01-29 20:05:30.589: Fetch 65536
2019-01-29 20:05:30.607: Fetch 65536
2019-01-29 20:05:30.626: Fetch 65536
2019-01-29 20:05:30.638: Fetch 65536
2019-01-29 20:05:30.649: Fetch 65536
2019-01-29 20:05:30.663: Fetch 65536
2019-01-29 20:05:30.678: Fetch 65536
2019-01-29 20:05:30.693: Fetch 65536
2019-01-29 20:05:30.707: Fetch 65536
2019-01-29 20:05:30.725: Fetch 65536
2019-01-29 20:05:30.740: Fetch 65536
2019-01-29 20:05:30.767: Fetch 65536
2019-01-29 20:05:30.787: Fetch 65536
2019-01-29 20:05:30.807: Fetch 65536
2019-01-29 20:05:30.833: Fetch 65536
2019-01-29 20:05:30.852: Fetch 65536
2019-01-29 20:05:30.864: Fetch 65536
2019-01-29 20:05:30.878: Fetch 65536
2019-01-29 20:05:30.896: Fetch 65536
2019-01-29 20:05:30.914: Fetch 65536
2019-01-29 20:05:30.928: Fetch 65536
2019-01-29 20:05:30.951: Fetch 65536
2019-01-29 20:05:30.965: Fetch 65536
2019-01-29 20:05:30.978: Fetch 65536
2019-01-29 20:05:30.991: Fetch 65536
2019-01-29 20:05:31.003: Fetch 65536
2019-01-29 20:05:31.014: Fetch 65536
2019-01-29 20:05:31.032: Fetch 65536
2019-01-29 20:05:31.048: Fetch 65536
2019-01-29 20:05:31.065: Fetch 65536
2019-01-29 20:05:31.091: Fetch 65536
2019-01-29 20:05:31.107: Fetch 65536
2019-01-29 20:05:31.124: Fetch 65536
2019-01-29 20:05:31.148: Fetch 65536
2019-01-29 20:05:31.171: Fetch 65536
2019-01-29 20:05:31.183: Fetch 65536
2019-01-29 20:05:31.200: Fetch 65536
2019-01-29 20:05:31.226: Fetch 65536
2019-01-29 20:05:31.246: Fetch 65536
2019-01-29 20:05:31.261: Fetch 65536
2019-01-29 20:05:31.276: Fetch 65536
2019-01-29 20:05:31.290: Fetch 65536
2019-01-29 20:05:31.302: Fetch 65536
2019-01-29 20:05:31.316: Fetch 65536
2019-01-29 20:05:31.337: Fetch 65536
2019-01-29 20:05:31.370: Fetch 65536
2019-01-29 20:05:31.393: Fetch 65536
2019-01-29 20:05:31.406: Fetch 65536
2019-01-29 20:05:31.420: Fetch 65536
2019-01-29 20:05:31.433: Fetch 65536
2019-01-29 20:05:31.447: Fetch 65536
2019-01-29 20:05:31.464: Fetch 65536
2019-01-29 20:05:31.481: Fetch 65536
2019-01-29 20:05:31.498: Fetch 65536
2019-01-29 20:05:31.517: Fetch 65536
2019-01-29 20:05:31.539: Fetch 65536
2019-01-29 20:05:31.552: Fetch 65536
2019-01-29 20:05:31.564: Fetch 65536
2019-01-29 20:05:42.417: Fetch 65536
2019-01-29 20:05:42.431: Fetch 65536
2019-01-29 20:05:42.445: Fetch 65536
2019-01-29 20:05:42.458: Fetch 65536
2019-01-29 20:05:42.474: Fetch 65536
2019-01-29 20:05:42.489: Fetch 65536
2019-01-29 20:05:42.512: Fetch 65536
2019-01-29 20:05:42.540: Fetch 65536
2019-01-29 20:05:42.557: Fetch 65536
2019-01-29 20:05:42.574: Fetch 65536
2019-01-29 20:05:42.588: Fetch 65536
2019-01-29 20:05:42.603: Fetch 65536
2019-01-29 20:05:42.616: Fetch 65536
2019-01-29 20:05:42.629: Fetch 65536
2019-01-29 20:05:42.642: Fetch 65536
2019-01-29 20:05:42.656: Fetch 65536
2019-01-29 20:05:42.679: Fetch 65536
2019-01-29 20:05:42.696: Fetch 65536
2019-01-29 20:05:42.715: Fetch 65536
2019-01-29 20:05:42.727: Fetch 65536
2019-01-29 20:05:42.739: Fetch 65536
2019-01-29 20:05:42.752: Fetch 65536
2019-01-29 20:05:42.766: Fetch 65536
2019-01-29 20:05:42.781: Fetch 65536
2019-01-29 20:05:42.798: Fetch 65536
2019-01-29 20:05:42.818: Fetch 65536
2019-01-29 20:05:42.832: Fetch 65536
2019-01-29 20:05:42.846: Fetch 65536
2019-01-29 20:05:42.861: Fetch 65536
2019-01-29 20:05:42.875: Fetch 65536
2019-01-29 20:05:42.886: Fetch 65536
2019-01-29 20:05:42.902: Fetch 65536
2019-01-29 20:05:42.916: Fetch 65536
2019-01-29 20:05:42.934: Fetch 65536
2019-01-29 20:05:42.961: Fetch 65536
2019-01-29 20:05:42.981: Fetch 65536
2019-01-29 20:05:42.994: Fetch 65536
2019-01-29 20:05:43.007: Fetch 65536
2019-01-29 20:05:43.021: Fetch 65536
2019-01-29 20:05:43.033: Fetch 65536
2019-01-29 20:05:43.046: Fetch 65536
2019-01-29 20:05:43.061: Fetch 65536
2019-01-29 20:05:43.081: Fetch 65536
2019-01-29 20:05:43.101: Fetch 65536
2019-01-29 20:05:43.134: Fetch 65536
2019-01-29 20:05:43.152: Fetch 65536
2019-01-29 20:05:43.164: Fetch 65536
2019-01-29 20:05:43.188: Fetch 65536
2019-01-29 20:05:43.202: Fetch 65536
2019-01-29 20:05:43.220: Fetch 65536
2019-01-29 20:05:43.239: Fetch 65536
2019-01-29 20:05:43.260: Fetch 65536
2019-01-29 20:05:43.277: Fetch 65536
2019-01-29 20:05:43.302: Fetch 65536
2019-01-29 20:05:43.324: Fetch 65536
2019-01-29 20:05:43.347: Fetch 65536
2019-01-29 20:05:43.360: Fetch 65536
2019-01-29 20:05:43.376: Fetch 65536
2019-01-29 20:05:43.394: Fetch 65536
2019-01-29 20:05:43.410: Fetch 65536
2019-01-29 20:05:43.426: Fetch 65536
2019-01-29 20:05:54.318: Fetch 65536
2019-01-29 20:05:54.356: Fetch 65536
2019-01-29 20:05:54.367: Fetch 65536
2019-01-29 20:05:54.381: Fetch 65536
2019-01-29 20:05:54.396: Fetch 65536
2019-01-29 20:05:54.410: Fetch 65536
2019-01-29 20:05:54.422: Fetch 65536
2019-01-29 20:05:54.442: Fetch 65536
2019-01-29 20:05:54.462: Fetch 65536
2019-01-29 20:05:54.481: Fetch 65536
2019-01-29 20:05:54.496: Fetch 65536
2019-01-29 20:05:54.513: Fetch 65536
2019-01-29 20:05:54.526: Fetch 65536
2019-01-29 20:05:54.542: Fetch 65536
2019-01-29 20:05:54.556: Fetch 65536
2019-01-29 20:05:54.571: Fetch 65536
2019-01-29 20:05:54.588: Fetch 65536
2019-01-29 20:05:54.602: Fetch 65536
2019-01-29 20:05:54.616: Fetch 65536
2019-01-29 20:05:54.629: Fetch 65536
2019-01-29 20:05:54.643: Fetch 65536
2019-01-29 20:05:54.661: Fetch 65536
2019-01-29 20:05:54.676: Fetch 65536
2019-01-29 20:05:54.692: Fetch 65536
2019-01-29 20:05:54.706: Fetch 65536
2019-01-29 20:05:54.720: Fetch 65536
2019-01-29 20:05:54.732: Fetch 65536
2019-01-29 20:05:54.743: Fetch 65536
2019-01-29 20:05:54.755: Fetch 65536
2019-01-29 20:05:54.771: Fetch 65536
2019-01-29 20:05:54.788: Fetch 65536
2019-01-29 20:05:54.808: Fetch 65536
2019-01-29 20:05:54.836: Fetch 65536
2019-01-29 20:05:54.852: Fetch 65536
2019-01-29 20:05:54.864: Fetch 65536
2019-01-29 20:05:54.883: Fetch 65536
2019-01-29 20:05:54.896: Fetch 65536
2019-01-29 20:05:54.910: Fetch 65536
2019-01-29 20:05:54.925: Fetch 65536
2019-01-29 20:05:54.940: Fetch 65536
2019-01-29 20:05:54.958: Fetch 65536
2019-01-29 20:05:54.977: Fetch 65536
2019-01-29 20:05:54.992: Fetch 65536
2019-01-29 20:05:55.008: Fetch 65536
2019-01-29 20:05:55.027: Fetch 65536
2019-01-29 20:05:55.048: Fetch 65536
2019-01-29 20:05:55.069: Fetch 65536
2019-01-29 20:05:55.083: Fetch 65536
2019-01-29 20:05:55.096: Fetch 65536
2019-01-29 20:05:55.110: Fetch 65536
2019-01-29 20:05:55.126: Fetch 65536
2019-01-29 20:05:55.139: Fetch 65536
2019-01-29 20:05:55.156: Fetch 65536
2019-01-29 20:05:55.173: Fetch 65536
2019-01-29 20:05:55.189: Fetch 65536
2019-01-29 20:05:55.203: Fetch 65536
2019-01-29 20:05:55.221: Fetch 65536
2019-01-29 20:05:55.236: Fetch 65536
2019-01-29 20:05:55.249: Fetch 65536
2019-01-29 20:05:55.263: Fetch 65536
2019-01-29 20:05:55.277: Fetch 65536
2019-01-29 20:06:06.198: Fetch 65536
2019-01-29 20:06:06.236: Fetch 65536
2019-01-29 20:06:06.254: Fetch 65536
2019-01-29 20:06:06.266: Fetch 65536
2019-01-29 20:06:06.278: Fetch 65536
2019-01-29 20:06:06.293: Fetch 65536
2019-01-29 20:06:06.315: Fetch 65536
2019-01-29 20:06:06.332: Fetch 65536
2019-01-29 20:06:06.348: Fetch 65536
2019-01-29 20:06:06.365: Fetch 65536
2019-01-29 20:06:06.377: Fetch 65536
2019-01-29 20:06:06.394: Fetch 65536
2019-01-29 20:06:06.409: Fetch 65536
2019-01-29 20:06:06.422: Fetch 65536
2019-01-29 20:06:06.436: Fetch 65536
2019-01-29 20:06:06.453: Fetch 65536
2019-01-29 20:06:06.472: Fetch 65536
2019-01-29 20:06:06.493: Fetch 65536
2019-01-29 20:06:06.511: Fetch 65536
2019-01-29 20:06:06.531: Fetch 65536
2019-01-29 20:06:06.544: Fetch 65536
2019-01-29 20:06:06.555: Fetch 65536
2019-01-29 20:06:06.567: Fetch 65536
2019-01-29 20:06:06.585: Fetch 65536
2019-01-29 20:06:06.600: Fetch 65536
2019-01-29 20:06:06.621: Fetch 65536
2019-01-29 20:06:06.642: Fetch 65536
2019-01-29 20:06:06.658: Fetch 65536
2019-01-29 20:06:06.670: Fetch 65536
2019-01-29 20:06:06.683: Fetch 65536
2019-01-29 20:06:06.704: Fetch 65536
2019-01-29 20:06:06.719: Fetch 65536
2019-01-29 20:06:06.731: Fetch 65536
2019-01-29 20:06:06.744: Fetch 65536
2019-01-29 20:06:06.756: Fetch 65536
2019-01-29 20:06:06.769: Fetch 65536
2019-01-29 20:06:06.782: Fetch 65536
2019-01-29 20:06:06.805: Fetch 65536
2019-01-29 20:06:06.823: Fetch 65536
2019-01-29 20:06:06.844: Fetch 65536
2019-01-29 20:06:06.858: Fetch 65536
2019-01-29 20:06:06.869: Fetch 65536
2019-01-29 20:06:06.881: Fetch 65536
2019-01-29 20:06:06.898: Fetch 65536
2019-01-29 20:06:06.920: Fetch 65536
2019-01-29 20:06:06.937: Fetch 65536
2019-01-29 20:06:06.957: Fetch 65536
2019-01-29 20:06:06.978: Fetch 65536
2019-01-29 20:06:06.989: Fetch 65536
2019-01-29 20:06:07.003: Fetch 65536
2019-01-29 20:06:07.025: Fetch 65536
2019-01-29 20:06:07.040: Fetch 65536
2019-01-29 20:06:07.057: Fetch 65536
2019-01-29 20:06:07.074: Fetch 65536
2019-01-29 20:06:07.087: Fetch 65536
2019-01-29 20:06:07.100: Fetch 65536
2019-01-29 20:06:07.112: Fetch 65536
2019-01-29 20:06:07.127: Fetch 65536
2019-01-29 20:06:07.144: Fetch 65536
2019-01-29 20:06:07.177: Fetch 65536
2019-01-29 20:06:07.195: Fetch 65536
2019-01-29 20:06:07.209: Fetch 65536
2019-01-29 20:06:07.224: Fetch 65536
2019-01-29 20:06:07.239: Fetch 65536
2019-01-29 20:06:18.101: Fetch 65536
2019-01-29 20:06:18.136: Fetch 65536
2019-01-29 20:06:18.149: Fetch 65536
2019-01-29 20:06:18.162: Fetch 65536
2019-01-29 20:06:18.178: Fetch 65536
2019-01-29 20:06:18.194: Fetch 65536
2019-01-29 20:06:18.207: Fetch 65536
2019-01-29 20:06:18.224: Fetch 65536
2019-01-29 20:06:18.243: Fetch 65536
2019-01-29 20:06:18.257: Fetch 65536
2019-01-29 20:06:18.275: Fetch 65536
2019-01-29 20:06:18.299: Fetch 65536
2019-01-29 20:06:18.311: Fetch 65536
2019-01-29 20:06:18.325: Fetch 65536
2019-01-29 20:06:18.337: Fetch 65536
2019-01-29 20:06:18.347: Fetch 65536
2019-01-29 20:06:18.359: Fetch 65536
2019-01-29 20:06:18.379: Fetch 65536
2019-01-29 20:06:18.396: Fetch 65536
2019-01-29 20:06:18.416: Fetch 65536
2019-01-29 20:06:18.436: Fetch 65536
2019-01-29 20:06:18.453: Fetch 65536
2019-01-29 20:06:18.468: Fetch 65536
2019-01-29 20:06:18.483: Fetch 65536
2019-01-29 20:06:18.501: Fetch 65536
2019-01-29 20:06:18.521: Fetch 65536
2019-01-29 20:06:18.543: Fetch 65536
2019-01-29 20:06:18.559: Fetch 65536
2019-01-29 20:06:18.572: Fetch 65536
2019-01-29 20:06:18.586: Fetch 65536
2019-01-29 20:06:18.606: Fetch 65536
2019-01-29 20:06:18.621: Fetch 65536
2019-01-29 20:06:18.638: Fetch 65536
2019-01-29 20:06:18.652: Fetch 65536
2019-01-29 20:06:18.667: Fetch 65536
2019-01-29 20:06:18.690: Fetch 65536
2019-01-29 20:06:18.706: Fetch 65536
2019-01-29 20:06:18.721: Fetch 65536
2019-01-29 20:06:18.741: Fetch 65536
2019-01-29 20:06:18.755: Fetch 65536
2019-01-29 20:06:18.772: Fetch 65536
2019-01-29 20:06:18.786: Fetch 65536
2019-01-29 20:06:18.799: Fetch 65536
2019-01-29 20:06:18.814: Fetch 65536
2019-01-29 20:06:18.831: Fetch 65536
2019-01-29 20:06:18.851: Fetch 65536
2019-01-29 20:06:18.874: Fetch 65536
2019-01-29 20:06:18.903: Fetch 65536
2019-01-29 20:06:18.916: Fetch 65536
2019-01-29 20:06:18.930: Fetch 65536
2019-01-29 20:06:18.956: Fetch 65536
2019-01-29 20:06:18.976: Fetch 65536
2019-01-29 20:06:18.990: Fetch 65536
2019-01-29 20:06:19.008: Fetch 65536
2019-01-29 20:06:19.028: Fetch 65536
2019-01-29 20:06:19.044: Fetch 65536
2019-01-29 20:06:31.463: Fetch 65536
2019-01-29 20:06:31.517: Fetch 65536
2019-01-29 20:06:31.546: Fetch 65536
2019-01-29 20:06:31.566: Fetch 65536
2019-01-29 20:06:31.591: Fetch 65536
2019-01-29 20:06:31.602: Fetch 65536
2019-01-29 20:06:31.621: Fetch 65536
2019-01-29 20:06:31.638: Fetch 65536
2019-01-29 20:06:31.661: Fetch 65536
2019-01-29 20:06:31.679: Fetch 65536
2019-01-29 20:06:31.694: Fetch 65536
2019-01-29 20:06:31.706: Fetch 65536
2019-01-29 20:06:31.720: Fetch 65536
2019-01-29 20:06:31.733: Fetch 65536
2019-01-29 20:06:31.744: Fetch 65536
2019-01-29 20:06:31.757: Fetch 65536
2019-01-29 20:06:31.781: Fetch 65536
2019-01-29 20:06:31.800: Fetch 65536
2019-01-29 20:06:31.819: Fetch 65536
2019-01-29 20:06:31.838: Fetch 65536
2019-01-29 20:06:31.856: Fetch 65536
2019-01-29 20:06:31.870: Fetch 65536
2019-01-29 20:06:31.882: Fetch 65536
2019-01-29 20:06:31.896: Fetch 65536
2019-01-29 20:06:31.910: Fetch 65536
2019-01-29 20:06:31.924: Fetch 65536
2019-01-29 20:06:31.944: Fetch 65536
2019-01-29 20:06:31.959: Fetch 65536
2019-01-29 20:06:31.975: Fetch 65536
2019-01-29 20:06:31.991: Fetch 65536
2019-01-29 20:06:32.008: Fetch 65536
2019-01-29 20:06:32.022: Fetch 65536
2019-01-29 20:06:32.035: Fetch 65536
2019-01-29 20:06:32.045: Fetch 65536
2019-01-29 20:06:32.060: Fetch 65536
2019-01-29 20:06:32.076: Fetch 65536
2019-01-29 20:06:32.099: Fetch 65536
2019-01-29 20:06:32.116: Fetch 65536
2019-01-29 20:06:32.137: Fetch 65536
2019-01-29 20:06:32.154: Fetch 65536
2019-01-29 20:06:32.175: Fetch 65536
2019-01-29 20:06:32.197: Fetch 65536
2019-01-29 20:06:32.211: Fetch 65536
2019-01-29 20:06:32.226: Fetch 65536
2019-01-29 20:06:32.239: Fetch 65536
2019-01-29 20:06:32.254: Fetch 65536
2019-01-29 20:06:32.274: Fetch 65536
2019-01-29 20:06:32.290: Fetch 65536
2019-01-29 20:06:32.305: Fetch 65536
2019-01-29 20:06:32.320: Fetch 65536
2019-01-29 20:06:32.337: Fetch 65536
2019-01-29 20:06:32.357: Fetch 65536
2019-01-29 20:06:32.375: Fetch 65536
2019-01-29 20:06:32.392: Fetch 65536
2019-01-29 20:06:32.405: Fetch 65536
2019-01-29 20:06:32.429: Fetch 65536
2019-01-29 20:06:32.453: Fetch 65536
2019-01-29 20:06:32.467: Fetch 65536
2019-01-29 20:06:32.480: Fetch 65536
2019-01-29 20:06:32.494: Fetch 65536
2019-01-29 20:06:41.876: Fetch 65536
2019-01-29 20:06:41.917: Fetch 65536
2019-01-29 20:06:41.937: Fetch 65536
2019-01-29 20:06:41.948: Fetch 65536
2019-01-29 20:06:41.960: Fetch 65536
2019-01-29 20:06:41.973: Fetch 65536
2019-01-29 20:06:41.995: Fetch 65536
2019-01-29 20:06:42.012: Fetch 65536
2019-01-29 20:06:42.032: Fetch 65536
2019-01-29 20:06:42.047: Fetch 65536
2019-01-29 20:06:42.060: Fetch 65536
2019-01-29 20:06:42.075: Fetch 65536
2019-01-29 20:06:42.094: Fetch 65536
2019-01-29 20:06:42.112: Fetch 65536
2019-01-29 20:06:42.137: Fetch 65536
2019-01-29 20:06:42.157: Fetch 65536
2019-01-29 20:06:42.170: Fetch 65536
2019-01-29 20:06:42.183: Fetch 65536
2019-01-29 20:06:42.198: Fetch 65536
2019-01-29 20:06:42.213: Fetch 65536
2019-01-29 20:06:42.228: Fetch 65536
2019-01-29 20:06:42.246: Fetch 65536
2019-01-29 20:06:42.262: Fetch 65536
2019-01-29 20:06:42.284: Fetch 65536
2019-01-29 20:06:42.303: Fetch 65536
2019-01-29 20:06:42.318: Fetch 65536
2019-01-29 20:06:42.334: Fetch 65536
2019-01-29 20:06:42.351: Fetch 65536
2019-01-29 20:06:42.365: Fetch 65536
2019-01-29 20:06:42.381: Fetch 65536
2019-01-29 20:06:42.398: Fetch 65536
2019-01-29 20:06:42.422: Fetch 65536
2019-01-29 20:06:42.438: Fetch 65536
2019-01-29 20:06:42.450: Fetch 65536
2019-01-29 20:06:42.467: Fetch 65536
2019-01-29 20:06:42.480: Fetch 65536
2019-01-29 20:06:42.497: Fetch 65536
2019-01-29 20:06:42.515: Fetch 65536
2019-01-29 20:06:42.529: Fetch 65536
2019-01-29 20:06:42.548: Fetch 65536
2019-01-29 20:06:42.567: Fetch 65536
2019-01-29 20:06:42.591: Fetch 65536
2019-01-29 20:06:42.605: Fetch 65536
2019-01-29 20:06:42.621: Fetch 65536
2019-01-29 20:06:42.636: Fetch 65536
2019-01-29 20:06:42.647: Fetch 65536
2019-01-29 20:06:42.659: Fetch 65536
2019-01-29 20:06:42.673: Fetch 65536
2019-01-29 20:06:42.685: Fetch 65536
2019-01-29 20:06:42.698: Fetch 65536
2019-01-29 20:06:42.720: Fetch 65536
2019-01-29 20:06:42.744: Fetch 65536
2019-01-29 20:06:42.757: Fetch 65536
2019-01-29 20:06:42.769: Fetch 65536
2019-01-29 20:06:42.783: Fetch 65536
2019-01-29 20:06:42.799: Fetch 65536
2019-01-29 20:06:42.821: Fetch 65536
2019-01-29 20:06:42.837: Fetch 65536
2019-01-29 20:06:53.742: Fetch 65536
2019-01-29 20:06:53.756: Fetch 65536
2019-01-29 20:06:53.769: Fetch 65536
2019-01-29 20:06:53.782: Fetch 65536
2019-01-29 20:06:53.796: Fetch 65536
2019-01-29 20:06:53.811: Fetch 65536
2019-01-29 20:06:53.826: Fetch 65536
2019-01-29 20:06:53.844: Fetch 65536
2019-01-29 20:06:53.863: Fetch 65536
2019-01-29 20:06:53.887: Fetch 65536
2019-01-29 20:06:53.911: Fetch 65536
2019-01-29 20:06:53.926: Fetch 65536
2019-01-29 20:06:53.944: Fetch 65536
2019-01-29 20:06:53.965: Fetch 65536
2019-01-29 20:06:53.980: Fetch 65536
2019-01-29 20:06:53.994: Fetch 65536
2019-01-29 20:06:54.008: Fetch 65536
2019-01-29 20:06:54.020: Fetch 65536
2019-01-29 20:06:54.033: Fetch 65536
2019-01-29 20:06:54.047: Fetch 65536
2019-01-29 20:06:54.060: Fetch 65536
2019-01-29 20:06:54.078: Fetch 65536
2019-01-29 20:06:54.096: Fetch 65536
2019-01-29 20:06:54.113: Fetch 65536
2019-01-29 20:06:54.129: Fetch 65536
2019-01-29 20:06:54.141: Fetch 65536
2019-01-29 20:06:54.157: Fetch 65536
2019-01-29 20:06:54.174: Fetch 65536
2019-01-29 20:06:54.188: Fetch 65536
2019-01-29 20:06:54.201: Fetch 65536
2019-01-29 20:06:54.212: Fetch 65536
2019-01-29 20:06:54.229: Fetch 65536
2019-01-29 20:06:54.250: Fetch 65536
2019-01-29 20:06:54.268: Fetch 65536
2019-01-29 20:06:54.288: Fetch 65536
2019-01-29 20:06:54.304: Fetch 65536
2019-01-29 20:06:54.319: Fetch 65536
2019-01-29 20:06:54.335: Fetch 65536
2019-01-29 20:06:54.350: Fetch 65536
2019-01-29 20:06:54.366: Fetch 65536
2019-01-29 20:06:54.383: Fetch 65536
2019-01-29 20:06:54.398: Fetch 65536
2019-01-29 20:06:54.410: Fetch 65536
2019-01-29 20:06:54.426: Fetch 65536
2019-01-29 20:06:54.441: Fetch 65536
2019-01-29 20:06:54.460: Fetch 65536
2019-01-29 20:06:54.478: Fetch 65536
2019-01-29 20:06:54.494: Fetch 65536
2019-01-29 20:06:54.508: Fetch 65536
2019-01-29 20:06:54.521: Fetch 65536
2019-01-29 20:06:54.540: Fetch 65536
2019-01-29 20:06:54.564: Fetch 65536
2019-01-29 20:06:54.583: Fetch 65536
2019-01-29 20:06:54.599: Fetch 65536
2019-01-29 20:06:54.619: Fetch 65536
2019-01-29 20:06:54.637: Fetch 65536
2019-01-29 20:06:54.657: Fetch 65536
2019-01-29 20:07:05.633: Fetch 65536
2019-01-29 20:07:05.648: Fetch 65536
2019-01-29 20:07:05.665: Fetch 65536
2019-01-29 20:07:05.682: Fetch 65536
2019-01-29 20:07:05.705: Fetch 65536
2019-01-29 20:07:05.736: Fetch 65536
2019-01-29 20:07:05.752: Fetch 65536
2019-01-29 20:07:05.767: Fetch 65536
2019-01-29 20:07:05.782: Fetch 65536
2019-01-29 20:07:05.799: Fetch 65536
2019-01-29 20:07:05.816: Fetch 65536
2019-01-29 20:07:05.829: Fetch 65536
2019-01-29 20:07:05.848: Fetch 65536
2019-01-29 20:07:05.865: Fetch 65536
2019-01-29 20:07:05.885: Fetch 65536
2019-01-29 20:07:05.899: Fetch 65536
2019-01-29 20:07:05.914: Fetch 65536
2019-01-29 20:07:05.926: Fetch 65536
2019-01-29 20:07:05.944: Fetch 65536
2019-01-29 20:07:05.960: Fetch 65536
2019-01-29 20:07:05.974: Fetch 65536
2019-01-29 20:07:05.992: Fetch 65536
2019-01-29 20:07:06.008: Fetch 65536
2019-01-29 20:07:06.024: Fetch 65536
2019-01-29 20:07:06.040: Fetch 65536
2019-01-29 20:07:06.056: Fetch 65536
2019-01-29 20:07:06.080: Fetch 65536
2019-01-29 20:07:06.107: Fetch 65536
2019-01-29 20:07:06.127: Fetch 65536
2019-01-29 20:07:06.147: Fetch 65536
2019-01-29 20:07:06.170: Fetch 65536
2019-01-29 20:07:06.191: Fetch 65536
2019-01-29 20:07:06.207: Fetch 65536
2019-01-29 20:07:06.225: Fetch 65536
2019-01-29 20:07:06.243: Fetch 65536
2019-01-29 20:07:06.259: Fetch 65536
2019-01-29 20:07:06.274: Fetch 65536
2019-01-29 20:07:06.287: Fetch 65536
2019-01-29 20:07:06.303: Fetch 65536
2019-01-29 20:07:06.324: Fetch 65536
2019-01-29 20:07:06.342: Fetch 65536
2019-01-29 20:07:06.362: Fetch 65536
2019-01-29 20:07:06.376: Fetch 65536
2019-01-29 20:07:06.392: Fetch 65536
2019-01-29 20:07:06.406: Fetch 65536
2019-01-29 20:07:06.417: Fetch 65536
2019-01-29 20:07:06.437: Fetch 65536
2019-01-29 20:07:06.452: Fetch 65536
2019-01-29 20:07:06.473: Fetch 65536
2019-01-29 20:07:06.494: Fetch 65536
2019-01-29 20:07:06.510: Fetch 65536
2019-01-29 20:07:06.527: Fetch 65536
2019-01-29 20:07:06.545: Fetch 65536
2019-01-29 20:07:06.563: Fetch 65536
2019-01-29 20:07:06.577: Fetch 65536
2019-01-29 20:07:06.592: Fetch 65536
2019-01-29 20:07:06.610: Fetch 65536
2019-01-29 20:07:06.631: Fetch 65536
2019-01-29 20:07:06.653: Fetch 65536
2019-01-29 20:07:06.667: Fetch 65536
2019-01-29 20:07:17.536: Fetch 65536
2019-01-29 20:07:17.561: Fetch 65536
2019-01-29 20:07:17.573: Fetch 65536
2019-01-29 20:07:17.584: Fetch 65536
2019-01-29 20:07:17.598: Fetch 65536
2019-01-29 20:07:17.615: Fetch 65536
2019-01-29 20:07:17.629: Fetch 65536
2019-01-29 20:07:17.644: Fetch 65536
2019-01-29 20:07:17.665: Fetch 65536
2019-01-29 20:07:17.683: Fetch 65536
2019-01-29 20:07:17.702: Fetch 65536
2019-01-29 20:07:17.718: Fetch 65536
2019-01-29 20:07:17.734: Fetch 65536
2019-01-29 20:07:17.750: Fetch 65536
2019-01-29 20:07:17.766: Fetch 65536
2019-01-29 20:07:17.778: Fetch 65536
2019-01-29 20:07:17.789: Fetch 65536
2019-01-29 20:07:17.800: Fetch 65536
2019-01-29 20:07:17.813: Fetch 65536
2019-01-29 20:07:17.831: Fetch 65536
2019-01-29 20:07:17.843: Fetch 65536
2019-01-29 20:07:17.858: Fetch 65536
2019-01-29 20:07:17.875: Fetch 65536
2019-01-29 20:07:17.888: Fetch 65536
2019-01-29 20:07:17.903: Fetch 65536
2019-01-29 20:07:17.917: Fetch 65536
2019-01-29 20:07:17.929: Fetch 65536
2019-01-29 20:07:17.942: Fetch 65536
2019-01-29 20:07:17.953: Fetch 65536
2019-01-29 20:07:17.964: Fetch 65536
2019-01-29 20:07:17.980: Fetch 65536
2019-01-29 20:07:17.998: Fetch 65536
2019-01-29 20:07:18.013: Fetch 65536
2019-01-29 20:07:18.036: Fetch 65536
2019-01-29 20:07:18.054: Fetch 65536
2019-01-29 20:07:18.072: Fetch 65536
2019-01-29 20:07:18.083: Fetch 65536
2019-01-29 20:07:18.103: Fetch 65536
2019-01-29 20:07:18.121: Fetch 65536
2019-01-29 20:07:18.138: Fetch 65536
2019-01-29 20:07:18.154: Fetch 65536
2019-01-29 20:07:18.170: Fetch 65536
2019-01-29 20:07:18.187: Fetch 65536
2019-01-29 20:07:18.200: Fetch 65536
2019-01-29 20:07:18.215: Fetch 65536
2019-01-29 20:07:18.233: Fetch 65536
2019-01-29 20:07:18.251: Fetch 65536
2019-01-29 20:07:18.268: Fetch 65536
2019-01-29 20:07:18.280: Fetch 65536
2019-01-29 20:07:18.291: Fetch 65536
2019-01-29 20:07:18.304: Fetch 65536
2019-01-29 20:07:18.318: Fetch 65536
2019-01-29 20:07:18.334: Fetch 65536
2019-01-29 20:07:18.354: Fetch 65536
2019-01-29 20:07:18.380: Fetch 65536
2019-01-29 20:07:18.408: Fetch 65536
2019-01-29 20:07:18.421: Fetch 65536
2019-01-29 20:07:18.434: Fetch 65536
2019-01-29 20:07:18.447: Fetch 65536
2019-01-29 20:07:18.460: Fetch 65536
2019-01-29 20:07:18.476: Fetch 65536
2019-01-29 20:07:18.491: Fetch 65536
2019-01-29 20:07:29.417: Fetch 65536
2019-01-29 20:07:29.444: Fetch 65536
2019-01-29 20:07:29.455: Fetch 65536
2019-01-29 20:07:29.468: Fetch 65536
2019-01-29 20:07:29.483: Fetch 65536
2019-01-29 20:07:29.497: Fetch 65536
2019-01-29 20:07:29.512: Fetch 65536
2019-01-29 20:07:29.525: Fetch 65536
2019-01-29 20:07:29.540: Fetch 65536
2019-01-29 20:07:29.557: Fetch 65536
2019-01-29 20:07:29.579: Fetch 65536
2019-01-29 20:07:29.601: Fetch 65536
2019-01-29 20:07:29.618: Fetch 65536
2019-01-29 20:07:29.630: Fetch 65536
2019-01-29 20:07:29.646: Fetch 65536
2019-01-29 20:07:29.662: Fetch 65536
2019-01-29 20:07:29.672: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 48610635, m_contentLength = 48607266
2019-01-29 20:07:29.685: Fetch 65536
2019-01-29 20:07:29.697: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 48648226, m_contentLength = 48607266
2019-01-29 20:07:29.713: Fetch 65536
2019-01-29 20:07:29.726: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 48664610, m_contentLength = 48607266
2019-01-29 20:07:29.742: Fetch 65536
2019-01-29 20:07:29.759: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 48672802, m_contentLength = 48607266
2019-01-29 20:07:29.782: HttpURLConnection: Returning -1 (end of file)!2019-01-29 20:07:29:805  not enough data, calling setNextToCurrent, framesToRead = 335872
2019-01-29 20:07:29:806  after setNextToCurrent: current = 0xd0349100, m_next = 0x0
2019-01-29 20:07:29.818: HttpURLConnection: fetchDataForReal: m_HttpURLConnection == null, creating request, this = com.extreamsd.usbaudioplayershared.ESDHTTPClient@8c1654e
2019-01-29 20:07:29.828: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:07:30.014: HttpURLConnection: contentLength = 22588706 for Tidal
2019-01-29 20:07:30.044: Fetch 65536
2019-01-29 20:07:30.060: Fetch 341466
2019-01-29 20:07:30.087: Fetch 169434
2019-01-29 20:07:30.101: Fetch 81920
2019-01-29 20:07:30.115: Fetch 65536
2019-01-29 20:07:30.127: Fetch 65536
2019-01-29 20:07:30.203: Fetch 65536
2019-01-29 20:07:30.215: Fetch 65536
2019-01-29 20:07:30.226: Fetch 65536
2019-01-29 20:07:30.245: Fetch 65536
2019-01-29 20:07:30.255: Fetch 65536
2019-01-29 20:07:30.266: Fetch 65536
2019-01-29 20:07:30.282: Fetch 65536
2019-01-29 20:07:30.296: Fetch 65536
2019-01-29 20:07:30.308: Fetch 65536
2019-01-29 20:07:30.318: Fetch 65536
2019-01-29 20:07:30.328: Fetch 65536
2019-01-29 20:07:30.341: Fetch 65536
2019-01-29 20:07:30.356: Fetch 65536
2019-01-29 20:07:30.366: Fetch 65536
2019-01-29 20:07:30.378: Fetch 65536
2019-01-29 20:07:30.391: Fetch 65536
2019-01-29 20:07:30.402: Fetch 65536
2019-01-29 20:07:30.415: Fetch 65536
2019-01-29 20:07:30.431: Fetch 65536
2019-01-29 20:07:30.446: Fetch 65536
2019-01-29 20:07:30.470: Fetch 65536
2019-01-29 20:07:30.483: Fetch 65536
2019-01-29 20:07:30.497: Fetch 65536
2019-01-29 20:07:30.514: Fetch 65536
2019-01-29 20:07:30.530: Fetch 65536
2019-01-29 20:07:30.543: Fetch 65536
2019-01-29 20:07:30.557: Fetch 65536
2019-01-29 20:07:30.572: Fetch 65536
2019-01-29 20:07:30.583: Fetch 65536
2019-01-29 20:07:30.597: Fetch 65536
2019-01-29 20:07:30.607: Fetch 65536
2019-01-29 20:07:30.618: Fetch 65536
2019-01-29 20:07:30.664: Fetch 65536
2019-01-29 20:07:30.680: Fetch 65536
2019-01-29 20:07:30.696: Fetch 65536
2019-01-29 20:07:30.712: Fetch 65536
2019-01-29 20:07:30.730: Fetch 65536
2019-01-29 20:07:30.748: Fetch 65536
2019-01-29 20:07:30.773: Fetch 65536
2019-01-29 20:07:30.792: Fetch 65536
2019-01-29 20:07:30.803: Fetch 65536
2019-01-29 20:07:30.819: Fetch 65536
2019-01-29 20:07:30.833: Fetch 65536
2019-01-29 20:07:30.844: Fetch 65536
2019-01-29 20:07:41.315: Fetch 65536
2019-01-29 20:07:41.328: Fetch 65536
2019-01-29 20:07:41.346: Fetch 65536
2019-01-29 20:07:41.362: Fetch 65536
2019-01-29 20:07:41.376: Fetch 65536
2019-01-29 20:07:41.389: Fetch 65536
2019-01-29 20:07:41.401: Fetch 65536
2019-01-29 20:07:41.424: Fetch 65536
2019-01-29 20:07:41.444: Fetch 65536
2019-01-29 20:07:41.460: Fetch 65536
2019-01-29 20:07:41.474: Fetch 65536
2019-01-29 20:07:41.490: Fetch 65536
2019-01-29 20:07:41.507: Fetch 65536
2019-01-29 20:07:41.530: Fetch 65536
2019-01-29 20:07:41.541: Fetch 65536
2019-01-29 20:07:41.558: Fetch 65536
2019-01-29 20:07:41.593: Fetch 65536
2019-01-29 20:07:41.608: Fetch 65536
2019-01-29 20:07:41.622: Fetch 65536
2019-01-29 20:07:41.636: Fetch 65536
2019-01-29 20:07:41.648: Fetch 65536
2019-01-29 20:07:41.661: Fetch 65536
2019-01-29 20:07:41.673: Fetch 65536
2019-01-29 20:07:41.688: Fetch 65536
2019-01-29 20:07:41.707: Fetch 65536
2019-01-29 20:07:41.725: Fetch 65536
2019-01-29 20:07:41.758: Fetch 65536
2019-01-29 20:07:41.774: Fetch 65536
2019-01-29 20:07:41.785: Fetch 65536
2019-01-29 20:07:41.805: Fetch 65536
2019-01-29 20:07:41.823: Fetch 65536
2019-01-29 20:07:41.841: Fetch 65536
2019-01-29 20:07:41.855: Fetch 65536
2019-01-29 20:07:41.869: Fetch 65536
2019-01-29 20:07:41.885: Fetch 65536
2019-01-29 20:07:41.900: Fetch 65536
2019-01-29 20:07:41.918: Fetch 65536
2019-01-29 20:07:41.935: Fetch 65536
2019-01-29 20:07:41.951: Fetch 65536
2019-01-29 20:07:41.967: Fetch 65536
2019-01-29 20:07:41.980: Fetch 65536
2019-01-29 20:07:41.999: Fetch 65536
2019-01-29 20:07:42.014: Fetch 65536
2019-01-29 20:07:42.029: Fetch 65536
2019-01-29 20:07:42.053: Fetch 65536
2019-01-29 20:07:42.070: Fetch 65536
2019-01-29 20:07:42.084: Fetch 65536
2019-01-29 20:07:42.103: Fetch 65536
2019-01-29 20:07:42.128: Fetch 65536
2019-01-29 20:07:42.145: Fetch 65536
2019-01-29 20:07:42.161: Fetch 65536
2019-01-29 20:07:42.176: Fetch 65536
2019-01-29 20:07:42.190: Fetch 65536
2019-01-29 20:07:42.206: Fetch 65536
2019-01-29 20:07:42.224: Fetch 65536
2019-01-29 20:07:42.245: Fetch 65536
2019-01-29 20:07:42.275: Fetch 65536
2019-01-29 20:07:42.290: Fetch 65536
2019-01-29 20:07:42.305: Fetch 65536
2019-01-29 20:07:42.319: Fetch 65536
2019-01-29 20:07:42.334: Fetch 65536
2019-01-29 20:07:42.348: Fetch 65536
2019-01-29 20:07:42.368: Fetch 65536
2019-01-29 20:07:42.386: Fetch 65536
2019-01-29 20:07:42.402: Fetch 655362019-01-29 20:07:45:724  FileQueue dump CB: switch required
2019-01-29 20:07:45:725  FileQueue dump: current = 0xd0349100, Tidal
2019-01-29 20:07:45:725  FileQueue dump: next    = 0x0,
2019-01-29 20:07:45:726  filldatacb: stopAndGo 0
2019-01-29 20:07:45.771: Open ASYNC: Gjeilo: North Country II
2019-01-29 20:07:51.197: onPositiveResult, i_isNextPosition = true
2019-01-29 20:07:51.247: Message MESSAGE_TYPE_QUEUE_SONG
2019-01-29 20:07:51.276: HttpURLConnection: fetchDataForReal: m_HttpURLConnection == null, creating request, this = com.extreamsd.usbaudioplayershared.ESDHTTPClient@52885a
2019-01-29 20:07:51.310: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:07:51.698: HttpURLConnection: contentLength = 46295618 for Tidal
2019-01-29 20:07:51.709: Fetch 65536
2019-01-29 20:07:51.729: Fetch 335268
2019-01-29 20:07:51.756: Fetch 216925
2019-01-29 20:07:51.783: Fetch 131493
2019-01-29 20:07:51.806: Fetch 65536
2019-01-29 20:07:51.816: Fetch 33189
2019-01-29 20:07:51.830: Fetch 65536
2019-01-29 20:07:51.893: Fetch 65536
2019-01-29 20:07:51.904: Fetch 65536
2019-01-29 20:07:51.916: Fetch 65536
2019-01-29 20:07:51.935: Fetch 65536
2019-01-29 20:07:51.947: Fetch 65536
2019-01-29 20:07:51.959: Fetch 65536
2019-01-29 20:07:51.975: Fetch 65536
2019-01-29 20:07:51.987: Fetch 65536
2019-01-29 20:07:52.014: Fetch 65536
2019-01-29 20:07:52.026: Fetch 65536
2019-01-29 20:07:52.035: Fetch 65536
2019-01-29 20:07:52.045: Fetch 65536
2019-01-29 20:07:52.059: Fetch 65536
2019-01-29 20:07:52.072: Fetch 65536
2019-01-29 20:07:52.085: Fetch 65536
2019-01-29 20:07:52.099: Fetch 65536
2019-01-29 20:07:52.119: Fetch 65536
2019-01-29 20:07:52.138: Fetch 65536
2019-01-29 20:07:52.156: Fetch 65536
2019-01-29 20:07:52.176: Fetch 65536
2019-01-29 20:07:52.194: Fetch 65536
2019-01-29 20:07:52.207: Fetch 65536
2019-01-29 20:07:52.218: Fetch 65536
2019-01-29 20:07:52.228: Fetch 655362019-01-29 20:07:52:243  Current wasn't NULL, so setting next to Gjeilo: North Country II = Tidal
2019-01-29 20:07:52:244  after setNextDataSource: current = 0xd0349100, m_next = 0xd217fe00
2019-01-29 20:07:52.253: Setting m_asyncInProgress to false in A
2019-01-29 20:07:53.215: Fetch 65536
2019-01-29 20:07:53.237: Fetch 65536
2019-01-29 20:07:53.248: Fetch 65536
2019-01-29 20:07:53.263: Fetch 65536
2019-01-29 20:07:53.278: Fetch 65536
2019-01-29 20:07:53.303: Fetch 65536
2019-01-29 20:07:53.316: Fetch 65536
2019-01-29 20:07:53.328: Fetch 65536
2019-01-29 20:07:53.343: Fetch 65536
2019-01-29 20:07:53.357: Fetch 65536
2019-01-29 20:07:53.378: Fetch 65536
2019-01-29 20:07:53.399: Fetch 65536
2019-01-29 20:07:53.414: Fetch 65536
2019-01-29 20:07:53.430: Fetch 65536
2019-01-29 20:07:53.461: Fetch 65536
2019-01-29 20:07:53.477: Fetch 65536
2019-01-29 20:07:53.492: Fetch 65536
2019-01-29 20:07:53.505: Fetch 65536
2019-01-29 20:07:53.518: Fetch 65536
2019-01-29 20:07:53.538: Fetch 65536
2019-01-29 20:07:53.553: Fetch 65536
2019-01-29 20:07:53.567: Fetch 65536
2019-01-29 20:07:53.581: Fetch 65536
2019-01-29 20:07:53.596: Fetch 65536
2019-01-29 20:07:53.621: Fetch 65536
2019-01-29 20:07:53.644: Fetch 65536
2019-01-29 20:07:53.660: Fetch 65536
2019-01-29 20:07:53.684: Fetch 65536
2019-01-29 20:07:53.705: Fetch 65536
2019-01-29 20:07:53.718: Fetch 65536
2019-01-29 20:07:53.731: Fetch 65536
2019-01-29 20:07:53.749: Fetch 65536
2019-01-29 20:07:53.761: Fetch 65536
2019-01-29 20:07:53.776: Fetch 65536
2019-01-29 20:07:53.800: Fetch 65536
2019-01-29 20:07:53.822: Fetch 65536
2019-01-29 20:07:53.836: Fetch 65536
2019-01-29 20:07:53.857: Fetch 65536
2019-01-29 20:07:53.870: Fetch 65536
2019-01-29 20:07:53.892: Fetch 65536
2019-01-29 20:07:53.906: Fetch 65536
2019-01-29 20:07:53.918: Fetch 65536
2019-01-29 20:07:53.931: Fetch 65536
2019-01-29 20:07:53.949: Fetch 65536
2019-01-29 20:07:53.966: Fetch 65536
2019-01-29 20:07:53.982: Fetch 65536
2019-01-29 20:07:53.999: Fetch 65536
2019-01-29 20:07:54.022: Fetch 65536
2019-01-29 20:07:54.043: Fetch 65536
2019-01-29 20:07:54.068: Fetch 65536
2019-01-29 20:07:54.092: Fetch 65536
2019-01-29 20:07:54.105: Fetch 65536
2019-01-29 20:07:54.124: Fetch 65536
2019-01-29 20:07:54.144: Fetch 65536
2019-01-29 20:07:54.158: Fetch 65536
2019-01-29 20:07:54.170: Fetch 65536
2019-01-29 20:07:54.184: Fetch 65536
2019-01-29 20:07:54.204: Fetch 65536
2019-01-29 20:07:54.221: Fetch 65536
2019-01-29 20:07:54.242: Fetch 65536
2019-01-29 20:07:54.259: Fetch 65536
2019-01-29 20:07:54.282: Fetch 65536
2019-01-29 20:07:54.321: Fetch 65536
2019-01-29 20:07:54.371: Fetch 65536
2019-01-29 20:07:54.387: Fetch 65536
2019-01-29 20:07:54.398: Fetch 65536
2019-01-29 20:08:05.095: Fetch 65536
2019-01-29 20:08:05.118: Fetch 65536
2019-01-29 20:08:05.130: Fetch 65536
2019-01-29 20:08:05.143: Fetch 65536
2019-01-29 20:08:05.156: Fetch 65536
2019-01-29 20:08:05.167: Fetch 65536
2019-01-29 20:08:05.184: Fetch 65536
2019-01-29 20:08:05.205: Fetch 65536
2019-01-29 20:08:05.228: Fetch 65536
2019-01-29 20:08:05.245: Fetch 65536
2019-01-29 20:08:05.263: Fetch 65536
2019-01-29 20:08:05.281: Fetch 65536
2019-01-29 20:08:05.293: Fetch 65536
2019-01-29 20:08:05.309: Fetch 65536
2019-01-29 20:08:05.322: Fetch 65536
2019-01-29 20:08:05.333: Fetch 65536
2019-01-29 20:08:05.344: Fetch 65536
2019-01-29 20:08:05.357: Fetch 65536
2019-01-29 20:08:05.368: Fetch 65536
2019-01-29 20:08:05.382: Fetch 65536
2019-01-29 20:08:05.397: Fetch 65536
2019-01-29 20:08:05.420: Fetch 65536
2019-01-29 20:08:05.443: Fetch 65536
2019-01-29 20:08:05.458: Fetch 65536
2019-01-29 20:08:05.474: Fetch 65536
2019-01-29 20:08:05.487: Fetch 65536
2019-01-29 20:08:05.501: Fetch 65536
2019-01-29 20:08:05.516: Fetch 65536
2019-01-29 20:08:05.530: Fetch 65536
2019-01-29 20:08:05.542: Fetch 65536
2019-01-29 20:08:05.554: Fetch 65536
2019-01-29 20:08:05.570: Fetch 65536
2019-01-29 20:08:05.586: Fetch 65536
2019-01-29 20:08:05.606: Fetch 65536
2019-01-29 20:08:05.621: Fetch 65536
2019-01-29 20:08:05.654: Fetch 65536
2019-01-29 20:08:05.668: Fetch 65536
2019-01-29 20:08:05.683: Fetch 65536
2019-01-29 20:08:05.700: Fetch 65536
2019-01-29 20:08:05.716: Fetch 65536
2019-01-29 20:08:05.736: Fetch 65536
2019-01-29 20:08:05.755: Fetch 65536
2019-01-29 20:08:05.774: Fetch 65536
2019-01-29 20:08:05.794: Fetch 65536
2019-01-29 20:08:05.806: Fetch 65536
2019-01-29 20:08:05.822: Fetch 65536
2019-01-29 20:08:05.835: Fetch 65536
2019-01-29 20:08:05.850: Fetch 65536
2019-01-29 20:08:05.863: Fetch 65536
2019-01-29 20:08:05.881: Fetch 65536
2019-01-29 20:08:05.896: Fetch 65536
2019-01-29 20:08:05.914: Fetch 65536
2019-01-29 20:08:05.930: Fetch 65536
2019-01-29 20:08:05.946: Fetch 65536
2019-01-29 20:08:05.962: Fetch 65536
2019-01-29 20:08:05.978: Fetch 65536
2019-01-29 20:08:05.993: Fetch 65536
2019-01-29 20:08:06.006: Fetch 65536
2019-01-29 20:08:06.017: Fetch 65536
2019-01-29 20:08:06.034: Fetch 65536
2019-01-29 20:08:06.053: Fetch 65536
2019-01-29 20:08:06.067: Fetch 65536
2019-01-29 20:08:06.092: Fetch 65536
2019-01-29 20:08:06.104: Fetch 65536
2019-01-29 20:08:06.117: Fetch 65536
2019-01-29 20:08:06.143: Fetch 65536
2019-01-29 20:08:06.157: Fetch 65536
2019-01-29 20:08:18.442: Fetch 65536
2019-01-29 20:08:18.482: Fetch 65536
2019-01-29 20:08:18.516: Fetch 65536
2019-01-29 20:08:18.576: Fetch 65536
2019-01-29 20:08:18.622: Fetch 65536
2019-01-29 20:08:18.638: Fetch 65536
2019-01-29 20:08:18.651: Fetch 65536
2019-01-29 20:08:18.670: Fetch 65536
2019-01-29 20:08:18.685: Fetch 65536
2019-01-29 20:08:18.696: Fetch 65536
2019-01-29 20:08:18.709: Fetch 65536
2019-01-29 20:08:18.730: Fetch 65536
2019-01-29 20:08:18.742: Fetch 65536
2019-01-29 20:08:18.763: Fetch 65536
2019-01-29 20:08:18.787: Fetch 65536
2019-01-29 20:08:18.810: Fetch 65536
2019-01-29 20:08:18.822: Fetch 65536
2019-01-29 20:08:18.835: Fetch 65536
2019-01-29 20:08:18.856: Fetch 65536
2019-01-29 20:08:18.871: Fetch 65536
2019-01-29 20:08:18.885: Fetch 65536
2019-01-29 20:08:18.902: Fetch 65536
2019-01-29 20:08:18.915: Fetch 65536
2019-01-29 20:08:18.930: Fetch 65536
2019-01-29 20:08:18.943: Fetch 65536
2019-01-29 20:08:18.955: Fetch 65536
2019-01-29 20:08:18.971: Fetch 65536
2019-01-29 20:08:18.984: Fetch 65536
2019-01-29 20:08:18.998: Fetch 65536
2019-01-29 20:08:19.014: Fetch 65536
2019-01-29 20:08:19.039: Fetch 65536
2019-01-29 20:08:19.065: Fetch 65536
2019-01-29 20:08:19.082: Fetch 65536
2019-01-29 20:08:19.107: Fetch 65536
2019-01-29 20:08:19.120: Fetch 65536
2019-01-29 20:08:19.133: Fetch 65536
2019-01-29 20:08:19.148: Fetch 65536
2019-01-29 20:08:19.164: Fetch 65536
2019-01-29 20:08:19.184: Fetch 65536
2019-01-29 20:08:19.197: Fetch 65536
2019-01-29 20:08:19.218: Fetch 65536
2019-01-29 20:08:19.237: Fetch 65536
2019-01-29 20:08:19.250: Fetch 65536
2019-01-29 20:08:19.263: Fetch 65536
2019-01-29 20:08:19.275: Fetch 65536
2019-01-29 20:08:19.288: Fetch 65536
2019-01-29 20:08:19.302: Fetch 65536
2019-01-29 20:08:19.325: Fetch 65536
2019-01-29 20:08:19.341: Fetch 65536
2019-01-29 20:08:19.356: Fetch 65536
2019-01-29 20:08:19.367: Fetch 65536
2019-01-29 20:08:19.382: Fetch 65536
2019-01-29 20:08:19.402: Fetch 65536
2019-01-29 20:08:19.421: Fetch 65536
2019-01-29 20:08:19.435: Fetch 65536
2019-01-29 20:08:19.445: Fetch 65536
2019-01-29 20:08:19.458: Fetch 65536
2019-01-29 20:08:19.470: Fetch 65536
2019-01-29 20:08:19.482: Fetch 65536
2019-01-29 20:08:19.499: Fetch 65536
2019-01-29 20:08:19.518: Fetch 65536
2019-01-29 20:08:19.531: Fetch 65536
2019-01-29 20:08:19.555: Fetch 65536
2019-01-29 20:08:19.568: Fetch 65536
2019-01-29 20:08:19.585: Fetch 65536
2019-01-29 20:08:19.599: Fetch 65536
2019-01-29 20:08:19.612: Fetch 65536
2019-01-29 20:08:30.327: Fetch 65536
2019-01-29 20:08:30.355: Fetch 65536
2019-01-29 20:08:30.366: Fetch 65536
2019-01-29 20:08:30.386: Fetch 65536
2019-01-29 20:08:30.396: Fetch 65536
2019-01-29 20:08:30.408: Fetch 65536
2019-01-29 20:08:30.420: Fetch 65536
2019-01-29 20:08:30.434: Fetch 65536
2019-01-29 20:08:30.452: Fetch 65536
2019-01-29 20:08:30.465: Fetch 65536
2019-01-29 20:08:30.480: Fetch 65536
2019-01-29 20:08:30.497: Fetch 65536
2019-01-29 20:08:30.516: Fetch 65536
2019-01-29 20:08:30.533: Fetch 65536
2019-01-29 20:08:30.553: Fetch 65536
2019-01-29 20:08:30.576: Fetch 65536
2019-01-29 20:08:30.591: Fetch 65536
2019-01-29 20:08:30.618: Fetch 65536
2019-01-29 20:08:30.634: Fetch 65536
2019-01-29 20:08:30.646: Fetch 65536
2019-01-29 20:08:30.660: Fetch 65536
2019-01-29 20:08:30.674: Fetch 65536
2019-01-29 20:08:30.685: Fetch 65536
2019-01-29 20:08:30.705: Fetch 65536
2019-01-29 20:08:30.724: Fetch 65536
2019-01-29 20:08:30.744: Fetch 65536
2019-01-29 20:08:30.766: Fetch 65536
2019-01-29 20:08:30.788: Fetch 65536
2019-01-29 20:08:30.800: Fetch 65536
2019-01-29 20:08:30.811: Fetch 65536
2019-01-29 20:08:30.832: Fetch 65536
2019-01-29 20:08:30.856: Fetch 65536
2019-01-29 20:08:30.870: Fetch 65536
2019-01-29 20:08:30.892: Fetch 65536
2019-01-29 20:08:30.905: Fetch 65536
2019-01-29 20:08:30.919: Fetch 65536
2019-01-29 20:08:30.933: Fetch 65536
2019-01-29 20:08:30.949: Fetch 65536
2019-01-29 20:08:30.960: Fetch 65536
2019-01-29 20:08:30.979: Fetch 65536
2019-01-29 20:08:30.991: Fetch 65536
2019-01-29 20:08:31.009: Fetch 65536
2019-01-29 20:08:31.024: Fetch 65536
2019-01-29 20:08:31.040: Fetch 65536
2019-01-29 20:08:31.054: Fetch 65536
2019-01-29 20:08:31.066: Fetch 65536
2019-01-29 20:08:31.087: Fetch 65536
2019-01-29 20:08:31.103: Fetch 65536
2019-01-29 20:08:31.124: Fetch 65536
2019-01-29 20:08:31.135: Fetch 65536
2019-01-29 20:08:31.147: Fetch 65536
2019-01-29 20:08:31.168: Fetch 65536
2019-01-29 20:08:31.183: Fetch 65536
2019-01-29 20:08:31.204: Fetch 65536
2019-01-29 20:08:31.223: Fetch 65536
2019-01-29 20:08:31.238: Fetch 65536
2019-01-29 20:08:31.249: Fetch 65536
2019-01-29 20:08:31.261: Fetch 65536
2019-01-29 20:08:31.281: Fetch 65536
2019-01-29 20:08:31.302: Fetch 65536
2019-01-29 20:08:31.317: Fetch 65536
2019-01-29 20:08:31.340: Fetch 65536
2019-01-29 20:08:31.353: Fetch 65536
2019-01-29 20:08:40.764: Fetch 65536
2019-01-29 20:08:40.802: Fetch 65536
2019-01-29 20:08:40.817: Fetch 65536
2019-01-29 20:08:40.830: Fetch 65536
2019-01-29 20:08:40.848: Fetch 65536
2019-01-29 20:08:40.864: Fetch 65536
2019-01-29 20:08:40.881: Fetch 65536
2019-01-29 20:08:40.908: Fetch 65536
2019-01-29 20:08:40.929: Fetch 65536
2019-01-29 20:08:40.942: Fetch 65536
2019-01-29 20:08:40.967: Fetch 65536
2019-01-29 20:08:40.992: Fetch 65536
2019-01-29 20:08:41.005: Fetch 65536
2019-01-29 20:08:41.018: Fetch 65536
2019-01-29 20:08:41.032: Fetch 65536
2019-01-29 20:08:41.044: Fetch 65536
2019-01-29 20:08:41.058: Fetch 65536
2019-01-29 20:08:41.072: Fetch 65536
2019-01-29 20:08:41.097: Fetch 65536
2019-01-29 20:08:41.125: Fetch 65536
2019-01-29 20:08:41.142: Fetch 65536
2019-01-29 20:08:41.164: Fetch 65536
2019-01-29 20:08:41.198: Fetch 65536
2019-01-29 20:08:41.210: Fetch 65536
2019-01-29 20:08:41.225: Fetch 65536
2019-01-29 20:08:41.240: Fetch 65536
2019-01-29 20:08:41.255: Fetch 65536
2019-01-29 20:08:41.268: Fetch 65536
2019-01-29 20:08:41.280: Fetch 65536
2019-01-29 20:08:41.298: Fetch 65536
2019-01-29 20:08:41.314: Fetch 65536
2019-01-29 20:08:41.328: Fetch 65536
2019-01-29 20:08:41.341: Fetch 65536
2019-01-29 20:08:41.354: Fetch 65536
2019-01-29 20:08:41.367: Fetch 65536
2019-01-29 20:08:41.381: Fetch 65536
2019-01-29 20:08:41.400: Fetch 65536
2019-01-29 20:08:41.420: Fetch 65536
2019-01-29 20:08:41.434: Fetch 65536
2019-01-29 20:08:41.446: Fetch 65536
2019-01-29 20:08:41.460: Fetch 65536
2019-01-29 20:08:41.482: Fetch 65536
2019-01-29 20:08:41.496: Fetch 65536
2019-01-29 20:08:41.510: Fetch 65536
2019-01-29 20:08:41.525: Fetch 65536
2019-01-29 20:08:41.540: Fetch 65536
2019-01-29 20:08:41.558: Fetch 65536
2019-01-29 20:08:41.574: Fetch 65536
2019-01-29 20:08:41.586: Fetch 65536
2019-01-29 20:08:41.598: Fetch 65536
2019-01-29 20:08:41.614: Fetch 65536
2019-01-29 20:08:41.627: Fetch 65536
2019-01-29 20:08:41.641: Fetch 65536
2019-01-29 20:08:41.654: Fetch 65536
2019-01-29 20:08:41.665: Fetch 65536
2019-01-29 20:08:41.677: Fetch 65536
2019-01-29 20:08:41.689: Fetch 65536
2019-01-29 20:08:41.703: Fetch 65536
2019-01-29 20:08:41.726: Fetch 65536
2019-01-29 20:08:41.740: Fetch 65536
2019-01-29 20:08:41.762: Fetch 65536
2019-01-29 20:08:52.642: Fetch 65536
2019-01-29 20:08:52.677: Fetch 65536
2019-01-29 20:08:52.690: Fetch 65536
2019-01-29 20:08:52.707: Fetch 65536
2019-01-29 20:08:52.724: Fetch 65536
2019-01-29 20:08:52.739: Fetch 65536
2019-01-29 20:08:52.752: Fetch 65536
2019-01-29 20:08:52.770: Fetch 65536
2019-01-29 20:08:52.786: Fetch 65536
2019-01-29 20:08:52.802: Fetch 65536
2019-01-29 20:08:52.817: Fetch 65536
2019-01-29 20:08:52.834: Fetch 65536
2019-01-29 20:08:52.847: Fetch 65536
2019-01-29 20:08:52.863: Fetch 65536
2019-01-29 20:08:52.882: Fetch 65536
2019-01-29 20:08:52.904: Fetch 65536
2019-01-29 20:08:52.935: Fetch 65536
2019-01-29 20:08:52.956: Fetch 65536
2019-01-29 20:08:52.976: Fetch 65536
2019-01-29 20:08:52.991: Fetch 65536
2019-01-29 20:08:53.005: Fetch 65536
2019-01-29 20:08:53.023: Fetch 65536
2019-01-29 20:08:53.041: Fetch 65536
2019-01-29 20:08:53.058: Fetch 65536
2019-01-29 20:08:53.072: Fetch 65536
2019-01-29 20:08:53.084: Fetch 65536
2019-01-29 20:08:53.098: Fetch 65536
2019-01-29 20:08:53.111: Fetch 65536
2019-01-29 20:08:53.122: Fetch 65536
2019-01-29 20:08:53.135: Fetch 65536
2019-01-29 20:08:53.152: Fetch 65536
2019-01-29 20:08:53.187: Fetch 65536
2019-01-29 20:08:53.212: Fetch 65536
2019-01-29 20:08:53.236: Fetch 65536
2019-01-29 20:08:53.254: Fetch 65536
2019-01-29 20:08:53.267: Fetch 65536
2019-01-29 20:08:53.284: Fetch 65536
2019-01-29 20:08:53.299: Fetch 65536
2019-01-29 20:08:53.317: Fetch 65536
2019-01-29 20:08:53.334: Fetch 65536
2019-01-29 20:08:53.347: Fetch 65536
2019-01-29 20:08:53.359: Fetch 65536
2019-01-29 20:08:53.374: Fetch 65536
2019-01-29 20:08:53.390: Fetch 65536
2019-01-29 20:08:53.405: Fetch 65536
2019-01-29 20:08:53.420: Fetch 65536
2019-01-29 20:08:53.434: Fetch 65536
2019-01-29 20:08:53.446: Fetch 65536
2019-01-29 20:08:53.460: Fetch 65536
2019-01-29 20:08:53.482: Fetch 65536
2019-01-29 20:08:53.497: Fetch 65536
2019-01-29 20:08:53.513: Fetch 65536
2019-01-29 20:08:53.525: Fetch 65536
2019-01-29 20:08:53.540: Fetch 65536
2019-01-29 20:08:53.553: Fetch 65536
2019-01-29 20:08:53.564: Fetch 65536
2019-01-29 20:08:53.584: Fetch 65536
2019-01-29 20:08:53.601: Fetch 65536
2019-01-29 20:08:53.618: Fetch 65536
2019-01-29 20:08:53.635: Fetch 65536
2019-01-29 20:08:53.654: Fetch 65536
2019-01-29 20:08:53.672: Fetch 65536
2019-01-29 20:08:53.687: Fetch 65536
2019-01-29 20:08:53.707: Fetch 65536
2019-01-29 20:09:04.537: Fetch 65536
2019-01-29 20:09:04.564: Fetch 65536
2019-01-29 20:09:04.581: Fetch 65536
2019-01-29 20:09:04.597: Fetch 65536
2019-01-29 20:09:04.612: Fetch 65536
2019-01-29 20:09:04.624: Fetch 65536
2019-01-29 20:09:04.641: Fetch 65536
2019-01-29 20:09:04.654: Fetch 65536
2019-01-29 20:09:04.669: Fetch 65536
2019-01-29 20:09:04.688: Fetch 65536
2019-01-29 20:09:04.715: Fetch 65536
2019-01-29 20:09:04.726: Fetch 65536
2019-01-29 20:09:04.737: Fetch 65536
2019-01-29 20:09:04.749: Fetch 65536
2019-01-29 20:09:04.768: Fetch 65536
2019-01-29 20:09:04.786: Fetch 65536
2019-01-29 20:09:04.803: Fetch 65536
2019-01-29 20:09:04.816: Fetch 65536
2019-01-29 20:09:04.829: Fetch 65536
2019-01-29 20:09:04.840: Fetch 65536
2019-01-29 20:09:04.853: Fetch 65536
2019-01-29 20:09:04.865: Fetch 65536
2019-01-29 20:09:04.877: Fetch 65536
2019-01-29 20:09:04.890: Fetch 65536
2019-01-29 20:09:04.904: Fetch 65536
2019-01-29 20:09:04.923: Fetch 65536
2019-01-29 20:09:04.950: Fetch 65536
2019-01-29 20:09:04.967: Fetch 65536
2019-01-29 20:09:04.983: Fetch 65536
2019-01-29 20:09:04.999: Fetch 65536
2019-01-29 20:09:05.015: Fetch 65536
2019-01-29 20:09:05.033: Fetch 65536
2019-01-29 20:09:05.048: Fetch 65536
2019-01-29 20:09:05.064: Fetch 65536
2019-01-29 20:09:05.076: Fetch 65536
2019-01-29 20:09:05.088: Fetch 65536
2019-01-29 20:09:05.110: Fetch 65536
2019-01-29 20:09:05.128: Fetch 65536
2019-01-29 20:09:05.151: Fetch 65536
2019-01-29 20:09:05.168: Fetch 65536
2019-01-29 20:09:05.183: Fetch 65536
2019-01-29 20:09:05.199: Fetch 65536
2019-01-29 20:09:05.216: Fetch 65536
2019-01-29 20:09:05.229: Fetch 65536
2019-01-29 20:09:05.244: Fetch 65536
2019-01-29 20:09:05.258: Fetch 65536
2019-01-29 20:09:05.272: Fetch 65536
2019-01-29 20:09:05.291: Fetch 65536
2019-01-29 20:09:05.311: Fetch 65536
2019-01-29 20:09:05.337: Fetch 65536
2019-01-29 20:09:05.353: Fetch 65536
2019-01-29 20:09:05.370: Fetch 65536
2019-01-29 20:09:05.388: Fetch 65536
2019-01-29 20:09:05.403: Fetch 65536
2019-01-29 20:09:05.422: Fetch 65536
2019-01-29 20:09:05.435: Fetch 65536
2019-01-29 20:09:05.449: Fetch 65536
2019-01-29 20:09:05.468: Fetch 65536
2019-01-29 20:09:05.481: Fetch 65536
2019-01-29 20:09:16.417: Fetch 65536
2019-01-29 20:09:16.430: Fetch 65536
2019-01-29 20:09:16.445: Fetch 65536
2019-01-29 20:09:16.460: Fetch 65536
2019-01-29 20:09:16.474: Fetch 65536
2019-01-29 20:09:16.486: Fetch 65536
2019-01-29 20:09:16.517: Fetch 65536
2019-01-29 20:09:16.534: Fetch 65536
2019-01-29 20:09:16.547: Fetch 65536
2019-01-29 20:09:16.561: Fetch 65536
2019-01-29 20:09:16.574: Fetch 65536
2019-01-29 20:09:16.591: Fetch 65536
2019-01-29 20:09:16.608: Fetch 65536
2019-01-29 20:09:16.626: Fetch 65536
2019-01-29 20:09:16.640: Fetch 65536
2019-01-29 20:09:16.657: Fetch 65536
2019-01-29 20:09:16.672: Fetch 65536
2019-01-29 20:09:16.685: Fetch 65536
2019-01-29 20:09:16.699: Fetch 65536
2019-01-29 20:09:16.718: Fetch 65536
2019-01-29 20:09:16.735: Fetch 65536
2019-01-29 20:09:16.758: Fetch 65536
2019-01-29 20:09:16.770: Fetch 65536
2019-01-29 20:09:16.792: Fetch 65536
2019-01-29 20:09:16.808: Fetch 65536
2019-01-29 20:09:16.828: Fetch 65536
2019-01-29 20:09:16.852: Fetch 65536
2019-01-29 20:09:16.874: Fetch 65536
2019-01-29 20:09:16.893: Fetch 65536
2019-01-29 20:09:16.908: Fetch 65536
2019-01-29 20:09:16.920: Fetch 65536
2019-01-29 20:09:16.933: Fetch 65536
2019-01-29 20:09:16.945: Fetch 65536
2019-01-29 20:09:16.958: Fetch 65536
2019-01-29 20:09:16.977: Fetch 65536
2019-01-29 20:09:16.999: Fetch 65536
2019-01-29 20:09:17.017: Fetch 65536
2019-01-29 20:09:17.042: Fetch 65536
2019-01-29 20:09:17.061: Fetch 65536
2019-01-29 20:09:17.076: Fetch 65536
2019-01-29 20:09:17.096: Fetch 65536
2019-01-29 20:09:17.111: Fetch 65536
2019-01-29 20:09:17.126: Fetch 65536
2019-01-29 20:09:17.148: Fetch 65536
2019-01-29 20:09:17.165: Fetch 65536
2019-01-29 20:09:17.178: Fetch 65536
2019-01-29 20:09:17.197: Fetch 65536
2019-01-29 20:09:17.214: Fetch 65536
2019-01-29 20:09:17.226: Fetch 65536
2019-01-29 20:09:17.237: Fetch 65536
2019-01-29 20:09:17.255: Fetch 65536
2019-01-29 20:09:17.268: Fetch 65536
2019-01-29 20:09:28.314: Fetch 65536
2019-01-29 20:09:28.343: Fetch 65536
2019-01-29 20:09:28.355: Fetch 65536
2019-01-29 20:09:28.367: Fetch 65536
2019-01-29 20:09:28.380: Fetch 65536
2019-01-29 20:09:28.395: Fetch 65536
2019-01-29 20:09:28.420: Fetch 65536
2019-01-29 20:09:28.445: Fetch 65536
2019-01-29 20:09:28.465: Fetch 65536
2019-01-29 20:09:28.483: Fetch 65536
2019-01-29 20:09:28.497: Fetch 65536
2019-01-29 20:09:28.510: Fetch 65536
2019-01-29 20:09:28.522: Fetch 65536
2019-01-29 20:09:28.540: Fetch 65536
2019-01-29 20:09:28.556: Fetch 65536
2019-01-29 20:09:28.574: Fetch 65536
2019-01-29 20:09:28.590: Fetch 65536
2019-01-29 20:09:28.608: Fetch 65536
2019-01-29 20:09:28.624: Fetch 65536
2019-01-29 20:09:28.641: Fetch 65536
2019-01-29 20:09:28.659: Fetch 65536
2019-01-29 20:09:28.675: Fetch 65536
2019-01-29 20:09:28.695: Fetch 65536
2019-01-29 20:09:28.709: Fetch 65536
2019-01-29 20:09:28.722: Fetch 65536
2019-01-29 20:09:28.737: Fetch 65536
2019-01-29 20:09:28.755: Fetch 65536
2019-01-29 20:09:28.776: Fetch 65536
2019-01-29 20:09:28.795: Fetch 65536
2019-01-29 20:09:28.825: Fetch 65536
2019-01-29 20:09:28.840: Fetch 65536
2019-01-29 20:09:28.854: Fetch 65536
2019-01-29 20:09:28.875: Fetch 65536
2019-01-29 20:09:28.891: Fetch 65536
2019-01-29 20:09:28.909: Fetch 65536
2019-01-29 20:09:28.925: Fetch 65536
2019-01-29 20:09:28.949: Fetch 65536
2019-01-29 20:09:28.966: Fetch 65536
2019-01-29 20:09:28.984: Fetch 65536
2019-01-29 20:09:29.001: Fetch 65536
2019-01-29 20:09:29.016: Fetch 65536
2019-01-29 20:09:29.030: Fetch 65536
2019-01-29 20:09:29.044: Fetch 65536
2019-01-29 20:09:29.056: Fetch 65536
2019-01-29 20:09:29.067: Fetch 65536
2019-01-29 20:09:29.080: Fetch 65536
2019-01-29 20:09:29.092: Fetch 65536
2019-01-29 20:09:29.107: Fetch 65536
2019-01-29 20:09:29.122: Fetch 65536
2019-01-29 20:09:29.139: Fetch 65536
2019-01-29 20:09:29.156: Fetch 65536
2019-01-29 20:09:29.172: Fetch 65536
2019-01-29 20:09:29.185: Fetch 65536
2019-01-29 20:09:29.200: Fetch 65536
2019-01-29 20:09:41.666: Fetch 65536
2019-01-29 20:09:41.698: Fetch 65536
2019-01-29 20:09:41.712: Fetch 65536
2019-01-29 20:09:41.725: Fetch 65536
2019-01-29 20:09:41.740: Fetch 65536
2019-01-29 20:09:41.757: Fetch 65536
2019-01-29 20:09:41.772: Fetch 65536
2019-01-29 20:09:41.785: Fetch 65536
2019-01-29 20:09:41.797: Fetch 65536
2019-01-29 20:09:41.810: Fetch 65536
2019-01-29 20:09:41.826: Fetch 65536
2019-01-29 20:09:41.840: Fetch 65536
2019-01-29 20:09:41.858: Fetch 65536
2019-01-29 20:09:41.878: Fetch 65536
2019-01-29 20:09:41.894: Fetch 65536
2019-01-29 20:09:41.903: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22608770, m_contentLength = 22588706
2019-01-29 20:09:41.915: Fetch 65536
2019-01-29 20:09:41.924: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22637858, m_contentLength = 22588706
2019-01-29 20:09:41.937: Fetch 65536
2019-01-29 20:09:41.951: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22646050, m_contentLength = 22588706
2019-01-29 20:09:41.970: Fetch 65536
2019-01-29 20:09:41.989: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:09:42.015: HttpURLConnection: Returning -1 (end of file)!2019-01-29 20:09:42:33  not enough data, calling setNextToCurrent, framesToRead = 315392
2019-01-29 20:09:42:34  after setNextToCurrent: current = 0xd217fe00, m_next = 0x0
2019-01-29 20:09:42.046: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:09:42.518: HttpURLConnection: contentLength = 46295618 for Tidal
2019-01-29 20:09:42.553: Fetch 65536
2019-01-29 20:09:42.587: Fetch 335268
2019-01-29 20:09:42.603: Fetch 163840
2019-01-29 20:09:42.620: Fetch 90020
2019-01-29 20:09:42.635: Fetch 65536
2019-01-29 20:09:42.648: Fetch 40868
2019-01-29 20:09:42.708: Fetch 65536
2019-01-29 20:09:42.720: Fetch 65536
2019-01-29 20:09:42.734: Fetch 65536
2019-01-29 20:09:42.744: Fetch 65536
2019-01-29 20:09:42.757: Fetch 65536
2019-01-29 20:09:42.769: Fetch 65536
2019-01-29 20:09:42.779: Fetch 65536
2019-01-29 20:09:42.788: Fetch 65536
2019-01-29 20:09:42.806: Fetch 65536
2019-01-29 20:09:42.818: Fetch 65536
2019-01-29 20:09:42.827: Fetch 65536
2019-01-29 20:09:42.839: Fetch 65536
2019-01-29 20:09:42.852: Fetch 65536
2019-01-29 20:09:42.876: Fetch 65536
2019-01-29 20:09:42.889: Fetch 65536
2019-01-29 20:09:42.900: Fetch 65536
2019-01-29 20:09:42.912: Fetch 65536
2019-01-29 20:09:42.925: Fetch 65536
2019-01-29 20:09:42.940: Fetch 65536
2019-01-29 20:09:42.953: Fetch 65536
2019-01-29 20:09:42.965: Fetch 65536
2019-01-29 20:09:42.987: Fetch 65536
2019-01-29 20:09:43.008: Fetch 65536
2019-01-29 20:09:43.024: Fetch 65536
2019-01-29 20:09:43.091: Fetch 65536
2019-01-29 20:09:43.105: Fetch 65536
2019-01-29 20:09:43.122: Fetch 65536
2019-01-29 20:09:43.138: Fetch 65536
2019-01-29 20:09:43.155: Fetch 65536
2019-01-29 20:09:43.170: Fetch 65536
2019-01-29 20:09:43.186: Fetch 65536
2019-01-29 20:09:52.073: Fetch 65536
2019-01-29 20:09:52.100: Fetch 65536
2019-01-29 20:09:52.115: Fetch 65536
2019-01-29 20:09:52.128: Fetch 65536
2019-01-29 20:09:52.142: Fetch 65536
2019-01-29 20:09:52.157: Fetch 65536
2019-01-29 20:09:52.179: Fetch 65536
2019-01-29 20:09:52.209: Fetch 65536
2019-01-29 20:09:52.227: Fetch 65536
2019-01-29 20:09:52.243: Fetch 65536
2019-01-29 20:09:52.257: Fetch 65536
2019-01-29 20:09:52.272: Fetch 65536
2019-01-29 20:09:52.285: Fetch 65536
2019-01-29 20:09:52.315: Fetch 65536
2019-01-29 20:09:52.328: Fetch 65536
2019-01-29 20:09:52.351: Fetch 65536
2019-01-29 20:09:52.371: Fetch 65536
2019-01-29 20:09:52.386: Fetch 65536
2019-01-29 20:09:52.401: Fetch 65536
2019-01-29 20:09:52.414: Fetch 65536
2019-01-29 20:09:52.426: Fetch 65536
2019-01-29 20:09:52.445: Fetch 65536
2019-01-29 20:09:52.462: Fetch 65536
2019-01-29 20:09:52.479: Fetch 65536
2019-01-29 20:09:52.493: Fetch 65536
2019-01-29 20:09:52.508: Fetch 65536
2019-01-29 20:09:52.523: Fetch 65536
2019-01-29 20:09:52.537: Fetch 65536
2019-01-29 20:09:52.557: Fetch 65536
2019-01-29 20:09:52.570: Fetch 65536
2019-01-29 20:09:52.586: Fetch 65536
2019-01-29 20:09:52.602: Fetch 65536
2019-01-29 20:09:52.616: Fetch 65536
2019-01-29 20:09:52.632: Fetch 65536
2019-01-29 20:09:52.649: Fetch 65536
2019-01-29 20:09:52.665: Fetch 65536
2019-01-29 20:09:52.678: Fetch 65536
2019-01-29 20:09:52.690: Fetch 65536
2019-01-29 20:09:52.702: Fetch 65536
2019-01-29 20:09:52.720: Fetch 65536
2019-01-29 20:09:52.736: Fetch 65536
2019-01-29 20:09:52.752: Fetch 65536
2019-01-29 20:09:52.772: Fetch 65536
2019-01-29 20:09:52.784: Fetch 65536
2019-01-29 20:09:52.803: Fetch 65536
2019-01-29 20:09:52.819: Fetch 65536
2019-01-29 20:09:52.834: Fetch 65536
2019-01-29 20:09:52.846: Fetch 655362019-01-29 20:09:57:988  FileQueue dump CB: switch required
2019-01-29 20:09:57:989  FileQueue dump: current = 0xd217fe00, Tidal
2019-01-29 20:09:57:990  FileQueue dump: next    = 0x0,
2019-01-29 20:09:57:990  filldatacb: stopAndGo 0
2019-01-29 20:09:58.025: Open ASYNC: Plagge: Duels For 2 Violins
2019-01-29 20:09:58.572: onPositiveResult, i_isNextPosition = true
2019-01-29 20:09:58.588: Message MESSAGE_TYPE_QUEUE_SONG
2019-01-29 20:09:58.600: HttpURLConnection: fetchDataForReal: m_HttpURLConnection == null, creating request, this = com.extreamsd.usbaudioplayershared.ESDHTTPClient@aee7b80
2019-01-29 20:09:58.611: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:09:59.001: HttpURLConnection: contentLength = 19188017 for Tidal
2019-01-29 20:09:59.017: Fetch 65536
2019-01-29 20:09:59.028: Fetch 335262
2019-01-29 20:09:59.053: Fetch 244950
2019-01-29 20:09:59.079: Fetch 188478
2019-01-29 20:09:59.095: Fetch 103046
2019-01-29 20:09:59.108: Fetch 65536
2019-01-29 20:09:59.122: Fetch 37510
2019-01-29 20:09:59.135: Fetch 65536
2019-01-29 20:09:59.198: Fetch 65536
2019-01-29 20:09:59.207: Fetch 65536
2019-01-29 20:09:59.218: Fetch 65536
2019-01-29 20:09:59.233: Fetch 65536
2019-01-29 20:09:59.243: Fetch 65536
2019-01-29 20:09:59.252: Fetch 65536
2019-01-29 20:09:59.261: Fetch 65536
2019-01-29 20:09:59.272: Fetch 65536
2019-01-29 20:09:59.297: Fetch 65536
2019-01-29 20:09:59.307: Fetch 65536
2019-01-29 20:09:59.317: Fetch 65536
2019-01-29 20:09:59.327: Fetch 65536
2019-01-29 20:09:59.346: Fetch 65536
2019-01-29 20:09:59.361: Fetch 65536
2019-01-29 20:09:59.373: Fetch 65536
2019-01-29 20:09:59.382: Fetch 65536
2019-01-29 20:09:59.391: Fetch 65536
2019-01-29 20:09:59.400: Fetch 65536
2019-01-29 20:09:59.409: Fetch 65536
2019-01-29 20:09:59.420: Fetch 65536
2019-01-29 20:09:59.429: Fetch 65536
2019-01-29 20:09:59.442: Fetch 65536
2019-01-29 20:09:59.461: Fetch 65536
2019-01-29 20:09:59.476: Fetch 65536
2019-01-29 20:09:59.490: Fetch 65536
2019-01-29 20:09:59.503: Fetch 655362019-01-29 20:09:59:519  Current wasn't NULL, so setting next to Plagge: Duels For 2 Violins = Tidal
2019-01-29 20:09:59:519  after setNextDataSource: current = 0xd217fe00, m_next = 0xd1849200
2019-01-29 20:09:59.527: Setting m_asyncInProgress to false in A
2019-01-29 20:10:03.975: Fetch 65536
2019-01-29 20:10:03.988: Fetch 65536
2019-01-29 20:10:04.003: Fetch 65536
2019-01-29 20:10:04.020: Fetch 65536
2019-01-29 20:10:04.040: Fetch 65536
2019-01-29 20:10:04.065: Fetch 65536
2019-01-29 20:10:04.077: Fetch 65536
2019-01-29 20:10:04.111: Fetch 65536
2019-01-29 20:10:04.133: Fetch 65536
2019-01-29 20:10:04.146: Fetch 65536
2019-01-29 20:10:04.159: Fetch 65536
2019-01-29 20:10:04.178: Fetch 65536
2019-01-29 20:10:04.198: Fetch 65536
2019-01-29 20:10:04.209: Fetch 65536
2019-01-29 20:10:04.223: Fetch 65536
2019-01-29 20:10:04.239: Fetch 65536
2019-01-29 20:10:04.254: Fetch 65536
2019-01-29 20:10:04.267: Fetch 65536
2019-01-29 20:10:04.286: Fetch 65536
2019-01-29 20:10:04.307: Fetch 65536
2019-01-29 20:10:04.335: Fetch 65536
2019-01-29 20:10:04.355: Fetch 65536
2019-01-29 20:10:04.367: Fetch 65536
2019-01-29 20:10:04.381: Fetch 65536
2019-01-29 20:10:04.394: Fetch 65536
2019-01-29 20:10:04.416: Fetch 65536
2019-01-29 20:10:04.433: Fetch 65536
2019-01-29 20:10:04.444: Fetch 65536
2019-01-29 20:10:04.457: Fetch 65536
2019-01-29 20:10:04.471: Fetch 65536
2019-01-29 20:10:04.483: Fetch 65536
2019-01-29 20:10:04.498: Fetch 65536
2019-01-29 20:10:04.511: Fetch 65536
2019-01-29 20:10:04.530: Fetch 65536
2019-01-29 20:10:04.551: Fetch 65536
2019-01-29 20:10:04.575: Fetch 65536
2019-01-29 20:10:04.595: Fetch 65536
2019-01-29 20:10:04.606: Fetch 65536
2019-01-29 20:10:04.620: Fetch 65536
2019-01-29 20:10:04.633: Fetch 65536
2019-01-29 20:10:04.646: Fetch 65536
2019-01-29 20:10:04.666: Fetch 65536
2019-01-29 20:10:04.683: Fetch 65536
2019-01-29 20:10:04.698: Fetch 65536
2019-01-29 20:10:04.710: Fetch 65536
2019-01-29 20:10:04.721: Fetch 65536
2019-01-29 20:10:04.735: Fetch 65536
2019-01-29 20:10:04.748: Fetch 65536
2019-01-29 20:10:04.764: Fetch 65536
2019-01-29 20:10:15.850: Fetch 65536
2019-01-29 20:10:15.867: Fetch 65536
2019-01-29 20:10:15.885: Fetch 65536
2019-01-29 20:10:15.902: Fetch 65536
2019-01-29 20:10:15.918: Fetch 65536
2019-01-29 20:10:15.930: Fetch 65536
2019-01-29 20:10:15.957: Fetch 65536
2019-01-29 20:10:15.982: Fetch 65536
2019-01-29 20:10:16.006: Fetch 65536
2019-01-29 20:10:16.029: Fetch 65536
2019-01-29 20:10:16.043: Fetch 65536
2019-01-29 20:10:16.057: Fetch 65536
2019-01-29 20:10:16.073: Fetch 65536
2019-01-29 20:10:16.086: Fetch 65536
2019-01-29 20:10:16.108: Fetch 65536
2019-01-29 20:10:16.127: Fetch 65536
2019-01-29 20:10:16.148: Fetch 65536
2019-01-29 20:10:16.170: Fetch 65536
2019-01-29 20:10:16.192: Fetch 65536
2019-01-29 20:10:16.204: Fetch 65536
2019-01-29 20:10:16.220: Fetch 65536
2019-01-29 20:10:16.235: Fetch 65536
2019-01-29 20:10:16.259: Fetch 65536
2019-01-29 20:10:16.274: Fetch 65536
2019-01-29 20:10:16.288: Fetch 65536
2019-01-29 20:10:16.301: Fetch 65536
2019-01-29 20:10:16.313: Fetch 65536
2019-01-29 20:10:16.323: Fetch 65536
2019-01-29 20:10:16.335: Fetch 65536
2019-01-29 20:10:16.347: Fetch 65536
2019-01-29 20:10:16.359: Fetch 65536
2019-01-29 20:10:16.379: Fetch 65536
2019-01-29 20:10:16.393: Fetch 65536
2019-01-29 20:10:16.417: Fetch 65536
2019-01-29 20:10:16.438: Fetch 65536
2019-01-29 20:10:16.456: Fetch 65536
2019-01-29 20:10:16.473: Fetch 65536
2019-01-29 20:10:16.487: Fetch 65536
2019-01-29 20:10:16.498: Fetch 65536
2019-01-29 20:10:16.508: Fetch 65536
2019-01-29 20:10:16.519: Fetch 65536
2019-01-29 20:10:16.532: Fetch 65536
2019-01-29 20:10:16.545: Fetch 65536
2019-01-29 20:10:16.558: Fetch 65536
2019-01-29 20:10:16.573: Fetch 65536
2019-01-29 20:10:16.589: Fetch 65536
2019-01-29 20:10:16.603: Fetch 65536
2019-01-29 20:10:16.622: Fetch 65536
2019-01-29 20:10:16.644: Fetch 65536
2019-01-29 20:10:16.668: Fetch 65536
2019-01-29 20:10:27.756: Fetch 65536
2019-01-29 20:10:27.772: Fetch 65536
2019-01-29 20:10:27.788: Fetch 65536
2019-01-29 20:10:27.806: Fetch 65536
2019-01-29 20:10:27.825: Fetch 65536
2019-01-29 20:10:27.847: Fetch 65536
2019-01-29 20:10:27.859: Fetch 65536
2019-01-29 20:10:27.874: Fetch 65536
2019-01-29 20:10:27.896: Fetch 65536
2019-01-29 20:10:27.914: Fetch 65536
2019-01-29 20:10:27.938: Fetch 65536
2019-01-29 20:10:27.951: Fetch 65536
2019-01-29 20:10:27.963: Fetch 65536
2019-01-29 20:10:27.980: Fetch 65536
2019-01-29 20:10:28.001: Fetch 65536
2019-01-29 20:10:28.018: Fetch 65536
2019-01-29 20:10:28.047: Fetch 65536
2019-01-29 20:10:28.060: Fetch 65536
2019-01-29 20:10:28.073: Fetch 65536
2019-01-29 20:10:28.084: Fetch 65536
2019-01-29 20:10:28.094: Fetch 65536
2019-01-29 20:10:28.105: Fetch 65536
2019-01-29 20:10:28.116: Fetch 65536
2019-01-29 20:10:28.129: Fetch 65536
2019-01-29 20:10:28.146: Fetch 65536
2019-01-29 20:10:28.166: Fetch 65536
2019-01-29 20:10:28.200: Fetch 65536
2019-01-29 20:10:28.218: Fetch 65536
2019-01-29 20:10:28.233: Fetch 65536
2019-01-29 20:10:28.245: Fetch 65536
2019-01-29 20:10:28.267: Fetch 65536
2019-01-29 20:10:28.294: Fetch 65536
2019-01-29 20:10:28.306: Fetch 65536
2019-01-29 20:10:28.321: Fetch 65536
2019-01-29 20:10:28.336: Fetch 65536
2019-01-29 20:10:28.350: Fetch 65536
2019-01-29 20:10:28.364: Fetch 65536
2019-01-29 20:10:28.381: Fetch 65536
2019-01-29 20:10:28.396: Fetch 65536
2019-01-29 20:10:28.412: Fetch 65536
2019-01-29 20:10:28.429: Fetch 65536
2019-01-29 20:10:28.442: Fetch 65536
2019-01-29 20:10:28.458: Fetch 65536
2019-01-29 20:10:28.478: Fetch 65536
2019-01-29 20:10:28.490: Fetch 65536
2019-01-29 20:10:28.506: Fetch 65536
2019-01-29 20:10:28.529: Fetch 65536
2019-01-29 20:10:28.549: Fetch 65536
2019-01-29 20:10:28.571: Fetch 65536
2019-01-29 20:10:28.588: Fetch 65536
2019-01-29 20:10:41.126: Fetch 65536
2019-01-29 20:10:41.158: Fetch 65536
2019-01-29 20:10:41.169: Fetch 65536
2019-01-29 20:10:41.181: Fetch 65536
2019-01-29 20:10:41.194: Fetch 65536
2019-01-29 20:10:41.212: Fetch 65536
2019-01-29 20:10:41.227: Fetch 65536
2019-01-29 20:10:41.239: Fetch 65536
2019-01-29 20:10:41.252: Fetch 65536
2019-01-29 20:10:41.263: Fetch 65536
2019-01-29 20:10:41.274: Fetch 65536
2019-01-29 20:10:41.288: Fetch 65536
2019-01-29 20:10:41.304: Fetch 65536
2019-01-29 20:10:41.320: Fetch 65536
2019-01-29 20:10:41.349: Fetch 65536
2019-01-29 20:10:41.378: Fetch 65536
2019-01-29 20:10:41.394: Fetch 65536
2019-01-29 20:10:41.405: Fetch 65536
2019-01-29 20:10:41.417: Fetch 65536
2019-01-29 20:10:41.431: Fetch 65536
2019-01-29 20:10:41.446: Fetch 65536
2019-01-29 20:10:41.469: Fetch 65536
2019-01-29 20:10:41.486: Fetch 65536
2019-01-29 20:10:41.504: Fetch 65536
2019-01-29 20:10:41.524: Fetch 65536
2019-01-29 20:10:41.540: Fetch 65536
2019-01-29 20:10:41.560: Fetch 65536
2019-01-29 20:10:41.576: Fetch 65536
2019-01-29 20:10:41.590: Fetch 65536
2019-01-29 20:10:41.602: Fetch 65536
2019-01-29 20:10:41.614: Fetch 65536
2019-01-29 20:10:41.627: Fetch 65536
2019-01-29 20:10:41.641: Fetch 65536
2019-01-29 20:10:41.657: Fetch 65536
2019-01-29 20:10:41.673: Fetch 65536
2019-01-29 20:10:41.686: Fetch 65536
2019-01-29 20:10:41.701: Fetch 65536
2019-01-29 20:10:41.719: Fetch 65536
2019-01-29 20:10:41.738: Fetch 65536
2019-01-29 20:10:41.764: Fetch 65536
2019-01-29 20:10:41.779: Fetch 65536
2019-01-29 20:10:41.795: Fetch 65536
2019-01-29 20:10:41.810: Fetch 65536
2019-01-29 20:10:41.829: Fetch 65536
2019-01-29 20:10:41.841: Fetch 65536
2019-01-29 20:10:41.867: Fetch 65536
2019-01-29 20:10:41.883: Fetch 65536
2019-01-29 20:10:41.896: Fetch 65536
2019-01-29 20:10:41.910: Fetch 65536
2019-01-29 20:10:41.923: Fetch 65536
2019-01-29 20:10:41.938: Fetch 65536
2019-01-29 20:10:51.516: Fetch 65536
2019-01-29 20:10:51.528: Fetch 65536
2019-01-29 20:10:51.542: Fetch 65536
2019-01-29 20:10:51.556: Fetch 65536
2019-01-29 20:10:51.570: Fetch 65536
2019-01-29 20:10:51.586: Fetch 65536
2019-01-29 20:10:51.625: Fetch 65536
2019-01-29 20:10:51.642: Fetch 65536
2019-01-29 20:10:51.656: Fetch 65536
2019-01-29 20:10:51.668: Fetch 65536
2019-01-29 20:10:51.680: Fetch 65536
2019-01-29 20:10:51.694: Fetch 65536
2019-01-29 20:10:51.708: Fetch 65536
2019-01-29 20:10:51.727: Fetch 65536
2019-01-29 20:10:51.741: Fetch 65536
2019-01-29 20:10:51.758: Fetch 65536
2019-01-29 20:10:51.771: Fetch 65536
2019-01-29 20:10:51.785: Fetch 65536
2019-01-29 20:10:51.799: Fetch 65536
2019-01-29 20:10:51.816: Fetch 65536
2019-01-29 20:10:51.831: Fetch 65536
2019-01-29 20:10:51.858: Fetch 65536
2019-01-29 20:10:51.873: Fetch 65536
2019-01-29 20:10:51.900: Fetch 65536
2019-01-29 20:10:51.913: Fetch 65536
2019-01-29 20:10:51.926: Fetch 65536
2019-01-29 20:10:51.946: Fetch 65536
2019-01-29 20:10:51.968: Fetch 65536
2019-01-29 20:10:51.978: Fetch 65536
2019-01-29 20:10:51.990: Fetch 65536
2019-01-29 20:10:52.009: Fetch 65536
2019-01-29 20:10:52.025: Fetch 65536
2019-01-29 20:10:52.038: Fetch 65536
2019-01-29 20:10:52.052: Fetch 65536
2019-01-29 20:10:52.066: Fetch 65536
2019-01-29 20:10:52.079: Fetch 65536
2019-01-29 20:10:52.092: Fetch 65536
2019-01-29 20:10:52.108: Fetch 65536
2019-01-29 20:10:52.125: Fetch 65536
2019-01-29 20:10:52.149: Fetch 65536
2019-01-29 20:10:52.171: Fetch 65536
2019-01-29 20:10:52.187: Fetch 65536
2019-01-29 20:10:52.200: Fetch 65536
2019-01-29 20:10:52.213: Fetch 65536
2019-01-29 20:10:52.228: Fetch 65536
2019-01-29 20:10:52.244: Fetch 65536
2019-01-29 20:10:52.258: Fetch 65536
2019-01-29 20:10:52.278: Fetch 65536
2019-01-29 20:10:52.300: Fetch 65536
2019-01-29 20:10:52.317: Fetch 65536
2019-01-29 20:11:03.448: Fetch 65536
2019-01-29 20:11:03.488: Fetch 65536
2019-01-29 20:11:03.521: Fetch 65536
2019-01-29 20:11:03.537: Fetch 65536
2019-01-29 20:11:03.552: Fetch 65536
2019-01-29 20:11:03.570: Fetch 65536
2019-01-29 20:11:03.605: Fetch 65536
2019-01-29 20:11:03.620: Fetch 65536
2019-01-29 20:11:03.636: Fetch 65536
2019-01-29 20:11:03.650: Fetch 65536
2019-01-29 20:11:03.665: Fetch 65536
2019-01-29 20:11:03.680: Fetch 65536
2019-01-29 20:11:03.694: Fetch 65536
2019-01-29 20:11:03.707: Fetch 65536
2019-01-29 20:11:03.728: Fetch 65536
2019-01-29 20:11:03.745: Fetch 65536
2019-01-29 20:11:03.759: Fetch 65536
2019-01-29 20:11:03.776: Fetch 65536
2019-01-29 20:11:03.790: Fetch 65536
2019-01-29 20:11:03.802: Fetch 65536
2019-01-29 20:11:03.815: Fetch 65536
2019-01-29 20:11:03.830: Fetch 65536
2019-01-29 20:11:03.845: Fetch 65536
2019-01-29 20:11:03.867: Fetch 65536
2019-01-29 20:11:03.886: Fetch 65536
2019-01-29 20:11:03.906: Fetch 65536
2019-01-29 20:11:03.921: Fetch 65536
2019-01-29 20:11:03.935: Fetch 65536
2019-01-29 20:11:03.946: Fetch 65536
2019-01-29 20:11:03.973: Fetch 65536
2019-01-29 20:11:03.993: Fetch 65536
2019-01-29 20:11:04.010: Fetch 65536
2019-01-29 20:11:04.032: Fetch 65536
2019-01-29 20:11:04.045: Fetch 65536
2019-01-29 20:11:04.062: Fetch 65536
2019-01-29 20:11:04.078: Fetch 65536
2019-01-29 20:11:04.094: Fetch 65536
2019-01-29 20:11:04.107: Fetch 65536
2019-01-29 20:11:04.121: Fetch 65536
2019-01-29 20:11:04.135: Fetch 65536
2019-01-29 20:11:04.155: Fetch 65536
2019-01-29 20:11:04.177: Fetch 65536
2019-01-29 20:11:04.195: Fetch 65536
2019-01-29 20:11:04.208: Fetch 65536
2019-01-29 20:11:04.226: Fetch 65536
2019-01-29 20:11:04.245: Fetch 65536
2019-01-29 20:11:04.259: Fetch 65536
2019-01-29 20:11:04.270: Fetch 65536
2019-01-29 20:11:04.282: Fetch 65536
2019-01-29 20:11:04.296: Fetch 65536
2019-01-29 20:11:04.318: Fetch 65536
2019-01-29 20:11:04.342: Fetch 65536
2019-01-29 20:11:15.300: Fetch 65536
2019-01-29 20:11:15.334: Fetch 65536
2019-01-29 20:11:15.347: Fetch 65536
2019-01-29 20:11:15.360: Fetch 65536
2019-01-29 20:11:15.374: Fetch 65536
2019-01-29 20:11:15.389: Fetch 65536
2019-01-29 20:11:15.405: Fetch 65536
2019-01-29 20:11:15.428: Fetch 65536
2019-01-29 20:11:15.443: Fetch 65536
2019-01-29 20:11:15.460: Fetch 65536
2019-01-29 20:11:15.475: Fetch 65536
2019-01-29 20:11:15.489: Fetch 65536
2019-01-29 20:11:15.504: Fetch 65536
2019-01-29 20:11:15.524: Fetch 65536
2019-01-29 20:11:15.541: Fetch 65536
2019-01-29 20:11:15.559: Fetch 65536
2019-01-29 20:11:15.575: Fetch 65536
2019-01-29 20:11:15.588: Fetch 65536
2019-01-29 20:11:15.603: Fetch 65536
2019-01-29 20:11:15.620: Fetch 65536
2019-01-29 20:11:15.639: Fetch 65536
2019-01-29 20:11:15.655: Fetch 65536
2019-01-29 20:11:15.675: Fetch 65536
2019-01-29 20:11:15.687: Fetch 65536
2019-01-29 20:11:15.699: Fetch 65536
2019-01-29 20:11:15.712: Fetch 65536
2019-01-29 20:11:15.726: Fetch 65536
2019-01-29 20:11:15.740: Fetch 65536
2019-01-29 20:11:15.756: Fetch 65536
2019-01-29 20:11:15.778: Fetch 65536
2019-01-29 20:11:15.796: Fetch 65536
2019-01-29 20:11:15.817: Fetch 65536
2019-01-29 20:11:15.831: Fetch 65536
2019-01-29 20:11:15.841: Fetch 65536
2019-01-29 20:11:15.852: Fetch 65536
2019-01-29 20:11:15.869: Fetch 65536
2019-01-29 20:11:15.894: Fetch 65536
2019-01-29 20:11:15.907: Fetch 65536
2019-01-29 20:11:15.922: Fetch 65536
2019-01-29 20:11:15.934: Fetch 65536
2019-01-29 20:11:15.947: Fetch 65536
2019-01-29 20:11:15.961: Fetch 65536
2019-01-29 20:11:15.977: Fetch 65536
2019-01-29 20:11:15.998: Fetch 65536
2019-01-29 20:11:16.015: Fetch 65536
2019-01-29 20:11:16.042: Fetch 65536
2019-01-29 20:11:16.065: Fetch 65536
2019-01-29 20:11:16.089: Fetch 65536
2019-01-29 20:11:16.103: Fetch 65536
2019-01-29 20:11:16.123: Fetch 65536
2019-01-29 20:11:16.139: Fetch 65536
2019-01-29 20:11:16.152: Fetch 65536
2019-01-29 20:11:16.164: Fetch 65536
2019-01-29 20:11:16.179: Fetch 65536
2019-01-29 20:11:16.195: Fetch 65536
2019-01-29 20:11:16.214: Fetch 65536
2019-01-29 20:11:28.669: Fetch 65536
2019-01-29 20:11:28.686: Fetch 65536
2019-01-29 20:11:28.703: Fetch 65536
2019-01-29 20:11:28.715: Fetch 65536
2019-01-29 20:11:28.727: Fetch 65536
2019-01-29 20:11:28.741: Fetch 65536
2019-01-29 20:11:28.755: Fetch 65536
2019-01-29 20:11:28.773: Fetch 65536
2019-01-29 20:11:28.797: Fetch 65536
2019-01-29 20:11:28.820: Fetch 65536
2019-01-29 20:11:28.835: Fetch 65536
2019-01-29 20:11:28.850: Fetch 65536
2019-01-29 20:11:28.867: Fetch 65536
2019-01-29 20:11:28.883: Fetch 65536
2019-01-29 20:11:28.901: Fetch 65536
2019-01-29 20:11:28.919: Fetch 65536
2019-01-29 20:11:28.935: Fetch 65536
2019-01-29 20:11:28.950: Fetch 65536
2019-01-29 20:11:28.967: Fetch 65536
2019-01-29 20:11:28.982: Fetch 65536
2019-01-29 20:11:29.001: Fetch 65536
2019-01-29 20:11:29.021: Fetch 65536
2019-01-29 20:11:29.037: Fetch 65536
2019-01-29 20:11:29.050: Fetch 65536
2019-01-29 20:11:29.063: Fetch 65536
2019-01-29 20:11:29.079: Fetch 65536
2019-01-29 20:11:29.094: Fetch 65536
2019-01-29 20:11:29.107: Fetch 65536
2019-01-29 20:11:29.126: Fetch 65536
2019-01-29 20:11:29.144: Fetch 65536
2019-01-29 20:11:29.164: Fetch 65536
2019-01-29 20:11:29.182: Fetch 65536
2019-01-29 20:11:29.203: Fetch 65536
2019-01-29 20:11:29.217: Fetch 65536
2019-01-29 20:11:29.227: Fetch 65536
2019-01-29 20:11:29.242: Fetch 65536
2019-01-29 20:11:29.258: Fetch 65536
2019-01-29 20:11:29.291: Fetch 65536
2019-01-29 20:11:29.313: Fetch 65536
2019-01-29 20:11:29.334: Fetch 65536
2019-01-29 20:11:29.347: Fetch 65536
2019-01-29 20:11:29.358: Fetch 65536
2019-01-29 20:11:29.369: Fetch 65536
2019-01-29 20:11:29.383: Fetch 65536
2019-01-29 20:11:29.395: Fetch 65536
2019-01-29 20:11:29.411: Fetch 65536
2019-01-29 20:11:29.426: Fetch 65536
2019-01-29 20:11:29.444: Fetch 65536
2019-01-29 20:11:29.459: Fetch 65536
2019-01-29 20:11:29.478: Fetch 65536
2019-01-29 20:11:29.497: Fetch 65536
2019-01-29 20:11:29.521: Fetch 65536
2019-01-29 20:11:29.538: Fetch 65536
2019-01-29 20:11:29.552: Fetch 65536
2019-01-29 20:11:29.566: Fetch 65536
2019-01-29 20:11:29.581: Fetch 65536
2019-01-29 20:11:39.092: Fetch 65536
2019-01-29 20:11:39.122: Fetch 65536
2019-01-29 20:11:39.136: Fetch 65536
2019-01-29 20:11:39.150: Fetch 65536
2019-01-29 20:11:39.166: Fetch 65536
2019-01-29 20:11:39.184: Fetch 65536
2019-01-29 20:11:39.197: Fetch 65536
2019-01-29 20:11:39.216: Fetch 65536
2019-01-29 20:11:39.236: Fetch 65536
2019-01-29 20:11:39.254: Fetch 65536
2019-01-29 20:11:39.266: Fetch 65536
2019-01-29 20:11:39.280: Fetch 65536
2019-01-29 20:11:39.295: Fetch 65536
2019-01-29 20:11:39.316: Fetch 65536
2019-01-29 20:11:39.333: Fetch 65536
2019-01-29 20:11:39.348: Fetch 65536
2019-01-29 20:11:39.366: Fetch 65536
2019-01-29 20:11:39.380: Fetch 65536
2019-01-29 20:11:39.396: Fetch 65536
2019-01-29 20:11:39.412: Fetch 65536
2019-01-29 20:11:39.430: Fetch 65536
2019-01-29 20:11:39.455: Fetch 65536
2019-01-29 20:11:39.477: Fetch 65536
2019-01-29 20:11:39.493: Fetch 65536
2019-01-29 20:11:39.513: Fetch 65536
2019-01-29 20:11:39.528: Fetch 65536
2019-01-29 20:11:39.539: Fetch 65536
2019-01-29 20:11:39.552: Fetch 65536
2019-01-29 20:11:39.565: Fetch 65536
2019-01-29 20:11:39.577: Fetch 65536
2019-01-29 20:11:39.596: Fetch 65536
2019-01-29 20:11:39.612: Fetch 65536
2019-01-29 20:11:39.627: Fetch 65536
2019-01-29 20:11:39.644: Fetch 65536
2019-01-29 20:11:39.664: Fetch 65536
2019-01-29 20:11:39.681: Fetch 65536
2019-01-29 20:11:39.699: Fetch 65536
2019-01-29 20:11:39.717: Fetch 65536
2019-01-29 20:11:39.734: Fetch 65536
2019-01-29 20:11:39.746: Fetch 65536
2019-01-29 20:11:39.763: Fetch 65536
2019-01-29 20:11:39.778: Fetch 65536
2019-01-29 20:11:39.795: Fetch 65536
2019-01-29 20:11:39.812: Fetch 65536
2019-01-29 20:11:39.824: Fetch 65536
2019-01-29 20:11:39.838: Fetch 65536
2019-01-29 20:11:39.856: Fetch 65536
2019-01-29 20:11:39.873: Fetch 65536
2019-01-29 20:11:39.888: Fetch 65536
2019-01-29 20:11:39.902: Fetch 65536
2019-01-29 20:11:50.982: Fetch 65536
2019-01-29 20:11:51.001: Fetch 65536
2019-01-29 20:11:51.015: Fetch 65536
2019-01-29 20:11:51.027: Fetch 65536
2019-01-29 20:11:51.041: Fetch 65536
2019-01-29 20:11:51.056: Fetch 65536
2019-01-29 20:11:51.073: Fetch 65536
2019-01-29 20:11:51.102: Fetch 65536
2019-01-29 20:11:51.126: Fetch 65536
2019-01-29 20:11:51.151: Fetch 65536
2019-01-29 20:11:51.165: Fetch 65536
2019-01-29 20:11:51.182: Fetch 65536
2019-01-29 20:11:51.198: Fetch 65536
2019-01-29 20:11:51.214: Fetch 65536
2019-01-29 20:11:51.226: Fetch 65536
2019-01-29 20:11:51.237: Fetch 65536
2019-01-29 20:11:51.251: Fetch 65536
2019-01-29 20:11:51.267: Fetch 65536
2019-01-29 20:11:51.289: Fetch 65536
2019-01-29 20:11:51.308: Fetch 65536
2019-01-29 20:11:51.325: Fetch 65536
2019-01-29 20:11:51.346: Fetch 65536
2019-01-29 20:11:51.363: Fetch 65536
2019-01-29 20:11:51.376: Fetch 65536
2019-01-29 20:11:51.388: Fetch 65536
2019-01-29 20:11:51.400: Fetch 65536
2019-01-29 20:11:51.414: Fetch 65536
2019-01-29 20:11:51.426: Fetch 65536
2019-01-29 20:11:51.443: Fetch 65536
2019-01-29 20:11:51.460: Fetch 65536
2019-01-29 20:11:51.476: Fetch 65536
2019-01-29 20:11:51.496: Fetch 65536
2019-01-29 20:11:51.513: Fetch 65536
2019-01-29 20:11:51.527: Fetch 65536
2019-01-29 20:11:51.539: Fetch 65536
2019-01-29 20:11:51.553: Fetch 65536
2019-01-29 20:11:51.565: Fetch 65536
2019-01-29 20:11:51.578: Fetch 65536
2019-01-29 20:11:51.596: Fetch 65536
2019-01-29 20:11:51.615: Fetch 65536
2019-01-29 20:11:51.635: Fetch 65536
2019-01-29 20:11:51.654: Fetch 65536
2019-01-29 20:11:51.674: Fetch 65536
2019-01-29 20:11:51.686: Fetch 65536
2019-01-29 20:11:51.700: Fetch 65536
2019-01-29 20:11:51.712: Fetch 65536
2019-01-29 20:11:51.725: Fetch 65536
2019-01-29 20:11:51.739: Fetch 65536
2019-01-29 20:11:51.752: Fetch 65536
2019-01-29 20:12:04.336: Fetch 65536
2019-01-29 20:12:04.381: Fetch 65536
2019-01-29 20:12:04.414: Fetch 65536
2019-01-29 20:12:04.428: Fetch 65536
2019-01-29 20:12:04.440: Fetch 65536
2019-01-29 20:12:04.453: Fetch 65536
2019-01-29 20:12:04.467: Fetch 65536
2019-01-29 20:12:04.479: Fetch 65536
2019-01-29 20:12:04.493: Fetch 65536
2019-01-29 20:12:04.512: Fetch 65536
2019-01-29 20:12:04.528: Fetch 65536
2019-01-29 20:12:04.546: Fetch 65536
2019-01-29 20:12:04.561: Fetch 65536
2019-01-29 20:12:04.579: Fetch 65536
2019-01-29 20:12:04.595: Fetch 65536
2019-01-29 20:12:04.611: Fetch 65536
2019-01-29 20:12:04.627: Fetch 65536
2019-01-29 20:12:04.645: Fetch 65536
2019-01-29 20:12:04.658: Fetch 65536
2019-01-29 20:12:04.669: Fetch 65536
2019-01-29 20:12:04.683: Fetch 65536
2019-01-29 20:12:04.703: Fetch 65536
2019-01-29 20:12:04.722: Fetch 65536
2019-01-29 20:12:04.741: Fetch 65536
2019-01-29 20:12:04.753: Fetch 65536
2019-01-29 20:12:04.769: Fetch 65536
2019-01-29 20:12:04.783: Fetch 65536
2019-01-29 20:12:04.796: Fetch 65536
2019-01-29 20:12:04.809: Fetch 65536
2019-01-29 20:12:04.828: Fetch 65536
2019-01-29 20:12:04.852: Fetch 65536
2019-01-29 20:12:04.871: Fetch 65536
2019-01-29 20:12:04.892: Fetch 65536
2019-01-29 20:12:04.905: Fetch 65536
2019-01-29 20:12:04.918: Fetch 65536
2019-01-29 20:12:04.933: Fetch 65536
2019-01-29 20:12:04.947: Fetch 65536
2019-01-29 20:12:04.960: Fetch 65536
2019-01-29 20:12:04.974: Fetch 65536
2019-01-29 20:12:04.996: Fetch 65536
2019-01-29 20:12:05.009: Fetch 65536
2019-01-29 20:12:05.026: Fetch 65536
2019-01-29 20:12:05.042: Fetch 65536
2019-01-29 20:12:05.057: Fetch 65536
2019-01-29 20:12:05.071: Fetch 65536
2019-01-29 20:12:05.083: Fetch 65536
2019-01-29 20:12:05.095: Fetch 65536
2019-01-29 20:12:05.109: Fetch 65536
2019-01-29 20:12:05.126: Fetch 65536
2019-01-29 20:12:05.152: Fetch 65536
2019-01-29 20:12:05.166: Fetch 65536
2019-01-29 20:12:05.188: Fetch 65536
2019-01-29 20:12:05.203: Fetch 65536
2019-01-29 20:12:14.747: Fetch 65536
2019-01-29 20:12:14.774: Fetch 65536
2019-01-29 20:12:14.785: Fetch 65536
2019-01-29 20:12:14.798: Fetch 65536
2019-01-29 20:12:14.815: Fetch 65536
2019-01-29 20:12:14.833: Fetch 65536
2019-01-29 20:12:14.849: Fetch 65536
2019-01-29 20:12:14.867: Fetch 65536
2019-01-29 20:12:14.883: Fetch 65536
2019-01-29 20:12:14.898: Fetch 65536
2019-01-29 20:12:14.915: Fetch 65536
2019-01-29 20:12:14.934: Fetch 65536
2019-01-29 20:12:14.950: Fetch 65536
2019-01-29 20:12:14.966: Fetch 65536
2019-01-29 20:12:14.982: Fetch 65536
2019-01-29 20:12:14.995: Fetch 65536
2019-01-29 20:12:15.006: Fetch 65536
2019-01-29 20:12:15.024: Fetch 65536
2019-01-29 20:12:15.039: Fetch 65536
2019-01-29 20:12:15.056: Fetch 65536
2019-01-29 20:12:15.075: Fetch 65536
2019-01-29 20:12:15.096: Fetch 65536
2019-01-29 20:12:15.112: Fetch 65536
2019-01-29 20:12:15.127: Fetch 65536
2019-01-29 20:12:15.139: Fetch 65536
2019-01-29 20:12:15.152: Fetch 65536
2019-01-29 20:12:15.167: Fetch 65536
2019-01-29 20:12:15.188: Fetch 65536
2019-01-29 20:12:15.213: Fetch 65536
2019-01-29 20:12:15.227: Fetch 65536
2019-01-29 20:12:15.247: Fetch 65536
2019-01-29 20:12:15.262: Fetch 65536
2019-01-29 20:12:15.283: Fetch 65536
2019-01-29 20:12:15.303: Fetch 65536
2019-01-29 20:12:15.326: Fetch 65536
2019-01-29 20:12:15.347: Fetch 65536
2019-01-29 20:12:15.359: Fetch 65536
2019-01-29 20:12:15.371: Fetch 65536
2019-01-29 20:12:15.388: Fetch 65536
2019-01-29 20:12:15.410: Fetch 65536
2019-01-29 20:12:15.425: Fetch 65536
2019-01-29 20:12:15.446: Fetch 65536
2019-01-29 20:12:15.466: Fetch 65536
2019-01-29 20:12:15.481: Fetch 65536
2019-01-29 20:12:15.496: Fetch 65536
2019-01-29 20:12:15.510: Fetch 65536
2019-01-29 20:12:15.524: Fetch 65536
2019-01-29 20:12:15.538: Fetch 65536
2019-01-29 20:12:15.558: Fetch 65536
2019-01-29 20:12:15.580: Fetch 65536
2019-01-29 20:12:15.597: Fetch 65536
2019-01-29 20:12:15.611: Fetch 65536
2019-01-29 20:12:15.625: Fetch 65536
2019-01-29 20:12:15.640: Fetch 65536
2019-01-29 20:12:28.119: Fetch 65536
2019-01-29 20:12:28.143: Fetch 65536
2019-01-29 20:12:28.157: Fetch 65536
2019-01-29 20:12:28.170: Fetch 65536
2019-01-29 20:12:28.184: Fetch 65536
2019-01-29 20:12:28.197: Fetch 65536
2019-01-29 20:12:28.211: Fetch 65536
2019-01-29 20:12:28.228: Fetch 65536
2019-01-29 20:12:28.244: Fetch 65536
2019-01-29 20:12:28.259: Fetch 65536
2019-01-29 20:12:28.277: Fetch 65536
2019-01-29 20:12:28.297: Fetch 65536
2019-01-29 20:12:28.314: Fetch 65536
2019-01-29 20:12:28.328: Fetch 65536
2019-01-29 20:12:28.345: Fetch 65536
2019-01-29 20:12:28.361: Fetch 65536
2019-01-29 20:12:28.376: Fetch 65536
2019-01-29 20:12:28.395: Fetch 65536
2019-01-29 20:12:28.409: Fetch 65536
2019-01-29 20:12:28.421: Fetch 65536
2019-01-29 20:12:28.441: Fetch 65536
2019-01-29 20:12:28.455: Fetch 65536
2019-01-29 20:12:28.477: Fetch 65536
2019-01-29 20:12:28.493: Fetch 65536
2019-01-29 20:12:28.504: Fetch 65536
2019-01-29 20:12:28.517: Fetch 65536
2019-01-29 20:12:28.530: Fetch 65536
2019-01-29 20:12:28.543: Fetch 65536
2019-01-29 20:12:28.561: Fetch 65536
2019-01-29 20:12:28.577: Fetch 65536
2019-01-29 20:12:28.595: Fetch 65536
2019-01-29 20:12:28.612: Fetch 65536
2019-01-29 20:12:28.628: Fetch 65536
2019-01-29 20:12:28.646: Fetch 65536
2019-01-29 20:12:28.665: Fetch 65536
2019-01-29 20:12:28.686: Fetch 65536
2019-01-29 20:12:28.700: Fetch 65536
2019-01-29 20:12:28.712: Fetch 65536
2019-01-29 20:12:28.726: Fetch 65536
2019-01-29 20:12:28.739: Fetch 65536
2019-01-29 20:12:28.756: Fetch 65536
2019-01-29 20:12:28.780: Fetch 65536
2019-01-29 20:12:28.800: Fetch 65536
2019-01-29 20:12:28.817: Fetch 65536
2019-01-29 20:12:28.828: Fetch 65536
2019-01-29 20:12:28.840: Fetch 65536
2019-01-29 20:12:28.854: Fetch 65536
2019-01-29 20:12:28.872: Fetch 65536
2019-01-29 20:12:28.890: Fetch 65536
2019-01-29 20:12:28.902: Fetch 65536
2019-01-29 20:12:28.919: Fetch 65536
2019-01-29 20:12:28.933: Fetch 65536
2019-01-29 20:12:28.949: Fetch 65536
2019-01-29 20:12:28.971: Fetch 65536
2019-01-29 20:12:38.514: Fetch 65536
2019-01-29 20:12:38.535: Fetch 65536
2019-01-29 20:12:38.546: Fetch 65536
2019-01-29 20:12:38.559: Fetch 65536
2019-01-29 20:12:38.575: Fetch 65536
2019-01-29 20:12:38.589: Fetch 65536
2019-01-29 20:12:38.606: Fetch 65536
2019-01-29 20:12:38.617: Fetch 65536
2019-01-29 20:12:38.628: Fetch 65536
2019-01-29 20:12:38.643: Fetch 65536
2019-01-29 20:12:38.660: Fetch 65536
2019-01-29 20:12:38.674: Fetch 65536
2019-01-29 20:12:38.687: Fetch 65536
2019-01-29 20:12:38.699: Fetch 65536
2019-01-29 20:12:38.713: Fetch 65536
2019-01-29 20:12:38.725: Fetch 65536
2019-01-29 20:12:38.741: Fetch 65536
2019-01-29 20:12:38.765: Fetch 65536
2019-01-29 20:12:38.786: Fetch 65536
2019-01-29 20:12:38.810: Fetch 65536
2019-01-29 20:12:38.830: Fetch 65536
2019-01-29 20:12:38.843: Fetch 65536
2019-01-29 20:12:38.859: Fetch 65536
2019-01-29 20:12:38.887: Fetch 65536
2019-01-29 20:12:38.907: Fetch 65536
2019-01-29 20:12:38.927: Fetch 65536
2019-01-29 20:12:38.949: Fetch 65536
2019-01-29 20:12:38.963: Fetch 65536
2019-01-29 20:12:38.977: Fetch 65536
2019-01-29 20:12:38.991: Fetch 65536
2019-01-29 20:12:39.002: Fetch 65536
2019-01-29 20:12:39.016: Fetch 65536
2019-01-29 20:12:39.029: Fetch 65536
2019-01-29 20:12:39.042: Fetch 65536
2019-01-29 20:12:39.066: Fetch 65536
2019-01-29 20:12:39.078: Fetch 65536
2019-01-29 20:12:39.093: Fetch 65536
2019-01-29 20:12:39.107: Fetch 65536
2019-01-29 20:12:39.122: Fetch 65536
2019-01-29 20:12:39.136: Fetch 65536
2019-01-29 20:12:39.152: Fetch 65536
2019-01-29 20:12:39.170: Fetch 65536
2019-01-29 20:12:39.188: Fetch 65536
2019-01-29 20:12:39.218: Fetch 65536
2019-01-29 20:12:39.237: Fetch 65536
2019-01-29 20:12:39.256: Fetch 65536
2019-01-29 20:12:39.275: Fetch 65536
2019-01-29 20:12:39.287: Fetch 65536
2019-01-29 20:12:39.300: Fetch 65536
2019-01-29 20:12:39.313: Fetch 65536
2019-01-29 20:12:39.329: Fetch 65536
2019-01-29 20:12:39.350: Fetch 65536
2019-01-29 20:12:39.382: Fetch 65536
2019-01-29 20:12:39.396: Fetch 65536
2019-01-29 20:12:39.410: Fetch 65536
2019-01-29 20:12:39.428: Fetch 65536
2019-01-29 20:12:51.872: Fetch 65536
2019-01-29 20:12:51.883: Fetch 65536
2019-01-29 20:12:51.897: Fetch 65536
2019-01-29 20:12:51.911: Fetch 65536
2019-01-29 20:12:51.931: Fetch 65536
2019-01-29 20:12:51.952: Fetch 65536
2019-01-29 20:12:51.973: Fetch 65536
2019-01-29 20:12:51.988: Fetch 65536
2019-01-29 20:12:52.004: Fetch 65536
2019-01-29 20:12:52.019: Fetch 65536
2019-01-29 20:12:52.033: Fetch 65536
2019-01-29 20:12:52.047: Fetch 65536
2019-01-29 20:12:52.071: Fetch 65536
2019-01-29 20:12:52.095: Fetch 65536
2019-01-29 20:12:52.113: Fetch 65536
2019-01-29 20:12:52.130: Fetch 65536
2019-01-29 20:12:52.148: Fetch 65536
2019-01-29 20:12:52.169: Fetch 65536
2019-01-29 20:12:52.183: Fetch 65536
2019-01-29 20:12:52.200: Fetch 65536
2019-01-29 20:12:52.213: Fetch 65536
2019-01-29 20:12:52.227: Fetch 65536
2019-01-29 20:12:52.246: Fetch 65536
2019-01-29 20:12:52.262: Fetch 65536
2019-01-29 20:12:52.280: Fetch 65536
2019-01-29 20:12:52.298: Fetch 65536
2019-01-29 20:12:52.316: Fetch 65536
2019-01-29 20:12:52.335: Fetch 65536
2019-01-29 20:12:52.351: Fetch 65536
2019-01-29 20:12:52.368: Fetch 65536
2019-01-29 20:12:52.386: Fetch 65536
2019-01-29 20:12:52.404: Fetch 65536
2019-01-29 20:12:52.417: Fetch 65536
2019-01-29 20:12:52.437: Fetch 65536
2019-01-29 20:12:52.455: Fetch 65536
2019-01-29 20:12:52.472: Fetch 65536
2019-01-29 20:12:52.493: Fetch 65536
2019-01-29 20:12:52.510: Fetch 65536
2019-01-29 20:12:52.525: Fetch 65536
2019-01-29 20:12:52.539: Fetch 65536
2019-01-29 20:12:52.556: Fetch 65536
2019-01-29 20:12:52.570: Fetch 65536
2019-01-29 20:12:52.586: Fetch 65536
2019-01-29 20:12:52.602: Fetch 65536
2019-01-29 20:12:52.622: Fetch 65536
2019-01-29 20:12:52.639: Fetch 65536
2019-01-29 20:12:52.658: Fetch 65536
2019-01-29 20:12:52.675: Fetch 65536
2019-01-29 20:12:52.689: Fetch 65536
2019-01-29 20:12:52.706: Fetch 65536
2019-01-29 20:12:52.723: Fetch 65536
2019-01-29 20:12:52.747: Fetch 65536
2019-01-29 20:12:52.761: Fetch 65536
2019-01-29 20:12:52.777: Fetch 65536
2019-01-29 20:12:52.793: Fetch 65536
2019-01-29 20:12:52.809: Fetch 65536
2019-01-29 20:12:52.823: Fetch 65536
2019-01-29 20:12:52.836: Fetch 65536
2019-01-29 20:12:52.855: Fetch 65536
2019-01-29 20:12:52.871: Fetch 65536
2019-01-29 20:12:52.891: Fetch 65536
2019-01-29 20:13:02.300: Fetch 65536
2019-01-29 20:13:02.355: Fetch 65536
2019-01-29 20:13:02.394: Fetch 65536
2019-01-29 20:13:02.407: Fetch 65536
2019-01-29 20:13:02.421: Fetch 65536
2019-01-29 20:13:02.434: Fetch 65536
2019-01-29 20:13:02.448: Fetch 65536
2019-01-29 20:13:02.461: Fetch 65536
2019-01-29 20:13:02.481: Fetch 65536
2019-01-29 20:13:02.497: Fetch 65536
2019-01-29 20:13:02.513: Fetch 65536
2019-01-29 20:13:02.529: Fetch 65536
2019-01-29 20:13:02.548: Fetch 65536
2019-01-29 20:13:02.565: Fetch 65536
2019-01-29 20:13:02.581: Fetch 65536
2019-01-29 20:13:02.594: Fetch 65536
2019-01-29 20:13:02.606: Fetch 65536
2019-01-29 20:13:02.617: Fetch 65536
2019-01-29 20:13:02.630: Fetch 65536
2019-01-29 20:13:02.644: Fetch 65536
2019-01-29 20:13:02.663: Fetch 65536
2019-01-29 20:13:02.691: Fetch 65536
2019-01-29 20:13:02.711: Fetch 65536
2019-01-29 20:13:02.723: Fetch 65536
2019-01-29 20:13:02.739: Fetch 65536
2019-01-29 20:13:02.753: Fetch 65536
2019-01-29 20:13:02.768: Fetch 65536
2019-01-29 20:13:02.778: Fetch 65536
2019-01-29 20:13:02.791: Fetch 65536
2019-01-29 20:13:02.802: Fetch 65536
2019-01-29 20:13:02.814: Fetch 65536
2019-01-29 20:13:02.828: Fetch 65536
2019-01-29 20:13:02.845: Fetch 65536
2019-01-29 20:13:02.862: Fetch 65536
2019-01-29 20:13:02.879: Fetch 65536
2019-01-29 20:13:02.897: Fetch 65536
2019-01-29 20:13:02.914: Fetch 65536
2019-01-29 20:13:02.929: Fetch 65536
2019-01-29 20:13:02.944: Fetch 65536
2019-01-29 20:13:02.957: Fetch 65536
2019-01-29 20:13:02.972: Fetch 65536
2019-01-29 20:13:02.991: Fetch 65536
2019-01-29 20:13:03.021: Fetch 65536
2019-01-29 20:13:03.041: Fetch 65536
2019-01-29 20:13:03.055: Fetch 65536
2019-01-29 20:13:03.073: Fetch 65536
2019-01-29 20:13:03.090: Fetch 65536
2019-01-29 20:13:03.103: Fetch 65536
2019-01-29 20:13:03.115: Fetch 65536
2019-01-29 20:13:03.129: Fetch 65536
2019-01-29 20:13:03.144: Fetch 65536
2019-01-29 20:13:03.157: Fetch 65536
2019-01-29 20:13:03.169: Fetch 65536
2019-01-29 20:13:03.185: Fetch 65536
2019-01-29 20:13:03.202: Fetch 65536
2019-01-29 20:13:03.222: Fetch 65536
2019-01-29 20:13:03.239: Fetch 65536
2019-01-29 20:13:03.257: Fetch 65536
2019-01-29 20:13:03.270: Fetch 65536
2019-01-29 20:13:03.283: Fetch 65536
2019-01-29 20:13:03.294: Fetch 65536
2019-01-29 20:13:03.306: Fetch 65536
2019-01-29 20:13:14.204: Fetch 65536
2019-01-29 20:13:14.223: Fetch 65536
2019-01-29 20:13:14.238: Fetch 65536
2019-01-29 20:13:14.252: Fetch 65536
2019-01-29 20:13:14.264: Fetch 65536
2019-01-29 20:13:14.281: Fetch 65536
2019-01-29 20:13:14.298: Fetch 65536
2019-01-29 20:13:14.324: Fetch 65536
2019-01-29 20:13:14.344: Fetch 65536
2019-01-29 20:13:14.361: Fetch 65536
2019-01-29 20:13:14.374: Fetch 65536
2019-01-29 20:13:14.393: Fetch 65536
2019-01-29 20:13:14.408: Fetch 65536
2019-01-29 20:13:14.419: Fetch 65536
2019-01-29 20:13:14.432: Fetch 65536
2019-01-29 20:13:14.444: Fetch 65536
2019-01-29 20:13:14.458: Fetch 65536
2019-01-29 20:13:14.473: Fetch 65536
2019-01-29 20:13:14.488: Fetch 65536
2019-01-29 20:13:14.510: Fetch 65536
2019-01-29 20:13:14.528: Fetch 65536
2019-01-29 20:13:14.544: Fetch 65536
2019-01-29 20:13:14.558: Fetch 65536
2019-01-29 20:13:14.573: Fetch 65536
2019-01-29 20:13:14.587: Fetch 65536
2019-01-29 20:13:14.601: Fetch 65536
2019-01-29 20:13:14.613: Fetch 65536
2019-01-29 20:13:14.626: Fetch 65536
2019-01-29 20:13:14.643: Fetch 65536
2019-01-29 20:13:14.673: Fetch 65536
2019-01-29 20:13:14.685: Fetch 65536
2019-01-29 20:13:14.701: Fetch 65536
2019-01-29 20:13:14.722: Fetch 65536
2019-01-29 20:13:14.738: Fetch 65536
2019-01-29 20:13:14.754: Fetch 65536
2019-01-29 20:13:14.766: Fetch 65536
2019-01-29 20:13:14.781: Fetch 65536
2019-01-29 20:13:14.795: Fetch 65536
2019-01-29 20:13:14.807: Fetch 65536
2019-01-29 20:13:14.823: Fetch 65536
2019-01-29 20:13:14.841: Fetch 65536
2019-01-29 20:13:14.857: Fetch 65536
2019-01-29 20:13:14.879: Fetch 65536
2019-01-29 20:13:14.898: Fetch 65536
2019-01-29 20:13:14.914: Fetch 65536
2019-01-29 20:13:14.935: Fetch 65536
2019-01-29 20:13:14.949: Fetch 65536
2019-01-29 20:13:14.966: Fetch 65536
2019-01-29 20:13:14.985: Fetch 65536
2019-01-29 20:13:15.004: Fetch 65536
2019-01-29 20:13:15.020: Fetch 65536
2019-01-29 20:13:15.033: Fetch 65536
2019-01-29 20:13:15.048: Fetch 65536
2019-01-29 20:13:15.063: Fetch 65536
2019-01-29 20:13:15.079: Fetch 65536
2019-01-29 20:13:15.094: Fetch 65536
2019-01-29 20:13:15.111: Fetch 65536
2019-01-29 20:13:15.129: Fetch 65536
2019-01-29 20:13:15.156: Fetch 65536
2019-01-29 20:13:15.184: Fetch 65536
2019-01-29 20:13:27.567: Fetch 65536
2019-01-29 20:13:27.583: Fetch 65536
2019-01-29 20:13:27.597: Fetch 65536
2019-01-29 20:13:27.611: Fetch 65536
2019-01-29 20:13:27.625: Fetch 65536
2019-01-29 20:13:27.648: Fetch 65536
2019-01-29 20:13:27.665: Fetch 65536
2019-01-29 20:13:27.683: Fetch 65536
2019-01-29 20:13:27.697: Fetch 65536
2019-01-29 20:13:27.712: Fetch 65536
2019-01-29 20:13:27.726: Fetch 65536
2019-01-29 20:13:27.737: Fetch 65536
2019-01-29 20:13:27.749: Fetch 65536
2019-01-29 20:13:27.766: Fetch 65536
2019-01-29 20:13:27.783: Fetch 65536
2019-01-29 20:13:27.798: Fetch 65536
2019-01-29 20:13:27.813: Fetch 65536
2019-01-29 20:13:27.834: Fetch 65536
2019-01-29 20:13:27.851: Fetch 65536
2019-01-29 20:13:27.868: Fetch 65536
2019-01-29 20:13:27.886: Fetch 65536
2019-01-29 20:13:27.907: Fetch 65536
2019-01-29 20:13:27.926: Fetch 65536
2019-01-29 20:13:27.939: Fetch 65536
2019-01-29 20:13:27.955: Fetch 65536
2019-01-29 20:13:27.975: Fetch 65536
2019-01-29 20:13:27.991: Fetch 65536
2019-01-29 20:13:28.006: Fetch 65536
2019-01-29 20:13:28.022: Fetch 65536
2019-01-29 20:13:28.044: Fetch 65536
2019-01-29 20:13:28.057: Fetch 65536
2019-01-29 20:13:28.068: Fetch 65536
2019-01-29 20:13:28.081: Fetch 65536
2019-01-29 20:13:28.098: Fetch 65536
2019-01-29 20:13:28.117: Fetch 65536
2019-01-29 20:13:28.131: Fetch 65536
2019-01-29 20:13:28.145: Fetch 65536
2019-01-29 20:13:28.164: Fetch 65536
2019-01-29 20:13:28.186: Fetch 65536
2019-01-29 20:13:28.200: Fetch 65536
2019-01-29 20:13:28.215: Fetch 65536
2019-01-29 20:13:28.230: Fetch 65536
2019-01-29 20:13:28.251: Fetch 65536
2019-01-29 20:13:28.266: Fetch 65536
2019-01-29 20:13:28.280: Fetch 65536
2019-01-29 20:13:28.293: Fetch 65536
2019-01-29 20:13:28.307: Fetch 65536
2019-01-29 20:13:28.321: Fetch 65536
2019-01-29 20:13:28.337: Fetch 65536
2019-01-29 20:13:28.351: Fetch 65536
2019-01-29 20:13:28.377: Fetch 65536
2019-01-29 20:13:28.407: Fetch 65536
2019-01-29 20:13:28.431: Fetch 65536
2019-01-29 20:13:28.443: Fetch 65536
2019-01-29 20:13:28.455: Fetch 65536
2019-01-29 20:13:28.468: Fetch 65536
2019-01-29 20:13:28.487: Fetch 65536
2019-01-29 20:13:28.510: Fetch 65536
2019-01-29 20:13:28.527: Fetch 65536
2019-01-29 20:13:28.542: Fetch 65536
2019-01-29 20:13:28.556: Fetch 65536
2019-01-29 20:13:28.570: Fetch 65536
2019-01-29 20:13:28.586: Fetch 65536
2019-01-29 20:13:28.605: Fetch 65536
2019-01-29 20:13:37.952: Fetch 65536
2019-01-29 20:13:37.976: Fetch 65536
2019-01-29 20:13:37.987: Fetch 65536
2019-01-29 20:13:38.000: Fetch 65536
2019-01-29 20:13:38.012: Fetch 65536
2019-01-29 20:13:38.030: Fetch 65536
2019-01-29 20:13:38.043: Fetch 65536
2019-01-29 20:13:38.063: Fetch 65536
2019-01-29 20:13:38.081: Fetch 65536
2019-01-29 20:13:38.095: Fetch 65536
2019-01-29 20:13:38.109: Fetch 65536
2019-01-29 20:13:38.124: Fetch 65536
2019-01-29 20:13:38.143: Fetch 65536
2019-01-29 20:13:38.160: Fetch 65536
2019-01-29 20:13:38.172: Fetch 65536
2019-01-29 20:13:38.185: Fetch 65536
2019-01-29 20:13:38.202: Fetch 65536
2019-01-29 20:13:38.221: Fetch 65536
2019-01-29 20:13:38.243: Fetch 65536
2019-01-29 20:13:38.263: Fetch 65536
2019-01-29 20:13:38.280: Fetch 65536
2019-01-29 20:13:38.296: Fetch 65536
2019-01-29 20:13:38.310: Fetch 65536
2019-01-29 20:13:38.323: Fetch 65536
2019-01-29 20:13:38.336: Fetch 65536
2019-01-29 20:13:38.349: Fetch 65536
2019-01-29 20:13:38.361: Fetch 65536
2019-01-29 20:13:38.373: Fetch 65536
2019-01-29 20:13:38.384: Fetch 65536
2019-01-29 20:13:38.399: Fetch 65536
2019-01-29 20:13:38.412: Fetch 65536
2019-01-29 20:13:38.430: Fetch 65536
2019-01-29 20:13:38.451: Fetch 65536
2019-01-29 20:13:38.468: Fetch 65536
2019-01-29 20:13:38.488: Fetch 65536
2019-01-29 20:13:38.500: Fetch 65536
2019-01-29 20:13:38.512: Fetch 65536
2019-01-29 20:13:38.526: Fetch 65536
2019-01-29 20:13:38.540: Fetch 65536
2019-01-29 20:13:38.556: Fetch 65536
2019-01-29 20:13:38.577: Fetch 65536
2019-01-29 20:13:38.600: Fetch 65536
2019-01-29 20:13:38.624: Fetch 65536
2019-01-29 20:13:38.639: Fetch 65536
2019-01-29 20:13:38.658: Fetch 65536
2019-01-29 20:13:38.672: Fetch 65536
2019-01-29 20:13:38.686: Fetch 65536
2019-01-29 20:13:38.697: Fetch 65536
2019-01-29 20:13:38.712: Fetch 65536
2019-01-29 20:13:38.725: Fetch 65536
2019-01-29 20:13:38.737: Fetch 65536
2019-01-29 20:13:38.750: Fetch 65536
2019-01-29 20:13:38.769: Fetch 65536
2019-01-29 20:13:38.786: Fetch 65536
2019-01-29 20:13:38.807: Fetch 65536
2019-01-29 20:13:38.823: Fetch 65536
2019-01-29 20:13:38.836: Fetch 65536
2019-01-29 20:13:38.847: Fetch 65536
2019-01-29 20:13:38.863: Fetch 65536
2019-01-29 20:13:38.878: Fetch 65536
2019-01-29 20:13:38.899: Fetch 65536
2019-01-29 20:13:38.917: Fetch 65536
2019-01-29 20:13:38.931: Fetch 65536
2019-01-29 20:13:51.320: Fetch 65536
2019-01-29 20:13:51.335: Fetch 65536
2019-01-29 20:13:51.350: Fetch 65536
2019-01-29 20:13:51.373: Fetch 65536
2019-01-29 20:13:51.393: Fetch 65536
2019-01-29 20:13:51.427: Fetch 65536
2019-01-29 20:13:51.453: Fetch 65536
2019-01-29 20:13:51.465: Fetch 65536
2019-01-29 20:13:51.480: Fetch 65536
2019-01-29 20:13:51.495: Fetch 65536
2019-01-29 20:13:51.508: Fetch 65536
2019-01-29 20:13:51.522: Fetch 65536
2019-01-29 20:13:51.537: Fetch 65536
2019-01-29 20:13:51.553: Fetch 65536
2019-01-29 20:13:51.572: Fetch 65536
2019-01-29 20:13:51.591: Fetch 65536
2019-01-29 20:13:51.616: Fetch 65536
2019-01-29 20:13:51.630: Fetch 65536
2019-01-29 20:13:51.651: Fetch 65536
2019-01-29 20:13:51.665: Fetch 65536
2019-01-29 20:13:51.680: Fetch 65536
2019-01-29 20:13:51.696: Fetch 65536
2019-01-29 20:13:51.709: Fetch 65536
2019-01-29 20:13:51.722: Fetch 65536
2019-01-29 20:13:51.736: Fetch 65536
2019-01-29 20:13:51.748: Fetch 65536
2019-01-29 20:13:51.760: Fetch 65536
2019-01-29 20:13:51.782: Fetch 65536
2019-01-29 20:13:51.798: Fetch 65536
2019-01-29 20:13:51.818: Fetch 65536
2019-01-29 20:13:51.832: Fetch 65536
2019-01-29 20:13:51.846: Fetch 65536
2019-01-29 20:13:51.860: Fetch 65536
2019-01-29 20:13:51.873: Fetch 65536
2019-01-29 20:13:51.888: Fetch 65536
2019-01-29 20:13:51.906: Fetch 65536
2019-01-29 20:13:51.929: Fetch 65536
2019-01-29 20:13:51.953: Fetch 65536
2019-01-29 20:13:51.982: Fetch 65536
2019-01-29 20:13:51.998: Fetch 65536
2019-01-29 20:13:52.010: Fetch 65536
2019-01-29 20:13:52.024: Fetch 65536
2019-01-29 20:13:52.037: Fetch 65536
2019-01-29 20:13:52.052: Fetch 65536
2019-01-29 20:13:52.065: Fetch 65536
2019-01-29 20:13:52.084: Fetch 65536
2019-01-29 20:13:52.104: Fetch 65536
2019-01-29 20:13:52.123: Fetch 65536
2019-01-29 20:13:52.139: Fetch 65536
2019-01-29 20:13:52.152: Fetch 65536
2019-01-29 20:13:52.167: Fetch 65536
2019-01-29 20:13:52.180: Fetch 65536
2019-01-29 20:13:52.195: Fetch 65536
2019-01-29 20:13:52.208: Fetch 65536
2019-01-29 20:13:52.227: Fetch 65536
2019-01-29 20:13:52.240: Fetch 65536
2019-01-29 20:13:52.254: Fetch 65536
2019-01-29 20:13:52.272: Fetch 65536
2019-01-29 20:13:52.289: Fetch 65536
2019-01-29 20:14:01.743: Fetch 65536
2019-01-29 20:14:01.759: Fetch 65536
2019-01-29 20:14:01.771: Fetch 65536
2019-01-29 20:14:01.783: Fetch 65536
2019-01-29 20:14:01.797: Fetch 65536
2019-01-29 20:14:01.812: Fetch 65536
2019-01-29 20:14:01.828: Fetch 65536
2019-01-29 20:14:01.849: Fetch 65536
2019-01-29 20:14:01.862: Fetch 65536
2019-01-29 20:14:01.877: Fetch 65536
2019-01-29 20:14:01.893: Fetch 65536
2019-01-29 20:14:01.905: Fetch 65536
2019-01-29 20:14:01.921: Fetch 65536
2019-01-29 20:14:01.938: Fetch 65536
2019-01-29 20:14:01.956: Fetch 65536
2019-01-29 20:14:01.970: Fetch 65536
2019-01-29 20:14:01.984: Fetch 65536
2019-01-29 20:14:01.998: Fetch 65536
2019-01-29 20:14:02.011: Fetch 65536
2019-01-29 20:14:02.023: Fetch 65536
2019-01-29 20:14:02.035: Fetch 65536
2019-01-29 20:14:02.051: Fetch 65536
2019-01-29 20:14:02.073: Fetch 65536
2019-01-29 20:14:02.091: Fetch 65536
2019-01-29 20:14:02.108: Fetch 65536
2019-01-29 20:14:02.123: Fetch 65536
2019-01-29 20:14:02.136: Fetch 65536
2019-01-29 20:14:02.148: Fetch 65536
2019-01-29 20:14:02.159: Fetch 65536
2019-01-29 20:14:02.171: Fetch 65536
2019-01-29 20:14:02.183: Fetch 65536
2019-01-29 20:14:02.195: Fetch 65536
2019-01-29 20:14:02.211: Fetch 65536
2019-01-29 20:14:02.228: Fetch 65536
2019-01-29 20:14:02.245: Fetch 65536
2019-01-29 20:14:02.260: Fetch 65536
2019-01-29 20:14:02.273: Fetch 65536
2019-01-29 20:14:02.287: Fetch 65536
2019-01-29 20:14:02.299: Fetch 65536
2019-01-29 20:14:02.314: Fetch 65536
2019-01-29 20:14:02.326: Fetch 65536
2019-01-29 20:14:02.337: Fetch 65536
2019-01-29 20:14:02.349: Fetch 65536
2019-01-29 20:14:02.362: Fetch 65536
2019-01-29 20:14:02.381: Fetch 65536
2019-01-29 20:14:02.396: Fetch 65536
2019-01-29 20:14:02.415: Fetch 65536
2019-01-29 20:14:02.433: Fetch 65536
2019-01-29 20:14:02.447: Fetch 65536
2019-01-29 20:14:02.463: Fetch 65536
2019-01-29 20:14:02.476: Fetch 65536
2019-01-29 20:14:02.488: Fetch 65536
2019-01-29 20:14:02.506: Fetch 65536
2019-01-29 20:14:02.523: Fetch 65536
2019-01-29 20:14:02.549: Fetch 65536
2019-01-29 20:14:02.567: Fetch 65536
2019-01-29 20:14:02.584: Fetch 65536
2019-01-29 20:14:15.098: Fetch 65536
2019-01-29 20:14:15.136: Fetch 65536
2019-01-29 20:14:15.172: Fetch 65536
2019-01-29 20:14:15.185: Fetch 65536
2019-01-29 20:14:15.200: Fetch 65536
2019-01-29 20:14:15.215: Fetch 65536
2019-01-29 20:14:15.230: Fetch 65536
2019-01-29 20:14:15.240: Fetch 65536
2019-01-29 20:14:15.253: Fetch 65536
2019-01-29 20:14:15.271: Fetch 65536
2019-01-29 20:14:15.285: Fetch 65536
2019-01-29 20:14:15.303: Fetch 65536
2019-01-29 20:14:15.323: Fetch 65536
2019-01-29 20:14:15.345: Fetch 65536
2019-01-29 20:14:15.365: Fetch 65536
2019-01-29 20:14:15.376: Fetch 65536
2019-01-29 20:14:15.387: Fetch 65536
2019-01-29 20:14:15.398: Fetch 65536
2019-01-29 20:14:15.413: Fetch 65536
2019-01-29 20:14:15.433: Fetch 65536
2019-01-29 20:14:15.450: Fetch 65536
2019-01-29 20:14:15.466: Fetch 65536
2019-01-29 20:14:15.482: Fetch 65536
2019-01-29 20:14:15.500: Fetch 65536
2019-01-29 20:14:15.513: Fetch 65536
2019-01-29 20:14:15.527: Fetch 65536
2019-01-29 20:14:15.539: Fetch 65536
2019-01-29 20:14:15.553: Fetch 65536
2019-01-29 20:14:15.565: Fetch 65536
2019-01-29 20:14:15.577: Fetch 65536
2019-01-29 20:14:15.590: Fetch 65536
2019-01-29 20:14:15.603: Fetch 65536
2019-01-29 20:14:15.617: Fetch 65536
2019-01-29 20:14:15.637: Fetch 65536
2019-01-29 20:14:15.668: Fetch 65536
2019-01-29 20:14:15.689: Fetch 65536
2019-01-29 20:14:15.701: Fetch 65536
2019-01-29 20:14:15.717: Fetch 65536
2019-01-29 20:14:15.733: Fetch 65536
2019-01-29 20:14:15.750: Fetch 65536
2019-01-29 20:14:15.761: Fetch 65536
2019-01-29 20:14:15.775: Fetch 65536
2019-01-29 20:14:15.790: Fetch 65536
2019-01-29 20:14:15.811: Fetch 65536
2019-01-29 20:14:15.835: Fetch 65536
2019-01-29 20:14:15.849: Fetch 65536
2019-01-29 20:14:15.864: Fetch 65536
2019-01-29 20:14:15.877: Fetch 65536
2019-01-29 20:14:15.891: Fetch 65536
2019-01-29 20:14:15.903: Fetch 65536
2019-01-29 20:14:15.917: Fetch 65536
2019-01-29 20:14:15.929: Fetch 65536
2019-01-29 20:14:15.943: Fetch 65536
2019-01-29 20:14:25.520: Fetch 65536
2019-01-29 20:14:25.558: Fetch 65536
2019-01-29 20:14:25.573: Fetch 65536
2019-01-29 20:14:25.593: Fetch 65536
2019-01-29 20:14:25.609: Fetch 65536
2019-01-29 20:14:25.622: Fetch 65536
2019-01-29 20:14:25.636: Fetch 65536
2019-01-29 20:14:25.665: Fetch 65536
2019-01-29 20:14:25.686: Fetch 65536
2019-01-29 20:14:25.704: Fetch 65536
2019-01-29 20:14:25.717: Fetch 65536
2019-01-29 20:14:25.730: Fetch 65536
2019-01-29 20:14:25.748: Fetch 65536
2019-01-29 20:14:25.763: Fetch 65536
2019-01-29 20:14:25.782: Fetch 65536
2019-01-29 20:14:25.800: Fetch 65536
2019-01-29 20:14:25.815: Fetch 65536
2019-01-29 20:14:25.832: Fetch 65536
2019-01-29 20:14:25.846: Fetch 65536
2019-01-29 20:14:25.859: Fetch 65536
2019-01-29 20:14:25.873: Fetch 65536
2019-01-29 20:14:25.887: Fetch 65536
2019-01-29 20:14:25.898: Fetch 65536
2019-01-29 20:14:25.913: Fetch 65536
2019-01-29 20:14:25.931: Fetch 65536
2019-01-29 20:14:25.951: Fetch 65536
2019-01-29 20:14:25.971: Fetch 65536
2019-01-29 20:14:25.991: Fetch 65536
2019-01-29 20:14:26.009: Fetch 65536
2019-01-29 20:14:26.028: Fetch 65536
2019-01-29 20:14:26.049: Fetch 65536
2019-01-29 20:14:26.062: Fetch 65536
2019-01-29 20:14:26.074: Fetch 65536
2019-01-29 20:14:26.087: Fetch 65536
2019-01-29 20:14:26.100: Fetch 65536
2019-01-29 20:14:26.123: Fetch 65536
2019-01-29 20:14:26.144: Fetch 65536
2019-01-29 20:14:26.160: Fetch 65536
2019-01-29 20:14:26.185: Fetch 65536
2019-01-29 20:14:26.204: Fetch 65536
2019-01-29 20:14:26.221: Fetch 65536
2019-01-29 20:14:26.236: Fetch 65536
2019-01-29 20:14:26.247: Fetch 65536
2019-01-29 20:14:26.260: Fetch 65536
2019-01-29 20:14:26.275: Fetch 65536
2019-01-29 20:14:26.289: Fetch 65536
2019-01-29 20:14:26.308: Fetch 65536
2019-01-29 20:14:26.326: Fetch 65536
2019-01-29 20:14:26.347: Fetch 65536
2019-01-29 20:14:26.367: Fetch 65536
2019-01-29 20:14:26.390: Fetch 65536
2019-01-29 20:14:37.424: Fetch 65536
2019-01-29 20:14:37.447: Fetch 65536
2019-01-29 20:14:37.462: Fetch 65536
2019-01-29 20:14:37.478: Fetch 65536
2019-01-29 20:14:37.496: Fetch 65536
2019-01-29 20:14:37.511: Fetch 65536
2019-01-29 20:14:37.525: Fetch 65536
2019-01-29 20:14:37.544: Fetch 65536
2019-01-29 20:14:37.560: Fetch 65536
2019-01-29 20:14:37.575: Fetch 65536
2019-01-29 20:14:37.587: Fetch 65536
2019-01-29 20:14:37.602: Fetch 65536
2019-01-29 20:14:37.621: Fetch 65536
2019-01-29 20:14:37.640: Fetch 65536
2019-01-29 20:14:37.660: Fetch 65536
2019-01-29 20:14:37.679: Fetch 65536
2019-01-29 20:14:37.696: Fetch 65536
2019-01-29 20:14:37.713: Fetch 65536
2019-01-29 20:14:37.734: Fetch 65536
2019-01-29 20:14:37.754: Fetch 65536
2019-01-29 20:14:37.772: Fetch 65536
2019-01-29 20:14:37.786: Fetch 65536
2019-01-29 20:14:37.802: Fetch 65536
2019-01-29 20:14:37.823: Fetch 65536
2019-01-29 20:14:37.842: Fetch 65536
2019-01-29 20:14:37.858: Fetch 65536
2019-01-29 20:14:37.875: Fetch 65536
2019-01-29 20:14:37.891: Fetch 65536
2019-01-29 20:14:37.905: Fetch 65536
2019-01-29 20:14:37.918: Fetch 65536
2019-01-29 20:14:37.933: Fetch 65536
2019-01-29 20:14:37.952: Fetch 65536
2019-01-29 20:14:37.968: Fetch 65536
2019-01-29 20:14:37.983: Fetch 65536
2019-01-29 20:14:37.997: Fetch 65536
2019-01-29 20:14:38.013: Fetch 65536
2019-01-29 20:14:38.028: Fetch 65536
2019-01-29 20:14:38.045: Fetch 65536
2019-01-29 20:14:38.061: Fetch 65536
2019-01-29 20:14:38.075: Fetch 65536
2019-01-29 20:14:38.087: Fetch 65536
2019-01-29 20:14:38.104: Fetch 65536
2019-01-29 20:14:38.118: Fetch 65536
2019-01-29 20:14:38.134: Fetch 65536
2019-01-29 20:14:38.150: Fetch 65536
2019-01-29 20:14:38.162: Fetch 65536
2019-01-29 20:14:50.775: Fetch 65536
2019-01-29 20:14:50.791: Fetch 65536
2019-01-29 20:14:50.804: Fetch 65536
2019-01-29 20:14:50.817: Fetch 65536
2019-01-29 20:14:50.830: Fetch 65536
2019-01-29 20:14:50.843: Fetch 65536
2019-01-29 20:14:50.860: Fetch 65536
2019-01-29 20:14:50.876: Fetch 65536
2019-01-29 20:14:50.894: Fetch 65536
2019-01-29 20:14:50.905: Fetch 65536
2019-01-29 20:14:50.918: Fetch 65536
2019-01-29 20:14:50.930: Fetch 65536
2019-01-29 20:14:50.944: Fetch 65536
2019-01-29 20:14:50.960: Fetch 65536
2019-01-29 20:14:50.978: Fetch 65536
2019-01-29 20:14:50.994: Fetch 65536
2019-01-29 20:14:51.003: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 46308345, m_contentLength = 46295618
2019-01-29 20:14:51.017: Fetch 65536
2019-01-29 20:14:51.031: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 46336578, m_contentLength = 46295618
2019-01-29 20:14:51.054: Fetch 65536
2019-01-29 20:14:51.079: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 46349305, m_contentLength = 46295618
2019-01-29 20:14:51.113: Fetch 65536
2019-01-29 20:14:51.153: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 46361154, m_contentLength = 46295618
2019-01-29 20:14:51.196: HttpURLConnection: Returning -1 (end of file)!2019-01-29 20:14:51:215  not enough data, calling setNextToCurrent, framesToRead = 286720
2019-01-29 20:14:51:215  after setNextToCurrent: current = 0xd1849200, m_next = 0x0
2019-01-29 20:14:51.228: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:14:51.664: HttpURLConnection: contentLength = 19188017 for Tidal
2019-01-29 20:14:51.695: Fetch 65536
2019-01-29 20:14:51.722: Fetch 335262
2019-01-29 20:14:51.748: Fetch 163840
2019-01-29 20:14:51.766: Fetch 89502
2019-01-29 20:14:51.782: Fetch 65536
2019-01-29 20:14:51.796: Fetch 40350
2019-01-29 20:14:51.848: Fetch 65536
2019-01-29 20:14:51.856: Fetch 65536
2019-01-29 20:14:51.863: Fetch 65536
2019-01-29 20:14:51.870: Fetch 65536
2019-01-29 20:14:51.882: Fetch 65536
2019-01-29 20:14:51.889: Fetch 65536
2019-01-29 20:14:51.896: Fetch 65536
2019-01-29 20:14:51.903: Fetch 65536
2019-01-29 20:14:51.911: Fetch 65536
2019-01-29 20:14:51.919: Fetch 65536
2019-01-29 20:14:51.928: Fetch 65536
2019-01-29 20:14:51.947: Fetch 65536
2019-01-29 20:14:51.962: Fetch 65536
2019-01-29 20:14:51.980: Fetch 65536
2019-01-29 20:14:51.994: Fetch 65536
2019-01-29 20:14:52.013: Fetch 65536
2019-01-29 20:14:52.034: Fetch 65536
2019-01-29 20:14:52.048: Fetch 65536
2019-01-29 20:14:52.065: Fetch 65536
2019-01-29 20:14:52.083: Fetch 65536
2019-01-29 20:14:52.103: Fetch 65536
2019-01-29 20:14:52.116: Fetch 65536
2019-01-29 20:14:52.126: Fetch 65536
2019-01-29 20:14:52.138: Fetch 65536
2019-01-29 20:14:52.158: Fetch 65536
2019-01-29 20:14:52.171: Fetch 65536
2019-01-29 20:14:52.187: Fetch 65536
2019-01-29 20:14:52.239: Fetch 65536
2019-01-29 20:14:52.268: Fetch 65536
2019-01-29 20:14:52.286: Fetch 65536
2019-01-29 20:14:52.312: Fetch 65536
2019-01-29 20:14:52.332: Fetch 65536
2019-01-29 20:14:52.343: Fetch 65536
2019-01-29 20:14:52.356: Fetch 65536
2019-01-29 20:15:01.182: Fetch 65536
2019-01-29 20:15:01.226: Fetch 65536
2019-01-29 20:15:01.275: Fetch 65536
2019-01-29 20:15:01.289: Fetch 65536
2019-01-29 20:15:01.303: Fetch 65536
2019-01-29 20:15:01.315: Fetch 65536
2019-01-29 20:15:01.340: Fetch 65536
2019-01-29 20:15:01.357: Fetch 65536
2019-01-29 20:15:01.377: Fetch 65536
2019-01-29 20:15:01.391: Fetch 65536
2019-01-29 20:15:01.405: Fetch 65536
2019-01-29 20:15:01.428: Fetch 65536
2019-01-29 20:15:01.442: Fetch 65536
2019-01-29 20:15:01.455: Fetch 65536
2019-01-29 20:15:01.466: Fetch 65536
2019-01-29 20:15:01.483: Fetch 65536
2019-01-29 20:15:01.496: Fetch 65536
2019-01-29 20:15:01.508: Fetch 65536
2019-01-29 20:15:01.523: Fetch 65536
2019-01-29 20:15:01.539: Fetch 65536
2019-01-29 20:15:01.555: Fetch 65536
2019-01-29 20:15:01.578: Fetch 65536
2019-01-29 20:15:01.601: Fetch 65536
2019-01-29 20:15:01.613: Fetch 65536
2019-01-29 20:15:01.635: Fetch 65536
2019-01-29 20:15:01.648: Fetch 65536
2019-01-29 20:15:01.663: Fetch 65536
2019-01-29 20:15:01.676: Fetch 65536
2019-01-29 20:15:01.690: Fetch 65536
2019-01-29 20:15:01.705: Fetch 65536
2019-01-29 20:15:01.721: Fetch 65536
2019-01-29 20:15:01.736: Fetch 65536
2019-01-29 20:15:01.752: Fetch 65536
2019-01-29 20:15:01.768: Fetch 65536
2019-01-29 20:15:01.788: Fetch 65536
2019-01-29 20:15:01.809: Fetch 65536
2019-01-29 20:15:01.832: Fetch 65536
2019-01-29 20:15:01.852: Fetch 65536
2019-01-29 20:15:01.863: Fetch 65536
2019-01-29 20:15:01.877: Fetch 65536
2019-01-29 20:15:01.892: Fetch 65536
2019-01-29 20:15:01.909: Fetch 65536
2019-01-29 20:15:01.924: Fetch 65536
2019-01-29 20:15:01.936: Fetch 65536
2019-01-29 20:15:01.950: Fetch 65536
2019-01-29 20:15:01.964: Fetch 65536
2019-01-29 20:15:01.987: Fetch 65536
2019-01-29 20:15:02.009: Fetch 65536
2019-01-29 20:15:02.022: Fetch 65536
2019-01-29 20:15:02.039: Fetch 65536
2019-01-29 20:15:02.056: Fetch 65536
2019-01-29 20:15:02.069: Fetch 65536
2019-01-29 20:15:02.080: Fetch 65536
2019-01-29 20:15:02.092: Fetch 65536
2019-01-29 20:15:02.112: Fetch 65536
2019-01-29 20:15:02.128: Fetch 65536
2019-01-29 20:15:02.153: Fetch 65536
2019-01-29 20:15:02.166: Fetch 65536
2019-01-29 20:15:02.179: Fetch 65536
2019-01-29 20:15:02.193: Fetch 65536
2019-01-29 20:15:02.211: Fetch 65536
2019-01-29 20:15:02.227: Fetch 655362019-01-29 20:15:07:84  FileQueue dump CB: switch required
2019-01-29 20:15:07:85  FileQueue dump: current = 0xd1849200, Tidal
2019-01-29 20:15:07:85  FileQueue dump: next    = 0x0,
2019-01-29 20:15:07:86  filldatacb: stopAndGo 0
2019-01-29 20:15:07.119: Open ASYNC: Slåttetrall: Springar Etter Gudmund Eide
2019-01-29 20:15:07.587: onPositiveResult, i_isNextPosition = true
2019-01-29 20:15:07.604: Message MESSAGE_TYPE_QUEUE_SONG
2019-01-29 20:15:07.614: HttpURLConnection: fetchDataForReal: m_HttpURLConnection == null, creating request, this = com.extreamsd.usbaudioplayershared.ESDHTTPClient@dd38ed6
2019-01-29 20:15:07.623: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:15:08.030: HttpURLConnection: contentLength = 15493606 for Tidal
2019-01-29 20:15:08.054: Fetch 65536
2019-01-29 20:15:08.068: Fetch 334684
2019-01-29 20:15:08.086: Fetch 233780
2019-01-29 20:15:08.100: Fetch 164276
2019-01-29 20:15:08.117: Fetch 81920
2019-01-29 20:15:08.133: Fetch 65536
2019-01-29 20:15:08.145: Fetch 65536
2019-01-29 20:15:08.208: Fetch 65536
2019-01-29 20:15:08.221: Fetch 65536
2019-01-29 20:15:08.237: Fetch 65536
2019-01-29 20:15:08.249: Fetch 65536
2019-01-29 20:15:08.259: Fetch 65536
2019-01-29 20:15:08.274: Fetch 65536
2019-01-29 20:15:08.286: Fetch 65536
2019-01-29 20:15:08.297: Fetch 65536
2019-01-29 20:15:08.307: Fetch 65536
2019-01-29 20:15:08.318: Fetch 65536
2019-01-29 20:15:08.330: Fetch 65536
2019-01-29 20:15:08.343: Fetch 65536
2019-01-29 20:15:08.361: Fetch 65536
2019-01-29 20:15:08.382: Fetch 65536
2019-01-29 20:15:08.396: Fetch 65536
2019-01-29 20:15:08.437: Fetch 65536
2019-01-29 20:15:08.446: Fetch 65536
2019-01-29 20:15:08.460: Fetch 65536
2019-01-29 20:15:08.474: Fetch 65536
2019-01-29 20:15:08.486: Fetch 65536
2019-01-29 20:15:08.499: Fetch 65536
2019-01-29 20:15:08.512: Fetch 65536
2019-01-29 20:15:08.524: Fetch 65536
2019-01-29 20:15:08.540: Fetch 65536
2019-01-29 20:15:08.554: Fetch 65536
2019-01-29 20:15:08.566: Fetch 65536
2019-01-29 20:15:08.584: Fetch 65536
2019-01-29 20:15:08.597: Fetch 65536
2019-01-29 20:15:08.612: Fetch 65536
2019-01-29 20:15:08.631: Fetch 65536
2019-01-29 20:15:08.641: Fetch 655362019-01-29 20:15:08:656  Current wasn't NULL, so setting next to Slåttetrall: Springar Etter Gudmund Eide = Tidal
2019-01-29 20:15:08:656  after setNextDataSource: current = 0xd1849200, m_next = 0xd1849e00
2019-01-29 20:15:08.665: Setting m_asyncInProgress to false in A
2019-01-29 20:15:14.553: Fetch 65536
2019-01-29 20:15:14.584: Fetch 65536
2019-01-29 20:15:14.599: Fetch 65536
2019-01-29 20:15:14.614: Fetch 65536
2019-01-29 20:15:14.631: Fetch 65536
2019-01-29 20:15:14.643: Fetch 65536
2019-01-29 20:15:14.665: Fetch 65536
2019-01-29 20:15:14.694: Fetch 65536
2019-01-29 20:15:14.705: Fetch 65536
2019-01-29 20:15:14.717: Fetch 65536
2019-01-29 20:15:14.735: Fetch 65536
2019-01-29 20:15:14.749: Fetch 65536
2019-01-29 20:15:14.763: Fetch 65536
2019-01-29 20:15:14.777: Fetch 65536
2019-01-29 20:15:14.793: Fetch 65536
2019-01-29 20:15:14.806: Fetch 65536
2019-01-29 20:15:14.818: Fetch 65536
2019-01-29 20:15:14.834: Fetch 65536
2019-01-29 20:15:14.854: Fetch 65536
2019-01-29 20:15:14.868: Fetch 65536
2019-01-29 20:15:14.899: Fetch 65536
2019-01-29 20:15:14.915: Fetch 65536
2019-01-29 20:15:14.934: Fetch 65536
2019-01-29 20:15:14.948: Fetch 65536
2019-01-29 20:15:14.960: Fetch 65536
2019-01-29 20:15:14.973: Fetch 65536
2019-01-29 20:15:14.985: Fetch 65536
2019-01-29 20:15:14.998: Fetch 65536
2019-01-29 20:15:15.012: Fetch 65536
2019-01-29 20:15:15.029: Fetch 65536
2019-01-29 20:15:15.040: Fetch 65536
2019-01-29 20:15:15.050: Fetch 65536
2019-01-29 20:15:15.061: Fetch 65536
2019-01-29 20:15:15.077: Fetch 65536
2019-01-29 20:15:15.096: Fetch 65536
2019-01-29 20:15:15.111: Fetch 65536
2019-01-29 20:15:15.128: Fetch 65536
2019-01-29 20:15:15.146: Fetch 65536
2019-01-29 20:15:15.173: Fetch 65536
2019-01-29 20:15:15.190: Fetch 65536
2019-01-29 20:15:15.206: Fetch 65536
2019-01-29 20:15:15.221: Fetch 65536
2019-01-29 20:15:15.236: Fetch 65536
2019-01-29 20:15:15.249: Fetch 65536
2019-01-29 20:15:15.259: Fetch 65536
2019-01-29 20:15:15.270: Fetch 65536
2019-01-29 20:15:15.287: Fetch 65536
2019-01-29 20:15:15.308: Fetch 65536
2019-01-29 20:15:15.322: Fetch 65536
2019-01-29 20:15:15.336: Fetch 65536
2019-01-29 20:15:15.355: Fetch 65536
2019-01-29 20:15:15.379: Fetch 65536
2019-01-29 20:15:15.392: Fetch 65536
2019-01-29 20:15:15.413: Fetch 65536
2019-01-29 20:15:15.437: Fetch 65536
2019-01-29 20:15:15.454: Fetch 65536
2019-01-29 20:15:15.471: Fetch 65536
2019-01-29 20:15:15.485: Fetch 65536
2019-01-29 20:15:15.500: Fetch 65536
2019-01-29 20:15:15.519: Fetch 65536
2019-01-29 20:15:15.533: Fetch 65536
2019-01-29 20:15:15.546: Fetch 65536
2019-01-29 20:15:15.564: Fetch 65536
2019-01-29 20:15:15.583: Fetch 65536
2019-01-29 20:15:15.597: Fetch 65536
2019-01-29 20:15:24.965: Fetch 65536
2019-01-29 20:15:25.010: Fetch 65536
2019-01-29 20:15:25.025: Fetch 65536
2019-01-29 20:15:25.038: Fetch 65536
2019-01-29 20:15:25.050: Fetch 65536
2019-01-29 20:15:25.092: Fetch 65536
2019-01-29 20:15:25.116: Fetch 65536
2019-01-29 20:15:25.128: Fetch 65536
2019-01-29 20:15:25.141: Fetch 65536
2019-01-29 20:15:25.156: Fetch 65536
2019-01-29 20:15:25.168: Fetch 65536
2019-01-29 20:15:25.181: Fetch 65536
2019-01-29 20:15:25.196: Fetch 65536
2019-01-29 20:15:25.214: Fetch 65536
2019-01-29 20:15:25.235: Fetch 65536
2019-01-29 20:15:25.260: Fetch 65536
2019-01-29 20:15:25.282: Fetch 65536
2019-01-29 20:15:25.296: Fetch 65536
2019-01-29 20:15:25.312: Fetch 65536
2019-01-29 20:15:25.330: Fetch 65536
2019-01-29 20:15:25.345: Fetch 65536
2019-01-29 20:15:25.362: Fetch 65536
2019-01-29 20:15:25.377: Fetch 65536
2019-01-29 20:15:25.392: Fetch 65536
2019-01-29 20:15:25.404: Fetch 65536
2019-01-29 20:15:25.417: Fetch 65536
2019-01-29 20:15:25.434: Fetch 65536
2019-01-29 20:15:25.451: Fetch 65536
2019-01-29 20:15:25.468: Fetch 65536
2019-01-29 20:15:25.479: Fetch 65536
2019-01-29 20:15:25.490: Fetch 65536
2019-01-29 20:15:25.503: Fetch 65536
2019-01-29 20:15:25.520: Fetch 65536
2019-01-29 20:15:25.534: Fetch 65536
2019-01-29 20:15:25.563: Fetch 65536
2019-01-29 20:15:25.577: Fetch 65536
2019-01-29 20:15:25.589: Fetch 65536
2019-01-29 20:15:25.609: Fetch 65536
2019-01-29 20:15:25.626: Fetch 65536
2019-01-29 20:15:25.642: Fetch 65536
2019-01-29 20:15:25.670: Fetch 65536
2019-01-29 20:15:25.691: Fetch 65536
2019-01-29 20:15:25.717: Fetch 65536
2019-01-29 20:15:25.749: Fetch 65536
2019-01-29 20:15:25.764: Fetch 65536
2019-01-29 20:15:25.780: Fetch 65536
2019-01-29 20:15:25.794: Fetch 65536
2019-01-29 20:15:25.809: Fetch 65536
2019-01-29 20:15:25.823: Fetch 65536
2019-01-29 20:15:25.836: Fetch 65536
2019-01-29 20:15:25.852: Fetch 65536
2019-01-29 20:15:25.873: Fetch 65536
2019-01-29 20:15:25.897: Fetch 65536
2019-01-29 20:15:25.926: Fetch 65536
2019-01-29 20:15:25.950: Fetch 65536
2019-01-29 20:15:25.971: Fetch 65536
2019-01-29 20:15:25.989: Fetch 65536
2019-01-29 20:15:26.001: Fetch 65536
2019-01-29 20:15:26.015: Fetch 65536
2019-01-29 20:15:26.028: Fetch 65536
2019-01-29 20:15:26.051: Fetch 65536
2019-01-29 20:15:26.064: Fetch 65536
2019-01-29 20:15:36.854: Fetch 65536
2019-01-29 20:15:36.866: Fetch 65536
2019-01-29 20:15:36.881: Fetch 65536
2019-01-29 20:15:36.897: Fetch 65536
2019-01-29 20:15:36.912: Fetch 65536
2019-01-29 20:15:36.924: Fetch 65536
2019-01-29 20:15:36.937: Fetch 65536
2019-01-29 20:15:36.949: Fetch 65536
2019-01-29 20:15:36.963: Fetch 65536
2019-01-29 20:15:36.993: Fetch 65536
2019-01-29 20:15:37.025: Fetch 65536
2019-01-29 20:15:37.040: Fetch 65536
2019-01-29 20:15:37.055: Fetch 65536
2019-01-29 20:15:37.069: Fetch 65536
2019-01-29 20:15:37.089: Fetch 65536
2019-01-29 20:15:37.100: Fetch 65536
2019-01-29 20:15:37.110: Fetch 65536
2019-01-29 20:15:37.124: Fetch 65536
2019-01-29 20:15:37.138: Fetch 65536
2019-01-29 20:15:37.158: Fetch 65536
2019-01-29 20:15:37.176: Fetch 65536
2019-01-29 20:15:37.195: Fetch 65536
2019-01-29 20:15:37.223: Fetch 65536
2019-01-29 20:15:37.236: Fetch 65536
2019-01-29 20:15:37.248: Fetch 65536
2019-01-29 20:15:37.261: Fetch 65536
2019-01-29 20:15:37.273: Fetch 65536
2019-01-29 20:15:37.285: Fetch 65536
2019-01-29 20:15:37.298: Fetch 65536
2019-01-29 20:15:37.317: Fetch 65536
2019-01-29 20:15:37.339: Fetch 65536
2019-01-29 20:15:37.356: Fetch 65536
2019-01-29 20:15:37.375: Fetch 65536
2019-01-29 20:15:37.397: Fetch 65536
2019-01-29 20:15:37.412: Fetch 65536
2019-01-29 20:15:37.430: Fetch 65536
2019-01-29 20:15:37.447: Fetch 65536
2019-01-29 20:15:37.461: Fetch 65536
2019-01-29 20:15:37.473: Fetch 65536
2019-01-29 20:15:37.486: Fetch 65536
2019-01-29 20:15:37.497: Fetch 65536
2019-01-29 20:15:37.509: Fetch 65536
2019-01-29 20:15:37.523: Fetch 65536
2019-01-29 20:15:37.536: Fetch 65536
2019-01-29 20:15:37.552: Fetch 65536
2019-01-29 20:15:37.570: Fetch 65536
2019-01-29 20:15:37.592: Fetch 65536
2019-01-29 20:15:37.603: Fetch 65536
2019-01-29 20:15:37.622: Fetch 65536
2019-01-29 20:15:37.641: Fetch 65536
2019-01-29 20:15:37.654: Fetch 65536
2019-01-29 20:15:37.670: Fetch 65536
2019-01-29 20:15:37.688: Fetch 65536
2019-01-29 20:15:37.700: Fetch 65536
2019-01-29 20:15:37.716: Fetch 65536
2019-01-29 20:15:37.729: Fetch 65536
2019-01-29 20:15:37.746: Fetch 65536
2019-01-29 20:15:37.762: Fetch 65536
2019-01-29 20:15:37.778: Fetch 65536
2019-01-29 20:15:37.795: Fetch 65536
2019-01-29 20:15:37.812: Fetch 65536
2019-01-29 20:15:37.833: Fetch 65536
2019-01-29 20:15:37.846: Fetch 65536
2019-01-29 20:15:37.859: Fetch 65536
2019-01-29 20:15:37.872: Fetch 65536
2019-01-29 20:15:48.724: Fetch 65536
2019-01-29 20:15:48.751: Fetch 65536
2019-01-29 20:15:48.765: Fetch 65536
2019-01-29 20:15:48.780: Fetch 65536
2019-01-29 20:15:48.796: Fetch 65536
2019-01-29 20:15:48.819: Fetch 65536
2019-01-29 20:15:48.831: Fetch 65536
2019-01-29 20:15:48.850: Fetch 65536
2019-01-29 20:15:48.863: Fetch 65536
2019-01-29 20:15:48.878: Fetch 65536
2019-01-29 20:15:48.892: Fetch 65536
2019-01-29 20:15:48.908: Fetch 65536
2019-01-29 20:15:48.935: Fetch 65536
2019-01-29 20:15:48.947: Fetch 65536
2019-01-29 20:15:48.966: Fetch 65536
2019-01-29 20:15:48.996: Fetch 65536
2019-01-29 20:15:49.013: Fetch 65536
2019-01-29 20:15:49.026: Fetch 65536
2019-01-29 20:15:49.040: Fetch 65536
2019-01-29 20:15:49.057: Fetch 65536
2019-01-29 20:15:49.068: Fetch 65536
2019-01-29 20:15:49.080: Fetch 65536
2019-01-29 20:15:49.102: Fetch 65536
2019-01-29 20:15:49.123: Fetch 65536
2019-01-29 20:15:49.138: Fetch 65536
2019-01-29 20:15:49.157: Fetch 65536
2019-01-29 20:15:49.186: Fetch 65536
2019-01-29 20:15:49.211: Fetch 65536
2019-01-29 20:15:49.229: Fetch 65536
2019-01-29 20:15:49.251: Fetch 65536
2019-01-29 20:15:49.264: Fetch 65536
2019-01-29 20:15:49.280: Fetch 65536
2019-01-29 20:15:49.295: Fetch 65536
2019-01-29 20:15:49.307: Fetch 65536
2019-01-29 20:15:49.319: Fetch 65536
2019-01-29 20:15:49.333: Fetch 65536
2019-01-29 20:15:49.347: Fetch 65536
2019-01-29 20:15:49.365: Fetch 65536
2019-01-29 20:15:49.379: Fetch 65536
2019-01-29 20:15:49.396: Fetch 65536
2019-01-29 20:15:49.416: Fetch 65536
2019-01-29 20:15:49.431: Fetch 65536
2019-01-29 20:15:49.444: Fetch 65536
2019-01-29 20:15:49.459: Fetch 65536
2019-01-29 20:15:49.473: Fetch 65536
2019-01-29 20:15:49.487: Fetch 65536
2019-01-29 20:15:49.505: Fetch 65536
2019-01-29 20:15:49.522: Fetch 65536
2019-01-29 20:15:49.543: Fetch 65536
2019-01-29 20:15:49.558: Fetch 65536
2019-01-29 20:15:49.574: Fetch 65536
2019-01-29 20:15:49.588: Fetch 65536
2019-01-29 20:15:49.600: Fetch 65536
2019-01-29 20:15:49.611: Fetch 65536
2019-01-29 20:15:49.629: Fetch 65536
2019-01-29 20:15:49.651: Fetch 65536
2019-01-29 20:15:49.665: Fetch 65536
2019-01-29 20:15:49.686: Fetch 65536
2019-01-29 20:15:49.711: Fetch 65536
2019-01-29 20:15:49.735: Fetch 65536
2019-01-29 20:15:49.746: Fetch 65536
2019-01-29 20:15:49.758: Fetch 65536
2019-01-29 20:15:49.779: Fetch 65536
2019-01-29 20:15:49.794: Fetch 65536
2019-01-29 20:15:49.807: Fetch 65536
2019-01-29 20:15:49.825: Fetch 65536
2019-01-29 20:16:00.645: Fetch 65536
2019-01-29 20:16:00.690: Fetch 65536
2019-01-29 20:16:00.707: Fetch 65536
2019-01-29 20:16:00.721: Fetch 65536
2019-01-29 20:16:00.734: Fetch 65536
2019-01-29 20:16:00.747: Fetch 65536
2019-01-29 20:16:00.760: Fetch 65536
2019-01-29 20:16:00.773: Fetch 65536
2019-01-29 20:16:00.787: Fetch 65536
2019-01-29 20:16:00.800: Fetch 65536
2019-01-29 20:16:00.814: Fetch 65536
2019-01-29 20:16:00.827: Fetch 65536
2019-01-29 20:16:00.840: Fetch 65536
2019-01-29 20:16:00.853: Fetch 65536
2019-01-29 20:16:00.868: Fetch 65536
2019-01-29 20:16:00.888: Fetch 65536
2019-01-29 20:16:00.900: Fetch 65536
2019-01-29 20:16:00.913: Fetch 65536
2019-01-29 20:16:00.929: Fetch 65536
2019-01-29 20:16:00.944: Fetch 65536
2019-01-29 20:16:00.963: Fetch 65536
2019-01-29 20:16:00.982: Fetch 65536
2019-01-29 20:16:01.004: Fetch 65536
2019-01-29 20:16:01.026: Fetch 65536
2019-01-29 20:16:01.038: Fetch 65536
2019-01-29 20:16:01.050: Fetch 65536
2019-01-29 20:16:01.065: Fetch 65536
2019-01-29 20:16:01.090: Fetch 65536
2019-01-29 20:16:01.106: Fetch 65536
2019-01-29 20:16:01.122: Fetch 65536
2019-01-29 20:16:01.135: Fetch 65536
2019-01-29 20:16:01.151: Fetch 65536
2019-01-29 20:16:01.168: Fetch 65536
2019-01-29 20:16:01.185: Fetch 65536
2019-01-29 20:16:01.203: Fetch 65536
2019-01-29 20:16:01.227: Fetch 65536
2019-01-29 20:16:01.251: Fetch 65536
2019-01-29 20:16:01.272: Fetch 65536
2019-01-29 20:16:01.285: Fetch 65536
2019-01-29 20:16:01.301: Fetch 65536
2019-01-29 20:16:01.314: Fetch 65536
2019-01-29 20:16:01.326: Fetch 65536
2019-01-29 20:16:01.339: Fetch 65536
2019-01-29 20:16:01.352: Fetch 65536
2019-01-29 20:16:01.364: Fetch 65536
2019-01-29 20:16:01.379: Fetch 65536
2019-01-29 20:16:01.399: Fetch 65536
2019-01-29 20:16:01.415: Fetch 65536
2019-01-29 20:16:01.428: Fetch 65536
2019-01-29 20:16:01.449: Fetch 65536
2019-01-29 20:16:01.465: Fetch 65536
2019-01-29 20:16:01.479: Fetch 65536
2019-01-29 20:16:01.490: Fetch 65536
2019-01-29 20:16:01.502: Fetch 65536
2019-01-29 20:16:01.514: Fetch 65536
2019-01-29 20:16:01.527: Fetch 65536
2019-01-29 20:16:01.541: Fetch 65536
2019-01-29 20:16:01.561: Fetch 65536
2019-01-29 20:16:01.574: Fetch 65536
2019-01-29 20:16:01.588: Fetch 65536
2019-01-29 20:16:01.604: Fetch 65536
2019-01-29 20:16:01.618: Fetch 65536
2019-01-29 20:16:01.637: Fetch 65536
2019-01-29 20:16:01.655: Fetch 65536
2019-01-29 20:16:01.667: Fetch 65536
2019-01-29 20:16:01.679: Fetch 65536
2019-01-29 20:16:13.996: Fetch 65536
2019-01-29 20:16:14.018: Fetch 65536
2019-01-29 20:16:14.029: Fetch 65536
2019-01-29 20:16:14.043: Fetch 65536
2019-01-29 20:16:14.064: Fetch 65536
2019-01-29 20:16:14.081: Fetch 65536
2019-01-29 20:16:14.099: Fetch 65536
2019-01-29 20:16:14.116: Fetch 65536
2019-01-29 20:16:14.128: Fetch 65536
2019-01-29 20:16:14.144: Fetch 65536
2019-01-29 20:16:14.159: Fetch 65536
2019-01-29 20:16:14.174: Fetch 65536
2019-01-29 20:16:14.192: Fetch 65536
2019-01-29 20:16:14.207: Fetch 65536
2019-01-29 20:16:14.234: Fetch 65536
2019-01-29 20:16:14.251: Fetch 65536
2019-01-29 20:16:14.262: Fetch 65536
2019-01-29 20:16:14.274: Fetch 65536
2019-01-29 20:16:14.288: Fetch 65536
2019-01-29 20:16:14.302: Fetch 65536
2019-01-29 20:16:14.315: Fetch 65536
2019-01-29 20:16:14.329: Fetch 65536
2019-01-29 20:16:14.349: Fetch 65536
2019-01-29 20:16:14.374: Fetch 65536
2019-01-29 20:16:14.390: Fetch 65536
2019-01-29 20:16:14.412: Fetch 65536
2019-01-29 20:16:14.428: Fetch 65536
2019-01-29 20:16:14.442: Fetch 65536
2019-01-29 20:16:14.456: Fetch 65536
2019-01-29 20:16:14.470: Fetch 65536
2019-01-29 20:16:14.487: Fetch 65536
2019-01-29 20:16:14.502: Fetch 65536
2019-01-29 20:16:14.519: Fetch 65536
2019-01-29 20:16:14.534: Fetch 65536
2019-01-29 20:16:14.547: Fetch 65536
2019-01-29 20:16:14.562: Fetch 65536
2019-01-29 20:16:14.582: Fetch 65536
2019-01-29 20:16:14.608: Fetch 65536
2019-01-29 20:16:14.632: Fetch 65536
2019-01-29 20:16:14.645: Fetch 65536
2019-01-29 20:16:14.661: Fetch 65536
2019-01-29 20:16:14.678: Fetch 65536
2019-01-29 20:16:14.695: Fetch 65536
2019-01-29 20:16:14.711: Fetch 65536
2019-01-29 20:16:14.727: Fetch 65536
2019-01-29 20:16:14.745: Fetch 65536
2019-01-29 20:16:14.758: Fetch 65536
2019-01-29 20:16:14.773: Fetch 65536
2019-01-29 20:16:14.785: Fetch 65536
2019-01-29 20:16:14.797: Fetch 65536
2019-01-29 20:16:14.815: Fetch 65536
2019-01-29 20:16:14.829: Fetch 65536
2019-01-29 20:16:14.850: Fetch 65536
2019-01-29 20:16:14.863: Fetch 65536
2019-01-29 20:16:14.878: Fetch 65536
2019-01-29 20:16:14.897: Fetch 65536
2019-01-29 20:16:14.918: Fetch 65536
2019-01-29 20:16:14.936: Fetch 65536
2019-01-29 20:16:14.948: Fetch 65536
2019-01-29 20:16:14.964: Fetch 65536
2019-01-29 20:16:14.984: Fetch 65536
2019-01-29 20:16:14.998: Fetch 65536
2019-01-29 20:16:15.015: Fetch 65536
2019-01-29 20:16:15.028: Fetch 65536
2019-01-29 20:16:15.042: Fetch 65536
2019-01-29 20:16:15.064: Fetch 65536
2019-01-29 20:16:15.082: Fetch 65536
2019-01-29 20:16:15.099: Fetch 65536
2019-01-29 20:16:24.402: Fetch 65536
2019-01-29 20:16:24.439: Fetch 65536
2019-01-29 20:16:24.452: Fetch 65536
2019-01-29 20:16:24.464: Fetch 65536
2019-01-29 20:16:24.477: Fetch 65536
2019-01-29 20:16:24.511: Fetch 65536
2019-01-29 20:16:24.529: Fetch 65536
2019-01-29 20:16:24.542: Fetch 65536
2019-01-29 20:16:24.556: Fetch 65536
2019-01-29 20:16:24.570: Fetch 65536
2019-01-29 20:16:24.582: Fetch 65536
2019-01-29 20:16:24.598: Fetch 65536
2019-01-29 20:16:24.621: Fetch 65536
2019-01-29 20:16:24.646: Fetch 65536
2019-01-29 20:16:24.668: Fetch 65536
2019-01-29 20:16:24.691: Fetch 65536
2019-01-29 20:16:24.703: Fetch 65536
2019-01-29 20:16:24.718: Fetch 65536
2019-01-29 20:16:24.733: Fetch 65536
2019-01-29 20:16:24.745: Fetch 65536
2019-01-29 20:16:24.766: Fetch 65536
2019-01-29 20:16:24.779: Fetch 65536
2019-01-29 20:16:24.796: Fetch 65536
2019-01-29 20:16:24.811: Fetch 65536
2019-01-29 20:16:24.824: Fetch 65536
2019-01-29 20:16:24.838: Fetch 65536
2019-01-29 20:16:24.852: Fetch 65536
2019-01-29 20:16:24.864: Fetch 65536
2019-01-29 20:16:24.881: Fetch 65536
2019-01-29 20:16:24.901: Fetch 65536
2019-01-29 20:16:24.915: Fetch 65536
2019-01-29 20:16:24.926: Fetch 65536
2019-01-29 20:16:24.945: Fetch 65536
2019-01-29 20:16:24.962: Fetch 65536
2019-01-29 20:16:24.975: Fetch 65536
2019-01-29 20:16:24.994: Fetch 65536
2019-01-29 20:16:25.020: Fetch 65536
2019-01-29 20:16:25.036: Fetch 65536
2019-01-29 20:16:25.052: Fetch 65536
2019-01-29 20:16:25.070: Fetch 65536
2019-01-29 20:16:25.086: Fetch 65536
2019-01-29 20:16:25.109: Fetch 65536
2019-01-29 20:16:25.123: Fetch 65536
2019-01-29 20:16:25.136: Fetch 65536
2019-01-29 20:16:25.149: Fetch 65536
2019-01-29 20:16:25.169: Fetch 65536
2019-01-29 20:16:25.183: Fetch 65536
2019-01-29 20:16:25.200: Fetch 65536
2019-01-29 20:16:25.227: Fetch 65536
2019-01-29 20:16:25.240: Fetch 65536
2019-01-29 20:16:25.253: Fetch 65536
2019-01-29 20:16:25.269: Fetch 65536
2019-01-29 20:16:25.281: Fetch 65536
2019-01-29 20:16:25.292: Fetch 65536
2019-01-29 20:16:25.303: Fetch 65536
2019-01-29 20:16:25.315: Fetch 65536
2019-01-29 20:16:25.327: Fetch 65536
2019-01-29 20:16:25.342: Fetch 65536
2019-01-29 20:16:25.358: Fetch 65536
2019-01-29 20:16:25.378: Fetch 65536
2019-01-29 20:16:25.398: Fetch 65536
2019-01-29 20:16:25.414: Fetch 65536
2019-01-29 20:16:25.426: Fetch 65536
2019-01-29 20:16:25.439: Fetch 65536
2019-01-29 20:16:25.450: Fetch 65536
2019-01-29 20:16:25.465: Fetch 65536
2019-01-29 20:16:25.479: Fetch 65536
2019-01-29 20:16:25.494: Fetch 65536
2019-01-29 20:16:25.510: Fetch 65536
2019-01-29 20:16:36.293: Fetch 65536
2019-01-29 20:16:36.308: Fetch 65536
2019-01-29 20:16:36.325: Fetch 65536
2019-01-29 20:16:36.339: Fetch 65536
2019-01-29 20:16:36.354: Fetch 65536
2019-01-29 20:16:36.368: Fetch 65536
2019-01-29 20:16:36.380: Fetch 65536
2019-01-29 20:16:36.392: Fetch 65536
2019-01-29 20:16:36.407: Fetch 65536
2019-01-29 20:16:36.423: Fetch 65536
2019-01-29 20:16:36.436: Fetch 65536
2019-01-29 20:16:36.447: Fetch 65536
2019-01-29 20:16:36.460: Fetch 65536
2019-01-29 20:16:36.474: Fetch 65536
2019-01-29 20:16:36.488: Fetch 65536
2019-01-29 20:16:36.502: Fetch 65536
2019-01-29 20:16:36.517: Fetch 65536
2019-01-29 20:16:36.528: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 19209721, m_contentLength = 19188017
2019-01-29 20:16:36.549: Fetch 65536
2019-01-29 20:16:36.563: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 19237169, m_contentLength = 19188017
2019-01-29 20:16:36.575: Fetch 65536
2019-01-29 20:16:36.584: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 19245361, m_contentLength = 19188017
2019-01-29 20:16:36.600: Fetch 65536
2019-01-29 20:16:36.618: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 19253553, m_contentLength = 19188017
2019-01-29 20:16:36.642: HttpURLConnection: Returning -1 (end of file)!2019-01-29 20:16:36:657  not enough data, calling setNextToCurrent, framesToRead = 319488
2019-01-29 20:16:36:658  after setNextToCurrent: current = 0xd1849e00, m_next = 0x0
2019-01-29 20:16:36.677: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:16:36.878: HttpURLConnection: contentLength = 15493606 for Tidal
2019-01-29 20:16:36.905: Fetch 65536
2019-01-29 20:16:36.917: Fetch 335211
2019-01-29 20:16:36.930: Fetch 163840
2019-01-29 20:16:36.947: Fetch 89451
2019-01-29 20:16:36.968: Fetch 65536
2019-01-29 20:16:36.978: Fetch 40299
2019-01-29 20:16:37.033: Fetch 65536
2019-01-29 20:16:37.042: Fetch 65536
2019-01-29 20:16:37.052: Fetch 65536
2019-01-29 20:16:37.065: Fetch 65536
2019-01-29 20:16:37.077: Fetch 65536
2019-01-29 20:16:37.086: Fetch 65536
2019-01-29 20:16:37.096: Fetch 65536
2019-01-29 20:16:37.121: Fetch 65536
2019-01-29 20:16:37.137: Fetch 65536
2019-01-29 20:16:37.155: Fetch 65536
2019-01-29 20:16:37.173: Fetch 65536
2019-01-29 20:16:37.184: Fetch 65536
2019-01-29 20:16:37.195: Fetch 65536
2019-01-29 20:16:37.206: Fetch 65536
2019-01-29 20:16:37.217: Fetch 65536
2019-01-29 20:16:37.226: Fetch 65536
2019-01-29 20:16:37.235: Fetch 65536
2019-01-29 20:16:37.244: Fetch 65536
2019-01-29 20:16:37.254: Fetch 65536
2019-01-29 20:16:37.266: Fetch 65536
2019-01-29 20:16:37.283: Fetch 65536
2019-01-29 20:16:37.298: Fetch 65536
2019-01-29 20:16:37.318: Fetch 65536
2019-01-29 20:16:37.337: Fetch 65536
2019-01-29 20:16:37.346: Fetch 65536
2019-01-29 20:16:37.358: Fetch 65536
2019-01-29 20:16:37.383: Fetch 65536
2019-01-29 20:16:37.400: Fetch 65536
2019-01-29 20:16:37.415: Fetch 65536
2019-01-29 20:16:37.428: Fetch 65536
2019-01-29 20:16:37.440: Fetch 65536
2019-01-29 20:16:37.450: Fetch 65536
2019-01-29 20:16:37.526: Fetch 65536
2019-01-29 20:16:37.552: Fetch 65536
2019-01-29 20:16:37.575: Fetch 65536
2019-01-29 20:16:37.594: Fetch 65536
2019-01-29 20:16:37.612: Fetch 65536
2019-01-29 20:16:37.629: Fetch 65536
2019-01-29 20:16:37.648: Fetch 65536
2019-01-29 20:16:37.665: Fetch 65536
2019-01-29 20:16:37.678: Fetch 65536
2019-01-29 20:16:37.690: Fetch 65536
2019-01-29 20:16:48.180: Fetch 65536
2019-01-29 20:16:48.199: Fetch 65536
2019-01-29 20:16:48.213: Fetch 65536
2019-01-29 20:16:48.226: Fetch 65536
2019-01-29 20:16:48.243: Fetch 65536
2019-01-29 20:16:48.262: Fetch 65536
2019-01-29 20:16:48.296: Fetch 65536
2019-01-29 20:16:48.310: Fetch 65536
2019-01-29 20:16:48.325: Fetch 65536
2019-01-29 20:16:48.342: Fetch 65536
2019-01-29 20:16:48.357: Fetch 65536
2019-01-29 20:16:48.376: Fetch 65536
2019-01-29 20:16:48.390: Fetch 65536
2019-01-29 20:16:48.412: Fetch 65536
2019-01-29 20:16:48.428: Fetch 65536
2019-01-29 20:16:48.444: Fetch 65536
2019-01-29 20:16:48.456: Fetch 65536
2019-01-29 20:16:48.466: Fetch 65536
2019-01-29 20:16:48.477: Fetch 65536
2019-01-29 20:16:48.494: Fetch 65536
2019-01-29 20:16:48.523: Fetch 65536
2019-01-29 20:16:48.546: Fetch 65536
2019-01-29 20:16:48.589: Fetch 65536
2019-01-29 20:16:48.602: Fetch 65536
2019-01-29 20:16:48.617: Fetch 65536
2019-01-29 20:16:48.630: Fetch 65536
2019-01-29 20:16:48.650: Fetch 65536
2019-01-29 20:16:48.664: Fetch 65536
2019-01-29 20:16:48.681: Fetch 65536
2019-01-29 20:16:48.695: Fetch 65536
2019-01-29 20:16:48.708: Fetch 65536
2019-01-29 20:16:48.721: Fetch 65536
2019-01-29 20:16:48.737: Fetch 65536
2019-01-29 20:16:48.750: Fetch 65536
2019-01-29 20:16:48.767: Fetch 65536
2019-01-29 20:16:48.782: Fetch 65536
2019-01-29 20:16:48.802: Fetch 65536
2019-01-29 20:16:48.823: Fetch 65536
2019-01-29 20:16:48.846: Fetch 65536
2019-01-29 20:16:48.868: Fetch 65536
2019-01-29 20:16:48.884: Fetch 65536
2019-01-29 20:16:48.905: Fetch 65536
2019-01-29 20:16:48.925: Fetch 65536
2019-01-29 20:16:48.939: Fetch 65536
2019-01-29 20:16:48.953: Fetch 65536
2019-01-29 20:16:48.968: Fetch 65536
2019-01-29 20:16:48.982: Fetch 65536
2019-01-29 20:16:49.003: Fetch 65536
2019-01-29 20:16:49.017: Fetch 65536
2019-01-29 20:16:49.041: Fetch 65536
2019-01-29 20:16:49.061: Fetch 65536
2019-01-29 20:16:49.079: Fetch 65536
2019-01-29 20:16:49.095: Fetch 65536
2019-01-29 20:16:49.107: Fetch 65536
2019-01-29 20:16:49.126: Fetch 65536
2019-01-29 20:16:49.146: Fetch 65536
2019-01-29 20:16:49.163: Fetch 65536
2019-01-29 20:16:49.178: Fetch 65536
2019-01-29 20:16:49.196: Fetch 655362019-01-29 20:16:54:92  FileQueue dump CB: switch required
2019-01-29 20:16:54:93  FileQueue dump: current = 0xd1849e00, Tidal
2019-01-29 20:16:54:94  FileQueue dump: next    = 0x0,
2019-01-29 20:16:54:94  filldatacb: stopAndGo 0
2019-01-29 20:16:54.131: Open ASYNC: Carter: Sonata For Violoncello And Piano - Moderato
2019-01-29 20:16:54.699: onPositiveResult, i_isNextPosition = true
2019-01-29 20:16:54.720: Message MESSAGE_TYPE_QUEUE_SONG
2019-01-29 20:16:54.729: HttpURLConnection: fetchDataForReal: m_HttpURLConnection == null, creating request, this = com.extreamsd.usbaudioplayershared.ESDHTTPClient@251c262
2019-01-29 20:16:54.736: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:16:54.908: HttpURLConnection: contentLength = 46687663 for Tidal
2019-01-29 20:16:54.935: Fetch 65536
2019-01-29 20:16:54.956: Fetch 335296
2019-01-29 20:16:54.971: Fetch 163840
2019-01-29 20:16:55.005: Fetch 92493
2019-01-29 20:16:55.023: Fetch 65536
2019-01-29 20:16:55.040: Fetch 65536
2019-01-29 20:16:55.094: Fetch 65536
2019-01-29 20:16:55.103: Fetch 65536
2019-01-29 20:16:55.116: Fetch 65536
2019-01-29 20:16:55.127: Fetch 65536
2019-01-29 20:16:55.135: Fetch 65536
2019-01-29 20:16:55.146: Fetch 65536
2019-01-29 20:16:55.156: Fetch 65536
2019-01-29 20:16:55.164: Fetch 65536
2019-01-29 20:16:55.172: Fetch 65536
2019-01-29 20:16:55.181: Fetch 65536
2019-01-29 20:16:55.188: Fetch 65536
2019-01-29 20:16:55.199: Fetch 65536
2019-01-29 20:16:55.211: Fetch 65536
2019-01-29 20:16:55.226: Fetch 65536
2019-01-29 20:16:55.244: Fetch 65536
2019-01-29 20:16:55.262: Fetch 65536
2019-01-29 20:16:55.276: Fetch 65536
2019-01-29 20:16:55.289: Fetch 65536
2019-01-29 20:16:55.306: Fetch 65536
2019-01-29 20:16:55.323: Fetch 65536
2019-01-29 20:16:55.334: Fetch 65536
2019-01-29 20:16:55.345: Fetch 65536
2019-01-29 20:16:55.360: Fetch 65536
2019-01-29 20:16:55.375: Fetch 65536
2019-01-29 20:16:55.395: Fetch 65536
2019-01-29 20:16:55.407: Fetch 655362019-01-29 20:16:55:422  Current wasn't NULL, so setting next to Carter: Sonata For Violoncello And Piano - Moderato = Tidal
2019-01-29 20:16:55:423  after setNextDataSource: current = 0xd1849e00, m_next = 0xd184f300
2019-01-29 20:16:55.430: Setting m_asyncInProgress to false in A
2019-01-29 20:17:00.076: Fetch 65536
2019-01-29 20:17:00.091: Fetch 65536
2019-01-29 20:17:00.104: Fetch 65536
2019-01-29 20:17:00.120: Fetch 65536
2019-01-29 20:17:00.136: Fetch 65536
2019-01-29 20:17:00.152: Fetch 65536
2019-01-29 20:17:00.174: Fetch 65536
2019-01-29 20:17:00.185: Fetch 65536
2019-01-29 20:17:00.200: Fetch 65536
2019-01-29 20:17:00.215: Fetch 65536
2019-01-29 20:17:00.227: Fetch 65536
2019-01-29 20:17:00.248: Fetch 65536
2019-01-29 20:17:00.272: Fetch 65536
2019-01-29 20:17:00.286: Fetch 65536
2019-01-29 20:17:00.313: Fetch 65536
2019-01-29 20:17:00.326: Fetch 65536
2019-01-29 20:17:00.337: Fetch 65536
2019-01-29 20:17:00.350: Fetch 65536
2019-01-29 20:17:00.361: Fetch 65536
2019-01-29 20:17:00.371: Fetch 65536
2019-01-29 20:17:00.382: Fetch 65536
2019-01-29 20:17:00.395: Fetch 65536
2019-01-29 20:17:00.410: Fetch 65536
2019-01-29 20:17:00.424: Fetch 65536
2019-01-29 20:17:00.440: Fetch 65536
2019-01-29 20:17:00.464: Fetch 65536
2019-01-29 20:17:00.485: Fetch 65536
2019-01-29 20:17:00.507: Fetch 65536
2019-01-29 20:17:00.525: Fetch 65536
2019-01-29 20:17:00.536: Fetch 65536
2019-01-29 20:17:00.547: Fetch 65536
2019-01-29 20:17:00.558: Fetch 65536
2019-01-29 20:17:00.569: Fetch 65536
2019-01-29 20:17:00.584: Fetch 65536
2019-01-29 20:17:00.602: Fetch 65536
2019-01-29 20:17:00.627: Fetch 65536
2019-01-29 20:17:00.650: Fetch 65536
2019-01-29 20:17:00.670: Fetch 65536
2019-01-29 20:17:00.700: Fetch 65536
2019-01-29 20:17:00.713: Fetch 65536
2019-01-29 20:17:00.731: Fetch 65536
2019-01-29 20:17:00.756: Fetch 65536
2019-01-29 20:17:00.776: Fetch 65536
2019-01-29 20:17:00.792: Fetch 65536
2019-01-29 20:17:00.807: Fetch 65536
2019-01-29 20:17:00.819: Fetch 65536
2019-01-29 20:17:00.831: Fetch 65536
2019-01-29 20:17:00.842: Fetch 65536
2019-01-29 20:17:00.855: Fetch 65536
2019-01-29 20:17:00.873: Fetch 65536
2019-01-29 20:17:00.892: Fetch 65536
2019-01-29 20:17:00.911: Fetch 65536
2019-01-29 20:17:00.923: Fetch 65536
2019-01-29 20:17:00.937: Fetch 65536
2019-01-29 20:17:00.950: Fetch 65536
2019-01-29 20:17:00.970: Fetch 65536
2019-01-29 20:17:00.985: Fetch 65536
2019-01-29 20:17:00.998: Fetch 65536
2019-01-29 20:17:01.012: Fetch 65536
2019-01-29 20:17:01.024: Fetch 65536
2019-01-29 20:17:11.954: Fetch 65536
2019-01-29 20:17:11.968: Fetch 65536
2019-01-29 20:17:11.982: Fetch 65536
2019-01-29 20:17:11.995: Fetch 65536
2019-01-29 20:17:12.010: Fetch 65536
2019-01-29 20:17:12.031: Fetch 65536
2019-01-29 20:17:12.063: Fetch 65536
2019-01-29 20:17:12.082: Fetch 65536
2019-01-29 20:17:12.097: Fetch 65536
2019-01-29 20:17:12.108: Fetch 65536
2019-01-29 20:17:12.126: Fetch 65536
2019-01-29 20:17:12.140: Fetch 65536
2019-01-29 20:17:12.152: Fetch 65536
2019-01-29 20:17:12.167: Fetch 65536
2019-01-29 20:17:12.190: Fetch 65536
2019-01-29 20:17:12.207: Fetch 65536
2019-01-29 20:17:12.221: Fetch 65536
2019-01-29 20:17:12.235: Fetch 65536
2019-01-29 20:17:12.245: Fetch 65536
2019-01-29 20:17:12.255: Fetch 65536
2019-01-29 20:17:12.267: Fetch 65536
2019-01-29 20:17:12.281: Fetch 65536
2019-01-29 20:17:12.302: Fetch 65536
2019-01-29 20:17:12.328: Fetch 65536
2019-01-29 20:17:12.342: Fetch 65536
2019-01-29 20:17:12.364: Fetch 65536
2019-01-29 20:17:12.375: Fetch 65536
2019-01-29 20:17:12.386: Fetch 65536
2019-01-29 20:17:12.406: Fetch 65536
2019-01-29 20:17:12.426: Fetch 65536
2019-01-29 20:17:12.440: Fetch 65536
2019-01-29 20:17:12.452: Fetch 65536
2019-01-29 20:17:12.464: Fetch 65536
2019-01-29 20:17:12.477: Fetch 65536
2019-01-29 20:17:12.491: Fetch 65536
2019-01-29 20:17:12.519: Fetch 65536
2019-01-29 20:17:12.530: Fetch 65536
2019-01-29 20:17:12.541: Fetch 65536
2019-01-29 20:17:12.555: Fetch 65536
2019-01-29 20:17:12.573: Fetch 65536
2019-01-29 20:17:12.588: Fetch 65536
2019-01-29 20:17:12.609: Fetch 65536
2019-01-29 20:17:12.645: Fetch 65536
2019-01-29 20:17:12.672: Fetch 65536
2019-01-29 20:17:12.685: Fetch 65536
2019-01-29 20:17:12.696: Fetch 65536
2019-01-29 20:17:12.706: Fetch 65536
2019-01-29 20:17:12.719: Fetch 65536
2019-01-29 20:17:12.731: Fetch 65536
2019-01-29 20:17:12.746: Fetch 65536
2019-01-29 20:17:12.760: Fetch 65536
2019-01-29 20:17:12.779: Fetch 65536
2019-01-29 20:17:12.795: Fetch 65536
2019-01-29 20:17:12.812: Fetch 65536
2019-01-29 20:17:12.824: Fetch 65536
2019-01-29 20:17:12.839: Fetch 65536
2019-01-29 20:17:12.855: Fetch 65536
2019-01-29 20:17:12.870: Fetch 65536
2019-01-29 20:17:12.888: Fetch 65536
2019-01-29 20:17:12.901: Fetch 65536
2019-01-29 20:17:12.934: Fetch 65536
2019-01-29 20:17:23.862: Fetch 65536
2019-01-29 20:17:23.899: Fetch 65536
2019-01-29 20:17:23.910: Fetch 65536
2019-01-29 20:17:23.925: Fetch 65536
2019-01-29 20:17:23.939: Fetch 65536
2019-01-29 20:17:23.954: Fetch 65536
2019-01-29 20:17:23.985: Fetch 65536
2019-01-29 20:17:23.997: Fetch 65536
2019-01-29 20:17:24.008: Fetch 65536
2019-01-29 20:17:24.021: Fetch 65536
2019-01-29 20:17:24.034: Fetch 65536
2019-01-29 20:17:24.056: Fetch 65536
2019-01-29 20:17:24.072: Fetch 65536
2019-01-29 20:17:24.084: Fetch 65536
2019-01-29 20:17:24.097: Fetch 65536
2019-01-29 20:17:24.110: Fetch 65536
2019-01-29 20:17:24.124: Fetch 65536
2019-01-29 20:17:24.146: Fetch 65536
2019-01-29 20:17:24.167: Fetch 65536
2019-01-29 20:17:24.186: Fetch 65536
2019-01-29 20:17:24.201: Fetch 65536
2019-01-29 20:17:24.217: Fetch 65536
2019-01-29 20:17:24.233: Fetch 65536
2019-01-29 20:17:24.252: Fetch 65536
2019-01-29 20:17:24.268: Fetch 65536
2019-01-29 20:17:24.280: Fetch 65536
2019-01-29 20:17:24.295: Fetch 65536
2019-01-29 20:17:24.309: Fetch 65536
2019-01-29 20:17:24.326: Fetch 65536
2019-01-29 20:17:24.345: Fetch 65536
2019-01-29 20:17:24.358: Fetch 65536
2019-01-29 20:17:24.373: Fetch 65536
2019-01-29 20:17:24.389: Fetch 65536
2019-01-29 20:17:24.406: Fetch 65536
2019-01-29 20:17:24.424: Fetch 65536
2019-01-29 20:17:24.449: Fetch 65536
2019-01-29 20:17:24.463: Fetch 65536
2019-01-29 20:17:24.478: Fetch 65536
2019-01-29 20:17:24.491: Fetch 65536
2019-01-29 20:17:24.506: Fetch 65536
2019-01-29 20:17:24.517: Fetch 65536
2019-01-29 20:17:24.532: Fetch 65536
2019-01-29 20:17:24.545: Fetch 65536
2019-01-29 20:17:24.557: Fetch 65536
2019-01-29 20:17:24.571: Fetch 65536
2019-01-29 20:17:24.593: Fetch 65536
2019-01-29 20:17:24.610: Fetch 65536
2019-01-29 20:17:24.625: Fetch 65536
2019-01-29 20:17:24.638: Fetch 65536
2019-01-29 20:17:24.649: Fetch 65536
2019-01-29 20:17:24.665: Fetch 65536
2019-01-29 20:17:24.679: Fetch 65536
2019-01-29 20:17:24.703: Fetch 65536
2019-01-29 20:17:24.722: Fetch 65536
2019-01-29 20:17:24.751: Fetch 65536
2019-01-29 20:17:24.773: Fetch 65536
2019-01-29 20:17:24.790: Fetch 65536
2019-01-29 20:17:24.802: Fetch 65536
2019-01-29 20:17:24.818: Fetch 65536
2019-01-29 20:17:24.840: Fetch 65536
2019-01-29 20:17:35.735: Fetch 65536
2019-01-29 20:17:35.747: Fetch 65536
2019-01-29 20:17:35.761: Fetch 65536
2019-01-29 20:17:35.775: Fetch 65536
2019-01-29 20:17:35.789: Fetch 65536
2019-01-29 20:17:35.841: Fetch 65536
2019-01-29 20:17:35.855: Fetch 65536
2019-01-29 20:17:35.869: Fetch 65536
2019-01-29 20:17:35.883: Fetch 65536
2019-01-29 20:17:35.896: Fetch 65536
2019-01-29 20:17:35.914: Fetch 65536
2019-01-29 20:17:35.932: Fetch 65536
2019-01-29 20:17:35.946: Fetch 65536
2019-01-29 20:17:35.961: Fetch 65536
2019-01-29 20:17:35.976: Fetch 65536
2019-01-29 20:17:35.988: Fetch 65536
2019-01-29 20:17:36.010: Fetch 65536
2019-01-29 20:17:36.027: Fetch 65536
2019-01-29 20:17:36.042: Fetch 65536
2019-01-29 20:17:36.058: Fetch 65536
2019-01-29 20:17:36.070: Fetch 65536
2019-01-29 20:17:36.082: Fetch 65536
2019-01-29 20:17:36.095: Fetch 65536
2019-01-29 20:17:36.106: Fetch 65536
2019-01-29 20:17:36.123: Fetch 65536
2019-01-29 20:17:36.138: Fetch 65536
2019-01-29 20:17:36.155: Fetch 65536
2019-01-29 20:17:36.168: Fetch 65536
2019-01-29 20:17:36.180: Fetch 65536
2019-01-29 20:17:36.207: Fetch 65536
2019-01-29 20:17:36.221: Fetch 65536
2019-01-29 20:17:36.235: Fetch 65536
2019-01-29 20:17:36.260: Fetch 65536
2019-01-29 20:17:36.280: Fetch 65536
2019-01-29 20:17:36.304: Fetch 65536
2019-01-29 20:17:36.323: Fetch 65536
2019-01-29 20:17:36.338: Fetch 65536
2019-01-29 20:17:36.352: Fetch 65536
2019-01-29 20:17:36.366: Fetch 65536
2019-01-29 20:17:36.378: Fetch 65536
2019-01-29 20:17:36.389: Fetch 65536
2019-01-29 20:17:36.401: Fetch 65536
2019-01-29 20:17:36.421: Fetch 65536
2019-01-29 20:17:36.441: Fetch 65536
2019-01-29 20:17:36.467: Fetch 65536
2019-01-29 20:17:36.494: Fetch 65536
2019-01-29 20:17:36.506: Fetch 65536
2019-01-29 20:17:36.526: Fetch 65536
2019-01-29 20:17:36.539: Fetch 65536
2019-01-29 20:17:36.553: Fetch 65536
2019-01-29 20:17:36.570: Fetch 65536
2019-01-29 20:17:36.586: Fetch 65536
2019-01-29 20:17:36.603: Fetch 65536
2019-01-29 20:17:36.615: Fetch 65536
2019-01-29 20:17:36.627: Fetch 65536
2019-01-29 20:17:36.640: Fetch 65536
2019-01-29 20:17:36.659: Fetch 65536
2019-01-29 20:17:36.687: Fetch 65536
2019-01-29 20:17:36.716: Fetch 65536
2019-01-29 20:17:36.744: Fetch 65536
2019-01-29 20:17:36.773: Fetch 65536
2019-01-29 20:17:36.795: Fetch 65536
2019-01-29 20:17:36.810: Fetch 65536
2019-01-29 20:17:36.828: Fetch 65536
2019-01-29 20:17:47.613: Fetch 65536
2019-01-29 20:17:47.626: Fetch 65536
2019-01-29 20:17:47.638: Fetch 65536
2019-01-29 20:17:47.651: Fetch 65536
2019-01-29 20:17:47.665: Fetch 65536
2019-01-29 20:17:47.681: Fetch 65536
2019-01-29 20:17:47.697: Fetch 65536
2019-01-29 20:17:47.714: Fetch 65536
2019-01-29 20:17:47.727: Fetch 65536
2019-01-29 20:17:47.739: Fetch 65536
2019-01-29 20:17:47.753: Fetch 65536
2019-01-29 20:17:47.765: Fetch 65536
2019-01-29 20:17:47.777: Fetch 65536
2019-01-29 20:17:47.790: Fetch 65536
2019-01-29 20:17:47.810: Fetch 65536
2019-01-29 20:17:47.827: Fetch 65536
2019-01-29 20:17:47.844: Fetch 65536
2019-01-29 20:17:47.859: Fetch 65536
2019-01-29 20:17:47.872: Fetch 65536
2019-01-29 20:17:47.886: Fetch 65536
2019-01-29 20:17:47.899: Fetch 65536
2019-01-29 20:17:47.917: Fetch 65536
2019-01-29 20:17:47.946: Fetch 65536
2019-01-29 20:17:47.966: Fetch 65536
2019-01-29 20:17:47.988: Fetch 65536
2019-01-29 20:17:48.007: Fetch 65536
2019-01-29 20:17:48.026: Fetch 65536
2019-01-29 20:17:48.062: Fetch 65536
2019-01-29 20:17:48.079: Fetch 65536
2019-01-29 20:17:48.092: Fetch 65536
2019-01-29 20:17:48.109: Fetch 65536
2019-01-29 20:17:48.126: Fetch 65536
2019-01-29 20:17:48.141: Fetch 65536
2019-01-29 20:17:48.156: Fetch 65536
2019-01-29 20:17:48.169: Fetch 65536
2019-01-29 20:17:48.184: Fetch 65536
2019-01-29 20:17:48.200: Fetch 65536
2019-01-29 20:17:48.228: Fetch 65536
2019-01-29 20:17:48.252: Fetch 65536
2019-01-29 20:17:48.265: Fetch 65536
2019-01-29 20:17:48.278: Fetch 65536
2019-01-29 20:17:48.294: Fetch 65536
2019-01-29 20:17:48.312: Fetch 65536
2019-01-29 20:17:48.325: Fetch 65536
2019-01-29 20:17:48.337: Fetch 65536
2019-01-29 20:17:48.354: Fetch 65536
2019-01-29 20:17:48.365: Fetch 65536
2019-01-29 20:17:48.383: Fetch 65536
2019-01-29 20:17:48.397: Fetch 65536
2019-01-29 20:17:48.412: Fetch 65536
2019-01-29 20:17:48.424: Fetch 65536
2019-01-29 20:17:48.436: Fetch 65536
2019-01-29 20:17:48.448: Fetch 65536
2019-01-29 20:17:48.467: Fetch 65536
2019-01-29 20:17:48.483: Fetch 65536
2019-01-29 20:17:48.502: Fetch 65536
2019-01-29 20:17:48.515: Fetch 65536
2019-01-29 20:18:00.991: Fetch 65536
2019-01-29 20:18:01.006: Fetch 65536
2019-01-29 20:18:01.022: Fetch 65536
2019-01-29 20:18:01.038: Fetch 65536
2019-01-29 20:18:01.052: Fetch 65536
2019-01-29 20:18:01.064: Fetch 65536
2019-01-29 20:18:01.079: Fetch 65536
2019-01-29 20:18:01.097: Fetch 65536
2019-01-29 20:18:01.121: Fetch 65536
2019-01-29 20:18:01.135: Fetch 65536
2019-01-29 20:18:01.162: Fetch 65536
2019-01-29 20:18:01.189: Fetch 65536
2019-01-29 20:18:01.216: Fetch 65536
2019-01-29 20:18:01.228: Fetch 65536
2019-01-29 20:18:01.240: Fetch 65536
2019-01-29 20:18:01.253: Fetch 65536
2019-01-29 20:18:01.269: Fetch 65536
2019-01-29 20:18:01.281: Fetch 65536
2019-01-29 20:18:01.299: Fetch 65536
2019-01-29 20:18:01.319: Fetch 65536
2019-01-29 20:18:01.336: Fetch 65536
2019-01-29 20:18:01.354: Fetch 65536
2019-01-29 20:18:01.371: Fetch 65536
2019-01-29 20:18:01.386: Fetch 65536
2019-01-29 20:18:01.400: Fetch 65536
2019-01-29 20:18:01.416: Fetch 65536
2019-01-29 20:18:01.433: Fetch 65536
2019-01-29 20:18:01.446: Fetch 65536
2019-01-29 20:18:01.460: Fetch 65536
2019-01-29 20:18:01.472: Fetch 65536
2019-01-29 20:18:01.485: Fetch 65536
2019-01-29 20:18:01.499: Fetch 65536
2019-01-29 20:18:01.516: Fetch 65536
2019-01-29 20:18:01.535: Fetch 65536
2019-01-29 20:18:01.551: Fetch 65536
2019-01-29 20:18:01.563: Fetch 65536
2019-01-29 20:18:01.576: Fetch 65536
2019-01-29 20:18:01.588: Fetch 65536
2019-01-29 20:18:01.605: Fetch 65536
2019-01-29 20:18:01.622: Fetch 65536
2019-01-29 20:18:01.636: Fetch 65536
2019-01-29 20:18:01.647: Fetch 65536
2019-01-29 20:18:01.659: Fetch 65536
2019-01-29 20:18:01.670: Fetch 65536
2019-01-29 20:18:01.685: Fetch 65536
2019-01-29 20:18:01.698: Fetch 65536
2019-01-29 20:18:01.713: Fetch 65536
2019-01-29 20:18:01.727: Fetch 65536
2019-01-29 20:18:01.741: Fetch 65536
2019-01-29 20:18:01.754: Fetch 65536
2019-01-29 20:18:01.766: Fetch 65536
2019-01-29 20:18:01.784: Fetch 65536
2019-01-29 20:18:01.799: Fetch 65536
2019-01-29 20:18:01.815: Fetch 65536
2019-01-29 20:18:01.825: Fetch 65536
2019-01-29 20:18:01.839: Fetch 65536
2019-01-29 20:18:11.399: Fetch 65536
2019-01-29 20:18:11.414: Fetch 65536
2019-01-29 20:18:11.426: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 15506929, m_contentLength = 15493606
2019-01-29 20:18:11.440: Fetch 65536
2019-01-29 20:18:11.451: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 15534566, m_contentLength = 15493606
2019-01-29 20:18:11.463: Fetch 65536
2019-01-29 20:18:11.482: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 15547889, m_contentLength = 15493606
2019-01-29 20:18:11.500: Fetch 65536
2019-01-29 20:18:11.518: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 15559142, m_contentLength = 15493606
2019-01-29 20:18:11.536: HttpURLConnection: Returning -1 (end of file)!2019-01-29 20:18:11:548  not enough data, calling setNextToCurrent, framesToRead = 458752
2019-01-29 20:18:11:549  after setNextToCurrent: current = 0xd184f300, m_next = 0x0
2019-01-29 20:18:11.571: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:18:12.030: HttpURLConnection: contentLength = 46687663 for Tidal
2019-01-29 20:18:12.042: Fetch 65536
2019-01-29 20:18:12.055: Fetch 335296
2019-01-29 20:18:12.115: Fetch 252358
2019-01-29 20:18:12.137: Fetch 159686
2019-01-29 20:18:12.148: Fetch 81494
2019-01-29 20:18:12.156: Fetch 65536
2019-01-29 20:18:12.166: Fetch 42784
2019-01-29 20:18:12.225: Fetch 65536
2019-01-29 20:18:12.234: Fetch 65536
2019-01-29 20:18:12.244: Fetch 65536
2019-01-29 20:18:12.254: Fetch 65536
2019-01-29 20:18:12.272: Fetch 65536
2019-01-29 20:18:12.298: Fetch 65536
2019-01-29 20:18:12.311: Fetch 65536
2019-01-29 20:18:12.324: Fetch 65536
2019-01-29 20:18:12.335: Fetch 65536
2019-01-29 20:18:12.344: Fetch 65536
2019-01-29 20:18:12.353: Fetch 65536
2019-01-29 20:18:12.362: Fetch 65536
2019-01-29 20:18:12.371: Fetch 65536
2019-01-29 20:18:12.385: Fetch 65536
2019-01-29 20:18:12.397: Fetch 65536
2019-01-29 20:18:12.412: Fetch 65536
2019-01-29 20:18:12.431: Fetch 65536
2019-01-29 20:18:12.463: Fetch 65536
2019-01-29 20:18:12.475: Fetch 65536
2019-01-29 20:18:12.484: Fetch 65536
2019-01-29 20:18:12.494: Fetch 65536
2019-01-29 20:18:12.505: Fetch 65536
2019-01-29 20:18:12.517: Fetch 65536
2019-01-29 20:18:12.527: Fetch 65536
2019-01-29 20:18:12.541: Fetch 65536
2019-01-29 20:18:12.552: Fetch 65536
2019-01-29 20:18:12.564: Fetch 65536
2019-01-29 20:18:12.637: Fetch 65536
2019-01-29 20:18:12.659: Fetch 65536
2019-01-29 20:18:12.674: Fetch 65536
2019-01-29 20:18:12.693: Fetch 65536
2019-01-29 20:18:12.706: Fetch 65536
2019-01-29 20:18:12.720: Fetch 65536
2019-01-29 20:18:12.735: Fetch 65536
2019-01-29 20:18:12.745: Fetch 65536
2019-01-29 20:18:12.757: Fetch 65536
2019-01-29 20:18:12.774: Fetch 65536
2019-01-29 20:18:12.786: Fetch 65536
2019-01-29 20:18:12.800: Fetch 65536
2019-01-29 20:18:12.816: Fetch 65536
2019-01-29 20:18:12.827: Fetch 65536
2019-01-29 20:18:12.840: Fetch 65536
2019-01-29 20:18:12.856: Fetch 65536
2019-01-29 20:18:12.875: Fetch 65536
2019-01-29 20:18:12.890: Fetch 65536
2019-01-29 20:18:12.914: Fetch 65536
2019-01-29 20:18:12.926: Fetch 65536
2019-01-29 20:18:23.304: Fetch 65536
2019-01-29 20:18:23.340: Fetch 65536
2019-01-29 20:18:23.358: Fetch 65536
2019-01-29 20:18:23.372: Fetch 65536
2019-01-29 20:18:23.389: Fetch 65536
2019-01-29 20:18:23.407: Fetch 65536
2019-01-29 20:18:23.420: Fetch 65536
2019-01-29 20:18:23.437: Fetch 65536
2019-01-29 20:18:23.452: Fetch 65536
2019-01-29 20:18:23.465: Fetch 65536
2019-01-29 20:18:23.484: Fetch 65536
2019-01-29 20:18:23.494: Fetch 65536
2019-01-29 20:18:23.501: Fetch 65536
2019-01-29 20:18:23.506: Fetch 65536
2019-01-29 20:18:23.516: Fetch 65536
2019-01-29 20:18:23.524: Fetch 65536
2019-01-29 20:18:23.533: Fetch 65536
2019-01-29 20:18:23.566: Fetch 65536
2019-01-29 20:18:23.599: Fetch 65536
2019-01-29 20:18:23.622: Fetch 65536
2019-01-29 20:18:23.637: Fetch 65536
2019-01-29 20:18:23.654: Fetch 65536
2019-01-29 20:18:23.664: Fetch 65536
2019-01-29 20:18:23.678: Fetch 65536
2019-01-29 20:18:23.690: Fetch 65536
2019-01-29 20:18:23.707: Fetch 65536
2019-01-29 20:18:23.718: Fetch 65536
2019-01-29 20:18:23.729: Fetch 65536
2019-01-29 20:18:23.744: Fetch 65536
2019-01-29 20:18:23.755: Fetch 65536
2019-01-29 20:18:23.766: Fetch 65536
2019-01-29 20:18:23.776: Fetch 65536
2019-01-29 20:18:23.783: Fetch 65536
2019-01-29 20:18:23.790: Fetch 65536
2019-01-29 20:18:23.797: Fetch 65536
2019-01-29 20:18:23.802: Fetch 65536
2019-01-29 20:18:23.809: Fetch 65536
2019-01-29 20:18:23.816: Fetch 65536
2019-01-29 20:18:23.823: Fetch 65536
2019-01-29 20:18:23.829: Fetch 65536
2019-01-29 20:18:23.835: Fetch 65536
2019-01-29 20:18:23.843: Fetch 65536
2019-01-29 20:18:23.849: Fetch 65536
2019-01-29 20:18:23.856: Fetch 65536
2019-01-29 20:18:23.861: Fetch 65536
2019-01-29 20:18:23.867: Fetch 65536
2019-01-29 20:18:23.873: Fetch 65536
2019-01-29 20:18:23.879: Fetch 65536
2019-01-29 20:18:23.884: Fetch 65536
2019-01-29 20:18:23.890: Fetch 65536
2019-01-29 20:18:23.895: Fetch 65536
2019-01-29 20:18:23.901: Fetch 65536
2019-01-29 20:18:23.906: Fetch 65536
2019-01-29 20:18:23.912: Fetch 655362019-01-29 20:18:24:736  FileQueue dump CB: switch required
2019-01-29 20:18:24:737  FileQueue dump: current = 0xd184f300, Tidal
2019-01-29 20:18:24:738  FileQueue dump: next    = 0x0,
2019-01-29 20:18:24:738  filldatacb: stopAndGo 0
2019-01-29 20:18:24.763: Open ASYNC: Bartók: Sonata For Solo Violin - Fuga
2019-01-29 20:18:25.225: onPositiveResult, i_isNextPosition = true
2019-01-29 20:18:25.245: Message MESSAGE_TYPE_QUEUE_SONG
2019-01-29 20:18:25.261: HttpURLConnection: fetchDataForReal: m_HttpURLConnection == null, creating request, this = com.extreamsd.usbaudioplayershared.ESDHTTPClient@23863a3
2019-01-29 20:18:25.285: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:18:25.472: HttpURLConnection: contentLength = 45056509 for Tidal
2019-01-29 20:18:25.507: Fetch 65536
2019-01-29 20:18:25.534: Fetch 334689
2019-01-29 20:18:25.559: Fetch 219761
2019-01-29 20:18:25.603: Fetch 161841
2019-01-29 20:18:25.636: Fetch 79921
2019-01-29 20:18:25.656: Fetch 65536
2019-01-29 20:18:25.665: Fetch 65536
2019-01-29 20:18:25.752: Fetch 65536
2019-01-29 20:18:25.774: Fetch 65536
2019-01-29 20:18:25.786: Fetch 65536
2019-01-29 20:18:25.803: Fetch 65536
2019-01-29 20:18:25.812: Fetch 65536
2019-01-29 20:18:25.820: Fetch 65536
2019-01-29 20:18:25.829: Fetch 65536
2019-01-29 20:18:25.837: Fetch 65536
2019-01-29 20:18:25.847: Fetch 65536
2019-01-29 20:18:25.862: Fetch 65536
2019-01-29 20:18:25.874: Fetch 65536
2019-01-29 20:18:25.886: Fetch 65536
2019-01-29 20:18:25.911: Fetch 65536
2019-01-29 20:18:25.926: Fetch 65536
2019-01-29 20:18:25.941: Fetch 65536
2019-01-29 20:18:25.953: Fetch 65536
2019-01-29 20:18:25.967: Fetch 65536
2019-01-29 20:18:25.977: Fetch 65536
2019-01-29 20:18:25.986: Fetch 65536
2019-01-29 20:18:25.995: Fetch 65536
2019-01-29 20:18:26.007: Fetch 65536
2019-01-29 20:18:26.022: Fetch 65536
2019-01-29 20:18:26.031: Fetch 65536
2019-01-29 20:18:26.048: Fetch 65536
2019-01-29 20:18:26.067: Fetch 65536
2019-01-29 20:18:26.077: Fetch 65536
2019-01-29 20:18:26.088: Fetch 65536
2019-01-29 20:18:26.107: Fetch 655362019-01-29 20:18:26:126  Current wasn't NULL, so setting next to Bartók: Sonata For Solo Violin - Fuga = Tidal
2019-01-29 20:18:26:126  after setNextDataSource: current = 0xd184f300, m_next = 0xd184f100
2019-01-29 20:18:26.142: Setting m_asyncInProgress to false in A
2019-01-29 20:18:35.129: Fetch 65536
2019-01-29 20:18:35.137: Fetch 65536
2019-01-29 20:18:35.145: Fetch 65536
2019-01-29 20:18:35.152: Fetch 65536
2019-01-29 20:18:35.160: Fetch 65536
2019-01-29 20:18:35.168: Fetch 65536
2019-01-29 20:18:35.176: Fetch 65536
2019-01-29 20:18:35.181: Fetch 65536
2019-01-29 20:18:35.188: Fetch 65536
2019-01-29 20:18:35.194: Fetch 65536
2019-01-29 20:18:35.199: Fetch 65536
2019-01-29 20:18:35.212: Fetch 65536
2019-01-29 20:18:35.221: Fetch 65536
2019-01-29 20:18:35.228: Fetch 65536
2019-01-29 20:18:35.235: Fetch 65536
2019-01-29 20:18:35.243: Fetch 65536
2019-01-29 20:18:35.251: Fetch 65536
2019-01-29 20:18:35.259: Fetch 65536
2019-01-29 20:18:35.268: Fetch 65536
2019-01-29 20:18:35.275: Fetch 65536
2019-01-29 20:18:35.283: Fetch 65536
2019-01-29 20:18:35.290: Fetch 65536
2019-01-29 20:18:35.296: Fetch 65536
2019-01-29 20:18:35.307: Fetch 65536
2019-01-29 20:18:35.314: Fetch 65536
2019-01-29 20:18:35.321: Fetch 65536
2019-01-29 20:18:35.327: Fetch 65536
2019-01-29 20:18:35.334: Fetch 65536
2019-01-29 20:18:35.340: Fetch 65536
2019-01-29 20:18:35.346: Fetch 65536
2019-01-29 20:18:35.353: Fetch 65536
2019-01-29 20:18:35.359: Fetch 65536
2019-01-29 20:18:35.366: Fetch 65536
2019-01-29 20:18:35.373: Fetch 65536
2019-01-29 20:18:35.379: Fetch 65536
2019-01-29 20:18:35.386: Fetch 65536
2019-01-29 20:18:35.393: Fetch 65536
2019-01-29 20:18:35.400: Fetch 65536
2019-01-29 20:18:35.407: Fetch 65536
2019-01-29 20:18:35.414: Fetch 65536
2019-01-29 20:18:35.422: Fetch 65536
2019-01-29 20:18:35.428: Fetch 65536
2019-01-29 20:18:35.435: Fetch 65536
2019-01-29 20:18:35.445: Fetch 65536
2019-01-29 20:18:35.453: Fetch 65536
2019-01-29 20:18:35.464: Fetch 65536
2019-01-29 20:18:35.472: Fetch 65536
2019-01-29 20:18:35.479: Fetch 65536
2019-01-29 20:18:35.487: Fetch 65536
2019-01-29 20:18:35.495: Fetch 65536
2019-01-29 20:18:35.505: Fetch 65536
2019-01-29 20:18:35.512: Fetch 65536
2019-01-29 20:18:35.520: Fetch 65536
2019-01-29 20:18:35.529: Fetch 65536
2019-01-29 20:18:35.539: Fetch 65536
2019-01-29 20:18:35.549: Fetch 65536
2019-01-29 20:18:35.556: Fetch 65536
2019-01-29 20:18:36.706: Message MESSAGE_TYPE_STOP
2019-01-29 20:18:36.718: Stop2019-01-29 20:18:36:719   ===================> STOP <====================
2019-01-29 20:18:36.754: MediaService: onDestroy
2019-01-29 20:18:36.759: MediaService: onDestroy, player stop
2019-01-29 20:18:36.770: Remove media session
2019-01-29 20:18:36.779: MediaService: onDestroy, send exit
2019-01-29 20:18:36.794: Closing DB
2019-01-29 20:18:36.801: MediaService: END onDestroy
2019-01-29 20:18:36.928: onDestroy SSPA2019-01-29 20:18:37:316  ATN stopped
2019-01-29 20:18:37.324: Message MESSAGE_TYPE_STOP
2019-01-29 20:18:37.330: Message MESSAGE_TYPE_EXIT
2019-01-29 20:18:37.335: T: delete AS2019:01:29 20:18:37.336 DTOR AS
2019-01-29 20:18:37:336  libusb_exit!
2019:01:29 20:18:37.341 Deleting old device
2019:01:29 20:18:37.341 Deleted old device
2019-01-29 20:18:37:341  Deleting device in thread
2019-01-29 20:18:37.345: T: AS deleted2019:01:29 20:18:37.412 DTOR OD 0xe83cf540
2019:01:29 20:18:37.412 Send exit message to decode thread
2019-01-29 20:18:37:413  Deleting device done
2019-01-29 20:19:21.627: App: loading 3rd party libs
2019-01-29 20:19:21.660: Loaded
2019-01-29 20:19:21.675: SSPA oncreate
2019-01-29 20:19:21.722: MediaService onCreate com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:19:21.726: Start LG-H932
lge
joan
26
com.extreamsd.usbaudioplayerpro 5.0.7
2019-01-29 20:19:21.740: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c2019:01:29 20:19:21.755 CTOR AS
2019-01-29 20:19:21.819: Android driver = 12019:01:29 20:19:21.821 setOutputType 2
2019:01:29 20:19:21.821 new ATN
2019:01:29 20:19:21.822 CTOR ATN 0xe83cf400
2019-01-29 20:19:21.833: Logmethod = 1
2019-01-29 20:19:21.944: logFileName = /storage/emulated/0/UAPP/UAPP.txt, log to file = true
2019-01-29 20:19:21.950: Calling getUSBAudioDevices()getUSBAudioDevices
getDevices
No USB devices found
2019-01-29 20:19:21:953  USBAudioManager: Finding audio device for rooted devices: 0 USB devices
Devices to query = 0, hasClass2Vendor5401 = false
2019-01-29 20:19:21.984: loadPlayQueueInfo
2019-01-29 20:19:21.996: loadPlayQueueInfo done, diff = 8, counter = 19, i_queue.size = 19
2019-01-29 20:19:22.002: After reloadQueue
2019-01-29 20:19:22.013: #devices 4
2019-01-29 20:19:22.016: Output 0
2019-01-29 20:19:22.021:     ID = 1
2019-01-29 20:19:22.026:     Type = 1
2019-01-29 20:19:22.030:     Name = LG-H932
2019-01-29 20:19:22.034: #rates = 1
2019-01-29 20:19:22.038:     Rate = 48000
2019-01-29 20:19:22.042: Output 1
2019-01-29 20:19:22.046:     ID = 2
2019-01-29 20:19:22.050:     Type = 2
2019-01-29 20:19:22.054:     Name = LG-H932
2019-01-29 20:19:22.058: #rates = 1
2019-01-29 20:19:22.062:     Rate = 48000
2019-01-29 20:19:22.066: Output 2
2019-01-29 20:19:22.070:     ID = 22
2019-01-29 20:19:22.074:     Type = 4
2019-01-29 20:19:22.078:     Name = LG-H932
2019-01-29 20:19:22.082: #rates = 1
2019-01-29 20:19:22.086:     Rate = 48000
2019-01-29 20:19:22.090: Output 3
2019-01-29 20:19:22.094:     ID = 5
2019-01-29 20:19:22.097:     Type = 18
2019-01-29 20:19:22.101:     Name = LG-H932
2019-01-29 20:19:22.105: #rates = 2
2019-01-29 20:19:22.109:     Rate = 8000
2019-01-29 20:19:22.113:     Rate = 16000
2019-01-29 20:19:22.121: Service created
2019-01-29 20:19:22.125: onStartCommand
2019-01-29 20:19:22.134: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:19:22.197: Connectivity change, state = CONNECTED, type = VPN
2019-01-29 20:19:22.235: CT 772195341009, 949194403724, 2679720
2019-01-29 20:19:22.238: DT
2019-01-29 20:19:22.401: onStartCommand
2019-01-29 20:19:22.410: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:19:22.422: onStartCommand
2019-01-29 20:19:22.432: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:19:22.475: postReloadQueue, i_currentPos = 13374
2019-01-29 20:19:22.479: setting async in prog because setting two songs
2019-01-29 20:19:22.485: Open ASYNC: Carter: Sonata For Violoncello And Piano - Moderato
2019-01-29 20:19:22.765: onPositiveResult, i_isNextPosition = false
2019-01-29 20:19:22.773: Message MESSAGE_TYPE_QUEUE_SONG2019-01-29 20:19:22:774  Current was NULL, so current becomes Carter: Sonata For Violoncello And Piano - Moderato = Tidal
2019-01-29 20:19:22:774  after setNextDataSource: current = 0xd04e8400, m_next = 0x0
2019-01-29 20:19:22.778: Open ASYNC: Bartók: Sonata For Solo Violin - Fuga
2019-01-29 20:19:22.863: onPositiveResult, i_isNextPosition = true
2019-01-29 20:19:22.871: Message MESSAGE_TYPE_QUEUE_SONG2019-01-29 20:19:22:871  Current wasn't NULL, so setting next to Bartók: Sonata For Solo Violin - Fuga = Tidal
2019-01-29 20:19:22:871  after setNextDataSource: current = 0xd04e8400, m_next = 0xd04e8500
2019-01-29 20:19:22.875: Setting m_asyncInProgress to false in A
2019-01-29 20:19:24.308: onStartCommand
2019-01-29 20:19:24.338: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:19:25.782: onStartCommand
2019-01-29 20:19:25.806: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:19:25.834: onStartCommand
2019-01-29 20:19:25.858: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:19:27.266: setting async in prog because setting two songs
2019-01-29 20:19:27.266: Message MESSAGE_TYPE_STOP
2019-01-29 20:19:27.277: Message MESSAGE_TYPE_STOP
2019-01-29 20:19:27.277: Open ASYNC: Carter: Sonata For Violoncello And Piano - Moderato
2019-01-29 20:19:27.504: onPositiveResult, i_isNextPosition = false
2019-01-29 20:19:27.543: Message MESSAGE_TYPE_QUEUE_SONG2019-01-29 20:19:27:544  Current was NULL, so current becomes Carter: Sonata For Violoncello And Piano - Moderato = Tidal
2019-01-29 20:19:27:544  after setNextDataSource: current = 0xcfaaaf00, m_next = 0x0
2019-01-29 20:19:27.568: Open ASYNC: Bartók: Sonata For Solo Violin - Fuga
2019-01-29 20:19:27.569: Message MESSAGE_TYPE_START
2019-01-29 20:19:27.583: linkSpeed = 866 Mbps
2019-01-29 20:19:27.592: Restrict bg status = 32019:01:29 20:19:27.597 setOutputType 2
2019-01-29 20:19:27.606: HttpURLConnection: fetchDataForReal: m_HttpURLConnection == null, creating request, this = com.extreamsd.usbaudioplayershared.ESDHTTPClient@cb340be
2019-01-29 20:19:27.616: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:19:27.650: onPositiveResult, i_isNextPosition = true
2019-01-29 20:19:27.838: HttpURLConnection: contentLength = 46687663 for Tidal
2019-01-29 20:19:27.847: Fetch 65536
2019-01-29 20:19:27.872: Fetch 335296
2019-01-29 20:19:27.914: Fetch 239192
2019-01-29 20:19:27.927: Fetch 116312
2019-01-29 20:19:27.942: Fetch 103080
2019-01-29 20:19:27.955: Fetch 65536
2019-01-29 20:19:27.964: Fetch 65536
2019-01-29 20:19:28.020: Fetch 65536
2019-01-29 20:19:28.044: Fetch 65536
2019-01-29 20:19:28.065: Fetch 65536
2019-01-29 20:19:28.077: Fetch 65536
2019-01-29 20:19:28.088: Fetch 65536
2019-01-29 20:19:28.100: Fetch 65536
2019-01-29 20:19:28.114: Fetch 65536
2019-01-29 20:19:28.134: Fetch 65536
2019-01-29 20:19:28.144: Fetch 65536
2019-01-29 20:19:28.155: Fetch 65536
2019-01-29 20:19:28.166: Fetch 65536
2019-01-29 20:19:28.183: Fetch 65536
2019-01-29 20:19:28.195: Fetch 65536
2019-01-29 20:19:28.206: Fetch 65536
2019-01-29 20:19:28.218: Fetch 65536
2019-01-29 20:19:28.230: Fetch 65536
2019-01-29 20:19:28.243: Fetch 65536
2019-01-29 20:19:28.260: Fetch 65536
2019-01-29 20:19:28.272: Fetch 65536
2019-01-29 20:19:28.287: Fetch 65536
2019-01-29 20:19:28.302: Fetch 65536
2019-01-29 20:19:28.313: Fetch 65536
2019-01-29 20:19:28.325: Fetch 65536
2019-01-29 20:19:28.337: Fetch 65536
2019-01-29 20:19:28.360: Fetch 65536
2019-01-29 20:19:28.373: Fetch 655362019-01-29 20:19:28:394  OutputDevice::preparePlayback, i_singleBufferSize = 131072, i_offsetMilliSeconds = 0, i_isWiredHeadsetOn = 1, i_upsampleMethod = 0
2019-01-29 20:19:28:395  setActualDeviceSampleRate: decoder rate = 44100
2019-01-29 20:19:28:395  setActualDeviceSampleRate: getNearestDeviceSampleRate = 44100
2019-01-29 20:19:28:395  Device rate becomes 44100
2019-01-29 20:19:28:395  m_diskBufferSizeFrames = 524288
2019-01-29 20:19:28.448: Fetch 65536
2019-01-29 20:19:28.456: Fetch 65536
2019-01-29 20:19:28.466: Fetch 65536
2019-01-29 20:19:28.478: Fetch 65536
2019-01-29 20:19:28.489: Fetch 65536
2019-01-29 20:19:28.501: Fetch 65536
2019-01-29 20:19:28.512: Fetch 65536
2019-01-29 20:19:28.523: Fetch 65536
2019-01-29 20:19:28.535: Fetch 65536
2019-01-29 20:19:28.555: Fetch 65536
2019-01-29 20:19:28.569: Fetch 65536
2019-01-29 20:19:28.585: Fetch 65536
2019-01-29 20:19:28.601: Fetch 65536
2019-01-29 20:19:28.613: Fetch 65536
2019-01-29 20:19:28.627: Fetch 65536
2019-01-29 20:19:28.649: Fetch 65536
2019-01-29 20:19:28.665: Fetch 65536
2019-01-29 20:19:28.679: Fetch 65536
2019-01-29 20:19:28.691: Fetch 65536
2019-01-29 20:19:28.706: Fetch 65536
2019-01-29 20:19:28.718: Fetch 65536
2019-01-29 20:19:28.733: Fetch 65536
2019-01-29 20:19:28.748: Fetch 65536
2019-01-29 20:19:28.760: Fetch 65536
2019-01-29 20:19:28.774: Fetch 65536
2019-01-29 20:19:28.789: Fetch 65536
2019-01-29 20:19:28.813: Fetch 65536
2019-01-29 20:19:28.834: Fetch 65536
2019-01-29 20:19:28.853: Fetch 65536
2019-01-29 20:19:28.865: Fetch 65536
2019-01-29 20:19:28.879: Fetch 65536
2019-01-29 20:19:28.894: Fetch 65536
2019-01-29 20:19:28.907: Fetch 65536
2019-01-29 20:19:28.920: Fetch 65536
2019-01-29 20:19:28.935: Fetch 65536
2019-01-29 20:19:28.947: Fetch 65536
2019-01-29 20:19:28.959: Fetch 65536
2019-01-29 20:19:28.972: Fetch 65536
2019-01-29 20:19:28.985: Fetch 65536
2019-01-29 20:19:29.000: Fetch 65536
2019-01-29 20:19:29.014: Fetch 65536
2019-01-29 20:19:29.028: Fetch 65536
2019-01-29 20:19:29.041: Fetch 65536
2019-01-29 20:19:29.054: Fetch 65536
2019-01-29 20:19:29.069: Fetch 65536
2019-01-29 20:19:29.082: Fetch 65536
2019-01-29 20:19:29.094: Fetch 65536
2019-01-29 20:19:29.109: Fetch 65536
2019-01-29 20:19:29.121: Fetch 65536
2019-01-29 20:19:29.134: Fetch 65536
2019-01-29 20:19:29.150: Fetch 65536
2019-01-29 20:19:29.164: Fetch 65536
2019-01-29 20:19:29.175: Fetch 65536
2019-01-29 20:19:29.191: Fetch 65536
2019-01-29 20:19:29.203: Fetch 65536
2019-01-29 20:19:29.218: Fetch 65536
2019-01-29 20:19:29.235: Fetch 65536
2019-01-29 20:19:29.249: Fetch 65536
2019-01-29 20:19:29.265: Fetch 65536
2019-01-29 20:19:29.277: Fetch 65536
2019-01-29 20:19:29.290: Fetch 65536
2019-01-29 20:19:29.306: Fetch 65536
2019-01-29 20:19:29.320: Fetch 65536
2019-01-29 20:19:29.341: Fetch 65536
2019-01-29 20:19:29.360: Fetch 65536
2019-01-29 20:19:29.382: Fetch 65536
2019-01-29 20:19:29.402: Fetch 65536
2019-01-29 20:19:29.420: Fetch 65536
2019-01-29 20:19:29.442: Fetch 65536
2019-01-29 20:19:29.480: Fetch 65536
2019-01-29 20:19:29.517: Fetch 65536
2019-01-29 20:19:29.538: Fetch 65536
2019-01-29 20:19:29.548: Fetch 65536
2019-01-29 20:19:29.562: Fetch 65536
2019-01-29 20:19:29.575: Fetch 65536
2019-01-29 20:19:29.587: Fetch 65536
2019-01-29 20:19:29.610: Fetch 65536
2019-01-29 20:19:29.622: Fetch 65536
2019-01-29 20:19:29.643: Fetch 65536
2019-01-29 20:19:29.657: Fetch 65536
2019-01-29 20:19:29.667: Fetch 655362019-01-29 20:19:29:671  createNewAudioTrack! m_sampleRate = 44100
2019-01-29 20:19:29:671  AudioTrackNative::init
2019-01-29 20:19:29:673  Creating AudioTrack
2019:01:29 20:19:29.673 prep ATN i_sampleRate = 44100, i_flags = 400000, i_format = 0, bufferSize = 131072
2019-01-29 20:19:29:674  V8, flags = 400001, format = 6
2019-01-29 20:19:29:705  bufferFrames = 131072 for sr 44100
2019-01-29 20:19:29.723: Play Android, HiRes = true2019-01-29 20:19:29:724  ATN start
2019-01-29 20:19:29.791: Message MESSAGE_TYPE_QUEUE_SONG2019-01-29 20:19:29:793  Current wasn't NULL, so setting next to Bartók: Sonata For Solo Violin - Fuga = Tidal
2019-01-29 20:19:29:793  after setNextDataSource: current = 0xcfaaaf00, m_next = 0xe2176900
2019-01-29 20:19:29.810: Setting m_asyncInProgress to false in A
2019-01-29 20:19:35.790: Message MESSAGE_TYPE_PAUSE2019-01-29 20:19:35:791   ===================> STOP <====================
2019-01-29 20:19:36:404  ATN stopped
2019-01-29 20:20:13.567: Focus change -2
2019-01-29 20:20:13.582: Pause due to focus loss transient
2019-01-29 20:20:33.700: Focus change 1
2019-01-29 20:21:58.635: onDestroy SSPA
2019-01-29 20:22:12.126: onStartCommand
2019-01-29 20:22:12.136: Message MESSAGE_TYPE_STOP
2019-01-29 20:22:12.141: MediaService: onDestroy
2019-01-29 20:22:12.149: MediaService: onDestroy, player stop
2019-01-29 20:22:12.159: Message MESSAGE_TYPE_STOP
2019-01-29 20:22:12.165: Remove media session
2019-01-29 20:22:12.173: MediaService: onDestroy, send exit
2019-01-29 20:22:12.180: Message MESSAGE_TYPE_EXIT
2019-01-29 20:22:12.186: T: delete AS
2019-01-29 20:22:12.186: Closing DB2019:01:29 20:22:12.187 DTOR AS
2019-01-29 20:22:12:187  libusb_exit!
2019:01:29 20:22:12.187 Deleting old device
2019:01:29 20:22:12.188 Deleted old device
2019-01-29 20:22:12:187  Deleting device in thread
2019:01:29 20:22:12.192 DTOR OD 0xe83cf400
2019:01:29 20:22:12.192 Send exit message to decode thread
2019-01-29 20:22:12.192: MediaService: END onDestroy
2019-01-29 20:22:12.192: T: AS deleted2019-01-29 20:22:12:194  Deleting device done
Jan 30, 2019 at 8:25 AM Post #2,391 of 6,408
* NO glitches EVER on local files, tested up to DSD256 and PCM 352kHz.
* Streaming Tidal on WiFi glitches consistently on both MQA and 16/44 tracks, usually more often on higher bandwidth tracks.
* Very, very occasionally do I hear glitches when streaming in Tidal app on WiFi. NEVER when playing offline in Tidal app.
* I do not stream on my cheap mobile data plan, so cannot speak to that. Have not tried Network (uPnP etc) streaming either.
I did some more testing yesterday. Things that affect this:
* Switching back and forth between UAPP and other apps that use the DAC, such as Tidal app or LG Music app. Rebooting solves this particular aspect. (I've reported this before.)
* Apps that run in background, such as ones with persistent notifications. I uninstalled Notification History app (helped), Deactivated Blokada (didn't help), Disabled Blokada Keep-alive persistent notification (helped), Settings->General-Developer options->Inactive apps->Made all apps Inactive that I could (helped). Even with all of those, I'd still get a pop in UAPP every 10 mins or so.
That's still in Battery Saver mode, deliberately, because I want to see if I can make that work (and it does work in Tidal app 99.9% of the time). Tomorrow I'll try excluding UAPP from Battery Saver and see if that helps.
I finally enabled logging in UAPP Settings->Logging->Log to file. I forgot to delete UAPP.txt first, so there was bunch of older log entries. I deleted everything before 2019-01-29, which is when all these tests were done. UAPP.txt attached.
I should add I have a T-Mobile H932 with Oreo.
Edit: Attaching UAPP.txt didn't work. ZIP didn't work either. Pasted into spoiler instead.
Code:
2019-01-29 19:08:08.254: App: loading 3rd party libs
2019-01-29 19:08:08.329: Loaded
2019-01-29 19:08:08.359: SSPA oncreate
2019-01-29 19:08:08.427: MediaService onCreate com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:08.433: Start LG-H932
lge
joan
26
2019-01-29 19:08:08.462: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b582019:01:29 19:08:08.487 CTOR AS
2019-01-29 19:08:08.566: Android driver = 12019:01:29 19:08:08.567 setOutputType 2
2019:01:29 19:08:08.568 new ATN
2019:01:29 19:08:08.569 CTOR ATN 0xe83cf540
2019-01-29 19:08:08.587: Logmethod = 0
2019-01-29 19:08:08.713: logFileName = /storage/emulated/0/UAPP/UAPP.txt, log to file = false
2019-01-29 19:08:08.720: Calling getUSBAudioDevices()
2019-01-29 19:08:08.764: loadPlayQueueInfo
2019-01-29 19:08:08.784: loadPlayQueueInfo done, diff = 16, counter = 44, i_queue.size = 44
2019-01-29 19:08:08.792: After reloadQueue
2019-01-29 19:08:08.805: #devices 4
2019-01-29 19:08:08.810: Output 0
2019-01-29 19:08:08.815:     ID = 1
2019-01-29 19:08:08.819:     Type = 1
2019-01-29 19:08:08.824:     Name = LG-H932
2019-01-29 19:08:08.828: #rates = 1
2019-01-29 19:08:08.832:     Rate = 48000
2019-01-29 19:08:08.836: Output 1
2019-01-29 19:08:08.840:     ID = 2
2019-01-29 19:08:08.844:     Type = 2
2019-01-29 19:08:08.848:     Name = LG-H932
2019-01-29 19:08:08.852: #rates = 1
2019-01-29 19:08:08.855:     Rate = 48000
2019-01-29 19:08:08.860: Output 2
2019-01-29 19:08:08.864:     ID = 22
2019-01-29 19:08:08.868:     Type = 4
2019-01-29 19:08:08.872:     Name = LG-H932
2019-01-29 19:08:08.876: #rates = 1
2019-01-29 19:08:08.880:     Rate = 48000
2019-01-29 19:08:08.884: Output 3
2019-01-29 19:08:08.889:     ID = 5
2019-01-29 19:08:08.893:     Type = 18
2019-01-29 19:08:08.897:     Name = LG-H932
2019-01-29 19:08:08.900: #rates = 2
2019-01-29 19:08:08.904:     Rate = 8000
2019-01-29 19:08:08.908:     Rate = 16000
2019-01-29 19:08:08.918: Service created
2019-01-29 19:08:08.922: onStartCommand
2019-01-29 19:08:08.930: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:08.990: Connectivity change, state = CONNECTED, type = WIFI
2019-01-29 19:08:09.028: CT 772195341009, 949194403724, 2679720
2019-01-29 19:08:09.032: DT
2019-01-29 19:08:09.260: onStartCommand
2019-01-29 19:08:09.274: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:09.290: onStartCommand
2019-01-29 19:08:09.298: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:09.375: postReloadQueue, i_currentPos = 103762
2019-01-29 19:08:13.181: onStartCommand
2019-01-29 19:08:13.194: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:13.224: onStartCommand
2019-01-29 19:08:13.246: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:18.317: onStartCommand
2019-01-29 19:08:18.329: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:36.477: onStartCommand
2019-01-29 19:08:36.499: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:36.551: onStartCommand
2019-01-29 19:08:36.569: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:08:43.722: linkSpeed = 866 Mbps
2019-01-29 19:08:43.732: Restrict bg status = 32019:01:29 19:08:43.746 setOutputType 2
2019:01:29 19:08:44.582 prep ATN i_sampleRate = 44100, i_flags = 400000, i_format = 0, bufferSize = 131072
2019-01-29 19:08:44.639: Play Android, HiRes = true
2019-01-29 19:09:18.730: onStartCommand
2019-01-29 19:09:18.801: MediaService: onDestroy
2019-01-29 19:09:18.816: MediaService: onDestroy, player stop
2019-01-29 19:09:18.832: Remove media session
2019-01-29 19:09:18.839: MediaService: onDestroy, send exit
2019-01-29 19:09:18.847: T: delete AS2019:01:29 19:09:18.848 DTOR AS
2019:01:29 19:09:18.848 Deleting old device
2019:01:29 19:09:18.849 Deleted old device
2019:01:29 19:09:18.852 DTOR OD 0xe83cf540
2019:01:29 19:09:18.852 Send exit message to decode thread
2019-01-29 19:09:18.853: Closing DB
2019-01-29 19:09:18.856: T: AS deleted
2019-01-29 19:09:18.859: MediaService: END onDestroy
2019-01-29 19:09:18.937: onDestroy SSPA
2019-01-29 19:11:24.764: App: loading 3rd party libs
2019-01-29 19:11:24.799: Loaded
2019-01-29 19:11:24.812: SSPA oncreate
2019-01-29 19:11:24.865: MediaService onCreate com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:24.870: Start LG-H932
lge
joan
26
2019-01-29 19:11:24.887: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b582019:01:29 19:11:24.916 CTOR AS
2019-01-29 19:11:24.975: Android driver = 12019:01:29 19:11:24.977 setOutputType 2
2019:01:29 19:11:24.977 new ATN
2019:01:29 19:11:24.978 CTOR ATN 0xe83ceb40
2019-01-29 19:11:24.989: Logmethod = 0
2019-01-29 19:11:25.101: logFileName = /storage/emulated/0/UAPP/UAPP.txt, log to file = false
2019-01-29 19:11:25.107: Calling getUSBAudioDevices()
2019-01-29 19:11:25.147: loadPlayQueueInfo
2019-01-29 19:11:25.160: loadPlayQueueInfo done, diff = 8, counter = 19, i_queue.size = 19
2019-01-29 19:11:25.166: After reloadQueue
2019-01-29 19:11:25.174: #devices 4
2019-01-29 19:11:25.178: Output 0
2019-01-29 19:11:25.182:     ID = 1
2019-01-29 19:11:25.186:     Type = 1
2019-01-29 19:11:25.190:     Name = LG-H932
2019-01-29 19:11:25.194: #rates = 1
2019-01-29 19:11:25.198:     Rate = 48000
2019-01-29 19:11:25.203: Output 1
2019-01-29 19:11:25.207:     ID = 2
2019-01-29 19:11:25.211:     Type = 2
2019-01-29 19:11:25.216:     Name = LG-H932
2019-01-29 19:11:25.220: #rates = 1
2019-01-29 19:11:25.224:     Rate = 48000
2019-01-29 19:11:25.228: Output 2
2019-01-29 19:11:25.232:     ID = 22
2019-01-29 19:11:25.236:     Type = 4
2019-01-29 19:11:25.240:     Name = LG-H932
2019-01-29 19:11:25.244: #rates = 1
2019-01-29 19:11:25.248:     Rate = 48000
2019-01-29 19:11:25.252: Output 3
2019-01-29 19:11:25.255:     ID = 5
2019-01-29 19:11:25.259:     Type = 18
2019-01-29 19:11:25.263:     Name = LG-H932
2019-01-29 19:11:25.267: #rates = 2
2019-01-29 19:11:25.271:     Rate = 8000
2019-01-29 19:11:25.275:     Rate = 16000
2019-01-29 19:11:25.281: Service created
2019-01-29 19:11:25.286: onStartCommand
2019-01-29 19:11:25.294: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:25.362: Connectivity change, state = CONNECTED, type = WIFI
2019-01-29 19:11:25.401: CT 772195341009, 949194403724, 2679720
2019-01-29 19:11:25.404: DT
2019-01-29 19:11:25.583: onStartCommand
2019-01-29 19:11:25.591: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:25.602: onStartCommand
2019-01-29 19:11:25.615: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:25.663: postReloadQueue, i_currentPos = 34179
2019-01-29 19:11:27.412: onStartCommand
2019-01-29 19:11:27.438: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:27.453: onStartCommand
2019-01-29 19:11:27.471: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:29.972: onStartCommand
2019-01-29 19:11:29.991: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:35.024: onStartCommand
2019-01-29 19:11:35.037: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:35.077: onStartCommand
2019-01-29 19:11:35.096: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:11:37.601: linkSpeed = 866 Mbps
2019-01-29 19:11:37.613: Restrict bg status = 32019:01:29 19:11:37.622 setOutputType 2
2019:01:29 19:11:38.497 prep ATN i_sampleRate = 44100, i_flags = 400000, i_format = 0, bufferSize = 131072
2019-01-29 19:11:38.557: Play Android, HiRes = true
2019-01-29 19:12:29.980: onStartCommand
2019-01-29 19:12:30.000: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@22b5b58
2019-01-29 19:18:34.371: onStartCommand
2019-01-29 19:18:42.674: onStartCommand
2019-01-29 19:18:42.742: MediaService: onDestroy
2019-01-29 19:18:42.752: MediaService: onDestroy, player stop
2019-01-29 19:18:42.759: Remove media session
2019-01-29 19:18:42.766: MediaService: onDestroy, send exit
2019-01-29 19:18:42.774: T: delete AS2019:01:29 19:18:42.777 DTOR AS
2019:01:29 19:18:42.777 Deleting old device
2019:01:29 19:18:42.777 Deleted old device
2019-01-29 19:18:42.777: Closing DB
2019-01-29 19:18:42.784: MediaService: END onDestroy
2019-01-29 19:18:42.784: T: AS deleted2019:01:29 19:18:42.787 DTOR OD 0xe83ceb40
2019:01:29 19:18:42.787 Send exit message to decode thread
2019-01-29 19:18:42.885: onDestroy SSPA
2019-01-29 19:19:36.039: App: loading 3rd party libs
2019-01-29 19:19:36.085: Loaded
2019-01-29 19:19:36.108: SSPA oncreate
2019-01-29 19:19:36.160: MediaService onCreate com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:19:36.165: Start LG-H932
lge
joan
26
2019-01-29 19:19:36.181: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c2019:01:29 19:19:36.196 CTOR AS
2019-01-29 19:19:36.253: Android driver = 12019:01:29 19:19:36.254 setOutputType 2
2019:01:29 19:19:36.255 new ATN
2019:01:29 19:19:36.255 CTOR ATN 0xe83cf400
2019-01-29 19:19:36.267: Logmethod = 0
2019-01-29 19:19:36.381: logFileName = /storage/emulated/0/UAPP/UAPP.txt, log to file = false
2019-01-29 19:19:36.386: Calling getUSBAudioDevices()
2019-01-29 19:19:36.426: loadPlayQueueInfo
2019-01-29 19:19:36.438: loadPlayQueueInfo done, diff = 7, counter = 19, i_queue.size = 19
2019-01-29 19:19:36.444: After reloadQueue
2019-01-29 19:19:36.452: #devices 4
2019-01-29 19:19:36.456: Output 0
2019-01-29 19:19:36.461:     ID = 1
2019-01-29 19:19:36.465:     Type = 1
2019-01-29 19:19:36.469:     Name = LG-H932
2019-01-29 19:19:36.473: #rates = 1
2019-01-29 19:19:36.477:     Rate = 48000
2019-01-29 19:19:36.481: Output 1
2019-01-29 19:19:36.485:     ID = 2
2019-01-29 19:19:36.490:     Type = 2
2019-01-29 19:19:36.494:     Name = LG-H932
2019-01-29 19:19:36.499: #rates = 1
2019-01-29 19:19:36.503:     Rate = 48000
2019-01-29 19:19:36.507: Output 2
2019-01-29 19:19:36.511:     ID = 22
2019-01-29 19:19:36.515:     Type = 4
2019-01-29 19:19:36.519:     Name = LG-H932
2019-01-29 19:19:36.523: #rates = 1
2019-01-29 19:19:36.526:     Rate = 48000
2019-01-29 19:19:36.530: Output 3
2019-01-29 19:19:36.534:     ID = 5
2019-01-29 19:19:36.538:     Type = 18
2019-01-29 19:19:36.542:     Name = LG-H932
2019-01-29 19:19:36.546: #rates = 2
2019-01-29 19:19:36.550:     Rate = 8000
2019-01-29 19:19:36.555:     Rate = 16000
2019-01-29 19:19:36.563: Service created
2019-01-29 19:19:36.568: onStartCommand
2019-01-29 19:19:36.576: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:19:36.629: Connectivity change, state = CONNECTED, type = WIFI
2019-01-29 19:19:36.666: CT 772195341009, 949194403724, 2679720
2019-01-29 19:19:36.670: DT
2019-01-29 19:19:36.844: onStartCommand
2019-01-29 19:19:36.852: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:19:36.866: onStartCommand
2019-01-29 19:19:36.877: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:19:36.929: postReloadQueue, i_currentPos = 419073
2019-01-29 19:19:40.027: onStartCommand
2019-01-29 19:19:40.047: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:19:41.587: onStartCommand
2019-01-29 19:19:41.597: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:19:41.612: onStartCommand
2019-01-29 19:19:41.628: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:19:42.959: linkSpeed = 866 Mbps
2019-01-29 19:19:42.968: Restrict bg status = 32019:01:29 19:19:42.973 setOutputType 2
2019:01:29 19:19:44.080 prep ATN i_sampleRate = 44100, i_flags = 400000, i_format = 0, bufferSize = 131072
2019-01-29 19:19:44.176: Play Android, HiRes = true2019:01:29 19:34:33.644 Decoding took too long!  totalMilliSeconds = 620, milliSecondsAllowed = 185, framesToRead = 8192
2019-01-29 19:38:44.427: onStartCommand
2019-01-29 19:38:44.486: MediaService: onDestroy
2019-01-29 19:38:44.492: MediaService: onDestroy, player stop
2019-01-29 19:38:44.501: Remove media session
2019-01-29 19:38:44.508: MediaService: onDestroy, send exit
2019-01-29 19:38:44.514: T: delete AS2019:01:29 19:38:44.515 DTOR AS
2019:01:29 19:38:44.515 Deleting old device
2019:01:29 19:38:44.515 Deleted old device
2019:01:29 19:38:44.519 DTOR OD 0xe83cf400
2019:01:29 19:38:44.519 Send exit message to decode thread
2019-01-29 19:38:44.521: Closing DB
2019-01-29 19:38:44.522: T: AS deleted
2019-01-29 19:38:44.527: MediaService: END onDestroy
2019-01-29 19:38:44.623: onDestroy SSPA
2019-01-29 19:41:21.781: App: loading 3rd party libs
2019-01-29 19:41:21.823: Loaded
2019-01-29 19:41:21.838: SSPA oncreate
2019-01-29 19:41:21.886: MediaService onCreate com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:41:21.890: Start LG-H932
lge
joan
26
2019-01-29 19:41:21.906: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c2019:01:29 19:41:21.920 CTOR AS
2019-01-29 19:41:21.977: Android driver = 12019:01:29 19:41:21.978 setOutputType 2
2019:01:29 19:41:21.979 new ATN
2019:01:29 19:41:21.979 CTOR ATN 0xe83cf400
2019-01-29 19:41:21.991: Logmethod = 0
2019-01-29 19:41:22.103: logFileName = /storage/emulated/0/UAPP/UAPP.txt, log to file = false
2019-01-29 19:41:22.109: Calling getUSBAudioDevices()
2019-01-29 19:41:22.147: loadPlayQueueInfo
2019-01-29 19:41:22.159: loadPlayQueueInfo done, diff = 8, counter = 19, i_queue.size = 19
2019-01-29 19:41:22.165: After reloadQueue
2019-01-29 19:41:22.179: #devices 4
2019-01-29 19:41:22.184: Output 0
2019-01-29 19:41:22.188:     ID = 1
2019-01-29 19:41:22.192:     Type = 1
2019-01-29 19:41:22.197:     Name = LG-H932
2019-01-29 19:41:22.201: #rates = 1
2019-01-29 19:41:22.205:     Rate = 48000
2019-01-29 19:41:22.209: Output 1
2019-01-29 19:41:22.213:     ID = 2
2019-01-29 19:41:22.217:     Type = 2
2019-01-29 19:41:22.221:     Name = LG-H932
2019-01-29 19:41:22.225: #rates = 1
2019-01-29 19:41:22.229:     Rate = 48000
2019-01-29 19:41:22.233: Output 2
2019-01-29 19:41:22.237:     ID = 22
2019-01-29 19:41:22.240:     Type = 4
2019-01-29 19:41:22.244:     Name = LG-H932
2019-01-29 19:41:22.248: #rates = 1
2019-01-29 19:41:22.252:     Rate = 48000
2019-01-29 19:41:22.255: Output 3
2019-01-29 19:41:22.259:     ID = 5
2019-01-29 19:41:22.263:     Type = 18
2019-01-29 19:41:22.267:     Name = LG-H932
2019-01-29 19:41:22.270: #rates = 2
2019-01-29 19:41:22.274:     Rate = 8000
2019-01-29 19:41:22.278:     Rate = 16000
2019-01-29 19:41:22.284: Service created
2019-01-29 19:41:22.288: onStartCommand
2019-01-29 19:41:22.296: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:41:22.347: Connectivity change, state = CONNECTED, type = WIFI
2019-01-29 19:41:22.387: CT 772195341009, 949194403724, 2679720
2019-01-29 19:41:22.391: DT
2019-01-29 19:41:22.559: onStartCommand
2019-01-29 19:41:22.567: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:41:22.579: onStartCommand
2019-01-29 19:41:22.586: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:41:22.632: postReloadQueue, i_currentPos = 96589
2019-01-29 19:41:24.800: onStartCommand
2019-01-29 19:41:24.810: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:41:24.829: onStartCommand
2019-01-29 19:41:24.841: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:41:26.590: onStartCommand
2019-01-29 19:41:26.631: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:41:26.665: onStartCommand
2019-01-29 19:41:26.681: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:41:30.393: linkSpeed = 866 Mbps
2019-01-29 19:41:30.403: Restrict bg status = 32019:01:29 19:41:30.407 setOutputType 2
2019:01:29 19:41:31.417 prep ATN i_sampleRate = 44100, i_flags = 400000, i_format = 0, bufferSize = 131072
2019-01-29 19:41:31.439: Play Android, HiRes = true
2019-01-29 19:41:56.560: Stop
2019-01-29 19:41:56.862: Return because isAsyncInProgress, pos = 4, i_play = true
2019-01-29 19:41:57.236: linkSpeed = 866 Mbps
2019-01-29 19:41:57.250: Restrict bg status = 32019:01:29 19:41:57.254 setOutputType 2
2019-01-29 19:41:58.037: Play Android, HiRes = true
2019-01-29 19:42:26.706: MediaService: onDestroy
2019-01-29 19:42:26.713: MediaService: onDestroy, player stop
2019-01-29 19:42:26.725: Remove media session
2019-01-29 19:42:26.734: MediaService: onDestroy, send exit
2019-01-29 19:42:26.742: T: delete AS2019:01:29 19:42:26.743 DTOR AS
2019:01:29 19:42:26.743 Deleting old device
2019:01:29 19:42:26.743 Deleted old device
2019:01:29 19:42:26.750 DTOR OD 0xe83cf400
2019:01:29 19:42:26.750 Send exit message to decode thread
2019-01-29 19:42:26.756: T: AS deleted
2019-01-29 19:42:26.759: Closing DB
2019-01-29 19:42:26.771: MediaService: END onDestroy
2019-01-29 19:42:26.923: onDestroy SSPA
2019-01-29 19:43:57.563: App: loading 3rd party libs
2019-01-29 19:43:57.597: Loaded
2019-01-29 19:43:57.613: SSPA oncreate
2019-01-29 19:43:57.660: MediaService onCreate com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:43:57.665: Start LG-H932
lge
joan
26
2019-01-29 19:43:57.679: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c2019:01:29 19:43:57.698 CTOR AS
2019-01-29 19:43:57.756: Android driver = 12019:01:29 19:43:57.758 setOutputType 2
2019:01:29 19:43:57.758 new ATN
2019:01:29 19:43:57.758 CTOR ATN 0xe83cf540
2019-01-29 19:43:57.770: Logmethod = 0
2019-01-29 19:43:57.881: logFileName = /storage/emulated/0/UAPP/UAPP.txt, log to file = false
2019-01-29 19:43:57.886: Calling getUSBAudioDevices()
2019-01-29 19:43:57.925: loadPlayQueueInfo
2019-01-29 19:43:57.937: loadPlayQueueInfo done, diff = 8, counter = 19, i_queue.size = 19
2019-01-29 19:43:57.949: After reloadQueue
2019-01-29 19:43:57.966: #devices 4
2019-01-29 19:43:57.972: Output 0
2019-01-29 19:43:57.977:     ID = 1
2019-01-29 19:43:57.983:     Type = 1
2019-01-29 19:43:57.987:     Name = LG-H932
2019-01-29 19:43:57.993: #rates = 1
2019-01-29 19:43:57.997:     Rate = 48000
2019-01-29 19:43:58.002: Output 1
2019-01-29 19:43:58.007:     ID = 2
2019-01-29 19:43:58.011:     Type = 2
2019-01-29 19:43:58.015:     Name = LG-H932
2019-01-29 19:43:58.020: #rates = 1
2019-01-29 19:43:58.025:     Rate = 48000
2019-01-29 19:43:58.030: Output 2
2019-01-29 19:43:58.036:     ID = 22
2019-01-29 19:43:58.041:     Type = 4
2019-01-29 19:43:58.045:     Name = LG-H932
2019-01-29 19:43:58.050: #rates = 1
2019-01-29 19:43:58.054:     Rate = 48000
2019-01-29 19:43:58.059: Output 3
2019-01-29 19:43:58.063:     ID = 5
2019-01-29 19:43:58.068:     Type = 18
2019-01-29 19:43:58.074:     Name = LG-H932
2019-01-29 19:43:58.081: #rates = 2
2019-01-29 19:43:58.087:     Rate = 8000
2019-01-29 19:43:58.092:     Rate = 16000
2019-01-29 19:43:58.100: Service created
2019-01-29 19:43:58.104: onStartCommand
2019-01-29 19:43:58.114: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:43:58.161: Connectivity change, state = CONNECTED, type = WIFI
2019-01-29 19:43:58.198: CT 772195341009, 949194403724, 2679720
2019-01-29 19:43:58.201: DT
2019-01-29 19:43:58.380: onStartCommand
2019-01-29 19:43:58.388: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:43:58.399: onStartCommand
2019-01-29 19:43:58.407: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:43:58.458: postReloadQueue, i_currentPos = 26743
2019-01-29 19:44:00.221: onStartCommand
2019-01-29 19:44:00.240: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:44:00.257: onStartCommand
2019-01-29 19:44:00.281: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:44:07.752: onStartCommand
2019-01-29 19:44:07.783: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:44:09.443: onStartCommand
2019-01-29 19:44:09.459: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:44:09.477: onStartCommand
2019-01-29 19:44:09.493: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:44:11.130: linkSpeed = 780 Mbps
2019-01-29 19:44:11.138: Restrict bg status = 32019:01:29 19:44:11.142 setOutputType 2
2019:01:29 19:44:12.390 prep ATN i_sampleRate = 44100, i_flags = 400000, i_format = 0, bufferSize = 131072
2019-01-29 19:44:12.432: Play Android, HiRes = true
2019-01-29 19:51:47.294: onStartCommand
2019-01-29 19:51:47.314: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:52:07.577: MediaService: onDestroy
2019-01-29 19:52:07.582: MediaService: onDestroy, player stop
2019-01-29 19:52:07.595: Remove media session
2019-01-29 19:52:07.605: MediaService: onDestroy, send exit
2019-01-29 19:52:07.615: T: delete AS2019:01:29 19:52:07.616 DTOR AS
2019:01:29 19:52:07.618 Deleting old device
2019:01:29 19:52:07.618 Deleted old device
2019:01:29 19:52:07.626 DTOR OD 0xe83cf540
2019:01:29 19:52:07.626 Send exit message to decode thread
2019-01-29 19:52:07.634: T: AS deleted
2019-01-29 19:52:07.637: Closing DB
2019-01-29 19:52:07.653: MediaService: END onDestroy
2019-01-29 19:52:07.796: onDestroy SSPA
2019-01-29 19:55:36.365: App: loading 3rd party libs
2019-01-29 19:55:36.398: Loaded
2019-01-29 19:55:36.413: SSPA oncreate
2019-01-29 19:55:36.459: MediaService onCreate com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:55:36.463: Start LG-H932
lge
joan
26
2019-01-29 19:55:36.479: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c2019:01:29 19:55:36.493 CTOR AS
2019-01-29 19:55:36.549: Android driver = 12019:01:29 19:55:36.551 setOutputType 2
2019:01:29 19:55:36.551 new ATN
2019:01:29 19:55:36.551 CTOR ATN 0xe83cf540
2019-01-29 19:55:36.563: Logmethod = 0
2019-01-29 19:55:36.674: logFileName = /storage/emulated/0/UAPP/UAPP.txt, log to file = false
2019-01-29 19:55:36.680: Calling getUSBAudioDevices()
2019-01-29 19:55:36.720: loadPlayQueueInfo
2019-01-29 19:55:36.732: loadPlayQueueInfo done, diff = 8, counter = 19, i_queue.size = 19
2019-01-29 19:55:36.739: After reloadQueue
2019-01-29 19:55:36.747: #devices 4
2019-01-29 19:55:36.758: Output 0
2019-01-29 19:55:36.763:     ID = 1
2019-01-29 19:55:36.767:     Type = 1
2019-01-29 19:55:36.771:     Name = LG-H932
2019-01-29 19:55:36.775: #rates = 1
2019-01-29 19:55:36.779:     Rate = 48000
2019-01-29 19:55:36.783: Output 1
2019-01-29 19:55:36.788:     ID = 2
2019-01-29 19:55:36.793:     Type = 2
2019-01-29 19:55:36.797:     Name = LG-H932
2019-01-29 19:55:36.802: #rates = 1
2019-01-29 19:55:36.805:     Rate = 48000
2019-01-29 19:55:36.809: Output 2
2019-01-29 19:55:36.813:     ID = 22
2019-01-29 19:55:36.817:     Type = 4
2019-01-29 19:55:36.820:     Name = LG-H932
2019-01-29 19:55:36.824: #rates = 1
2019-01-29 19:55:36.828:     Rate = 48000
2019-01-29 19:55:36.832: Output 3
2019-01-29 19:55:36.835:     ID = 5
2019-01-29 19:55:36.839:     Type = 18
2019-01-29 19:55:36.843:     Name = LG-H932
2019-01-29 19:55:36.847: #rates = 2
2019-01-29 19:55:36.852:     Rate = 8000
2019-01-29 19:55:36.856:     Rate = 16000
2019-01-29 19:55:36.863: Service created
2019-01-29 19:55:36.868: onStartCommand
2019-01-29 19:55:36.876: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:55:36.926: Connectivity change, state = CONNECTED, type = WIFI
2019-01-29 19:55:36.964: CT 772195341009, 949194403724, 2679720
2019-01-29 19:55:36.969: DT
2019-01-29 19:55:37.131: onStartCommand
2019-01-29 19:55:37.149: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:55:37.161: onStartCommand
2019-01-29 19:55:37.170: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:55:37.218: postReloadQueue, i_currentPos = 170910
2019-01-29 19:55:40.123: onStartCommand
2019-01-29 19:55:40.147: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:55:41.757: onStartCommand
2019-01-29 19:55:41.770: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:55:44.364: onStartCommand
2019-01-29 19:55:44.412: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:55:44.446: onStartCommand
2019-01-29 19:55:44.470: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 19:55:47.138: linkSpeed = 866 Mbps
2019-01-29 19:55:47.144: Restrict bg status = 32019:01:29 19:55:47.149 setOutputType 2
2019-01-29 19:55:50.628: onStartCommand
2019-01-29 19:55:50.651: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c2019:01:29 19:55:52.023 prep ATN i_sampleRate = 44100, i_flags = 400000, i_format = 0, bufferSize = 131072
2019-01-29 19:55:52.062: Play Android, HiRes = true
2019-01-29 20:02:27.153: Message MESSAGE_TYPE_START
2019-01-29 20:02:27.163: linkSpeed = 866 Mbps
2019-01-29 20:02:27.170: Restrict bg status = 32019:01:29 20:02:27.174 setOutputType 2
2019-01-29 20:02:27:184  OutputDevice::preparePlayback, i_singleBufferSize = 131072, i_offsetMilliSeconds = 282539, i_isWiredHeadsetOn = 1, i_upsampleMethod = 0
2019-01-29 20:02:27.196: HttpURLConnection: Opening connection for Tidal, i_offset = 22587681
2019-01-29 20:02:27.448: Fetch 65536
2019-01-29 20:02:27.476: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22653217, m_contentLength = 22588706
2019-01-29 20:02:27.594: Diff: bytesRead 1025 of (1025) in 93 msec
2019-01-29 20:02:27.605: Fetch 65536
2019-01-29 20:02:27.615: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:02:27.629: HttpURLConnection: Returning -1 (end of file)!
2019-01-29 20:02:27.641: HttpURLConnection: Opening connection for Tidal, i_offset = 22585633
2019-01-29 20:02:27.736: Fetch 65536
2019-01-29 20:02:27.761: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22651169, m_contentLength = 22588706
2019-01-29 20:02:27.787: Fetch 65536
2019-01-29 20:02:27.816: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:02:27.844: HttpURLConnection: Returning -1 (end of file)!
2019-01-29 20:02:27.871: HttpURLConnection: Opening connection for Tidal, i_offset = 22581537
2019-01-29 20:02:28.008: Fetch 65536
2019-01-29 20:02:28.030: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22647073, m_contentLength = 22588706
2019-01-29 20:02:28.052: Fetch 65536
2019-01-29 20:02:28.062: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:02:28.070: HttpURLConnection: Returning -1 (end of file)!
2019-01-29 20:02:28.078: HttpURLConnection: Opening connection for Tidal, i_offset = 22573345
2019-01-29 20:02:28.161: Fetch 65536
2019-01-29 20:02:28.184: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22638881, m_contentLength = 22588706
2019-01-29 20:02:28.223: Fetch 65536
2019-01-29 20:02:28.235: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:02:28.244: HttpURLConnection: Returning -1 (end of file)!
2019-01-29 20:02:28.253: HttpURLConnection: Opening connection for Tidal, i_offset = 22556961
2019-01-29 20:02:28.367: Fetch 65536
2019-01-29 20:02:28.380: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22622497, m_contentLength = 22588706
2019-01-29 20:02:28.396: Fetch 65536
2019-01-29 20:02:28.410: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22640754, m_contentLength = 22588706
2019-01-29 20:02:28.434: Fetch 65536
2019-01-29 20:02:28.452: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:02:28.462: HttpURLConnection: Returning -1 (end of file)!
2019-01-29 20:02:28.474: HttpURLConnection: Opening connection for Tidal, i_offset = 22524193
2019-01-29 20:02:28.638: Fetch 65536
2019-01-29 20:02:28.665: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22589729, m_contentLength = 22588706
2019-01-29 20:02:28.697: Fetch 65536
2019-01-29 20:02:28.729: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22629079, m_contentLength = 22588706
2019-01-29 20:02:28.760: Fetch 65536
2019-01-29 20:02:28.788: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22646050, m_contentLength = 22588706
2019-01-29 20:02:28.829: Fetch 65536
2019-01-29 20:02:28.858: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:02:28.868: HttpURLConnection: Returning -1 (end of file)!
2019-01-29 20:02:28.878: HttpURLConnection: Opening connection for Tidal, i_offset = 22458657
2019-01-29 20:02:29.147: Fetch 65536
2019-01-29 20:02:29.194: Fetch 65536
2019-01-29 20:02:29.205: Fetch 65536
2019-01-29 20:02:29.218: Fetch 65536
2019-01-29 20:02:29.227: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22589353, m_contentLength = 22588706
2019-01-29 20:02:29.248: Fetch 65536
2019-01-29 20:02:29.259: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22619570, m_contentLength = 22588706
2019-01-29 20:02:29.272: Fetch 65536
2019-01-29 20:02:29.288: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22637858, m_contentLength = 22588706
2019-01-29 20:02:29.301: Fetch 65536
2019-01-29 20:02:29.313: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22638394, m_contentLength = 22588706
2019-01-29 20:02:29.326: HttpURLConnection: Opening connection for Tidal, i_offset = 22462821
2019-01-29 20:02:29.480: Fetch 65536
2019-01-29 20:02:29.511: Fetch 65536
2019-01-29 20:02:29.535: Fetch 65536
2019-01-29 20:02:29.545: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22593305, m_contentLength = 22588706
2019-01-29 20:02:29.557: Fetch 65536
2019-01-29 20:02:29.568: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22629666, m_contentLength = 22588706
2019-01-29 20:02:29.580: Fetch 65536
2019-01-29 20:02:29.590: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22646050, m_contentLength = 22588706
2019-01-29 20:02:29.601: HttpURLConnection: Opening connection for Tidal, i_offset = 22474470
2019-01-29 20:02:29.743: Fetch 65536
2019-01-29 20:02:29.758: Fetch 65536
2019-01-29 20:02:29.769: Fetch 65536
2019-01-29 20:02:29.780: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22602554, m_contentLength = 22588706
2019-01-29 20:02:29.789: Fetch 65536
2019-01-29 20:02:29.798: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22629666, m_contentLength = 22588706
2019-01-29 20:02:29.806: Fetch 65536
2019-01-29 20:02:29.815: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22643514, m_contentLength = 22588706
2019-01-29 20:02:29.824: Fetch 65536
2019-01-29 20:02:29.832: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:02:29.841: HttpURLConnection: Returning -1 (end of file)!
2019-01-29 20:02:29.850: HttpURLConnection: Opening connection for Tidal, i_offset = 224744692019-01-29 20:02:29:969  setActualDeviceSampleRate: decoder rate = 44100
2019-01-29 20:02:29:970  setActualDeviceSampleRate: getNearestDeviceSampleRate = 44100
2019-01-29 20:02:29:970  Device rate becomes 44100
2019-01-29 20:02:29:970  m_diskBufferSizeFrames = 524288
2019-01-29 20:02:29.993: Fetch 65536
2019-01-29 20:02:30.002: Fetch 65536
2019-01-29 20:02:30.023: Fetch 65536
2019-01-29 20:02:30.050: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22595029, m_contentLength = 22588706
2019-01-29 20:02:30.067: Fetch 65536
2019-01-29 20:02:30.077: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22629666, m_contentLength = 22588706
2019-01-29 20:02:30.086: Fetch 65536
2019-01-29 20:02:30.095: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22646050, m_contentLength = 22588706
2019-01-29 20:02:30.106: Fetch 65536
2019-01-29 20:02:30.115: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:02:30.126: HttpURLConnection: Returning -1 (end of file)!2019-01-29 20:02:30:133  not enough data, calling setNextToCurrent, framesToRead = 487424
2019-01-29 20:02:30:133  after setNextToCurrent: current = 0x0, m_next = 0x0
2019-01-29 20:02:30:133  Clearing double buffer area due to stop and go
2019-01-29 20:02:30:136  Error decoding or not enough frames in first block!
2019-01-29 20:02:30:136  bufferFrames = 131072 for sr 44100
2019-01-29 20:02:30.145: preparePlayback failed!
2019-01-29 20:02:48.106: onStartCommand
2019-01-29 20:02:48.124: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:02:52.230: onStartCommand
2019-01-29 20:02:52.247: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:02:52.264: onStartCommand
2019-01-29 20:02:52.293: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:02:56.455: setting async in prog because setting two songs
2019-01-29 20:02:56.464: Open ASYNC: Islandsmoen: Requiem - Lacrymosa
2019-01-29 20:02:56.831: onPositiveResult, i_isNextPosition = false
2019-01-29 20:02:56.846: Message MESSAGE_TYPE_QUEUE_SONG2019-01-29 20:02:56:847  Current was NULL, so current becomes Islandsmoen: Requiem - Lacrymosa = Tidal
2019-01-29 20:02:56:847  after setNextDataSource: current = 0xd187dd00, m_next = 0x0
2019-01-29 20:02:56.863: Message MESSAGE_TYPE_START
2019-01-29 20:02:56.863: Open ASYNC: Islandsmoen: Requiem - Confutatis
2019-01-29 20:02:56.882: linkSpeed = 866 Mbps
2019-01-29 20:02:56.894: Restrict bg status = 32019:01:29 20:02:56.900 setOutputType 2
2019-01-29 20:02:56.910: HttpURLConnection: fetchDataForReal: m_HttpURLConnection == null, creating request, this = com.extreamsd.usbaudioplayershared.ESDHTTPClient@85392a8
2019-01-29 20:02:56.918: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:02:57.100: HttpURLConnection: contentLength = 48607266 for Tidal
2019-01-29 20:02:57.121: Fetch 65536
2019-01-29 20:02:57.137: Fetch 335249
2019-01-29 20:02:57.168: Fetch 214529
2019-01-29 20:02:57.181: Fetch 126201
2019-01-29 20:02:57.198: Fetch 105929
2019-01-29 20:02:57.210: Fetch 65536
2019-01-29 20:02:57.220: Fetch 40393
2019-01-29 20:02:57.232: Fetch 65536
2019-01-29 20:02:57.274: onPositiveResult, i_isNextPosition = true
2019-01-29 20:02:57.285: Fetch 65536
2019-01-29 20:02:57.291: Fetch 65536
2019-01-29 20:02:57.297: Fetch 65536
2019-01-29 20:02:57.303: Fetch 65536
2019-01-29 20:02:57.311: Fetch 65536
2019-01-29 20:02:57.320: Fetch 65536
2019-01-29 20:02:57.328: Fetch 65536
2019-01-29 20:02:57.344: Fetch 65536
2019-01-29 20:02:57.363: Fetch 65536
2019-01-29 20:02:57.394: Fetch 65536
2019-01-29 20:02:57.411: Fetch 65536
2019-01-29 20:02:57.421: Fetch 65536
2019-01-29 20:02:57.433: Fetch 65536
2019-01-29 20:02:57.443: Fetch 65536
2019-01-29 20:02:57.453: Fetch 65536
2019-01-29 20:02:57.468: Fetch 65536
2019-01-29 20:02:57.484: Fetch 65536
2019-01-29 20:02:57.495: Fetch 65536
2019-01-29 20:02:57.511: Fetch 65536
2019-01-29 20:02:57.534: Fetch 65536
2019-01-29 20:02:57.544: Fetch 65536
2019-01-29 20:02:57.558: Fetch 65536
2019-01-29 20:02:57.576: Fetch 65536
2019-01-29 20:02:57.587: Fetch 65536
2019-01-29 20:02:57.599: Fetch 655362019-01-29 20:02:57:613  OutputDevice::preparePlayback, i_singleBufferSize = 131072, i_offsetMilliSeconds = 0, i_isWiredHeadsetOn = 1, i_upsampleMethod = 0
2019-01-29 20:02:57:613  setActualDeviceSampleRate: decoder rate = 44100
2019-01-29 20:02:57:613  setActualDeviceSampleRate: getNearestDeviceSampleRate = 44100
2019-01-29 20:02:57:614  Device rate becomes 44100
2019-01-29 20:02:57:614  m_diskBufferSizeFrames = 524288
2019-01-29 20:02:57.665: Fetch 65536
2019-01-29 20:02:57.683: Fetch 65536
2019-01-29 20:02:57.698: Fetch 65536
2019-01-29 20:02:57.705: Fetch 65536
2019-01-29 20:02:57.716: Fetch 65536
2019-01-29 20:02:57.727: Fetch 65536
2019-01-29 20:02:57.746: Fetch 65536
2019-01-29 20:02:57.791: Fetch 65536
2019-01-29 20:02:57.815: Fetch 65536
2019-01-29 20:02:57.828: Fetch 65536
2019-01-29 20:02:57.843: Fetch 65536
2019-01-29 20:02:57.856: Fetch 65536
2019-01-29 20:02:57.871: Fetch 65536
2019-01-29 20:02:57.883: Fetch 65536
2019-01-29 20:02:57.895: Fetch 65536
2019-01-29 20:02:57.908: Fetch 65536
2019-01-29 20:02:57.925: Fetch 65536
2019-01-29 20:02:57.938: Fetch 65536
2019-01-29 20:02:57.957: Fetch 65536
2019-01-29 20:02:57.973: Fetch 65536
2019-01-29 20:02:57.988: Fetch 65536
2019-01-29 20:02:58.005: Fetch 65536
2019-01-29 20:02:58.018: Fetch 65536
2019-01-29 20:02:58.031: Fetch 65536
2019-01-29 20:02:58.044: Fetch 65536
2019-01-29 20:02:58.057: Fetch 65536
2019-01-29 20:02:58.069: Fetch 65536
2019-01-29 20:02:58.086: Fetch 65536
2019-01-29 20:02:58.100: Fetch 65536
2019-01-29 20:02:58.113: Fetch 65536
2019-01-29 20:02:58.127: Fetch 65536
2019-01-29 20:02:58.141: Fetch 65536
2019-01-29 20:02:58.155: Fetch 65536
2019-01-29 20:02:58.175: Fetch 65536
2019-01-29 20:02:58.189: Fetch 65536
2019-01-29 20:02:58.205: Fetch 65536
2019-01-29 20:02:58.219: Fetch 65536
2019-01-29 20:02:58.231: Fetch 65536
2019-01-29 20:02:58.245: Fetch 65536
2019-01-29 20:02:58.256: Fetch 65536
2019-01-29 20:02:58.267: Fetch 65536
2019-01-29 20:02:58.279: Fetch 65536
2019-01-29 20:02:58.294: Fetch 65536
2019-01-29 20:02:58.305: Fetch 65536
2019-01-29 20:02:58.321: Fetch 65536
2019-01-29 20:02:58.334: Fetch 65536
2019-01-29 20:02:58.345: Fetch 65536
2019-01-29 20:02:58.359: Fetch 65536
2019-01-29 20:02:58.370: Fetch 65536
2019-01-29 20:02:58.384: Fetch 65536
2019-01-29 20:02:58.397: Fetch 65536
2019-01-29 20:02:58.413: Fetch 65536
2019-01-29 20:02:58.436: Fetch 65536
2019-01-29 20:02:58.453: Fetch 65536
2019-01-29 20:02:58.472: Fetch 65536
2019-01-29 20:02:58.484: Fetch 65536
2019-01-29 20:02:58.501: Fetch 65536
2019-01-29 20:02:58.515: Fetch 65536
2019-01-29 20:02:58.525: Fetch 65536
2019-01-29 20:02:58.541: Fetch 65536
2019-01-29 20:02:58.554: Fetch 65536
2019-01-29 20:02:58.580: Fetch 65536
2019-01-29 20:02:58.600: Fetch 65536
2019-01-29 20:02:58.616: Fetch 65536
2019-01-29 20:02:58.630: Fetch 65536
2019-01-29 20:02:58.645: Fetch 65536
2019-01-29 20:02:58.664: Fetch 65536
2019-01-29 20:02:58.678: Fetch 65536
2019-01-29 20:02:58.701: Fetch 65536
2019-01-29 20:02:58.722: Fetch 65536
2019-01-29 20:02:58.743: Fetch 65536
2019-01-29 20:02:58.765: Fetch 65536
2019-01-29 20:02:58.784: Fetch 65536
2019-01-29 20:02:58.797: Fetch 65536
2019-01-29 20:02:58.808: Fetch 65536
2019-01-29 20:02:58.826: Fetch 65536
2019-01-29 20:02:58.838: Fetch 65536
2019-01-29 20:02:58.853: Fetch 65536
2019-01-29 20:02:58.870: Fetch 65536
2019-01-29 20:02:58.884: Fetch 65536
2019-01-29 20:02:58.899: Fetch 65536
2019-01-29 20:02:58.915: Fetch 65536
2019-01-29 20:02:58.928: Fetch 65536
2019-01-29 20:02:58.949: Fetch 65536
2019-01-29 20:02:58.963: Fetch 65536
2019-01-29 20:02:58.976: Fetch 655362019-01-29 20:02:58:980  Reusing audiotrack
2019-01-29 20:02:58:983  bufferFrames = 131072 for sr 44100
2019-01-29 20:02:58.997: Play Android, HiRes = true2019-01-29 20:02:58:997  ATN start
2019-01-29 20:02:59.057: Message MESSAGE_TYPE_QUEUE_SONG2019-01-29 20:02:59:59  Current wasn't NULL, so setting next to Islandsmoen: Requiem - Confutatis = Tidal
2019-01-29 20:02:59:59  after setNextDataSource: current = 0xd187dd00, m_next = 0xd0349100
2019-01-29 20:02:59.080: Setting m_asyncInProgress to false in A
2019-01-29 20:03:07.872: Fetch 65536
2019-01-29 20:03:07.918: Fetch 65536
2019-01-29 20:03:07.932: Fetch 65536
2019-01-29 20:03:07.945: Fetch 65536
2019-01-29 20:03:07.958: Fetch 65536
2019-01-29 20:03:07.972: Fetch 65536
2019-01-29 20:03:07.986: Fetch 65536
2019-01-29 20:03:08.002: Fetch 65536
2019-01-29 20:03:08.022: Fetch 65536
2019-01-29 20:03:08.043: Fetch 65536
2019-01-29 20:03:08.061: Fetch 65536
2019-01-29 20:03:08.076: Fetch 65536
2019-01-29 20:03:08.089: Fetch 65536
2019-01-29 20:03:08.101: Fetch 65536
2019-01-29 20:03:08.113: Fetch 65536
2019-01-29 20:03:08.132: Fetch 65536
2019-01-29 20:03:08.146: Fetch 65536
2019-01-29 20:03:08.162: Fetch 65536
2019-01-29 20:03:08.180: Fetch 65536
2019-01-29 20:03:08.195: Fetch 65536
2019-01-29 20:03:08.211: Fetch 65536
2019-01-29 20:03:08.222: Fetch 65536
2019-01-29 20:03:08.233: Fetch 65536
2019-01-29 20:03:08.243: Fetch 65536
2019-01-29 20:03:08.253: Fetch 65536
2019-01-29 20:03:08.264: Fetch 65536
2019-01-29 20:03:08.281: Fetch 65536
2019-01-29 20:03:08.295: Fetch 65536
2019-01-29 20:03:08.310: Fetch 65536
2019-01-29 20:03:08.325: Fetch 65536
2019-01-29 20:03:08.338: Fetch 65536
2019-01-29 20:03:08.356: Fetch 65536
2019-01-29 20:03:08.379: Fetch 65536
2019-01-29 20:03:08.404: Fetch 65536
2019-01-29 20:03:08.417: Fetch 65536
2019-01-29 20:03:08.430: Fetch 65536
2019-01-29 20:03:08.444: Fetch 65536
2019-01-29 20:03:08.460: Fetch 65536
2019-01-29 20:03:08.474: Fetch 65536
2019-01-29 20:03:08.488: Fetch 65536
2019-01-29 20:03:08.501: Fetch 65536
2019-01-29 20:03:08.518: Fetch 65536
2019-01-29 20:03:08.533: Fetch 65536
2019-01-29 20:03:08.545: Fetch 65536
2019-01-29 20:03:08.557: Fetch 65536
2019-01-29 20:03:08.571: Fetch 65536
2019-01-29 20:03:08.582: Fetch 65536
2019-01-29 20:03:08.594: Fetch 65536
2019-01-29 20:03:08.612: Fetch 65536
2019-01-29 20:03:08.624: Fetch 65536
2019-01-29 20:03:08.640: Fetch 65536
2019-01-29 20:03:08.658: Fetch 65536
2019-01-29 20:03:08.675: Fetch 65536
2019-01-29 20:03:08.691: Fetch 65536
2019-01-29 20:03:08.705: Fetch 65536
2019-01-29 20:03:08.719: Fetch 65536
2019-01-29 20:03:08.735: Fetch 65536
2019-01-29 20:03:19.746: Fetch 65536
2019-01-29 20:03:19.773: Fetch 65536
2019-01-29 20:03:19.786: Fetch 65536
2019-01-29 20:03:19.799: Fetch 65536
2019-01-29 20:03:19.813: Fetch 65536
2019-01-29 20:03:19.826: Fetch 65536
2019-01-29 20:03:19.838: Fetch 65536
2019-01-29 20:03:19.856: Fetch 65536
2019-01-29 20:03:19.874: Fetch 65536
2019-01-29 20:03:19.892: Fetch 65536
2019-01-29 20:03:19.906: Fetch 65536
2019-01-29 20:03:19.919: Fetch 65536
2019-01-29 20:03:19.938: Fetch 65536
2019-01-29 20:03:19.951: Fetch 65536
2019-01-29 20:03:19.965: Fetch 65536
2019-01-29 20:03:19.984: Fetch 65536
2019-01-29 20:03:19.996: Fetch 65536
2019-01-29 20:03:20.008: Fetch 65536
2019-01-29 20:03:20.018: Fetch 65536
2019-01-29 20:03:20.028: Fetch 65536
2019-01-29 20:03:20.038: Fetch 65536
2019-01-29 20:03:20.050: Fetch 65536
2019-01-29 20:03:20.066: Fetch 65536
2019-01-29 20:03:20.079: Fetch 65536
2019-01-29 20:03:20.092: Fetch 65536
2019-01-29 20:03:20.110: Fetch 65536
2019-01-29 20:03:20.123: Fetch 65536
2019-01-29 20:03:20.137: Fetch 65536
2019-01-29 20:03:20.154: Fetch 65536
2019-01-29 20:03:20.169: Fetch 65536
2019-01-29 20:03:20.184: Fetch 65536
2019-01-29 20:03:20.200: Fetch 65536
2019-01-29 20:03:20.217: Fetch 65536
2019-01-29 20:03:20.231: Fetch 65536
2019-01-29 20:03:20.244: Fetch 65536
2019-01-29 20:03:20.269: Fetch 65536
2019-01-29 20:03:20.282: Fetch 65536
2019-01-29 20:03:20.293: Fetch 65536
2019-01-29 20:03:20.304: Fetch 65536
2019-01-29 20:03:20.314: Fetch 65536
2019-01-29 20:03:20.322: Fetch 65536
2019-01-29 20:03:20.333: Fetch 65536
2019-01-29 20:03:20.348: Fetch 65536
2019-01-29 20:03:20.366: Fetch 65536
2019-01-29 20:03:20.395: Fetch 65536
2019-01-29 20:03:20.436: Fetch 65536
2019-01-29 20:03:20.456: Fetch 65536
2019-01-29 20:03:20.468: Fetch 65536
2019-01-29 20:03:20.480: Fetch 65536
2019-01-29 20:03:20.494: Fetch 65536
2019-01-29 20:03:20.505: Fetch 65536
2019-01-29 20:03:20.518: Fetch 65536
2019-01-29 20:03:20.536: Fetch 65536
2019-01-29 20:03:20.549: Fetch 65536
2019-01-29 20:03:20.564: Fetch 65536
2019-01-29 20:03:20.581: Fetch 65536
2019-01-29 20:03:20.597: Fetch 65536
2019-01-29 20:03:20.614: Fetch 65536
2019-01-29 20:03:20.630: Fetch 65536
2019-01-29 20:03:20.640: Fetch 65536
2019-01-29 20:03:31.669: Fetch 65536
2019-01-29 20:03:31.699: Fetch 65536
2019-01-29 20:03:31.712: Fetch 65536
2019-01-29 20:03:31.725: Fetch 65536
2019-01-29 20:03:31.740: Fetch 65536
2019-01-29 20:03:31.756: Fetch 65536
2019-01-29 20:03:31.774: Fetch 65536
2019-01-29 20:03:31.815: Fetch 65536
2019-01-29 20:03:31.833: Fetch 65536
2019-01-29 20:03:31.847: Fetch 65536
2019-01-29 20:03:31.863: Fetch 65536
2019-01-29 20:03:31.876: Fetch 65536
2019-01-29 20:03:31.889: Fetch 65536
2019-01-29 20:03:31.903: Fetch 65536
2019-01-29 20:03:31.920: Fetch 65536
2019-01-29 20:03:31.938: Fetch 65536
2019-01-29 20:03:31.958: Fetch 65536
2019-01-29 20:03:31.975: Fetch 65536
2019-01-29 20:03:31.989: Fetch 65536
2019-01-29 20:03:32.006: Fetch 65536
2019-01-29 20:03:32.016: Fetch 65536
2019-01-29 20:03:32.025: Fetch 65536
2019-01-29 20:03:32.035: Fetch 65536
2019-01-29 20:03:32.046: Fetch 65536
2019-01-29 20:03:32.059: Fetch 65536
2019-01-29 20:03:32.069: Fetch 65536
2019-01-29 20:03:32.083: Fetch 65536
2019-01-29 20:03:32.106: Fetch 65536
2019-01-29 20:03:32.119: Fetch 65536
2019-01-29 20:03:32.130: Fetch 65536
2019-01-29 20:03:32.143: Fetch 65536
2019-01-29 20:03:32.157: Fetch 65536
2019-01-29 20:03:32.174: Fetch 65536
2019-01-29 20:03:32.191: Fetch 65536
2019-01-29 20:03:32.203: Fetch 65536
2019-01-29 20:03:32.217: Fetch 65536
2019-01-29 20:03:32.234: Fetch 65536
2019-01-29 20:03:32.245: Fetch 65536
2019-01-29 20:03:32.258: Fetch 65536
2019-01-29 20:03:32.273: Fetch 65536
2019-01-29 20:03:32.286: Fetch 65536
2019-01-29 20:03:32.302: Fetch 65536
2019-01-29 20:03:32.324: Fetch 65536
2019-01-29 20:03:32.339: Fetch 65536
2019-01-29 20:03:32.356: Fetch 65536
2019-01-29 20:03:32.370: Fetch 65536
2019-01-29 20:03:32.384: Fetch 65536
2019-01-29 20:03:32.397: Fetch 65536
2019-01-29 20:03:32.408: Fetch 65536
2019-01-29 20:03:32.426: Fetch 65536
2019-01-29 20:03:32.443: Fetch 65536
2019-01-29 20:03:32.466: Fetch 65536
2019-01-29 20:03:32.488: Fetch 65536
2019-01-29 20:03:32.500: Fetch 65536
2019-01-29 20:03:32.511: Fetch 65536
2019-01-29 20:03:32.530: Fetch 65536
2019-01-29 20:03:32.556: Fetch 65536
2019-01-29 20:03:32.570: Fetch 65536
2019-01-29 20:03:32.583: Fetch 65536
2019-01-29 20:03:32.594: Fetch 65536
2019-01-29 20:03:32.607: Fetch 65536
2019-01-29 20:03:45.021: Fetch 65536
2019-01-29 20:03:45.045: Fetch 65536
2019-01-29 20:03:45.058: Fetch 65536
2019-01-29 20:03:45.071: Fetch 65536
2019-01-29 20:03:45.084: Fetch 65536
2019-01-29 20:03:45.101: Fetch 65536
2019-01-29 20:03:45.124: Fetch 65536
2019-01-29 20:03:45.149: Fetch 65536
2019-01-29 20:03:45.174: Fetch 65536
2019-01-29 20:03:45.185: Fetch 65536
2019-01-29 20:03:45.196: Fetch 65536
2019-01-29 20:03:45.208: Fetch 65536
2019-01-29 20:03:45.219: Fetch 65536
2019-01-29 20:03:45.230: Fetch 65536
2019-01-29 20:03:45.243: Fetch 65536
2019-01-29 20:03:45.257: Fetch 65536
2019-01-29 20:03:45.281: Fetch 65536
2019-01-29 20:03:45.296: Fetch 65536
2019-01-29 20:03:45.313: Fetch 65536
2019-01-29 20:03:45.335: Fetch 65536
2019-01-29 20:03:45.353: Fetch 65536
2019-01-29 20:03:45.364: Fetch 65536
2019-01-29 20:03:45.378: Fetch 65536
2019-01-29 20:03:45.391: Fetch 65536
2019-01-29 20:03:45.404: Fetch 65536
2019-01-29 20:03:45.418: Fetch 65536
2019-01-29 20:03:45.432: Fetch 65536
2019-01-29 20:03:45.443: Fetch 65536
2019-01-29 20:03:45.457: Fetch 65536
2019-01-29 20:03:45.470: Fetch 65536
2019-01-29 20:03:45.485: Fetch 65536
2019-01-29 20:03:45.501: Fetch 65536
2019-01-29 20:03:45.532: Fetch 65536
2019-01-29 20:03:45.554: Fetch 65536
2019-01-29 20:03:45.568: Fetch 65536
2019-01-29 20:03:45.584: Fetch 65536
2019-01-29 20:03:45.597: Fetch 65536
2019-01-29 20:03:45.615: Fetch 65536
2019-01-29 20:03:45.628: Fetch 65536
2019-01-29 20:03:45.641: Fetch 65536
2019-01-29 20:03:45.654: Fetch 65536
2019-01-29 20:03:45.667: Fetch 65536
2019-01-29 20:03:45.682: Fetch 65536
2019-01-29 20:03:45.701: Fetch 65536
2019-01-29 20:03:45.715: Fetch 65536
2019-01-29 20:03:45.749: Fetch 65536
2019-01-29 20:03:45.763: Fetch 65536
2019-01-29 20:03:45.778: Fetch 65536
2019-01-29 20:03:45.796: Fetch 65536
2019-01-29 20:03:45.811: Fetch 65536
2019-01-29 20:03:45.823: Fetch 65536
2019-01-29 20:03:45.836: Fetch 65536
2019-01-29 20:03:45.851: Fetch 65536
2019-01-29 20:03:45.874: Fetch 65536
2019-01-29 20:03:45.889: Fetch 65536
2019-01-29 20:03:45.905: Fetch 65536
2019-01-29 20:03:45.918: Fetch 65536
2019-01-29 20:03:45.930: Fetch 65536
2019-01-29 20:03:45.944: Fetch 65536
2019-01-29 20:03:45.959: Fetch 65536
2019-01-29 20:03:45.980: Fetch 65536
2019-01-29 20:03:46.000: Fetch 65536
2019-01-29 20:03:55.431: Fetch 65536
2019-01-29 20:03:55.472: Fetch 65536
2019-01-29 20:03:55.485: Fetch 65536
2019-01-29 20:03:55.498: Fetch 65536
2019-01-29 20:03:55.513: Fetch 65536
2019-01-29 20:03:55.527: Fetch 65536
2019-01-29 20:03:55.552: Fetch 65536
2019-01-29 20:03:55.563: Fetch 65536
2019-01-29 20:03:55.574: Fetch 65536
2019-01-29 20:03:55.588: Fetch 65536
2019-01-29 20:03:55.603: Fetch 65536
2019-01-29 20:03:55.618: Fetch 65536
2019-01-29 20:03:55.636: Fetch 65536
2019-01-29 20:03:55.659: Fetch 65536
2019-01-29 20:03:55.675: Fetch 65536
2019-01-29 20:03:55.692: Fetch 65536
2019-01-29 20:03:55.706: Fetch 65536
2019-01-29 20:03:55.720: Fetch 65536
2019-01-29 20:03:55.734: Fetch 65536
2019-01-29 20:03:55.748: Fetch 65536
2019-01-29 20:03:55.772: Fetch 65536
2019-01-29 20:03:55.791: Fetch 65536
2019-01-29 20:03:55.803: Fetch 65536
2019-01-29 20:03:55.819: Fetch 65536
2019-01-29 20:03:55.833: Fetch 65536
2019-01-29 20:03:55.854: Fetch 65536
2019-01-29 20:03:55.866: Fetch 65536
2019-01-29 20:03:55.880: Fetch 65536
2019-01-29 20:03:55.895: Fetch 65536
2019-01-29 20:03:55.911: Fetch 65536
2019-01-29 20:03:55.935: Fetch 65536
2019-01-29 20:03:55.948: Fetch 65536
2019-01-29 20:03:55.960: Fetch 65536
2019-01-29 20:03:55.973: Fetch 65536
2019-01-29 20:03:55.993: Fetch 65536
2019-01-29 20:03:56.005: Fetch 65536
2019-01-29 20:03:56.018: Fetch 65536
2019-01-29 20:03:56.030: Fetch 65536
2019-01-29 20:03:56.044: Fetch 65536
2019-01-29 20:03:56.059: Fetch 65536
2019-01-29 20:03:56.078: Fetch 65536
2019-01-29 20:03:56.098: Fetch 65536
2019-01-29 20:03:56.120: Fetch 65536
2019-01-29 20:03:56.138: Fetch 65536
2019-01-29 20:03:56.156: Fetch 65536
2019-01-29 20:03:56.174: Fetch 65536
2019-01-29 20:03:56.185: Fetch 65536
2019-01-29 20:03:56.198: Fetch 65536
2019-01-29 20:03:56.210: Fetch 65536
2019-01-29 20:03:56.223: Fetch 65536
2019-01-29 20:03:56.246: Fetch 65536
2019-01-29 20:03:56.265: Fetch 65536
2019-01-29 20:03:56.278: Fetch 65536
2019-01-29 20:03:56.293: Fetch 65536
2019-01-29 20:03:56.316: Fetch 65536
2019-01-29 20:03:56.331: Fetch 65536
2019-01-29 20:03:56.342: Fetch 65536
2019-01-29 20:03:56.365: Fetch 65536
2019-01-29 20:03:56.380: Fetch 65536
2019-01-29 20:03:56.395: Fetch 65536
2019-01-29 20:03:56.407: Fetch 65536
2019-01-29 20:03:56.422: Fetch 65536
2019-01-29 20:03:56.439: Fetch 65536
2019-01-29 20:03:56.461: Fetch 65536
2019-01-29 20:04:08.791: Fetch 65536
2019-01-29 20:04:08.831: Fetch 65536
2019-01-29 20:04:08.845: Fetch 65536
2019-01-29 20:04:08.858: Fetch 65536
2019-01-29 20:04:08.871: Fetch 65536
2019-01-29 20:04:08.885: Fetch 65536
2019-01-29 20:04:08.902: Fetch 65536
2019-01-29 20:04:08.923: Fetch 65536
2019-01-29 20:04:08.951: Fetch 65536
2019-01-29 20:04:08.971: Fetch 65536
2019-01-29 20:04:08.982: Fetch 65536
2019-01-29 20:04:08.995: Fetch 65536
2019-01-29 20:04:09.006: Fetch 65536
2019-01-29 20:04:09.022: Fetch 65536
2019-01-29 20:04:09.044: Fetch 65536
2019-01-29 20:04:09.059: Fetch 65536
2019-01-29 20:04:09.080: Fetch 65536
2019-01-29 20:04:09.093: Fetch 65536
2019-01-29 20:04:09.107: Fetch 65536
2019-01-29 20:04:09.125: Fetch 65536
2019-01-29 20:04:09.138: Fetch 65536
2019-01-29 20:04:09.155: Fetch 65536
2019-01-29 20:04:09.169: Fetch 65536
2019-01-29 20:04:09.185: Fetch 65536
2019-01-29 20:04:09.201: Fetch 65536
2019-01-29 20:04:09.220: Fetch 65536
2019-01-29 20:04:09.236: Fetch 65536
2019-01-29 20:04:09.250: Fetch 65536
2019-01-29 20:04:09.262: Fetch 65536
2019-01-29 20:04:09.281: Fetch 65536
2019-01-29 20:04:09.294: Fetch 65536
2019-01-29 20:04:09.308: Fetch 65536
2019-01-29 20:04:09.331: Fetch 65536
2019-01-29 20:04:09.344: Fetch 65536
2019-01-29 20:04:09.358: Fetch 65536
2019-01-29 20:04:09.371: Fetch 65536
2019-01-29 20:04:09.384: Fetch 65536
2019-01-29 20:04:09.399: Fetch 65536
2019-01-29 20:04:09.414: Fetch 65536
2019-01-29 20:04:09.435: Fetch 65536
2019-01-29 20:04:09.458: Fetch 65536
2019-01-29 20:04:09.476: Fetch 65536
2019-01-29 20:04:09.487: Fetch 65536
2019-01-29 20:04:09.500: Fetch 65536
2019-01-29 20:04:09.517: Fetch 65536
2019-01-29 20:04:09.538: Fetch 65536
2019-01-29 20:04:09.554: Fetch 65536
2019-01-29 20:04:09.571: Fetch 65536
2019-01-29 20:04:09.587: Fetch 65536
2019-01-29 20:04:09.604: Fetch 65536
2019-01-29 20:04:09.618: Fetch 65536
2019-01-29 20:04:09.630: Fetch 65536
2019-01-29 20:04:09.644: Fetch 65536
2019-01-29 20:04:09.662: Fetch 65536
2019-01-29 20:04:09.680: Fetch 65536
2019-01-29 20:04:09.700: Fetch 65536
2019-01-29 20:04:09.714: Fetch 65536
2019-01-29 20:04:09.726: Fetch 65536
2019-01-29 20:04:09.746: Fetch 65536
2019-01-29 20:04:09.759: Fetch 65536
2019-01-29 20:04:09.772: Fetch 65536
2019-01-29 20:04:09.785: Fetch 65536
2019-01-29 20:04:09.796: Fetch 65536
2019-01-29 20:04:09.806: Fetch 65536
2019-01-29 20:04:09.817: Fetch 65536
2019-01-29 20:04:19.203: Fetch 65536
2019-01-29 20:04:19.224: Fetch 65536
2019-01-29 20:04:19.237: Fetch 65536
2019-01-29 20:04:19.248: Fetch 65536
2019-01-29 20:04:19.264: Fetch 65536
2019-01-29 20:04:19.279: Fetch 65536
2019-01-29 20:04:19.303: Fetch 65536
2019-01-29 20:04:19.326: Fetch 65536
2019-01-29 20:04:19.339: Fetch 65536
2019-01-29 20:04:19.353: Fetch 65536
2019-01-29 20:04:19.366: Fetch 65536
2019-01-29 20:04:19.378: Fetch 65536
2019-01-29 20:04:19.392: Fetch 65536
2019-01-29 20:04:19.407: Fetch 65536
2019-01-29 20:04:19.423: Fetch 65536
2019-01-29 20:04:19.440: Fetch 65536
2019-01-29 20:04:19.461: Fetch 65536
2019-01-29 20:04:19.479: Fetch 65536
2019-01-29 20:04:19.509: Fetch 65536
2019-01-29 20:04:19.536: Fetch 65536
2019-01-29 20:04:19.552: Fetch 65536
2019-01-29 20:04:19.564: Fetch 65536
2019-01-29 20:04:19.581: Fetch 65536
2019-01-29 20:04:19.596: Fetch 65536
2019-01-29 20:04:19.608: Fetch 65536
2019-01-29 20:04:19.624: Fetch 65536
2019-01-29 20:04:19.639: Fetch 65536
2019-01-29 20:04:19.655: Fetch 65536
2019-01-29 20:04:19.668: Fetch 65536
2019-01-29 20:04:19.681: Fetch 65536
2019-01-29 20:04:19.697: Fetch 65536
2019-01-29 20:04:19.711: Fetch 65536
2019-01-29 20:04:19.737: Fetch 65536
2019-01-29 20:04:19.754: Fetch 65536
2019-01-29 20:04:19.765: Fetch 65536
2019-01-29 20:04:19.781: Fetch 65536
2019-01-29 20:04:19.795: Fetch 65536
2019-01-29 20:04:19.810: Fetch 65536
2019-01-29 20:04:19.828: Fetch 65536
2019-01-29 20:04:19.843: Fetch 65536
2019-01-29 20:04:19.859: Fetch 65536
2019-01-29 20:04:19.871: Fetch 65536
2019-01-29 20:04:19.887: Fetch 65536
2019-01-29 20:04:19.904: Fetch 65536
2019-01-29 20:04:19.922: Fetch 65536
2019-01-29 20:04:19.942: Fetch 65536
2019-01-29 20:04:19.961: Fetch 65536
2019-01-29 20:04:19.977: Fetch 65536
2019-01-29 20:04:19.992: Fetch 65536
2019-01-29 20:04:20.004: Fetch 65536
2019-01-29 20:04:20.016: Fetch 65536
2019-01-29 20:04:20.028: Fetch 65536
2019-01-29 20:04:20.041: Fetch 65536
2019-01-29 20:04:20.058: Fetch 65536
2019-01-29 20:04:20.071: Fetch 65536
2019-01-29 20:04:20.086: Fetch 65536
2019-01-29 20:04:20.105: Fetch 65536
2019-01-29 20:04:20.120: Fetch 65536
2019-01-29 20:04:20.134: Fetch 65536
2019-01-29 20:04:20.147: Fetch 65536
2019-01-29 20:04:20.163: Fetch 65536
2019-01-29 20:04:31.097: Fetch 65536
2019-01-29 20:04:31.131: Fetch 65536
2019-01-29 20:04:31.147: Fetch 65536
2019-01-29 20:04:31.161: Fetch 65536
2019-01-29 20:04:31.175: Fetch 65536
2019-01-29 20:04:31.186: Fetch 65536
2019-01-29 20:04:31.198: Fetch 65536
2019-01-29 20:04:31.215: Fetch 65536
2019-01-29 20:04:31.238: Fetch 65536
2019-01-29 20:04:31.254: Fetch 65536
2019-01-29 20:04:31.273: Fetch 65536
2019-01-29 20:04:31.286: Fetch 65536
2019-01-29 20:04:31.297: Fetch 65536
2019-01-29 20:04:31.307: Fetch 65536
2019-01-29 20:04:31.328: Fetch 65536
2019-01-29 20:04:31.348: Fetch 65536
2019-01-29 20:04:31.365: Fetch 65536
2019-01-29 20:04:31.381: Fetch 65536
2019-01-29 20:04:31.393: Fetch 65536
2019-01-29 20:04:31.407: Fetch 65536
2019-01-29 20:04:31.433: Fetch 65536
2019-01-29 20:04:31.445: Fetch 65536
2019-01-29 20:04:31.457: Fetch 65536
2019-01-29 20:04:31.471: Fetch 65536
2019-01-29 20:04:31.485: Fetch 65536
2019-01-29 20:04:31.498: Fetch 65536
2019-01-29 20:04:31.512: Fetch 65536
2019-01-29 20:04:31.528: Fetch 65536
2019-01-29 20:04:31.541: Fetch 65536
2019-01-29 20:04:31.553: Fetch 65536
2019-01-29 20:04:31.567: Fetch 65536
2019-01-29 20:04:31.583: Fetch 65536
2019-01-29 20:04:31.607: Fetch 65536
2019-01-29 20:04:31.628: Fetch 65536
2019-01-29 20:04:31.647: Fetch 65536
2019-01-29 20:04:31.659: Fetch 65536
2019-01-29 20:04:31.670: Fetch 65536
2019-01-29 20:04:31.682: Fetch 65536
2019-01-29 20:04:31.694: Fetch 65536
2019-01-29 20:04:31.707: Fetch 65536
2019-01-29 20:04:31.728: Fetch 65536
2019-01-29 20:04:31.744: Fetch 65536
2019-01-29 20:04:31.764: Fetch 65536
2019-01-29 20:04:31.783: Fetch 65536
2019-01-29 20:04:31.798: Fetch 65536
2019-01-29 20:04:31.808: Fetch 65536
2019-01-29 20:04:31.822: Fetch 65536
2019-01-29 20:04:31.834: Fetch 65536
2019-01-29 20:04:31.846: Fetch 65536
2019-01-29 20:04:31.859: Fetch 65536
2019-01-29 20:04:31.884: Fetch 65536
2019-01-29 20:04:31.898: Fetch 65536
2019-01-29 20:04:31.918: Fetch 65536
2019-01-29 20:04:31.933: Fetch 65536
2019-01-29 20:04:31.946: Fetch 65536
2019-01-29 20:04:31.959: Fetch 65536
2019-01-29 20:04:31.975: Fetch 65536
2019-01-29 20:04:31.994: Fetch 65536
2019-01-29 20:04:32.015: Fetch 65536
2019-01-29 20:04:32.038: Fetch 65536
2019-01-29 20:04:32.050: Fetch 65536
2019-01-29 20:04:32.065: Fetch 65536
2019-01-29 20:04:32.084: Fetch 65536
2019-01-29 20:04:42.974: Fetch 65536
2019-01-29 20:04:43.004: Fetch 65536
2019-01-29 20:04:43.017: Fetch 65536
2019-01-29 20:04:43.030: Fetch 65536
2019-01-29 20:04:43.040: Fetch 65536
2019-01-29 20:04:43.052: Fetch 65536
2019-01-29 20:04:43.065: Fetch 65536
2019-01-29 20:04:43.084: Fetch 65536
2019-01-29 20:04:43.103: Fetch 65536
2019-01-29 20:04:43.133: Fetch 65536
2019-01-29 20:04:43.148: Fetch 65536
2019-01-29 20:04:43.161: Fetch 65536
2019-01-29 20:04:43.179: Fetch 65536
2019-01-29 20:04:43.196: Fetch 65536
2019-01-29 20:04:43.216: Fetch 65536
2019-01-29 20:04:43.231: Fetch 65536
2019-01-29 20:04:43.244: Fetch 65536
2019-01-29 20:04:43.261: Fetch 65536
2019-01-29 20:04:43.282: Fetch 65536
2019-01-29 20:04:43.312: Fetch 65536
2019-01-29 20:04:43.346: Fetch 65536
2019-01-29 20:04:43.366: Fetch 65536
2019-01-29 20:04:43.382: Fetch 65536
2019-01-29 20:04:43.396: Fetch 65536
2019-01-29 20:04:43.409: Fetch 65536
2019-01-29 20:04:43.423: Fetch 65536
2019-01-29 20:04:43.445: Fetch 65536
2019-01-29 20:04:43.459: Fetch 65536
2019-01-29 20:04:43.472: Fetch 65536
2019-01-29 20:04:43.495: Fetch 65536
2019-01-29 20:04:43.512: Fetch 65536
2019-01-29 20:04:43.533: Fetch 65536
2019-01-29 20:04:43.545: Fetch 65536
2019-01-29 20:04:43.556: Fetch 65536
2019-01-29 20:04:43.567: Fetch 65536
2019-01-29 20:04:43.588: Fetch 65536
2019-01-29 20:04:43.607: Fetch 65536
2019-01-29 20:04:43.633: Fetch 65536
2019-01-29 20:04:43.646: Fetch 65536
2019-01-29 20:04:43.658: Fetch 65536
2019-01-29 20:04:43.674: Fetch 65536
2019-01-29 20:04:43.686: Fetch 65536
2019-01-29 20:04:43.699: Fetch 65536
2019-01-29 20:04:43.716: Fetch 65536
2019-01-29 20:04:43.734: Fetch 65536
2019-01-29 20:04:43.757: Fetch 65536
2019-01-29 20:04:43.776: Fetch 65536
2019-01-29 20:04:43.794: Fetch 65536
2019-01-29 20:04:43.805: Fetch 65536
2019-01-29 20:04:43.819: Fetch 65536
2019-01-29 20:04:43.834: Fetch 65536
2019-01-29 20:04:43.856: Fetch 65536
2019-01-29 20:04:43.868: Fetch 65536
2019-01-29 20:04:43.880: Fetch 65536
2019-01-29 20:04:43.898: Fetch 65536
2019-01-29 20:04:43.914: Fetch 65536
2019-01-29 20:04:43.934: Fetch 65536
2019-01-29 20:04:43.951: Fetch 65536
2019-01-29 20:04:43.968: Fetch 65536
2019-01-29 20:04:43.983: Fetch 65536
2019-01-29 20:04:43.996: Fetch 65536
2019-01-29 20:04:44.007: Fetch 65536
2019-01-29 20:04:44.025: Fetch 65536
2019-01-29 20:04:44.037: Fetch 65536
2019-01-29 20:04:44.053: Fetch 65536
2019-01-29 20:04:44.070: Fetch 65536
2019-01-29 20:04:44.082: Fetch 65536
2019-01-29 20:04:44.097: Fetch 65536
2019-01-29 20:04:54.877: Fetch 65536
2019-01-29 20:04:54.911: Fetch 65536
2019-01-29 20:04:54.923: Fetch 65536
2019-01-29 20:04:54.935: Fetch 65536
2019-01-29 20:04:54.949: Fetch 65536
2019-01-29 20:04:54.963: Fetch 65536
2019-01-29 20:04:54.991: Fetch 65536
2019-01-29 20:04:55.007: Fetch 65536
2019-01-29 20:04:55.035: Fetch 65536
2019-01-29 20:04:55.047: Fetch 65536
2019-01-29 20:04:55.058: Fetch 65536
2019-01-29 20:04:55.080: Fetch 65536
2019-01-29 20:04:55.100: Fetch 65536
2019-01-29 20:04:55.114: Fetch 65536
2019-01-29 20:04:55.129: Fetch 65536
2019-01-29 20:04:55.147: Fetch 65536
2019-01-29 20:04:55.165: Fetch 65536
2019-01-29 20:04:55.182: Fetch 65536
2019-01-29 20:04:55.210: Fetch 65536
2019-01-29 20:04:55.228: Fetch 65536
2019-01-29 20:04:55.243: Fetch 65536
2019-01-29 20:04:55.259: Fetch 65536
2019-01-29 20:04:55.276: Fetch 65536
2019-01-29 20:04:55.288: Fetch 65536
2019-01-29 20:04:55.302: Fetch 65536
2019-01-29 20:04:55.319: Fetch 65536
2019-01-29 20:04:55.335: Fetch 65536
2019-01-29 20:04:55.360: Fetch 65536
2019-01-29 20:04:55.380: Fetch 65536
2019-01-29 20:04:55.400: Fetch 65536
2019-01-29 20:04:55.413: Fetch 65536
2019-01-29 20:04:55.426: Fetch 65536
2019-01-29 20:04:55.440: Fetch 65536
2019-01-29 20:04:55.454: Fetch 65536
2019-01-29 20:04:55.467: Fetch 65536
2019-01-29 20:04:55.480: Fetch 65536
2019-01-29 20:04:55.500: Fetch 65536
2019-01-29 20:04:55.520: Fetch 65536
2019-01-29 20:04:55.539: Fetch 65536
2019-01-29 20:04:55.558: Fetch 65536
2019-01-29 20:04:55.575: Fetch 65536
2019-01-29 20:04:55.588: Fetch 65536
2019-01-29 20:04:55.602: Fetch 65536
2019-01-29 20:04:55.615: Fetch 65536
2019-01-29 20:04:55.626: Fetch 65536
2019-01-29 20:04:55.645: Fetch 65536
2019-01-29 20:04:55.662: Fetch 65536
2019-01-29 20:04:55.679: Fetch 65536
2019-01-29 20:04:55.698: Fetch 65536
2019-01-29 20:04:55.722: Fetch 65536
2019-01-29 20:04:55.737: Fetch 65536
2019-01-29 20:04:55.751: Fetch 65536
2019-01-29 20:04:55.764: Fetch 65536
2019-01-29 20:04:55.778: Fetch 65536
2019-01-29 20:04:55.796: Fetch 65536
2019-01-29 20:04:55.812: Fetch 65536
2019-01-29 20:04:55.831: Fetch 65536
2019-01-29 20:04:55.852: Fetch 65536
2019-01-29 20:04:55.865: Fetch 65536
2019-01-29 20:04:55.880: Fetch 65536
2019-01-29 20:05:08.247: Fetch 65536
2019-01-29 20:05:08.294: Fetch 65536
2019-01-29 20:05:08.308: Fetch 65536
2019-01-29 20:05:08.321: Fetch 65536
2019-01-29 20:05:08.335: Fetch 65536
2019-01-29 20:05:08.353: Fetch 65536
2019-01-29 20:05:08.376: Fetch 65536
2019-01-29 20:05:08.394: Fetch 65536
2019-01-29 20:05:08.408: Fetch 65536
2019-01-29 20:05:08.422: Fetch 65536
2019-01-29 20:05:08.442: Fetch 65536
2019-01-29 20:05:08.456: Fetch 65536
2019-01-29 20:05:08.468: Fetch 65536
2019-01-29 20:05:08.488: Fetch 65536
2019-01-29 20:05:08.501: Fetch 65536
2019-01-29 20:05:08.513: Fetch 65536
2019-01-29 20:05:08.528: Fetch 65536
2019-01-29 20:05:08.542: Fetch 65536
2019-01-29 20:05:08.564: Fetch 65536
2019-01-29 20:05:08.579: Fetch 65536
2019-01-29 20:05:08.596: Fetch 65536
2019-01-29 20:05:08.613: Fetch 65536
2019-01-29 20:05:08.625: Fetch 65536
2019-01-29 20:05:08.640: Fetch 65536
2019-01-29 20:05:08.657: Fetch 65536
2019-01-29 20:05:08.675: Fetch 65536
2019-01-29 20:05:08.689: Fetch 65536
2019-01-29 20:05:08.704: Fetch 65536
2019-01-29 20:05:08.723: Fetch 65536
2019-01-29 20:05:08.736: Fetch 65536
2019-01-29 20:05:08.751: Fetch 65536
2019-01-29 20:05:08.764: Fetch 65536
2019-01-29 20:05:08.778: Fetch 65536
2019-01-29 20:05:08.791: Fetch 65536
2019-01-29 20:05:08.808: Fetch 65536
2019-01-29 20:05:08.829: Fetch 65536
2019-01-29 20:05:08.844: Fetch 65536
2019-01-29 20:05:08.857: Fetch 65536
2019-01-29 20:05:08.874: Fetch 65536
2019-01-29 20:05:08.892: Fetch 65536
2019-01-29 20:05:08.908: Fetch 65536
2019-01-29 20:05:08.923: Fetch 65536
2019-01-29 20:05:08.938: Fetch 65536
2019-01-29 20:05:08.950: Fetch 65536
2019-01-29 20:05:08.966: Fetch 65536
2019-01-29 20:05:08.979: Fetch 65536
2019-01-29 20:05:08.999: Fetch 65536
2019-01-29 20:05:09.015: Fetch 65536
2019-01-29 20:05:09.031: Fetch 65536
2019-01-29 20:05:09.047: Fetch 65536
2019-01-29 20:05:09.062: Fetch 65536
2019-01-29 20:05:09.080: Fetch 65536
2019-01-29 20:05:09.096: Fetch 65536
2019-01-29 20:05:09.113: Fetch 65536
2019-01-29 20:05:09.130: Fetch 65536
2019-01-29 20:05:09.144: Fetch 65536
2019-01-29 20:05:09.162: Fetch 65536
2019-01-29 20:05:09.178: Fetch 65536
2019-01-29 20:05:09.195: Fetch 65536
2019-01-29 20:05:09.215: Fetch 65536
2019-01-29 20:05:09.229: Fetch 65536
2019-01-29 20:05:09.244: Fetch 65536
2019-01-29 20:05:18.646: Fetch 65536
2019-01-29 20:05:18.660: Fetch 65536
2019-01-29 20:05:18.673: Fetch 65536
2019-01-29 20:05:18.684: Fetch 65536
2019-01-29 20:05:18.697: Fetch 65536
2019-01-29 20:05:18.712: Fetch 65536
2019-01-29 20:05:18.733: Fetch 65536
2019-01-29 20:05:18.752: Fetch 65536
2019-01-29 20:05:18.768: Fetch 65536
2019-01-29 20:05:18.784: Fetch 65536
2019-01-29 20:05:18.798: Fetch 65536
2019-01-29 20:05:18.811: Fetch 65536
2019-01-29 20:05:18.822: Fetch 65536
2019-01-29 20:05:18.834: Fetch 65536
2019-01-29 20:05:18.846: Fetch 65536
2019-01-29 20:05:18.863: Fetch 65536
2019-01-29 20:05:18.881: Fetch 65536
2019-01-29 20:05:18.898: Fetch 65536
2019-01-29 20:05:18.915: Fetch 65536
2019-01-29 20:05:18.930: Fetch 65536
2019-01-29 20:05:18.943: Fetch 65536
2019-01-29 20:05:18.958: Fetch 65536
2019-01-29 20:05:18.975: Fetch 65536
2019-01-29 20:05:18.994: Fetch 65536
2019-01-29 20:05:19.018: Fetch 65536
2019-01-29 20:05:19.034: Fetch 65536
2019-01-29 20:05:19.047: Fetch 65536
2019-01-29 20:05:19.063: Fetch 65536
2019-01-29 20:05:19.079: Fetch 65536
2019-01-29 20:05:19.093: Fetch 65536
2019-01-29 20:05:19.105: Fetch 65536
2019-01-29 20:05:19.117: Fetch 65536
2019-01-29 20:05:19.128: Fetch 65536
2019-01-29 20:05:19.144: Fetch 65536
2019-01-29 20:05:19.165: Fetch 65536
2019-01-29 20:05:19.180: Fetch 65536
2019-01-29 20:05:19.193: Fetch 65536
2019-01-29 20:05:19.209: Fetch 65536
2019-01-29 20:05:19.221: Fetch 65536
2019-01-29 20:05:19.233: Fetch 65536
2019-01-29 20:05:19.247: Fetch 65536
2019-01-29 20:05:19.260: Fetch 65536
2019-01-29 20:05:19.274: Fetch 65536
2019-01-29 20:05:19.294: Fetch 65536
2019-01-29 20:05:19.311: Fetch 65536
2019-01-29 20:05:19.326: Fetch 65536
2019-01-29 20:05:19.343: Fetch 65536
2019-01-29 20:05:19.358: Fetch 65536
2019-01-29 20:05:19.377: Fetch 65536
2019-01-29 20:05:19.395: Fetch 65536
2019-01-29 20:05:19.407: Fetch 65536
2019-01-29 20:05:19.422: Fetch 65536
2019-01-29 20:05:19.440: Fetch 65536
2019-01-29 20:05:19.460: Fetch 65536
2019-01-29 20:05:19.480: Fetch 65536
2019-01-29 20:05:19.500: Fetch 65536
2019-01-29 20:05:19.515: Fetch 65536
2019-01-29 20:05:19.535: Fetch 65536
2019-01-29 20:05:19.549: Fetch 65536
2019-01-29 20:05:19.563: Fetch 65536
2019-01-29 20:05:19.581: Fetch 65536
2019-01-29 20:05:30.538: Fetch 65536
2019-01-29 20:05:30.575: Fetch 65536
2019-01-29 20:05:30.589: Fetch 65536
2019-01-29 20:05:30.607: Fetch 65536
2019-01-29 20:05:30.626: Fetch 65536
2019-01-29 20:05:30.638: Fetch 65536
2019-01-29 20:05:30.649: Fetch 65536
2019-01-29 20:05:30.663: Fetch 65536
2019-01-29 20:05:30.678: Fetch 65536
2019-01-29 20:05:30.693: Fetch 65536
2019-01-29 20:05:30.707: Fetch 65536
2019-01-29 20:05:30.725: Fetch 65536
2019-01-29 20:05:30.740: Fetch 65536
2019-01-29 20:05:30.767: Fetch 65536
2019-01-29 20:05:30.787: Fetch 65536
2019-01-29 20:05:30.807: Fetch 65536
2019-01-29 20:05:30.833: Fetch 65536
2019-01-29 20:05:30.852: Fetch 65536
2019-01-29 20:05:30.864: Fetch 65536
2019-01-29 20:05:30.878: Fetch 65536
2019-01-29 20:05:30.896: Fetch 65536
2019-01-29 20:05:30.914: Fetch 65536
2019-01-29 20:05:30.928: Fetch 65536
2019-01-29 20:05:30.951: Fetch 65536
2019-01-29 20:05:30.965: Fetch 65536
2019-01-29 20:05:30.978: Fetch 65536
2019-01-29 20:05:30.991: Fetch 65536
2019-01-29 20:05:31.003: Fetch 65536
2019-01-29 20:05:31.014: Fetch 65536
2019-01-29 20:05:31.032: Fetch 65536
2019-01-29 20:05:31.048: Fetch 65536
2019-01-29 20:05:31.065: Fetch 65536
2019-01-29 20:05:31.091: Fetch 65536
2019-01-29 20:05:31.107: Fetch 65536
2019-01-29 20:05:31.124: Fetch 65536
2019-01-29 20:05:31.148: Fetch 65536
2019-01-29 20:05:31.171: Fetch 65536
2019-01-29 20:05:31.183: Fetch 65536
2019-01-29 20:05:31.200: Fetch 65536
2019-01-29 20:05:31.226: Fetch 65536
2019-01-29 20:05:31.246: Fetch 65536
2019-01-29 20:05:31.261: Fetch 65536
2019-01-29 20:05:31.276: Fetch 65536
2019-01-29 20:05:31.290: Fetch 65536
2019-01-29 20:05:31.302: Fetch 65536
2019-01-29 20:05:31.316: Fetch 65536
2019-01-29 20:05:31.337: Fetch 65536
2019-01-29 20:05:31.370: Fetch 65536
2019-01-29 20:05:31.393: Fetch 65536
2019-01-29 20:05:31.406: Fetch 65536
2019-01-29 20:05:31.420: Fetch 65536
2019-01-29 20:05:31.433: Fetch 65536
2019-01-29 20:05:31.447: Fetch 65536
2019-01-29 20:05:31.464: Fetch 65536
2019-01-29 20:05:31.481: Fetch 65536
2019-01-29 20:05:31.498: Fetch 65536
2019-01-29 20:05:31.517: Fetch 65536
2019-01-29 20:05:31.539: Fetch 65536
2019-01-29 20:05:31.552: Fetch 65536
2019-01-29 20:05:31.564: Fetch 65536
2019-01-29 20:05:42.417: Fetch 65536
2019-01-29 20:05:42.431: Fetch 65536
2019-01-29 20:05:42.445: Fetch 65536
2019-01-29 20:05:42.458: Fetch 65536
2019-01-29 20:05:42.474: Fetch 65536
2019-01-29 20:05:42.489: Fetch 65536
2019-01-29 20:05:42.512: Fetch 65536
2019-01-29 20:05:42.540: Fetch 65536
2019-01-29 20:05:42.557: Fetch 65536
2019-01-29 20:05:42.574: Fetch 65536
2019-01-29 20:05:42.588: Fetch 65536
2019-01-29 20:05:42.603: Fetch 65536
2019-01-29 20:05:42.616: Fetch 65536
2019-01-29 20:05:42.629: Fetch 65536
2019-01-29 20:05:42.642: Fetch 65536
2019-01-29 20:05:42.656: Fetch 65536
2019-01-29 20:05:42.679: Fetch 65536
2019-01-29 20:05:42.696: Fetch 65536
2019-01-29 20:05:42.715: Fetch 65536
2019-01-29 20:05:42.727: Fetch 65536
2019-01-29 20:05:42.739: Fetch 65536
2019-01-29 20:05:42.752: Fetch 65536
2019-01-29 20:05:42.766: Fetch 65536
2019-01-29 20:05:42.781: Fetch 65536
2019-01-29 20:05:42.798: Fetch 65536
2019-01-29 20:05:42.818: Fetch 65536
2019-01-29 20:05:42.832: Fetch 65536
2019-01-29 20:05:42.846: Fetch 65536
2019-01-29 20:05:42.861: Fetch 65536
2019-01-29 20:05:42.875: Fetch 65536
2019-01-29 20:05:42.886: Fetch 65536
2019-01-29 20:05:42.902: Fetch 65536
2019-01-29 20:05:42.916: Fetch 65536
2019-01-29 20:05:42.934: Fetch 65536
2019-01-29 20:05:42.961: Fetch 65536
2019-01-29 20:05:42.981: Fetch 65536
2019-01-29 20:05:42.994: Fetch 65536
2019-01-29 20:05:43.007: Fetch 65536
2019-01-29 20:05:43.021: Fetch 65536
2019-01-29 20:05:43.033: Fetch 65536
2019-01-29 20:05:43.046: Fetch 65536
2019-01-29 20:05:43.061: Fetch 65536
2019-01-29 20:05:43.081: Fetch 65536
2019-01-29 20:05:43.101: Fetch 65536
2019-01-29 20:05:43.134: Fetch 65536
2019-01-29 20:05:43.152: Fetch 65536
2019-01-29 20:05:43.164: Fetch 65536
2019-01-29 20:05:43.188: Fetch 65536
2019-01-29 20:05:43.202: Fetch 65536
2019-01-29 20:05:43.220: Fetch 65536
2019-01-29 20:05:43.239: Fetch 65536
2019-01-29 20:05:43.260: Fetch 65536
2019-01-29 20:05:43.277: Fetch 65536
2019-01-29 20:05:43.302: Fetch 65536
2019-01-29 20:05:43.324: Fetch 65536
2019-01-29 20:05:43.347: Fetch 65536
2019-01-29 20:05:43.360: Fetch 65536
2019-01-29 20:05:43.376: Fetch 65536
2019-01-29 20:05:43.394: Fetch 65536
2019-01-29 20:05:43.410: Fetch 65536
2019-01-29 20:05:43.426: Fetch 65536
2019-01-29 20:05:54.318: Fetch 65536
2019-01-29 20:05:54.356: Fetch 65536
2019-01-29 20:05:54.367: Fetch 65536
2019-01-29 20:05:54.381: Fetch 65536
2019-01-29 20:05:54.396: Fetch 65536
2019-01-29 20:05:54.410: Fetch 65536
2019-01-29 20:05:54.422: Fetch 65536
2019-01-29 20:05:54.442: Fetch 65536
2019-01-29 20:05:54.462: Fetch 65536
2019-01-29 20:05:54.481: Fetch 65536
2019-01-29 20:05:54.496: Fetch 65536
2019-01-29 20:05:54.513: Fetch 65536
2019-01-29 20:05:54.526: Fetch 65536
2019-01-29 20:05:54.542: Fetch 65536
2019-01-29 20:05:54.556: Fetch 65536
2019-01-29 20:05:54.571: Fetch 65536
2019-01-29 20:05:54.588: Fetch 65536
2019-01-29 20:05:54.602: Fetch 65536
2019-01-29 20:05:54.616: Fetch 65536
2019-01-29 20:05:54.629: Fetch 65536
2019-01-29 20:05:54.643: Fetch 65536
2019-01-29 20:05:54.661: Fetch 65536
2019-01-29 20:05:54.676: Fetch 65536
2019-01-29 20:05:54.692: Fetch 65536
2019-01-29 20:05:54.706: Fetch 65536
2019-01-29 20:05:54.720: Fetch 65536
2019-01-29 20:05:54.732: Fetch 65536
2019-01-29 20:05:54.743: Fetch 65536
2019-01-29 20:05:54.755: Fetch 65536
2019-01-29 20:05:54.771: Fetch 65536
2019-01-29 20:05:54.788: Fetch 65536
2019-01-29 20:05:54.808: Fetch 65536
2019-01-29 20:05:54.836: Fetch 65536
2019-01-29 20:05:54.852: Fetch 65536
2019-01-29 20:05:54.864: Fetch 65536
2019-01-29 20:05:54.883: Fetch 65536
2019-01-29 20:05:54.896: Fetch 65536
2019-01-29 20:05:54.910: Fetch 65536
2019-01-29 20:05:54.925: Fetch 65536
2019-01-29 20:05:54.940: Fetch 65536
2019-01-29 20:05:54.958: Fetch 65536
2019-01-29 20:05:54.977: Fetch 65536
2019-01-29 20:05:54.992: Fetch 65536
2019-01-29 20:05:55.008: Fetch 65536
2019-01-29 20:05:55.027: Fetch 65536
2019-01-29 20:05:55.048: Fetch 65536
2019-01-29 20:05:55.069: Fetch 65536
2019-01-29 20:05:55.083: Fetch 65536
2019-01-29 20:05:55.096: Fetch 65536
2019-01-29 20:05:55.110: Fetch 65536
2019-01-29 20:05:55.126: Fetch 65536
2019-01-29 20:05:55.139: Fetch 65536
2019-01-29 20:05:55.156: Fetch 65536
2019-01-29 20:05:55.173: Fetch 65536
2019-01-29 20:05:55.189: Fetch 65536
2019-01-29 20:05:55.203: Fetch 65536
2019-01-29 20:05:55.221: Fetch 65536
2019-01-29 20:05:55.236: Fetch 65536
2019-01-29 20:05:55.249: Fetch 65536
2019-01-29 20:05:55.263: Fetch 65536
2019-01-29 20:05:55.277: Fetch 65536
2019-01-29 20:06:06.198: Fetch 65536
2019-01-29 20:06:06.236: Fetch 65536
2019-01-29 20:06:06.254: Fetch 65536
2019-01-29 20:06:06.266: Fetch 65536
2019-01-29 20:06:06.278: Fetch 65536
2019-01-29 20:06:06.293: Fetch 65536
2019-01-29 20:06:06.315: Fetch 65536
2019-01-29 20:06:06.332: Fetch 65536
2019-01-29 20:06:06.348: Fetch 65536
2019-01-29 20:06:06.365: Fetch 65536
2019-01-29 20:06:06.377: Fetch 65536
2019-01-29 20:06:06.394: Fetch 65536
2019-01-29 20:06:06.409: Fetch 65536
2019-01-29 20:06:06.422: Fetch 65536
2019-01-29 20:06:06.436: Fetch 65536
2019-01-29 20:06:06.453: Fetch 65536
2019-01-29 20:06:06.472: Fetch 65536
2019-01-29 20:06:06.493: Fetch 65536
2019-01-29 20:06:06.511: Fetch 65536
2019-01-29 20:06:06.531: Fetch 65536
2019-01-29 20:06:06.544: Fetch 65536
2019-01-29 20:06:06.555: Fetch 65536
2019-01-29 20:06:06.567: Fetch 65536
2019-01-29 20:06:06.585: Fetch 65536
2019-01-29 20:06:06.600: Fetch 65536
2019-01-29 20:06:06.621: Fetch 65536
2019-01-29 20:06:06.642: Fetch 65536
2019-01-29 20:06:06.658: Fetch 65536
2019-01-29 20:06:06.670: Fetch 65536
2019-01-29 20:06:06.683: Fetch 65536
2019-01-29 20:06:06.704: Fetch 65536
2019-01-29 20:06:06.719: Fetch 65536
2019-01-29 20:06:06.731: Fetch 65536
2019-01-29 20:06:06.744: Fetch 65536
2019-01-29 20:06:06.756: Fetch 65536
2019-01-29 20:06:06.769: Fetch 65536
2019-01-29 20:06:06.782: Fetch 65536
2019-01-29 20:06:06.805: Fetch 65536
2019-01-29 20:06:06.823: Fetch 65536
2019-01-29 20:06:06.844: Fetch 65536
2019-01-29 20:06:06.858: Fetch 65536
2019-01-29 20:06:06.869: Fetch 65536
2019-01-29 20:06:06.881: Fetch 65536
2019-01-29 20:06:06.898: Fetch 65536
2019-01-29 20:06:06.920: Fetch 65536
2019-01-29 20:06:06.937: Fetch 65536
2019-01-29 20:06:06.957: Fetch 65536
2019-01-29 20:06:06.978: Fetch 65536
2019-01-29 20:06:06.989: Fetch 65536
2019-01-29 20:06:07.003: Fetch 65536
2019-01-29 20:06:07.025: Fetch 65536
2019-01-29 20:06:07.040: Fetch 65536
2019-01-29 20:06:07.057: Fetch 65536
2019-01-29 20:06:07.074: Fetch 65536
2019-01-29 20:06:07.087: Fetch 65536
2019-01-29 20:06:07.100: Fetch 65536
2019-01-29 20:06:07.112: Fetch 65536
2019-01-29 20:06:07.127: Fetch 65536
2019-01-29 20:06:07.144: Fetch 65536
2019-01-29 20:06:07.177: Fetch 65536
2019-01-29 20:06:07.195: Fetch 65536
2019-01-29 20:06:07.209: Fetch 65536
2019-01-29 20:06:07.224: Fetch 65536
2019-01-29 20:06:07.239: Fetch 65536
2019-01-29 20:06:18.101: Fetch 65536
2019-01-29 20:06:18.136: Fetch 65536
2019-01-29 20:06:18.149: Fetch 65536
2019-01-29 20:06:18.162: Fetch 65536
2019-01-29 20:06:18.178: Fetch 65536
2019-01-29 20:06:18.194: Fetch 65536
2019-01-29 20:06:18.207: Fetch 65536
2019-01-29 20:06:18.224: Fetch 65536
2019-01-29 20:06:18.243: Fetch 65536
2019-01-29 20:06:18.257: Fetch 65536
2019-01-29 20:06:18.275: Fetch 65536
2019-01-29 20:06:18.299: Fetch 65536
2019-01-29 20:06:18.311: Fetch 65536
2019-01-29 20:06:18.325: Fetch 65536
2019-01-29 20:06:18.337: Fetch 65536
2019-01-29 20:06:18.347: Fetch 65536
2019-01-29 20:06:18.359: Fetch 65536
2019-01-29 20:06:18.379: Fetch 65536
2019-01-29 20:06:18.396: Fetch 65536
2019-01-29 20:06:18.416: Fetch 65536
2019-01-29 20:06:18.436: Fetch 65536
2019-01-29 20:06:18.453: Fetch 65536
2019-01-29 20:06:18.468: Fetch 65536
2019-01-29 20:06:18.483: Fetch 65536
2019-01-29 20:06:18.501: Fetch 65536
2019-01-29 20:06:18.521: Fetch 65536
2019-01-29 20:06:18.543: Fetch 65536
2019-01-29 20:06:18.559: Fetch 65536
2019-01-29 20:06:18.572: Fetch 65536
2019-01-29 20:06:18.586: Fetch 65536
2019-01-29 20:06:18.606: Fetch 65536
2019-01-29 20:06:18.621: Fetch 65536
2019-01-29 20:06:18.638: Fetch 65536
2019-01-29 20:06:18.652: Fetch 65536
2019-01-29 20:06:18.667: Fetch 65536
2019-01-29 20:06:18.690: Fetch 65536
2019-01-29 20:06:18.706: Fetch 65536
2019-01-29 20:06:18.721: Fetch 65536
2019-01-29 20:06:18.741: Fetch 65536
2019-01-29 20:06:18.755: Fetch 65536
2019-01-29 20:06:18.772: Fetch 65536
2019-01-29 20:06:18.786: Fetch 65536
2019-01-29 20:06:18.799: Fetch 65536
2019-01-29 20:06:18.814: Fetch 65536
2019-01-29 20:06:18.831: Fetch 65536
2019-01-29 20:06:18.851: Fetch 65536
2019-01-29 20:06:18.874: Fetch 65536
2019-01-29 20:06:18.903: Fetch 65536
2019-01-29 20:06:18.916: Fetch 65536
2019-01-29 20:06:18.930: Fetch 65536
2019-01-29 20:06:18.956: Fetch 65536
2019-01-29 20:06:18.976: Fetch 65536
2019-01-29 20:06:18.990: Fetch 65536
2019-01-29 20:06:19.008: Fetch 65536
2019-01-29 20:06:19.028: Fetch 65536
2019-01-29 20:06:19.044: Fetch 65536
2019-01-29 20:06:31.463: Fetch 65536
2019-01-29 20:06:31.517: Fetch 65536
2019-01-29 20:06:31.546: Fetch 65536
2019-01-29 20:06:31.566: Fetch 65536
2019-01-29 20:06:31.591: Fetch 65536
2019-01-29 20:06:31.602: Fetch 65536
2019-01-29 20:06:31.621: Fetch 65536
2019-01-29 20:06:31.638: Fetch 65536
2019-01-29 20:06:31.661: Fetch 65536
2019-01-29 20:06:31.679: Fetch 65536
2019-01-29 20:06:31.694: Fetch 65536
2019-01-29 20:06:31.706: Fetch 65536
2019-01-29 20:06:31.720: Fetch 65536
2019-01-29 20:06:31.733: Fetch 65536
2019-01-29 20:06:31.744: Fetch 65536
2019-01-29 20:06:31.757: Fetch 65536
2019-01-29 20:06:31.781: Fetch 65536
2019-01-29 20:06:31.800: Fetch 65536
2019-01-29 20:06:31.819: Fetch 65536
2019-01-29 20:06:31.838: Fetch 65536
2019-01-29 20:06:31.856: Fetch 65536
2019-01-29 20:06:31.870: Fetch 65536
2019-01-29 20:06:31.882: Fetch 65536
2019-01-29 20:06:31.896: Fetch 65536
2019-01-29 20:06:31.910: Fetch 65536
2019-01-29 20:06:31.924: Fetch 65536
2019-01-29 20:06:31.944: Fetch 65536
2019-01-29 20:06:31.959: Fetch 65536
2019-01-29 20:06:31.975: Fetch 65536
2019-01-29 20:06:31.991: Fetch 65536
2019-01-29 20:06:32.008: Fetch 65536
2019-01-29 20:06:32.022: Fetch 65536
2019-01-29 20:06:32.035: Fetch 65536
2019-01-29 20:06:32.045: Fetch 65536
2019-01-29 20:06:32.060: Fetch 65536
2019-01-29 20:06:32.076: Fetch 65536
2019-01-29 20:06:32.099: Fetch 65536
2019-01-29 20:06:32.116: Fetch 65536
2019-01-29 20:06:32.137: Fetch 65536
2019-01-29 20:06:32.154: Fetch 65536
2019-01-29 20:06:32.175: Fetch 65536
2019-01-29 20:06:32.197: Fetch 65536
2019-01-29 20:06:32.211: Fetch 65536
2019-01-29 20:06:32.226: Fetch 65536
2019-01-29 20:06:32.239: Fetch 65536
2019-01-29 20:06:32.254: Fetch 65536
2019-01-29 20:06:32.274: Fetch 65536
2019-01-29 20:06:32.290: Fetch 65536
2019-01-29 20:06:32.305: Fetch 65536
2019-01-29 20:06:32.320: Fetch 65536
2019-01-29 20:06:32.337: Fetch 65536
2019-01-29 20:06:32.357: Fetch 65536
2019-01-29 20:06:32.375: Fetch 65536
2019-01-29 20:06:32.392: Fetch 65536
2019-01-29 20:06:32.405: Fetch 65536
2019-01-29 20:06:32.429: Fetch 65536
2019-01-29 20:06:32.453: Fetch 65536
2019-01-29 20:06:32.467: Fetch 65536
2019-01-29 20:06:32.480: Fetch 65536
2019-01-29 20:06:32.494: Fetch 65536
2019-01-29 20:06:41.876: Fetch 65536
2019-01-29 20:06:41.917: Fetch 65536
2019-01-29 20:06:41.937: Fetch 65536
2019-01-29 20:06:41.948: Fetch 65536
2019-01-29 20:06:41.960: Fetch 65536
2019-01-29 20:06:41.973: Fetch 65536
2019-01-29 20:06:41.995: Fetch 65536
2019-01-29 20:06:42.012: Fetch 65536
2019-01-29 20:06:42.032: Fetch 65536
2019-01-29 20:06:42.047: Fetch 65536
2019-01-29 20:06:42.060: Fetch 65536
2019-01-29 20:06:42.075: Fetch 65536
2019-01-29 20:06:42.094: Fetch 65536
2019-01-29 20:06:42.112: Fetch 65536
2019-01-29 20:06:42.137: Fetch 65536
2019-01-29 20:06:42.157: Fetch 65536
2019-01-29 20:06:42.170: Fetch 65536
2019-01-29 20:06:42.183: Fetch 65536
2019-01-29 20:06:42.198: Fetch 65536
2019-01-29 20:06:42.213: Fetch 65536
2019-01-29 20:06:42.228: Fetch 65536
2019-01-29 20:06:42.246: Fetch 65536
2019-01-29 20:06:42.262: Fetch 65536
2019-01-29 20:06:42.284: Fetch 65536
2019-01-29 20:06:42.303: Fetch 65536
2019-01-29 20:06:42.318: Fetch 65536
2019-01-29 20:06:42.334: Fetch 65536
2019-01-29 20:06:42.351: Fetch 65536
2019-01-29 20:06:42.365: Fetch 65536
2019-01-29 20:06:42.381: Fetch 65536
2019-01-29 20:06:42.398: Fetch 65536
2019-01-29 20:06:42.422: Fetch 65536
2019-01-29 20:06:42.438: Fetch 65536
2019-01-29 20:06:42.450: Fetch 65536
2019-01-29 20:06:42.467: Fetch 65536
2019-01-29 20:06:42.480: Fetch 65536
2019-01-29 20:06:42.497: Fetch 65536
2019-01-29 20:06:42.515: Fetch 65536
2019-01-29 20:06:42.529: Fetch 65536
2019-01-29 20:06:42.548: Fetch 65536
2019-01-29 20:06:42.567: Fetch 65536
2019-01-29 20:06:42.591: Fetch 65536
2019-01-29 20:06:42.605: Fetch 65536
2019-01-29 20:06:42.621: Fetch 65536
2019-01-29 20:06:42.636: Fetch 65536
2019-01-29 20:06:42.647: Fetch 65536
2019-01-29 20:06:42.659: Fetch 65536
2019-01-29 20:06:42.673: Fetch 65536
2019-01-29 20:06:42.685: Fetch 65536
2019-01-29 20:06:42.698: Fetch 65536
2019-01-29 20:06:42.720: Fetch 65536
2019-01-29 20:06:42.744: Fetch 65536
2019-01-29 20:06:42.757: Fetch 65536
2019-01-29 20:06:42.769: Fetch 65536
2019-01-29 20:06:42.783: Fetch 65536
2019-01-29 20:06:42.799: Fetch 65536
2019-01-29 20:06:42.821: Fetch 65536
2019-01-29 20:06:42.837: Fetch 65536
2019-01-29 20:06:53.742: Fetch 65536
2019-01-29 20:06:53.756: Fetch 65536
2019-01-29 20:06:53.769: Fetch 65536
2019-01-29 20:06:53.782: Fetch 65536
2019-01-29 20:06:53.796: Fetch 65536
2019-01-29 20:06:53.811: Fetch 65536
2019-01-29 20:06:53.826: Fetch 65536
2019-01-29 20:06:53.844: Fetch 65536
2019-01-29 20:06:53.863: Fetch 65536
2019-01-29 20:06:53.887: Fetch 65536
2019-01-29 20:06:53.911: Fetch 65536
2019-01-29 20:06:53.926: Fetch 65536
2019-01-29 20:06:53.944: Fetch 65536
2019-01-29 20:06:53.965: Fetch 65536
2019-01-29 20:06:53.980: Fetch 65536
2019-01-29 20:06:53.994: Fetch 65536
2019-01-29 20:06:54.008: Fetch 65536
2019-01-29 20:06:54.020: Fetch 65536
2019-01-29 20:06:54.033: Fetch 65536
2019-01-29 20:06:54.047: Fetch 65536
2019-01-29 20:06:54.060: Fetch 65536
2019-01-29 20:06:54.078: Fetch 65536
2019-01-29 20:06:54.096: Fetch 65536
2019-01-29 20:06:54.113: Fetch 65536
2019-01-29 20:06:54.129: Fetch 65536
2019-01-29 20:06:54.141: Fetch 65536
2019-01-29 20:06:54.157: Fetch 65536
2019-01-29 20:06:54.174: Fetch 65536
2019-01-29 20:06:54.188: Fetch 65536
2019-01-29 20:06:54.201: Fetch 65536
2019-01-29 20:06:54.212: Fetch 65536
2019-01-29 20:06:54.229: Fetch 65536
2019-01-29 20:06:54.250: Fetch 65536
2019-01-29 20:06:54.268: Fetch 65536
2019-01-29 20:06:54.288: Fetch 65536
2019-01-29 20:06:54.304: Fetch 65536
2019-01-29 20:06:54.319: Fetch 65536
2019-01-29 20:06:54.335: Fetch 65536
2019-01-29 20:06:54.350: Fetch 65536
2019-01-29 20:06:54.366: Fetch 65536
2019-01-29 20:06:54.383: Fetch 65536
2019-01-29 20:06:54.398: Fetch 65536
2019-01-29 20:06:54.410: Fetch 65536
2019-01-29 20:06:54.426: Fetch 65536
2019-01-29 20:06:54.441: Fetch 65536
2019-01-29 20:06:54.460: Fetch 65536
2019-01-29 20:06:54.478: Fetch 65536
2019-01-29 20:06:54.494: Fetch 65536
2019-01-29 20:06:54.508: Fetch 65536
2019-01-29 20:06:54.521: Fetch 65536
2019-01-29 20:06:54.540: Fetch 65536
2019-01-29 20:06:54.564: Fetch 65536
2019-01-29 20:06:54.583: Fetch 65536
2019-01-29 20:06:54.599: Fetch 65536
2019-01-29 20:06:54.619: Fetch 65536
2019-01-29 20:06:54.637: Fetch 65536
2019-01-29 20:06:54.657: Fetch 65536
2019-01-29 20:07:05.633: Fetch 65536
2019-01-29 20:07:05.648: Fetch 65536
2019-01-29 20:07:05.665: Fetch 65536
2019-01-29 20:07:05.682: Fetch 65536
2019-01-29 20:07:05.705: Fetch 65536
2019-01-29 20:07:05.736: Fetch 65536
2019-01-29 20:07:05.752: Fetch 65536
2019-01-29 20:07:05.767: Fetch 65536
2019-01-29 20:07:05.782: Fetch 65536
2019-01-29 20:07:05.799: Fetch 65536
2019-01-29 20:07:05.816: Fetch 65536
2019-01-29 20:07:05.829: Fetch 65536
2019-01-29 20:07:05.848: Fetch 65536
2019-01-29 20:07:05.865: Fetch 65536
2019-01-29 20:07:05.885: Fetch 65536
2019-01-29 20:07:05.899: Fetch 65536
2019-01-29 20:07:05.914: Fetch 65536
2019-01-29 20:07:05.926: Fetch 65536
2019-01-29 20:07:05.944: Fetch 65536
2019-01-29 20:07:05.960: Fetch 65536
2019-01-29 20:07:05.974: Fetch 65536
2019-01-29 20:07:05.992: Fetch 65536
2019-01-29 20:07:06.008: Fetch 65536
2019-01-29 20:07:06.024: Fetch 65536
2019-01-29 20:07:06.040: Fetch 65536
2019-01-29 20:07:06.056: Fetch 65536
2019-01-29 20:07:06.080: Fetch 65536
2019-01-29 20:07:06.107: Fetch 65536
2019-01-29 20:07:06.127: Fetch 65536
2019-01-29 20:07:06.147: Fetch 65536
2019-01-29 20:07:06.170: Fetch 65536
2019-01-29 20:07:06.191: Fetch 65536
2019-01-29 20:07:06.207: Fetch 65536
2019-01-29 20:07:06.225: Fetch 65536
2019-01-29 20:07:06.243: Fetch 65536
2019-01-29 20:07:06.259: Fetch 65536
2019-01-29 20:07:06.274: Fetch 65536
2019-01-29 20:07:06.287: Fetch 65536
2019-01-29 20:07:06.303: Fetch 65536
2019-01-29 20:07:06.324: Fetch 65536
2019-01-29 20:07:06.342: Fetch 65536
2019-01-29 20:07:06.362: Fetch 65536
2019-01-29 20:07:06.376: Fetch 65536
2019-01-29 20:07:06.392: Fetch 65536
2019-01-29 20:07:06.406: Fetch 65536
2019-01-29 20:07:06.417: Fetch 65536
2019-01-29 20:07:06.437: Fetch 65536
2019-01-29 20:07:06.452: Fetch 65536
2019-01-29 20:07:06.473: Fetch 65536
2019-01-29 20:07:06.494: Fetch 65536
2019-01-29 20:07:06.510: Fetch 65536
2019-01-29 20:07:06.527: Fetch 65536
2019-01-29 20:07:06.545: Fetch 65536
2019-01-29 20:07:06.563: Fetch 65536
2019-01-29 20:07:06.577: Fetch 65536
2019-01-29 20:07:06.592: Fetch 65536
2019-01-29 20:07:06.610: Fetch 65536
2019-01-29 20:07:06.631: Fetch 65536
2019-01-29 20:07:06.653: Fetch 65536
2019-01-29 20:07:06.667: Fetch 65536
2019-01-29 20:07:17.536: Fetch 65536
2019-01-29 20:07:17.561: Fetch 65536
2019-01-29 20:07:17.573: Fetch 65536
2019-01-29 20:07:17.584: Fetch 65536
2019-01-29 20:07:17.598: Fetch 65536
2019-01-29 20:07:17.615: Fetch 65536
2019-01-29 20:07:17.629: Fetch 65536
2019-01-29 20:07:17.644: Fetch 65536
2019-01-29 20:07:17.665: Fetch 65536
2019-01-29 20:07:17.683: Fetch 65536
2019-01-29 20:07:17.702: Fetch 65536
2019-01-29 20:07:17.718: Fetch 65536
2019-01-29 20:07:17.734: Fetch 65536
2019-01-29 20:07:17.750: Fetch 65536
2019-01-29 20:07:17.766: Fetch 65536
2019-01-29 20:07:17.778: Fetch 65536
2019-01-29 20:07:17.789: Fetch 65536
2019-01-29 20:07:17.800: Fetch 65536
2019-01-29 20:07:17.813: Fetch 65536
2019-01-29 20:07:17.831: Fetch 65536
2019-01-29 20:07:17.843: Fetch 65536
2019-01-29 20:07:17.858: Fetch 65536
2019-01-29 20:07:17.875: Fetch 65536
2019-01-29 20:07:17.888: Fetch 65536
2019-01-29 20:07:17.903: Fetch 65536
2019-01-29 20:07:17.917: Fetch 65536
2019-01-29 20:07:17.929: Fetch 65536
2019-01-29 20:07:17.942: Fetch 65536
2019-01-29 20:07:17.953: Fetch 65536
2019-01-29 20:07:17.964: Fetch 65536
2019-01-29 20:07:17.980: Fetch 65536
2019-01-29 20:07:17.998: Fetch 65536
2019-01-29 20:07:18.013: Fetch 65536
2019-01-29 20:07:18.036: Fetch 65536
2019-01-29 20:07:18.054: Fetch 65536
2019-01-29 20:07:18.072: Fetch 65536
2019-01-29 20:07:18.083: Fetch 65536
2019-01-29 20:07:18.103: Fetch 65536
2019-01-29 20:07:18.121: Fetch 65536
2019-01-29 20:07:18.138: Fetch 65536
2019-01-29 20:07:18.154: Fetch 65536
2019-01-29 20:07:18.170: Fetch 65536
2019-01-29 20:07:18.187: Fetch 65536
2019-01-29 20:07:18.200: Fetch 65536
2019-01-29 20:07:18.215: Fetch 65536
2019-01-29 20:07:18.233: Fetch 65536
2019-01-29 20:07:18.251: Fetch 65536
2019-01-29 20:07:18.268: Fetch 65536
2019-01-29 20:07:18.280: Fetch 65536
2019-01-29 20:07:18.291: Fetch 65536
2019-01-29 20:07:18.304: Fetch 65536
2019-01-29 20:07:18.318: Fetch 65536
2019-01-29 20:07:18.334: Fetch 65536
2019-01-29 20:07:18.354: Fetch 65536
2019-01-29 20:07:18.380: Fetch 65536
2019-01-29 20:07:18.408: Fetch 65536
2019-01-29 20:07:18.421: Fetch 65536
2019-01-29 20:07:18.434: Fetch 65536
2019-01-29 20:07:18.447: Fetch 65536
2019-01-29 20:07:18.460: Fetch 65536
2019-01-29 20:07:18.476: Fetch 65536
2019-01-29 20:07:18.491: Fetch 65536
2019-01-29 20:07:29.417: Fetch 65536
2019-01-29 20:07:29.444: Fetch 65536
2019-01-29 20:07:29.455: Fetch 65536
2019-01-29 20:07:29.468: Fetch 65536
2019-01-29 20:07:29.483: Fetch 65536
2019-01-29 20:07:29.497: Fetch 65536
2019-01-29 20:07:29.512: Fetch 65536
2019-01-29 20:07:29.525: Fetch 65536
2019-01-29 20:07:29.540: Fetch 65536
2019-01-29 20:07:29.557: Fetch 65536
2019-01-29 20:07:29.579: Fetch 65536
2019-01-29 20:07:29.601: Fetch 65536
2019-01-29 20:07:29.618: Fetch 65536
2019-01-29 20:07:29.630: Fetch 65536
2019-01-29 20:07:29.646: Fetch 65536
2019-01-29 20:07:29.662: Fetch 65536
2019-01-29 20:07:29.672: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 48610635, m_contentLength = 48607266
2019-01-29 20:07:29.685: Fetch 65536
2019-01-29 20:07:29.697: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 48648226, m_contentLength = 48607266
2019-01-29 20:07:29.713: Fetch 65536
2019-01-29 20:07:29.726: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 48664610, m_contentLength = 48607266
2019-01-29 20:07:29.742: Fetch 65536
2019-01-29 20:07:29.759: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 48672802, m_contentLength = 48607266
2019-01-29 20:07:29.782: HttpURLConnection: Returning -1 (end of file)!2019-01-29 20:07:29:805  not enough data, calling setNextToCurrent, framesToRead = 335872
2019-01-29 20:07:29:806  after setNextToCurrent: current = 0xd0349100, m_next = 0x0
2019-01-29 20:07:29.818: HttpURLConnection: fetchDataForReal: m_HttpURLConnection == null, creating request, this = com.extreamsd.usbaudioplayershared.ESDHTTPClient@8c1654e
2019-01-29 20:07:29.828: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:07:30.014: HttpURLConnection: contentLength = 22588706 for Tidal
2019-01-29 20:07:30.044: Fetch 65536
2019-01-29 20:07:30.060: Fetch 341466
2019-01-29 20:07:30.087: Fetch 169434
2019-01-29 20:07:30.101: Fetch 81920
2019-01-29 20:07:30.115: Fetch 65536
2019-01-29 20:07:30.127: Fetch 65536
2019-01-29 20:07:30.203: Fetch 65536
2019-01-29 20:07:30.215: Fetch 65536
2019-01-29 20:07:30.226: Fetch 65536
2019-01-29 20:07:30.245: Fetch 65536
2019-01-29 20:07:30.255: Fetch 65536
2019-01-29 20:07:30.266: Fetch 65536
2019-01-29 20:07:30.282: Fetch 65536
2019-01-29 20:07:30.296: Fetch 65536
2019-01-29 20:07:30.308: Fetch 65536
2019-01-29 20:07:30.318: Fetch 65536
2019-01-29 20:07:30.328: Fetch 65536
2019-01-29 20:07:30.341: Fetch 65536
2019-01-29 20:07:30.356: Fetch 65536
2019-01-29 20:07:30.366: Fetch 65536
2019-01-29 20:07:30.378: Fetch 65536
2019-01-29 20:07:30.391: Fetch 65536
2019-01-29 20:07:30.402: Fetch 65536
2019-01-29 20:07:30.415: Fetch 65536
2019-01-29 20:07:30.431: Fetch 65536
2019-01-29 20:07:30.446: Fetch 65536
2019-01-29 20:07:30.470: Fetch 65536
2019-01-29 20:07:30.483: Fetch 65536
2019-01-29 20:07:30.497: Fetch 65536
2019-01-29 20:07:30.514: Fetch 65536
2019-01-29 20:07:30.530: Fetch 65536
2019-01-29 20:07:30.543: Fetch 65536
2019-01-29 20:07:30.557: Fetch 65536
2019-01-29 20:07:30.572: Fetch 65536
2019-01-29 20:07:30.583: Fetch 65536
2019-01-29 20:07:30.597: Fetch 65536
2019-01-29 20:07:30.607: Fetch 65536
2019-01-29 20:07:30.618: Fetch 65536
2019-01-29 20:07:30.664: Fetch 65536
2019-01-29 20:07:30.680: Fetch 65536
2019-01-29 20:07:30.696: Fetch 65536
2019-01-29 20:07:30.712: Fetch 65536
2019-01-29 20:07:30.730: Fetch 65536
2019-01-29 20:07:30.748: Fetch 65536
2019-01-29 20:07:30.773: Fetch 65536
2019-01-29 20:07:30.792: Fetch 65536
2019-01-29 20:07:30.803: Fetch 65536
2019-01-29 20:07:30.819: Fetch 65536
2019-01-29 20:07:30.833: Fetch 65536
2019-01-29 20:07:30.844: Fetch 65536
2019-01-29 20:07:41.315: Fetch 65536
2019-01-29 20:07:41.328: Fetch 65536
2019-01-29 20:07:41.346: Fetch 65536
2019-01-29 20:07:41.362: Fetch 65536
2019-01-29 20:07:41.376: Fetch 65536
2019-01-29 20:07:41.389: Fetch 65536
2019-01-29 20:07:41.401: Fetch 65536
2019-01-29 20:07:41.424: Fetch 65536
2019-01-29 20:07:41.444: Fetch 65536
2019-01-29 20:07:41.460: Fetch 65536
2019-01-29 20:07:41.474: Fetch 65536
2019-01-29 20:07:41.490: Fetch 65536
2019-01-29 20:07:41.507: Fetch 65536
2019-01-29 20:07:41.530: Fetch 65536
2019-01-29 20:07:41.541: Fetch 65536
2019-01-29 20:07:41.558: Fetch 65536
2019-01-29 20:07:41.593: Fetch 65536
2019-01-29 20:07:41.608: Fetch 65536
2019-01-29 20:07:41.622: Fetch 65536
2019-01-29 20:07:41.636: Fetch 65536
2019-01-29 20:07:41.648: Fetch 65536
2019-01-29 20:07:41.661: Fetch 65536
2019-01-29 20:07:41.673: Fetch 65536
2019-01-29 20:07:41.688: Fetch 65536
2019-01-29 20:07:41.707: Fetch 65536
2019-01-29 20:07:41.725: Fetch 65536
2019-01-29 20:07:41.758: Fetch 65536
2019-01-29 20:07:41.774: Fetch 65536
2019-01-29 20:07:41.785: Fetch 65536
2019-01-29 20:07:41.805: Fetch 65536
2019-01-29 20:07:41.823: Fetch 65536
2019-01-29 20:07:41.841: Fetch 65536
2019-01-29 20:07:41.855: Fetch 65536
2019-01-29 20:07:41.869: Fetch 65536
2019-01-29 20:07:41.885: Fetch 65536
2019-01-29 20:07:41.900: Fetch 65536
2019-01-29 20:07:41.918: Fetch 65536
2019-01-29 20:07:41.935: Fetch 65536
2019-01-29 20:07:41.951: Fetch 65536
2019-01-29 20:07:41.967: Fetch 65536
2019-01-29 20:07:41.980: Fetch 65536
2019-01-29 20:07:41.999: Fetch 65536
2019-01-29 20:07:42.014: Fetch 65536
2019-01-29 20:07:42.029: Fetch 65536
2019-01-29 20:07:42.053: Fetch 65536
2019-01-29 20:07:42.070: Fetch 65536
2019-01-29 20:07:42.084: Fetch 65536
2019-01-29 20:07:42.103: Fetch 65536
2019-01-29 20:07:42.128: Fetch 65536
2019-01-29 20:07:42.145: Fetch 65536
2019-01-29 20:07:42.161: Fetch 65536
2019-01-29 20:07:42.176: Fetch 65536
2019-01-29 20:07:42.190: Fetch 65536
2019-01-29 20:07:42.206: Fetch 65536
2019-01-29 20:07:42.224: Fetch 65536
2019-01-29 20:07:42.245: Fetch 65536
2019-01-29 20:07:42.275: Fetch 65536
2019-01-29 20:07:42.290: Fetch 65536
2019-01-29 20:07:42.305: Fetch 65536
2019-01-29 20:07:42.319: Fetch 65536
2019-01-29 20:07:42.334: Fetch 65536
2019-01-29 20:07:42.348: Fetch 65536
2019-01-29 20:07:42.368: Fetch 65536
2019-01-29 20:07:42.386: Fetch 65536
2019-01-29 20:07:42.402: Fetch 655362019-01-29 20:07:45:724  FileQueue dump CB: switch required
2019-01-29 20:07:45:725  FileQueue dump: current = 0xd0349100, Tidal
2019-01-29 20:07:45:725  FileQueue dump: next    = 0x0,
2019-01-29 20:07:45:726  filldatacb: stopAndGo 0
2019-01-29 20:07:45.771: Open ASYNC: Gjeilo: North Country II
2019-01-29 20:07:51.197: onPositiveResult, i_isNextPosition = true
2019-01-29 20:07:51.247: Message MESSAGE_TYPE_QUEUE_SONG
2019-01-29 20:07:51.276: HttpURLConnection: fetchDataForReal: m_HttpURLConnection == null, creating request, this = com.extreamsd.usbaudioplayershared.ESDHTTPClient@52885a
2019-01-29 20:07:51.310: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:07:51.698: HttpURLConnection: contentLength = 46295618 for Tidal
2019-01-29 20:07:51.709: Fetch 65536
2019-01-29 20:07:51.729: Fetch 335268
2019-01-29 20:07:51.756: Fetch 216925
2019-01-29 20:07:51.783: Fetch 131493
2019-01-29 20:07:51.806: Fetch 65536
2019-01-29 20:07:51.816: Fetch 33189
2019-01-29 20:07:51.830: Fetch 65536
2019-01-29 20:07:51.893: Fetch 65536
2019-01-29 20:07:51.904: Fetch 65536
2019-01-29 20:07:51.916: Fetch 65536
2019-01-29 20:07:51.935: Fetch 65536
2019-01-29 20:07:51.947: Fetch 65536
2019-01-29 20:07:51.959: Fetch 65536
2019-01-29 20:07:51.975: Fetch 65536
2019-01-29 20:07:51.987: Fetch 65536
2019-01-29 20:07:52.014: Fetch 65536
2019-01-29 20:07:52.026: Fetch 65536
2019-01-29 20:07:52.035: Fetch 65536
2019-01-29 20:07:52.045: Fetch 65536
2019-01-29 20:07:52.059: Fetch 65536
2019-01-29 20:07:52.072: Fetch 65536
2019-01-29 20:07:52.085: Fetch 65536
2019-01-29 20:07:52.099: Fetch 65536
2019-01-29 20:07:52.119: Fetch 65536
2019-01-29 20:07:52.138: Fetch 65536
2019-01-29 20:07:52.156: Fetch 65536
2019-01-29 20:07:52.176: Fetch 65536
2019-01-29 20:07:52.194: Fetch 65536
2019-01-29 20:07:52.207: Fetch 65536
2019-01-29 20:07:52.218: Fetch 65536
2019-01-29 20:07:52.228: Fetch 655362019-01-29 20:07:52:243  Current wasn't NULL, so setting next to Gjeilo: North Country II = Tidal
2019-01-29 20:07:52:244  after setNextDataSource: current = 0xd0349100, m_next = 0xd217fe00
2019-01-29 20:07:52.253: Setting m_asyncInProgress to false in A
2019-01-29 20:07:53.215: Fetch 65536
2019-01-29 20:07:53.237: Fetch 65536
2019-01-29 20:07:53.248: Fetch 65536
2019-01-29 20:07:53.263: Fetch 65536
2019-01-29 20:07:53.278: Fetch 65536
2019-01-29 20:07:53.303: Fetch 65536
2019-01-29 20:07:53.316: Fetch 65536
2019-01-29 20:07:53.328: Fetch 65536
2019-01-29 20:07:53.343: Fetch 65536
2019-01-29 20:07:53.357: Fetch 65536
2019-01-29 20:07:53.378: Fetch 65536
2019-01-29 20:07:53.399: Fetch 65536
2019-01-29 20:07:53.414: Fetch 65536
2019-01-29 20:07:53.430: Fetch 65536
2019-01-29 20:07:53.461: Fetch 65536
2019-01-29 20:07:53.477: Fetch 65536
2019-01-29 20:07:53.492: Fetch 65536
2019-01-29 20:07:53.505: Fetch 65536
2019-01-29 20:07:53.518: Fetch 65536
2019-01-29 20:07:53.538: Fetch 65536
2019-01-29 20:07:53.553: Fetch 65536
2019-01-29 20:07:53.567: Fetch 65536
2019-01-29 20:07:53.581: Fetch 65536
2019-01-29 20:07:53.596: Fetch 65536
2019-01-29 20:07:53.621: Fetch 65536
2019-01-29 20:07:53.644: Fetch 65536
2019-01-29 20:07:53.660: Fetch 65536
2019-01-29 20:07:53.684: Fetch 65536
2019-01-29 20:07:53.705: Fetch 65536
2019-01-29 20:07:53.718: Fetch 65536
2019-01-29 20:07:53.731: Fetch 65536
2019-01-29 20:07:53.749: Fetch 65536
2019-01-29 20:07:53.761: Fetch 65536
2019-01-29 20:07:53.776: Fetch 65536
2019-01-29 20:07:53.800: Fetch 65536
2019-01-29 20:07:53.822: Fetch 65536
2019-01-29 20:07:53.836: Fetch 65536
2019-01-29 20:07:53.857: Fetch 65536
2019-01-29 20:07:53.870: Fetch 65536
2019-01-29 20:07:53.892: Fetch 65536
2019-01-29 20:07:53.906: Fetch 65536
2019-01-29 20:07:53.918: Fetch 65536
2019-01-29 20:07:53.931: Fetch 65536
2019-01-29 20:07:53.949: Fetch 65536
2019-01-29 20:07:53.966: Fetch 65536
2019-01-29 20:07:53.982: Fetch 65536
2019-01-29 20:07:53.999: Fetch 65536
2019-01-29 20:07:54.022: Fetch 65536
2019-01-29 20:07:54.043: Fetch 65536
2019-01-29 20:07:54.068: Fetch 65536
2019-01-29 20:07:54.092: Fetch 65536
2019-01-29 20:07:54.105: Fetch 65536
2019-01-29 20:07:54.124: Fetch 65536
2019-01-29 20:07:54.144: Fetch 65536
2019-01-29 20:07:54.158: Fetch 65536
2019-01-29 20:07:54.170: Fetch 65536
2019-01-29 20:07:54.184: Fetch 65536
2019-01-29 20:07:54.204: Fetch 65536
2019-01-29 20:07:54.221: Fetch 65536
2019-01-29 20:07:54.242: Fetch 65536
2019-01-29 20:07:54.259: Fetch 65536
2019-01-29 20:07:54.282: Fetch 65536
2019-01-29 20:07:54.321: Fetch 65536
2019-01-29 20:07:54.371: Fetch 65536
2019-01-29 20:07:54.387: Fetch 65536
2019-01-29 20:07:54.398: Fetch 65536
2019-01-29 20:08:05.095: Fetch 65536
2019-01-29 20:08:05.118: Fetch 65536
2019-01-29 20:08:05.130: Fetch 65536
2019-01-29 20:08:05.143: Fetch 65536
2019-01-29 20:08:05.156: Fetch 65536
2019-01-29 20:08:05.167: Fetch 65536
2019-01-29 20:08:05.184: Fetch 65536
2019-01-29 20:08:05.205: Fetch 65536
2019-01-29 20:08:05.228: Fetch 65536
2019-01-29 20:08:05.245: Fetch 65536
2019-01-29 20:08:05.263: Fetch 65536
2019-01-29 20:08:05.281: Fetch 65536
2019-01-29 20:08:05.293: Fetch 65536
2019-01-29 20:08:05.309: Fetch 65536
2019-01-29 20:08:05.322: Fetch 65536
2019-01-29 20:08:05.333: Fetch 65536
2019-01-29 20:08:05.344: Fetch 65536
2019-01-29 20:08:05.357: Fetch 65536
2019-01-29 20:08:05.368: Fetch 65536
2019-01-29 20:08:05.382: Fetch 65536
2019-01-29 20:08:05.397: Fetch 65536
2019-01-29 20:08:05.420: Fetch 65536
2019-01-29 20:08:05.443: Fetch 65536
2019-01-29 20:08:05.458: Fetch 65536
2019-01-29 20:08:05.474: Fetch 65536
2019-01-29 20:08:05.487: Fetch 65536
2019-01-29 20:08:05.501: Fetch 65536
2019-01-29 20:08:05.516: Fetch 65536
2019-01-29 20:08:05.530: Fetch 65536
2019-01-29 20:08:05.542: Fetch 65536
2019-01-29 20:08:05.554: Fetch 65536
2019-01-29 20:08:05.570: Fetch 65536
2019-01-29 20:08:05.586: Fetch 65536
2019-01-29 20:08:05.606: Fetch 65536
2019-01-29 20:08:05.621: Fetch 65536
2019-01-29 20:08:05.654: Fetch 65536
2019-01-29 20:08:05.668: Fetch 65536
2019-01-29 20:08:05.683: Fetch 65536
2019-01-29 20:08:05.700: Fetch 65536
2019-01-29 20:08:05.716: Fetch 65536
2019-01-29 20:08:05.736: Fetch 65536
2019-01-29 20:08:05.755: Fetch 65536
2019-01-29 20:08:05.774: Fetch 65536
2019-01-29 20:08:05.794: Fetch 65536
2019-01-29 20:08:05.806: Fetch 65536
2019-01-29 20:08:05.822: Fetch 65536
2019-01-29 20:08:05.835: Fetch 65536
2019-01-29 20:08:05.850: Fetch 65536
2019-01-29 20:08:05.863: Fetch 65536
2019-01-29 20:08:05.881: Fetch 65536
2019-01-29 20:08:05.896: Fetch 65536
2019-01-29 20:08:05.914: Fetch 65536
2019-01-29 20:08:05.930: Fetch 65536
2019-01-29 20:08:05.946: Fetch 65536
2019-01-29 20:08:05.962: Fetch 65536
2019-01-29 20:08:05.978: Fetch 65536
2019-01-29 20:08:05.993: Fetch 65536
2019-01-29 20:08:06.006: Fetch 65536
2019-01-29 20:08:06.017: Fetch 65536
2019-01-29 20:08:06.034: Fetch 65536
2019-01-29 20:08:06.053: Fetch 65536
2019-01-29 20:08:06.067: Fetch 65536
2019-01-29 20:08:06.092: Fetch 65536
2019-01-29 20:08:06.104: Fetch 65536
2019-01-29 20:08:06.117: Fetch 65536
2019-01-29 20:08:06.143: Fetch 65536
2019-01-29 20:08:06.157: Fetch 65536
2019-01-29 20:08:18.442: Fetch 65536
2019-01-29 20:08:18.482: Fetch 65536
2019-01-29 20:08:18.516: Fetch 65536
2019-01-29 20:08:18.576: Fetch 65536
2019-01-29 20:08:18.622: Fetch 65536
2019-01-29 20:08:18.638: Fetch 65536
2019-01-29 20:08:18.651: Fetch 65536
2019-01-29 20:08:18.670: Fetch 65536
2019-01-29 20:08:18.685: Fetch 65536
2019-01-29 20:08:18.696: Fetch 65536
2019-01-29 20:08:18.709: Fetch 65536
2019-01-29 20:08:18.730: Fetch 65536
2019-01-29 20:08:18.742: Fetch 65536
2019-01-29 20:08:18.763: Fetch 65536
2019-01-29 20:08:18.787: Fetch 65536
2019-01-29 20:08:18.810: Fetch 65536
2019-01-29 20:08:18.822: Fetch 65536
2019-01-29 20:08:18.835: Fetch 65536
2019-01-29 20:08:18.856: Fetch 65536
2019-01-29 20:08:18.871: Fetch 65536
2019-01-29 20:08:18.885: Fetch 65536
2019-01-29 20:08:18.902: Fetch 65536
2019-01-29 20:08:18.915: Fetch 65536
2019-01-29 20:08:18.930: Fetch 65536
2019-01-29 20:08:18.943: Fetch 65536
2019-01-29 20:08:18.955: Fetch 65536
2019-01-29 20:08:18.971: Fetch 65536
2019-01-29 20:08:18.984: Fetch 65536
2019-01-29 20:08:18.998: Fetch 65536
2019-01-29 20:08:19.014: Fetch 65536
2019-01-29 20:08:19.039: Fetch 65536
2019-01-29 20:08:19.065: Fetch 65536
2019-01-29 20:08:19.082: Fetch 65536
2019-01-29 20:08:19.107: Fetch 65536
2019-01-29 20:08:19.120: Fetch 65536
2019-01-29 20:08:19.133: Fetch 65536
2019-01-29 20:08:19.148: Fetch 65536
2019-01-29 20:08:19.164: Fetch 65536
2019-01-29 20:08:19.184: Fetch 65536
2019-01-29 20:08:19.197: Fetch 65536
2019-01-29 20:08:19.218: Fetch 65536
2019-01-29 20:08:19.237: Fetch 65536
2019-01-29 20:08:19.250: Fetch 65536
2019-01-29 20:08:19.263: Fetch 65536
2019-01-29 20:08:19.275: Fetch 65536
2019-01-29 20:08:19.288: Fetch 65536
2019-01-29 20:08:19.302: Fetch 65536
2019-01-29 20:08:19.325: Fetch 65536
2019-01-29 20:08:19.341: Fetch 65536
2019-01-29 20:08:19.356: Fetch 65536
2019-01-29 20:08:19.367: Fetch 65536
2019-01-29 20:08:19.382: Fetch 65536
2019-01-29 20:08:19.402: Fetch 65536
2019-01-29 20:08:19.421: Fetch 65536
2019-01-29 20:08:19.435: Fetch 65536
2019-01-29 20:08:19.445: Fetch 65536
2019-01-29 20:08:19.458: Fetch 65536
2019-01-29 20:08:19.470: Fetch 65536
2019-01-29 20:08:19.482: Fetch 65536
2019-01-29 20:08:19.499: Fetch 65536
2019-01-29 20:08:19.518: Fetch 65536
2019-01-29 20:08:19.531: Fetch 65536
2019-01-29 20:08:19.555: Fetch 65536
2019-01-29 20:08:19.568: Fetch 65536
2019-01-29 20:08:19.585: Fetch 65536
2019-01-29 20:08:19.599: Fetch 65536
2019-01-29 20:08:19.612: Fetch 65536
2019-01-29 20:08:30.327: Fetch 65536
2019-01-29 20:08:30.355: Fetch 65536
2019-01-29 20:08:30.366: Fetch 65536
2019-01-29 20:08:30.386: Fetch 65536
2019-01-29 20:08:30.396: Fetch 65536
2019-01-29 20:08:30.408: Fetch 65536
2019-01-29 20:08:30.420: Fetch 65536
2019-01-29 20:08:30.434: Fetch 65536
2019-01-29 20:08:30.452: Fetch 65536
2019-01-29 20:08:30.465: Fetch 65536
2019-01-29 20:08:30.480: Fetch 65536
2019-01-29 20:08:30.497: Fetch 65536
2019-01-29 20:08:30.516: Fetch 65536
2019-01-29 20:08:30.533: Fetch 65536
2019-01-29 20:08:30.553: Fetch 65536
2019-01-29 20:08:30.576: Fetch 65536
2019-01-29 20:08:30.591: Fetch 65536
2019-01-29 20:08:30.618: Fetch 65536
2019-01-29 20:08:30.634: Fetch 65536
2019-01-29 20:08:30.646: Fetch 65536
2019-01-29 20:08:30.660: Fetch 65536
2019-01-29 20:08:30.674: Fetch 65536
2019-01-29 20:08:30.685: Fetch 65536
2019-01-29 20:08:30.705: Fetch 65536
2019-01-29 20:08:30.724: Fetch 65536
2019-01-29 20:08:30.744: Fetch 65536
2019-01-29 20:08:30.766: Fetch 65536
2019-01-29 20:08:30.788: Fetch 65536
2019-01-29 20:08:30.800: Fetch 65536
2019-01-29 20:08:30.811: Fetch 65536
2019-01-29 20:08:30.832: Fetch 65536
2019-01-29 20:08:30.856: Fetch 65536
2019-01-29 20:08:30.870: Fetch 65536
2019-01-29 20:08:30.892: Fetch 65536
2019-01-29 20:08:30.905: Fetch 65536
2019-01-29 20:08:30.919: Fetch 65536
2019-01-29 20:08:30.933: Fetch 65536
2019-01-29 20:08:30.949: Fetch 65536
2019-01-29 20:08:30.960: Fetch 65536
2019-01-29 20:08:30.979: Fetch 65536
2019-01-29 20:08:30.991: Fetch 65536
2019-01-29 20:08:31.009: Fetch 65536
2019-01-29 20:08:31.024: Fetch 65536
2019-01-29 20:08:31.040: Fetch 65536
2019-01-29 20:08:31.054: Fetch 65536
2019-01-29 20:08:31.066: Fetch 65536
2019-01-29 20:08:31.087: Fetch 65536
2019-01-29 20:08:31.103: Fetch 65536
2019-01-29 20:08:31.124: Fetch 65536
2019-01-29 20:08:31.135: Fetch 65536
2019-01-29 20:08:31.147: Fetch 65536
2019-01-29 20:08:31.168: Fetch 65536
2019-01-29 20:08:31.183: Fetch 65536
2019-01-29 20:08:31.204: Fetch 65536
2019-01-29 20:08:31.223: Fetch 65536
2019-01-29 20:08:31.238: Fetch 65536
2019-01-29 20:08:31.249: Fetch 65536
2019-01-29 20:08:31.261: Fetch 65536
2019-01-29 20:08:31.281: Fetch 65536
2019-01-29 20:08:31.302: Fetch 65536
2019-01-29 20:08:31.317: Fetch 65536
2019-01-29 20:08:31.340: Fetch 65536
2019-01-29 20:08:31.353: Fetch 65536
2019-01-29 20:08:40.764: Fetch 65536
2019-01-29 20:08:40.802: Fetch 65536
2019-01-29 20:08:40.817: Fetch 65536
2019-01-29 20:08:40.830: Fetch 65536
2019-01-29 20:08:40.848: Fetch 65536
2019-01-29 20:08:40.864: Fetch 65536
2019-01-29 20:08:40.881: Fetch 65536
2019-01-29 20:08:40.908: Fetch 65536
2019-01-29 20:08:40.929: Fetch 65536
2019-01-29 20:08:40.942: Fetch 65536
2019-01-29 20:08:40.967: Fetch 65536
2019-01-29 20:08:40.992: Fetch 65536
2019-01-29 20:08:41.005: Fetch 65536
2019-01-29 20:08:41.018: Fetch 65536
2019-01-29 20:08:41.032: Fetch 65536
2019-01-29 20:08:41.044: Fetch 65536
2019-01-29 20:08:41.058: Fetch 65536
2019-01-29 20:08:41.072: Fetch 65536
2019-01-29 20:08:41.097: Fetch 65536
2019-01-29 20:08:41.125: Fetch 65536
2019-01-29 20:08:41.142: Fetch 65536
2019-01-29 20:08:41.164: Fetch 65536
2019-01-29 20:08:41.198: Fetch 65536
2019-01-29 20:08:41.210: Fetch 65536
2019-01-29 20:08:41.225: Fetch 65536
2019-01-29 20:08:41.240: Fetch 65536
2019-01-29 20:08:41.255: Fetch 65536
2019-01-29 20:08:41.268: Fetch 65536
2019-01-29 20:08:41.280: Fetch 65536
2019-01-29 20:08:41.298: Fetch 65536
2019-01-29 20:08:41.314: Fetch 65536
2019-01-29 20:08:41.328: Fetch 65536
2019-01-29 20:08:41.341: Fetch 65536
2019-01-29 20:08:41.354: Fetch 65536
2019-01-29 20:08:41.367: Fetch 65536
2019-01-29 20:08:41.381: Fetch 65536
2019-01-29 20:08:41.400: Fetch 65536
2019-01-29 20:08:41.420: Fetch 65536
2019-01-29 20:08:41.434: Fetch 65536
2019-01-29 20:08:41.446: Fetch 65536
2019-01-29 20:08:41.460: Fetch 65536
2019-01-29 20:08:41.482: Fetch 65536
2019-01-29 20:08:41.496: Fetch 65536
2019-01-29 20:08:41.510: Fetch 65536
2019-01-29 20:08:41.525: Fetch 65536
2019-01-29 20:08:41.540: Fetch 65536
2019-01-29 20:08:41.558: Fetch 65536
2019-01-29 20:08:41.574: Fetch 65536
2019-01-29 20:08:41.586: Fetch 65536
2019-01-29 20:08:41.598: Fetch 65536
2019-01-29 20:08:41.614: Fetch 65536
2019-01-29 20:08:41.627: Fetch 65536
2019-01-29 20:08:41.641: Fetch 65536
2019-01-29 20:08:41.654: Fetch 65536
2019-01-29 20:08:41.665: Fetch 65536
2019-01-29 20:08:41.677: Fetch 65536
2019-01-29 20:08:41.689: Fetch 65536
2019-01-29 20:08:41.703: Fetch 65536
2019-01-29 20:08:41.726: Fetch 65536
2019-01-29 20:08:41.740: Fetch 65536
2019-01-29 20:08:41.762: Fetch 65536
2019-01-29 20:08:52.642: Fetch 65536
2019-01-29 20:08:52.677: Fetch 65536
2019-01-29 20:08:52.690: Fetch 65536
2019-01-29 20:08:52.707: Fetch 65536
2019-01-29 20:08:52.724: Fetch 65536
2019-01-29 20:08:52.739: Fetch 65536
2019-01-29 20:08:52.752: Fetch 65536
2019-01-29 20:08:52.770: Fetch 65536
2019-01-29 20:08:52.786: Fetch 65536
2019-01-29 20:08:52.802: Fetch 65536
2019-01-29 20:08:52.817: Fetch 65536
2019-01-29 20:08:52.834: Fetch 65536
2019-01-29 20:08:52.847: Fetch 65536
2019-01-29 20:08:52.863: Fetch 65536
2019-01-29 20:08:52.882: Fetch 65536
2019-01-29 20:08:52.904: Fetch 65536
2019-01-29 20:08:52.935: Fetch 65536
2019-01-29 20:08:52.956: Fetch 65536
2019-01-29 20:08:52.976: Fetch 65536
2019-01-29 20:08:52.991: Fetch 65536
2019-01-29 20:08:53.005: Fetch 65536
2019-01-29 20:08:53.023: Fetch 65536
2019-01-29 20:08:53.041: Fetch 65536
2019-01-29 20:08:53.058: Fetch 65536
2019-01-29 20:08:53.072: Fetch 65536
2019-01-29 20:08:53.084: Fetch 65536
2019-01-29 20:08:53.098: Fetch 65536
2019-01-29 20:08:53.111: Fetch 65536
2019-01-29 20:08:53.122: Fetch 65536
2019-01-29 20:08:53.135: Fetch 65536
2019-01-29 20:08:53.152: Fetch 65536
2019-01-29 20:08:53.187: Fetch 65536
2019-01-29 20:08:53.212: Fetch 65536
2019-01-29 20:08:53.236: Fetch 65536
2019-01-29 20:08:53.254: Fetch 65536
2019-01-29 20:08:53.267: Fetch 65536
2019-01-29 20:08:53.284: Fetch 65536
2019-01-29 20:08:53.299: Fetch 65536
2019-01-29 20:08:53.317: Fetch 65536
2019-01-29 20:08:53.334: Fetch 65536
2019-01-29 20:08:53.347: Fetch 65536
2019-01-29 20:08:53.359: Fetch 65536
2019-01-29 20:08:53.374: Fetch 65536
2019-01-29 20:08:53.390: Fetch 65536
2019-01-29 20:08:53.405: Fetch 65536
2019-01-29 20:08:53.420: Fetch 65536
2019-01-29 20:08:53.434: Fetch 65536
2019-01-29 20:08:53.446: Fetch 65536
2019-01-29 20:08:53.460: Fetch 65536
2019-01-29 20:08:53.482: Fetch 65536
2019-01-29 20:08:53.497: Fetch 65536
2019-01-29 20:08:53.513: Fetch 65536
2019-01-29 20:08:53.525: Fetch 65536
2019-01-29 20:08:53.540: Fetch 65536
2019-01-29 20:08:53.553: Fetch 65536
2019-01-29 20:08:53.564: Fetch 65536
2019-01-29 20:08:53.584: Fetch 65536
2019-01-29 20:08:53.601: Fetch 65536
2019-01-29 20:08:53.618: Fetch 65536
2019-01-29 20:08:53.635: Fetch 65536
2019-01-29 20:08:53.654: Fetch 65536
2019-01-29 20:08:53.672: Fetch 65536
2019-01-29 20:08:53.687: Fetch 65536
2019-01-29 20:08:53.707: Fetch 65536
2019-01-29 20:09:04.537: Fetch 65536
2019-01-29 20:09:04.564: Fetch 65536
2019-01-29 20:09:04.581: Fetch 65536
2019-01-29 20:09:04.597: Fetch 65536
2019-01-29 20:09:04.612: Fetch 65536
2019-01-29 20:09:04.624: Fetch 65536
2019-01-29 20:09:04.641: Fetch 65536
2019-01-29 20:09:04.654: Fetch 65536
2019-01-29 20:09:04.669: Fetch 65536
2019-01-29 20:09:04.688: Fetch 65536
2019-01-29 20:09:04.715: Fetch 65536
2019-01-29 20:09:04.726: Fetch 65536
2019-01-29 20:09:04.737: Fetch 65536
2019-01-29 20:09:04.749: Fetch 65536
2019-01-29 20:09:04.768: Fetch 65536
2019-01-29 20:09:04.786: Fetch 65536
2019-01-29 20:09:04.803: Fetch 65536
2019-01-29 20:09:04.816: Fetch 65536
2019-01-29 20:09:04.829: Fetch 65536
2019-01-29 20:09:04.840: Fetch 65536
2019-01-29 20:09:04.853: Fetch 65536
2019-01-29 20:09:04.865: Fetch 65536
2019-01-29 20:09:04.877: Fetch 65536
2019-01-29 20:09:04.890: Fetch 65536
2019-01-29 20:09:04.904: Fetch 65536
2019-01-29 20:09:04.923: Fetch 65536
2019-01-29 20:09:04.950: Fetch 65536
2019-01-29 20:09:04.967: Fetch 65536
2019-01-29 20:09:04.983: Fetch 65536
2019-01-29 20:09:04.999: Fetch 65536
2019-01-29 20:09:05.015: Fetch 65536
2019-01-29 20:09:05.033: Fetch 65536
2019-01-29 20:09:05.048: Fetch 65536
2019-01-29 20:09:05.064: Fetch 65536
2019-01-29 20:09:05.076: Fetch 65536
2019-01-29 20:09:05.088: Fetch 65536
2019-01-29 20:09:05.110: Fetch 65536
2019-01-29 20:09:05.128: Fetch 65536
2019-01-29 20:09:05.151: Fetch 65536
2019-01-29 20:09:05.168: Fetch 65536
2019-01-29 20:09:05.183: Fetch 65536
2019-01-29 20:09:05.199: Fetch 65536
2019-01-29 20:09:05.216: Fetch 65536
2019-01-29 20:09:05.229: Fetch 65536
2019-01-29 20:09:05.244: Fetch 65536
2019-01-29 20:09:05.258: Fetch 65536
2019-01-29 20:09:05.272: Fetch 65536
2019-01-29 20:09:05.291: Fetch 65536
2019-01-29 20:09:05.311: Fetch 65536
2019-01-29 20:09:05.337: Fetch 65536
2019-01-29 20:09:05.353: Fetch 65536
2019-01-29 20:09:05.370: Fetch 65536
2019-01-29 20:09:05.388: Fetch 65536
2019-01-29 20:09:05.403: Fetch 65536
2019-01-29 20:09:05.422: Fetch 65536
2019-01-29 20:09:05.435: Fetch 65536
2019-01-29 20:09:05.449: Fetch 65536
2019-01-29 20:09:05.468: Fetch 65536
2019-01-29 20:09:05.481: Fetch 65536
2019-01-29 20:09:16.417: Fetch 65536
2019-01-29 20:09:16.430: Fetch 65536
2019-01-29 20:09:16.445: Fetch 65536
2019-01-29 20:09:16.460: Fetch 65536
2019-01-29 20:09:16.474: Fetch 65536
2019-01-29 20:09:16.486: Fetch 65536
2019-01-29 20:09:16.517: Fetch 65536
2019-01-29 20:09:16.534: Fetch 65536
2019-01-29 20:09:16.547: Fetch 65536
2019-01-29 20:09:16.561: Fetch 65536
2019-01-29 20:09:16.574: Fetch 65536
2019-01-29 20:09:16.591: Fetch 65536
2019-01-29 20:09:16.608: Fetch 65536
2019-01-29 20:09:16.626: Fetch 65536
2019-01-29 20:09:16.640: Fetch 65536
2019-01-29 20:09:16.657: Fetch 65536
2019-01-29 20:09:16.672: Fetch 65536
2019-01-29 20:09:16.685: Fetch 65536
2019-01-29 20:09:16.699: Fetch 65536
2019-01-29 20:09:16.718: Fetch 65536
2019-01-29 20:09:16.735: Fetch 65536
2019-01-29 20:09:16.758: Fetch 65536
2019-01-29 20:09:16.770: Fetch 65536
2019-01-29 20:09:16.792: Fetch 65536
2019-01-29 20:09:16.808: Fetch 65536
2019-01-29 20:09:16.828: Fetch 65536
2019-01-29 20:09:16.852: Fetch 65536
2019-01-29 20:09:16.874: Fetch 65536
2019-01-29 20:09:16.893: Fetch 65536
2019-01-29 20:09:16.908: Fetch 65536
2019-01-29 20:09:16.920: Fetch 65536
2019-01-29 20:09:16.933: Fetch 65536
2019-01-29 20:09:16.945: Fetch 65536
2019-01-29 20:09:16.958: Fetch 65536
2019-01-29 20:09:16.977: Fetch 65536
2019-01-29 20:09:16.999: Fetch 65536
2019-01-29 20:09:17.017: Fetch 65536
2019-01-29 20:09:17.042: Fetch 65536
2019-01-29 20:09:17.061: Fetch 65536
2019-01-29 20:09:17.076: Fetch 65536
2019-01-29 20:09:17.096: Fetch 65536
2019-01-29 20:09:17.111: Fetch 65536
2019-01-29 20:09:17.126: Fetch 65536
2019-01-29 20:09:17.148: Fetch 65536
2019-01-29 20:09:17.165: Fetch 65536
2019-01-29 20:09:17.178: Fetch 65536
2019-01-29 20:09:17.197: Fetch 65536
2019-01-29 20:09:17.214: Fetch 65536
2019-01-29 20:09:17.226: Fetch 65536
2019-01-29 20:09:17.237: Fetch 65536
2019-01-29 20:09:17.255: Fetch 65536
2019-01-29 20:09:17.268: Fetch 65536
2019-01-29 20:09:28.314: Fetch 65536
2019-01-29 20:09:28.343: Fetch 65536
2019-01-29 20:09:28.355: Fetch 65536
2019-01-29 20:09:28.367: Fetch 65536
2019-01-29 20:09:28.380: Fetch 65536
2019-01-29 20:09:28.395: Fetch 65536
2019-01-29 20:09:28.420: Fetch 65536
2019-01-29 20:09:28.445: Fetch 65536
2019-01-29 20:09:28.465: Fetch 65536
2019-01-29 20:09:28.483: Fetch 65536
2019-01-29 20:09:28.497: Fetch 65536
2019-01-29 20:09:28.510: Fetch 65536
2019-01-29 20:09:28.522: Fetch 65536
2019-01-29 20:09:28.540: Fetch 65536
2019-01-29 20:09:28.556: Fetch 65536
2019-01-29 20:09:28.574: Fetch 65536
2019-01-29 20:09:28.590: Fetch 65536
2019-01-29 20:09:28.608: Fetch 65536
2019-01-29 20:09:28.624: Fetch 65536
2019-01-29 20:09:28.641: Fetch 65536
2019-01-29 20:09:28.659: Fetch 65536
2019-01-29 20:09:28.675: Fetch 65536
2019-01-29 20:09:28.695: Fetch 65536
2019-01-29 20:09:28.709: Fetch 65536
2019-01-29 20:09:28.722: Fetch 65536
2019-01-29 20:09:28.737: Fetch 65536
2019-01-29 20:09:28.755: Fetch 65536
2019-01-29 20:09:28.776: Fetch 65536
2019-01-29 20:09:28.795: Fetch 65536
2019-01-29 20:09:28.825: Fetch 65536
2019-01-29 20:09:28.840: Fetch 65536
2019-01-29 20:09:28.854: Fetch 65536
2019-01-29 20:09:28.875: Fetch 65536
2019-01-29 20:09:28.891: Fetch 65536
2019-01-29 20:09:28.909: Fetch 65536
2019-01-29 20:09:28.925: Fetch 65536
2019-01-29 20:09:28.949: Fetch 65536
2019-01-29 20:09:28.966: Fetch 65536
2019-01-29 20:09:28.984: Fetch 65536
2019-01-29 20:09:29.001: Fetch 65536
2019-01-29 20:09:29.016: Fetch 65536
2019-01-29 20:09:29.030: Fetch 65536
2019-01-29 20:09:29.044: Fetch 65536
2019-01-29 20:09:29.056: Fetch 65536
2019-01-29 20:09:29.067: Fetch 65536
2019-01-29 20:09:29.080: Fetch 65536
2019-01-29 20:09:29.092: Fetch 65536
2019-01-29 20:09:29.107: Fetch 65536
2019-01-29 20:09:29.122: Fetch 65536
2019-01-29 20:09:29.139: Fetch 65536
2019-01-29 20:09:29.156: Fetch 65536
2019-01-29 20:09:29.172: Fetch 65536
2019-01-29 20:09:29.185: Fetch 65536
2019-01-29 20:09:29.200: Fetch 65536
2019-01-29 20:09:41.666: Fetch 65536
2019-01-29 20:09:41.698: Fetch 65536
2019-01-29 20:09:41.712: Fetch 65536
2019-01-29 20:09:41.725: Fetch 65536
2019-01-29 20:09:41.740: Fetch 65536
2019-01-29 20:09:41.757: Fetch 65536
2019-01-29 20:09:41.772: Fetch 65536
2019-01-29 20:09:41.785: Fetch 65536
2019-01-29 20:09:41.797: Fetch 65536
2019-01-29 20:09:41.810: Fetch 65536
2019-01-29 20:09:41.826: Fetch 65536
2019-01-29 20:09:41.840: Fetch 65536
2019-01-29 20:09:41.858: Fetch 65536
2019-01-29 20:09:41.878: Fetch 65536
2019-01-29 20:09:41.894: Fetch 65536
2019-01-29 20:09:41.903: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22608770, m_contentLength = 22588706
2019-01-29 20:09:41.915: Fetch 65536
2019-01-29 20:09:41.924: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22637858, m_contentLength = 22588706
2019-01-29 20:09:41.937: Fetch 65536
2019-01-29 20:09:41.951: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22646050, m_contentLength = 22588706
2019-01-29 20:09:41.970: Fetch 65536
2019-01-29 20:09:41.989: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 22654242, m_contentLength = 22588706
2019-01-29 20:09:42.015: HttpURLConnection: Returning -1 (end of file)!2019-01-29 20:09:42:33  not enough data, calling setNextToCurrent, framesToRead = 315392
2019-01-29 20:09:42:34  after setNextToCurrent: current = 0xd217fe00, m_next = 0x0
2019-01-29 20:09:42.046: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:09:42.518: HttpURLConnection: contentLength = 46295618 for Tidal
2019-01-29 20:09:42.553: Fetch 65536
2019-01-29 20:09:42.587: Fetch 335268
2019-01-29 20:09:42.603: Fetch 163840
2019-01-29 20:09:42.620: Fetch 90020
2019-01-29 20:09:42.635: Fetch 65536
2019-01-29 20:09:42.648: Fetch 40868
2019-01-29 20:09:42.708: Fetch 65536
2019-01-29 20:09:42.720: Fetch 65536
2019-01-29 20:09:42.734: Fetch 65536
2019-01-29 20:09:42.744: Fetch 65536
2019-01-29 20:09:42.757: Fetch 65536
2019-01-29 20:09:42.769: Fetch 65536
2019-01-29 20:09:42.779: Fetch 65536
2019-01-29 20:09:42.788: Fetch 65536
2019-01-29 20:09:42.806: Fetch 65536
2019-01-29 20:09:42.818: Fetch 65536
2019-01-29 20:09:42.827: Fetch 65536
2019-01-29 20:09:42.839: Fetch 65536
2019-01-29 20:09:42.852: Fetch 65536
2019-01-29 20:09:42.876: Fetch 65536
2019-01-29 20:09:42.889: Fetch 65536
2019-01-29 20:09:42.900: Fetch 65536
2019-01-29 20:09:42.912: Fetch 65536
2019-01-29 20:09:42.925: Fetch 65536
2019-01-29 20:09:42.940: Fetch 65536
2019-01-29 20:09:42.953: Fetch 65536
2019-01-29 20:09:42.965: Fetch 65536
2019-01-29 20:09:42.987: Fetch 65536
2019-01-29 20:09:43.008: Fetch 65536
2019-01-29 20:09:43.024: Fetch 65536
2019-01-29 20:09:43.091: Fetch 65536
2019-01-29 20:09:43.105: Fetch 65536
2019-01-29 20:09:43.122: Fetch 65536
2019-01-29 20:09:43.138: Fetch 65536
2019-01-29 20:09:43.155: Fetch 65536
2019-01-29 20:09:43.170: Fetch 65536
2019-01-29 20:09:43.186: Fetch 65536
2019-01-29 20:09:52.073: Fetch 65536
2019-01-29 20:09:52.100: Fetch 65536
2019-01-29 20:09:52.115: Fetch 65536
2019-01-29 20:09:52.128: Fetch 65536
2019-01-29 20:09:52.142: Fetch 65536
2019-01-29 20:09:52.157: Fetch 65536
2019-01-29 20:09:52.179: Fetch 65536
2019-01-29 20:09:52.209: Fetch 65536
2019-01-29 20:09:52.227: Fetch 65536
2019-01-29 20:09:52.243: Fetch 65536
2019-01-29 20:09:52.257: Fetch 65536
2019-01-29 20:09:52.272: Fetch 65536
2019-01-29 20:09:52.285: Fetch 65536
2019-01-29 20:09:52.315: Fetch 65536
2019-01-29 20:09:52.328: Fetch 65536
2019-01-29 20:09:52.351: Fetch 65536
2019-01-29 20:09:52.371: Fetch 65536
2019-01-29 20:09:52.386: Fetch 65536
2019-01-29 20:09:52.401: Fetch 65536
2019-01-29 20:09:52.414: Fetch 65536
2019-01-29 20:09:52.426: Fetch 65536
2019-01-29 20:09:52.445: Fetch 65536
2019-01-29 20:09:52.462: Fetch 65536
2019-01-29 20:09:52.479: Fetch 65536
2019-01-29 20:09:52.493: Fetch 65536
2019-01-29 20:09:52.508: Fetch 65536
2019-01-29 20:09:52.523: Fetch 65536
2019-01-29 20:09:52.537: Fetch 65536
2019-01-29 20:09:52.557: Fetch 65536
2019-01-29 20:09:52.570: Fetch 65536
2019-01-29 20:09:52.586: Fetch 65536
2019-01-29 20:09:52.602: Fetch 65536
2019-01-29 20:09:52.616: Fetch 65536
2019-01-29 20:09:52.632: Fetch 65536
2019-01-29 20:09:52.649: Fetch 65536
2019-01-29 20:09:52.665: Fetch 65536
2019-01-29 20:09:52.678: Fetch 65536
2019-01-29 20:09:52.690: Fetch 65536
2019-01-29 20:09:52.702: Fetch 65536
2019-01-29 20:09:52.720: Fetch 65536
2019-01-29 20:09:52.736: Fetch 65536
2019-01-29 20:09:52.752: Fetch 65536
2019-01-29 20:09:52.772: Fetch 65536
2019-01-29 20:09:52.784: Fetch 65536
2019-01-29 20:09:52.803: Fetch 65536
2019-01-29 20:09:52.819: Fetch 65536
2019-01-29 20:09:52.834: Fetch 65536
2019-01-29 20:09:52.846: Fetch 655362019-01-29 20:09:57:988  FileQueue dump CB: switch required
2019-01-29 20:09:57:989  FileQueue dump: current = 0xd217fe00, Tidal
2019-01-29 20:09:57:990  FileQueue dump: next    = 0x0,
2019-01-29 20:09:57:990  filldatacb: stopAndGo 0
2019-01-29 20:09:58.025: Open ASYNC: Plagge: Duels For 2 Violins
2019-01-29 20:09:58.572: onPositiveResult, i_isNextPosition = true
2019-01-29 20:09:58.588: Message MESSAGE_TYPE_QUEUE_SONG
2019-01-29 20:09:58.600: HttpURLConnection: fetchDataForReal: m_HttpURLConnection == null, creating request, this = com.extreamsd.usbaudioplayershared.ESDHTTPClient@aee7b80
2019-01-29 20:09:58.611: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:09:59.001: HttpURLConnection: contentLength = 19188017 for Tidal
2019-01-29 20:09:59.017: Fetch 65536
2019-01-29 20:09:59.028: Fetch 335262
2019-01-29 20:09:59.053: Fetch 244950
2019-01-29 20:09:59.079: Fetch 188478
2019-01-29 20:09:59.095: Fetch 103046
2019-01-29 20:09:59.108: Fetch 65536
2019-01-29 20:09:59.122: Fetch 37510
2019-01-29 20:09:59.135: Fetch 65536
2019-01-29 20:09:59.198: Fetch 65536
2019-01-29 20:09:59.207: Fetch 65536
2019-01-29 20:09:59.218: Fetch 65536
2019-01-29 20:09:59.233: Fetch 65536
2019-01-29 20:09:59.243: Fetch 65536
2019-01-29 20:09:59.252: Fetch 65536
2019-01-29 20:09:59.261: Fetch 65536
2019-01-29 20:09:59.272: Fetch 65536
2019-01-29 20:09:59.297: Fetch 65536
2019-01-29 20:09:59.307: Fetch 65536
2019-01-29 20:09:59.317: Fetch 65536
2019-01-29 20:09:59.327: Fetch 65536
2019-01-29 20:09:59.346: Fetch 65536
2019-01-29 20:09:59.361: Fetch 65536
2019-01-29 20:09:59.373: Fetch 65536
2019-01-29 20:09:59.382: Fetch 65536
2019-01-29 20:09:59.391: Fetch 65536
2019-01-29 20:09:59.400: Fetch 65536
2019-01-29 20:09:59.409: Fetch 65536
2019-01-29 20:09:59.420: Fetch 65536
2019-01-29 20:09:59.429: Fetch 65536
2019-01-29 20:09:59.442: Fetch 65536
2019-01-29 20:09:59.461: Fetch 65536
2019-01-29 20:09:59.476: Fetch 65536
2019-01-29 20:09:59.490: Fetch 65536
2019-01-29 20:09:59.503: Fetch 655362019-01-29 20:09:59:519  Current wasn't NULL, so setting next to Plagge: Duels For 2 Violins = Tidal
2019-01-29 20:09:59:519  after setNextDataSource: current = 0xd217fe00, m_next = 0xd1849200
2019-01-29 20:09:59.527: Setting m_asyncInProgress to false in A
2019-01-29 20:10:03.975: Fetch 65536
2019-01-29 20:10:03.988: Fetch 65536
2019-01-29 20:10:04.003: Fetch 65536
2019-01-29 20:10:04.020: Fetch 65536
2019-01-29 20:10:04.040: Fetch 65536
2019-01-29 20:10:04.065: Fetch 65536
2019-01-29 20:10:04.077: Fetch 65536
2019-01-29 20:10:04.111: Fetch 65536
2019-01-29 20:10:04.133: Fetch 65536
2019-01-29 20:10:04.146: Fetch 65536
2019-01-29 20:10:04.159: Fetch 65536
2019-01-29 20:10:04.178: Fetch 65536
2019-01-29 20:10:04.198: Fetch 65536
2019-01-29 20:10:04.209: Fetch 65536
2019-01-29 20:10:04.223: Fetch 65536
2019-01-29 20:10:04.239: Fetch 65536
2019-01-29 20:10:04.254: Fetch 65536
2019-01-29 20:10:04.267: Fetch 65536
2019-01-29 20:10:04.286: Fetch 65536
2019-01-29 20:10:04.307: Fetch 65536
2019-01-29 20:10:04.335: Fetch 65536
2019-01-29 20:10:04.355: Fetch 65536
2019-01-29 20:10:04.367: Fetch 65536
2019-01-29 20:10:04.381: Fetch 65536
2019-01-29 20:10:04.394: Fetch 65536
2019-01-29 20:10:04.416: Fetch 65536
2019-01-29 20:10:04.433: Fetch 65536
2019-01-29 20:10:04.444: Fetch 65536
2019-01-29 20:10:04.457: Fetch 65536
2019-01-29 20:10:04.471: Fetch 65536
2019-01-29 20:10:04.483: Fetch 65536
2019-01-29 20:10:04.498: Fetch 65536
2019-01-29 20:10:04.511: Fetch 65536
2019-01-29 20:10:04.530: Fetch 65536
2019-01-29 20:10:04.551: Fetch 65536
2019-01-29 20:10:04.575: Fetch 65536
2019-01-29 20:10:04.595: Fetch 65536
2019-01-29 20:10:04.606: Fetch 65536
2019-01-29 20:10:04.620: Fetch 65536
2019-01-29 20:10:04.633: Fetch 65536
2019-01-29 20:10:04.646: Fetch 65536
2019-01-29 20:10:04.666: Fetch 65536
2019-01-29 20:10:04.683: Fetch 65536
2019-01-29 20:10:04.698: Fetch 65536
2019-01-29 20:10:04.710: Fetch 65536
2019-01-29 20:10:04.721: Fetch 65536
2019-01-29 20:10:04.735: Fetch 65536
2019-01-29 20:10:04.748: Fetch 65536
2019-01-29 20:10:04.764: Fetch 65536
2019-01-29 20:10:15.850: Fetch 65536
2019-01-29 20:10:15.867: Fetch 65536
2019-01-29 20:10:15.885: Fetch 65536
2019-01-29 20:10:15.902: Fetch 65536
2019-01-29 20:10:15.918: Fetch 65536
2019-01-29 20:10:15.930: Fetch 65536
2019-01-29 20:10:15.957: Fetch 65536
2019-01-29 20:10:15.982: Fetch 65536
2019-01-29 20:10:16.006: Fetch 65536
2019-01-29 20:10:16.029: Fetch 65536
2019-01-29 20:10:16.043: Fetch 65536
2019-01-29 20:10:16.057: Fetch 65536
2019-01-29 20:10:16.073: Fetch 65536
2019-01-29 20:10:16.086: Fetch 65536
2019-01-29 20:10:16.108: Fetch 65536
2019-01-29 20:10:16.127: Fetch 65536
2019-01-29 20:10:16.148: Fetch 65536
2019-01-29 20:10:16.170: Fetch 65536
2019-01-29 20:10:16.192: Fetch 65536
2019-01-29 20:10:16.204: Fetch 65536
2019-01-29 20:10:16.220: Fetch 65536
2019-01-29 20:10:16.235: Fetch 65536
2019-01-29 20:10:16.259: Fetch 65536
2019-01-29 20:10:16.274: Fetch 65536
2019-01-29 20:10:16.288: Fetch 65536
2019-01-29 20:10:16.301: Fetch 65536
2019-01-29 20:10:16.313: Fetch 65536
2019-01-29 20:10:16.323: Fetch 65536
2019-01-29 20:10:16.335: Fetch 65536
2019-01-29 20:10:16.347: Fetch 65536
2019-01-29 20:10:16.359: Fetch 65536
2019-01-29 20:10:16.379: Fetch 65536
2019-01-29 20:10:16.393: Fetch 65536
2019-01-29 20:10:16.417: Fetch 65536
2019-01-29 20:10:16.438: Fetch 65536
2019-01-29 20:10:16.456: Fetch 65536
2019-01-29 20:10:16.473: Fetch 65536
2019-01-29 20:10:16.487: Fetch 65536
2019-01-29 20:10:16.498: Fetch 65536
2019-01-29 20:10:16.508: Fetch 65536
2019-01-29 20:10:16.519: Fetch 65536
2019-01-29 20:10:16.532: Fetch 65536
2019-01-29 20:10:16.545: Fetch 65536
2019-01-29 20:10:16.558: Fetch 65536
2019-01-29 20:10:16.573: Fetch 65536
2019-01-29 20:10:16.589: Fetch 65536
2019-01-29 20:10:16.603: Fetch 65536
2019-01-29 20:10:16.622: Fetch 65536
2019-01-29 20:10:16.644: Fetch 65536
2019-01-29 20:10:16.668: Fetch 65536
2019-01-29 20:10:27.756: Fetch 65536
2019-01-29 20:10:27.772: Fetch 65536
2019-01-29 20:10:27.788: Fetch 65536
2019-01-29 20:10:27.806: Fetch 65536
2019-01-29 20:10:27.825: Fetch 65536
2019-01-29 20:10:27.847: Fetch 65536
2019-01-29 20:10:27.859: Fetch 65536
2019-01-29 20:10:27.874: Fetch 65536
2019-01-29 20:10:27.896: Fetch 65536
2019-01-29 20:10:27.914: Fetch 65536
2019-01-29 20:10:27.938: Fetch 65536
2019-01-29 20:10:27.951: Fetch 65536
2019-01-29 20:10:27.963: Fetch 65536
2019-01-29 20:10:27.980: Fetch 65536
2019-01-29 20:10:28.001: Fetch 65536
2019-01-29 20:10:28.018: Fetch 65536
2019-01-29 20:10:28.047: Fetch 65536
2019-01-29 20:10:28.060: Fetch 65536
2019-01-29 20:10:28.073: Fetch 65536
2019-01-29 20:10:28.084: Fetch 65536
2019-01-29 20:10:28.094: Fetch 65536
2019-01-29 20:10:28.105: Fetch 65536
2019-01-29 20:10:28.116: Fetch 65536
2019-01-29 20:10:28.129: Fetch 65536
2019-01-29 20:10:28.146: Fetch 65536
2019-01-29 20:10:28.166: Fetch 65536
2019-01-29 20:10:28.200: Fetch 65536
2019-01-29 20:10:28.218: Fetch 65536
2019-01-29 20:10:28.233: Fetch 65536
2019-01-29 20:10:28.245: Fetch 65536
2019-01-29 20:10:28.267: Fetch 65536
2019-01-29 20:10:28.294: Fetch 65536
2019-01-29 20:10:28.306: Fetch 65536
2019-01-29 20:10:28.321: Fetch 65536
2019-01-29 20:10:28.336: Fetch 65536
2019-01-29 20:10:28.350: Fetch 65536
2019-01-29 20:10:28.364: Fetch 65536
2019-01-29 20:10:28.381: Fetch 65536
2019-01-29 20:10:28.396: Fetch 65536
2019-01-29 20:10:28.412: Fetch 65536
2019-01-29 20:10:28.429: Fetch 65536
2019-01-29 20:10:28.442: Fetch 65536
2019-01-29 20:10:28.458: Fetch 65536
2019-01-29 20:10:28.478: Fetch 65536
2019-01-29 20:10:28.490: Fetch 65536
2019-01-29 20:10:28.506: Fetch 65536
2019-01-29 20:10:28.529: Fetch 65536
2019-01-29 20:10:28.549: Fetch 65536
2019-01-29 20:10:28.571: Fetch 65536
2019-01-29 20:10:28.588: Fetch 65536
2019-01-29 20:10:41.126: Fetch 65536
2019-01-29 20:10:41.158: Fetch 65536
2019-01-29 20:10:41.169: Fetch 65536
2019-01-29 20:10:41.181: Fetch 65536
2019-01-29 20:10:41.194: Fetch 65536
2019-01-29 20:10:41.212: Fetch 65536
2019-01-29 20:10:41.227: Fetch 65536
2019-01-29 20:10:41.239: Fetch 65536
2019-01-29 20:10:41.252: Fetch 65536
2019-01-29 20:10:41.263: Fetch 65536
2019-01-29 20:10:41.274: Fetch 65536
2019-01-29 20:10:41.288: Fetch 65536
2019-01-29 20:10:41.304: Fetch 65536
2019-01-29 20:10:41.320: Fetch 65536
2019-01-29 20:10:41.349: Fetch 65536
2019-01-29 20:10:41.378: Fetch 65536
2019-01-29 20:10:41.394: Fetch 65536
2019-01-29 20:10:41.405: Fetch 65536
2019-01-29 20:10:41.417: Fetch 65536
2019-01-29 20:10:41.431: Fetch 65536
2019-01-29 20:10:41.446: Fetch 65536
2019-01-29 20:10:41.469: Fetch 65536
2019-01-29 20:10:41.486: Fetch 65536
2019-01-29 20:10:41.504: Fetch 65536
2019-01-29 20:10:41.524: Fetch 65536
2019-01-29 20:10:41.540: Fetch 65536
2019-01-29 20:10:41.560: Fetch 65536
2019-01-29 20:10:41.576: Fetch 65536
2019-01-29 20:10:41.590: Fetch 65536
2019-01-29 20:10:41.602: Fetch 65536
2019-01-29 20:10:41.614: Fetch 65536
2019-01-29 20:10:41.627: Fetch 65536
2019-01-29 20:10:41.641: Fetch 65536
2019-01-29 20:10:41.657: Fetch 65536
2019-01-29 20:10:41.673: Fetch 65536
2019-01-29 20:10:41.686: Fetch 65536
2019-01-29 20:10:41.701: Fetch 65536
2019-01-29 20:10:41.719: Fetch 65536
2019-01-29 20:10:41.738: Fetch 65536
2019-01-29 20:10:41.764: Fetch 65536
2019-01-29 20:10:41.779: Fetch 65536
2019-01-29 20:10:41.795: Fetch 65536
2019-01-29 20:10:41.810: Fetch 65536
2019-01-29 20:10:41.829: Fetch 65536
2019-01-29 20:10:41.841: Fetch 65536
2019-01-29 20:10:41.867: Fetch 65536
2019-01-29 20:10:41.883: Fetch 65536
2019-01-29 20:10:41.896: Fetch 65536
2019-01-29 20:10:41.910: Fetch 65536
2019-01-29 20:10:41.923: Fetch 65536
2019-01-29 20:10:41.938: Fetch 65536
2019-01-29 20:10:51.516: Fetch 65536
2019-01-29 20:10:51.528: Fetch 65536
2019-01-29 20:10:51.542: Fetch 65536
2019-01-29 20:10:51.556: Fetch 65536
2019-01-29 20:10:51.570: Fetch 65536
2019-01-29 20:10:51.586: Fetch 65536
2019-01-29 20:10:51.625: Fetch 65536
2019-01-29 20:10:51.642: Fetch 65536
2019-01-29 20:10:51.656: Fetch 65536
2019-01-29 20:10:51.668: Fetch 65536
2019-01-29 20:10:51.680: Fetch 65536
2019-01-29 20:10:51.694: Fetch 65536
2019-01-29 20:10:51.708: Fetch 65536
2019-01-29 20:10:51.727: Fetch 65536
2019-01-29 20:10:51.741: Fetch 65536
2019-01-29 20:10:51.758: Fetch 65536
2019-01-29 20:10:51.771: Fetch 65536
2019-01-29 20:10:51.785: Fetch 65536
2019-01-29 20:10:51.799: Fetch 65536
2019-01-29 20:10:51.816: Fetch 65536
2019-01-29 20:10:51.831: Fetch 65536
2019-01-29 20:10:51.858: Fetch 65536
2019-01-29 20:10:51.873: Fetch 65536
2019-01-29 20:10:51.900: Fetch 65536
2019-01-29 20:10:51.913: Fetch 65536
2019-01-29 20:10:51.926: Fetch 65536
2019-01-29 20:10:51.946: Fetch 65536
2019-01-29 20:10:51.968: Fetch 65536
2019-01-29 20:10:51.978: Fetch 65536
2019-01-29 20:10:51.990: Fetch 65536
2019-01-29 20:10:52.009: Fetch 65536
2019-01-29 20:10:52.025: Fetch 65536
2019-01-29 20:10:52.038: Fetch 65536
2019-01-29 20:10:52.052: Fetch 65536
2019-01-29 20:10:52.066: Fetch 65536
2019-01-29 20:10:52.079: Fetch 65536
2019-01-29 20:10:52.092: Fetch 65536
2019-01-29 20:10:52.108: Fetch 65536
2019-01-29 20:10:52.125: Fetch 65536
2019-01-29 20:10:52.149: Fetch 65536
2019-01-29 20:10:52.171: Fetch 65536
2019-01-29 20:10:52.187: Fetch 65536
2019-01-29 20:10:52.200: Fetch 65536
2019-01-29 20:10:52.213: Fetch 65536
2019-01-29 20:10:52.228: Fetch 65536
2019-01-29 20:10:52.244: Fetch 65536
2019-01-29 20:10:52.258: Fetch 65536
2019-01-29 20:10:52.278: Fetch 65536
2019-01-29 20:10:52.300: Fetch 65536
2019-01-29 20:10:52.317: Fetch 65536
2019-01-29 20:11:03.448: Fetch 65536
2019-01-29 20:11:03.488: Fetch 65536
2019-01-29 20:11:03.521: Fetch 65536
2019-01-29 20:11:03.537: Fetch 65536
2019-01-29 20:11:03.552: Fetch 65536
2019-01-29 20:11:03.570: Fetch 65536
2019-01-29 20:11:03.605: Fetch 65536
2019-01-29 20:11:03.620: Fetch 65536
2019-01-29 20:11:03.636: Fetch 65536
2019-01-29 20:11:03.650: Fetch 65536
2019-01-29 20:11:03.665: Fetch 65536
2019-01-29 20:11:03.680: Fetch 65536
2019-01-29 20:11:03.694: Fetch 65536
2019-01-29 20:11:03.707: Fetch 65536
2019-01-29 20:11:03.728: Fetch 65536
2019-01-29 20:11:03.745: Fetch 65536
2019-01-29 20:11:03.759: Fetch 65536
2019-01-29 20:11:03.776: Fetch 65536
2019-01-29 20:11:03.790: Fetch 65536
2019-01-29 20:11:03.802: Fetch 65536
2019-01-29 20:11:03.815: Fetch 65536
2019-01-29 20:11:03.830: Fetch 65536
2019-01-29 20:11:03.845: Fetch 65536
2019-01-29 20:11:03.867: Fetch 65536
2019-01-29 20:11:03.886: Fetch 65536
2019-01-29 20:11:03.906: Fetch 65536
2019-01-29 20:11:03.921: Fetch 65536
2019-01-29 20:11:03.935: Fetch 65536
2019-01-29 20:11:03.946: Fetch 65536
2019-01-29 20:11:03.973: Fetch 65536
2019-01-29 20:11:03.993: Fetch 65536
2019-01-29 20:11:04.010: Fetch 65536
2019-01-29 20:11:04.032: Fetch 65536
2019-01-29 20:11:04.045: Fetch 65536
2019-01-29 20:11:04.062: Fetch 65536
2019-01-29 20:11:04.078: Fetch 65536
2019-01-29 20:11:04.094: Fetch 65536
2019-01-29 20:11:04.107: Fetch 65536
2019-01-29 20:11:04.121: Fetch 65536
2019-01-29 20:11:04.135: Fetch 65536
2019-01-29 20:11:04.155: Fetch 65536
2019-01-29 20:11:04.177: Fetch 65536
2019-01-29 20:11:04.195: Fetch 65536
2019-01-29 20:11:04.208: Fetch 65536
2019-01-29 20:11:04.226: Fetch 65536
2019-01-29 20:11:04.245: Fetch 65536
2019-01-29 20:11:04.259: Fetch 65536
2019-01-29 20:11:04.270: Fetch 65536
2019-01-29 20:11:04.282: Fetch 65536
2019-01-29 20:11:04.296: Fetch 65536
2019-01-29 20:11:04.318: Fetch 65536
2019-01-29 20:11:04.342: Fetch 65536
2019-01-29 20:11:15.300: Fetch 65536
2019-01-29 20:11:15.334: Fetch 65536
2019-01-29 20:11:15.347: Fetch 65536
2019-01-29 20:11:15.360: Fetch 65536
2019-01-29 20:11:15.374: Fetch 65536
2019-01-29 20:11:15.389: Fetch 65536
2019-01-29 20:11:15.405: Fetch 65536
2019-01-29 20:11:15.428: Fetch 65536
2019-01-29 20:11:15.443: Fetch 65536
2019-01-29 20:11:15.460: Fetch 65536
2019-01-29 20:11:15.475: Fetch 65536
2019-01-29 20:11:15.489: Fetch 65536
2019-01-29 20:11:15.504: Fetch 65536
2019-01-29 20:11:15.524: Fetch 65536
2019-01-29 20:11:15.541: Fetch 65536
2019-01-29 20:11:15.559: Fetch 65536
2019-01-29 20:11:15.575: Fetch 65536
2019-01-29 20:11:15.588: Fetch 65536
2019-01-29 20:11:15.603: Fetch 65536
2019-01-29 20:11:15.620: Fetch 65536
2019-01-29 20:11:15.639: Fetch 65536
2019-01-29 20:11:15.655: Fetch 65536
2019-01-29 20:11:15.675: Fetch 65536
2019-01-29 20:11:15.687: Fetch 65536
2019-01-29 20:11:15.699: Fetch 65536
2019-01-29 20:11:15.712: Fetch 65536
2019-01-29 20:11:15.726: Fetch 65536
2019-01-29 20:11:15.740: Fetch 65536
2019-01-29 20:11:15.756: Fetch 65536
2019-01-29 20:11:15.778: Fetch 65536
2019-01-29 20:11:15.796: Fetch 65536
2019-01-29 20:11:15.817: Fetch 65536
2019-01-29 20:11:15.831: Fetch 65536
2019-01-29 20:11:15.841: Fetch 65536
2019-01-29 20:11:15.852: Fetch 65536
2019-01-29 20:11:15.869: Fetch 65536
2019-01-29 20:11:15.894: Fetch 65536
2019-01-29 20:11:15.907: Fetch 65536
2019-01-29 20:11:15.922: Fetch 65536
2019-01-29 20:11:15.934: Fetch 65536
2019-01-29 20:11:15.947: Fetch 65536
2019-01-29 20:11:15.961: Fetch 65536
2019-01-29 20:11:15.977: Fetch 65536
2019-01-29 20:11:15.998: Fetch 65536
2019-01-29 20:11:16.015: Fetch 65536
2019-01-29 20:11:16.042: Fetch 65536
2019-01-29 20:11:16.065: Fetch 65536
2019-01-29 20:11:16.089: Fetch 65536
2019-01-29 20:11:16.103: Fetch 65536
2019-01-29 20:11:16.123: Fetch 65536
2019-01-29 20:11:16.139: Fetch 65536
2019-01-29 20:11:16.152: Fetch 65536
2019-01-29 20:11:16.164: Fetch 65536
2019-01-29 20:11:16.179: Fetch 65536
2019-01-29 20:11:16.195: Fetch 65536
2019-01-29 20:11:16.214: Fetch 65536
2019-01-29 20:11:28.669: Fetch 65536
2019-01-29 20:11:28.686: Fetch 65536
2019-01-29 20:11:28.703: Fetch 65536
2019-01-29 20:11:28.715: Fetch 65536
2019-01-29 20:11:28.727: Fetch 65536
2019-01-29 20:11:28.741: Fetch 65536
2019-01-29 20:11:28.755: Fetch 65536
2019-01-29 20:11:28.773: Fetch 65536
2019-01-29 20:11:28.797: Fetch 65536
2019-01-29 20:11:28.820: Fetch 65536
2019-01-29 20:11:28.835: Fetch 65536
2019-01-29 20:11:28.850: Fetch 65536
2019-01-29 20:11:28.867: Fetch 65536
2019-01-29 20:11:28.883: Fetch 65536
2019-01-29 20:11:28.901: Fetch 65536
2019-01-29 20:11:28.919: Fetch 65536
2019-01-29 20:11:28.935: Fetch 65536
2019-01-29 20:11:28.950: Fetch 65536
2019-01-29 20:11:28.967: Fetch 65536
2019-01-29 20:11:28.982: Fetch 65536
2019-01-29 20:11:29.001: Fetch 65536
2019-01-29 20:11:29.021: Fetch 65536
2019-01-29 20:11:29.037: Fetch 65536
2019-01-29 20:11:29.050: Fetch 65536
2019-01-29 20:11:29.063: Fetch 65536
2019-01-29 20:11:29.079: Fetch 65536
2019-01-29 20:11:29.094: Fetch 65536
2019-01-29 20:11:29.107: Fetch 65536
2019-01-29 20:11:29.126: Fetch 65536
2019-01-29 20:11:29.144: Fetch 65536
2019-01-29 20:11:29.164: Fetch 65536
2019-01-29 20:11:29.182: Fetch 65536
2019-01-29 20:11:29.203: Fetch 65536
2019-01-29 20:11:29.217: Fetch 65536
2019-01-29 20:11:29.227: Fetch 65536
2019-01-29 20:11:29.242: Fetch 65536
2019-01-29 20:11:29.258: Fetch 65536
2019-01-29 20:11:29.291: Fetch 65536
2019-01-29 20:11:29.313: Fetch 65536
2019-01-29 20:11:29.334: Fetch 65536
2019-01-29 20:11:29.347: Fetch 65536
2019-01-29 20:11:29.358: Fetch 65536
2019-01-29 20:11:29.369: Fetch 65536
2019-01-29 20:11:29.383: Fetch 65536
2019-01-29 20:11:29.395: Fetch 65536
2019-01-29 20:11:29.411: Fetch 65536
2019-01-29 20:11:29.426: Fetch 65536
2019-01-29 20:11:29.444: Fetch 65536
2019-01-29 20:11:29.459: Fetch 65536
2019-01-29 20:11:29.478: Fetch 65536
2019-01-29 20:11:29.497: Fetch 65536
2019-01-29 20:11:29.521: Fetch 65536
2019-01-29 20:11:29.538: Fetch 65536
2019-01-29 20:11:29.552: Fetch 65536
2019-01-29 20:11:29.566: Fetch 65536
2019-01-29 20:11:29.581: Fetch 65536
2019-01-29 20:11:39.092: Fetch 65536
2019-01-29 20:11:39.122: Fetch 65536
2019-01-29 20:11:39.136: Fetch 65536
2019-01-29 20:11:39.150: Fetch 65536
2019-01-29 20:11:39.166: Fetch 65536
2019-01-29 20:11:39.184: Fetch 65536
2019-01-29 20:11:39.197: Fetch 65536
2019-01-29 20:11:39.216: Fetch 65536
2019-01-29 20:11:39.236: Fetch 65536
2019-01-29 20:11:39.254: Fetch 65536
2019-01-29 20:11:39.266: Fetch 65536
2019-01-29 20:11:39.280: Fetch 65536
2019-01-29 20:11:39.295: Fetch 65536
2019-01-29 20:11:39.316: Fetch 65536
2019-01-29 20:11:39.333: Fetch 65536
2019-01-29 20:11:39.348: Fetch 65536
2019-01-29 20:11:39.366: Fetch 65536
2019-01-29 20:11:39.380: Fetch 65536
2019-01-29 20:11:39.396: Fetch 65536
2019-01-29 20:11:39.412: Fetch 65536
2019-01-29 20:11:39.430: Fetch 65536
2019-01-29 20:11:39.455: Fetch 65536
2019-01-29 20:11:39.477: Fetch 65536
2019-01-29 20:11:39.493: Fetch 65536
2019-01-29 20:11:39.513: Fetch 65536
2019-01-29 20:11:39.528: Fetch 65536
2019-01-29 20:11:39.539: Fetch 65536
2019-01-29 20:11:39.552: Fetch 65536
2019-01-29 20:11:39.565: Fetch 65536
2019-01-29 20:11:39.577: Fetch 65536
2019-01-29 20:11:39.596: Fetch 65536
2019-01-29 20:11:39.612: Fetch 65536
2019-01-29 20:11:39.627: Fetch 65536
2019-01-29 20:11:39.644: Fetch 65536
2019-01-29 20:11:39.664: Fetch 65536
2019-01-29 20:11:39.681: Fetch 65536
2019-01-29 20:11:39.699: Fetch 65536
2019-01-29 20:11:39.717: Fetch 65536
2019-01-29 20:11:39.734: Fetch 65536
2019-01-29 20:11:39.746: Fetch 65536
2019-01-29 20:11:39.763: Fetch 65536
2019-01-29 20:11:39.778: Fetch 65536
2019-01-29 20:11:39.795: Fetch 65536
2019-01-29 20:11:39.812: Fetch 65536
2019-01-29 20:11:39.824: Fetch 65536
2019-01-29 20:11:39.838: Fetch 65536
2019-01-29 20:11:39.856: Fetch 65536
2019-01-29 20:11:39.873: Fetch 65536
2019-01-29 20:11:39.888: Fetch 65536
2019-01-29 20:11:39.902: Fetch 65536
2019-01-29 20:11:50.982: Fetch 65536
2019-01-29 20:11:51.001: Fetch 65536
2019-01-29 20:11:51.015: Fetch 65536
2019-01-29 20:11:51.027: Fetch 65536
2019-01-29 20:11:51.041: Fetch 65536
2019-01-29 20:11:51.056: Fetch 65536
2019-01-29 20:11:51.073: Fetch 65536
2019-01-29 20:11:51.102: Fetch 65536
2019-01-29 20:11:51.126: Fetch 65536
2019-01-29 20:11:51.151: Fetch 65536
2019-01-29 20:11:51.165: Fetch 65536
2019-01-29 20:11:51.182: Fetch 65536
2019-01-29 20:11:51.198: Fetch 65536
2019-01-29 20:11:51.214: Fetch 65536
2019-01-29 20:11:51.226: Fetch 65536
2019-01-29 20:11:51.237: Fetch 65536
2019-01-29 20:11:51.251: Fetch 65536
2019-01-29 20:11:51.267: Fetch 65536
2019-01-29 20:11:51.289: Fetch 65536
2019-01-29 20:11:51.308: Fetch 65536
2019-01-29 20:11:51.325: Fetch 65536
2019-01-29 20:11:51.346: Fetch 65536
2019-01-29 20:11:51.363: Fetch 65536
2019-01-29 20:11:51.376: Fetch 65536
2019-01-29 20:11:51.388: Fetch 65536
2019-01-29 20:11:51.400: Fetch 65536
2019-01-29 20:11:51.414: Fetch 65536
2019-01-29 20:11:51.426: Fetch 65536
2019-01-29 20:11:51.443: Fetch 65536
2019-01-29 20:11:51.460: Fetch 65536
2019-01-29 20:11:51.476: Fetch 65536
2019-01-29 20:11:51.496: Fetch 65536
2019-01-29 20:11:51.513: Fetch 65536
2019-01-29 20:11:51.527: Fetch 65536
2019-01-29 20:11:51.539: Fetch 65536
2019-01-29 20:11:51.553: Fetch 65536
2019-01-29 20:11:51.565: Fetch 65536
2019-01-29 20:11:51.578: Fetch 65536
2019-01-29 20:11:51.596: Fetch 65536
2019-01-29 20:11:51.615: Fetch 65536
2019-01-29 20:11:51.635: Fetch 65536
2019-01-29 20:11:51.654: Fetch 65536
2019-01-29 20:11:51.674: Fetch 65536
2019-01-29 20:11:51.686: Fetch 65536
2019-01-29 20:11:51.700: Fetch 65536
2019-01-29 20:11:51.712: Fetch 65536
2019-01-29 20:11:51.725: Fetch 65536
2019-01-29 20:11:51.739: Fetch 65536
2019-01-29 20:11:51.752: Fetch 65536
2019-01-29 20:12:04.336: Fetch 65536
2019-01-29 20:12:04.381: Fetch 65536
2019-01-29 20:12:04.414: Fetch 65536
2019-01-29 20:12:04.428: Fetch 65536
2019-01-29 20:12:04.440: Fetch 65536
2019-01-29 20:12:04.453: Fetch 65536
2019-01-29 20:12:04.467: Fetch 65536
2019-01-29 20:12:04.479: Fetch 65536
2019-01-29 20:12:04.493: Fetch 65536
2019-01-29 20:12:04.512: Fetch 65536
2019-01-29 20:12:04.528: Fetch 65536
2019-01-29 20:12:04.546: Fetch 65536
2019-01-29 20:12:04.561: Fetch 65536
2019-01-29 20:12:04.579: Fetch 65536
2019-01-29 20:12:04.595: Fetch 65536
2019-01-29 20:12:04.611: Fetch 65536
2019-01-29 20:12:04.627: Fetch 65536
2019-01-29 20:12:04.645: Fetch 65536
2019-01-29 20:12:04.658: Fetch 65536
2019-01-29 20:12:04.669: Fetch 65536
2019-01-29 20:12:04.683: Fetch 65536
2019-01-29 20:12:04.703: Fetch 65536
2019-01-29 20:12:04.722: Fetch 65536
2019-01-29 20:12:04.741: Fetch 65536
2019-01-29 20:12:04.753: Fetch 65536
2019-01-29 20:12:04.769: Fetch 65536
2019-01-29 20:12:04.783: Fetch 65536
2019-01-29 20:12:04.796: Fetch 65536
2019-01-29 20:12:04.809: Fetch 65536
2019-01-29 20:12:04.828: Fetch 65536
2019-01-29 20:12:04.852: Fetch 65536
2019-01-29 20:12:04.871: Fetch 65536
2019-01-29 20:12:04.892: Fetch 65536
2019-01-29 20:12:04.905: Fetch 65536
2019-01-29 20:12:04.918: Fetch 65536
2019-01-29 20:12:04.933: Fetch 65536
2019-01-29 20:12:04.947: Fetch 65536
2019-01-29 20:12:04.960: Fetch 65536
2019-01-29 20:12:04.974: Fetch 65536
2019-01-29 20:12:04.996: Fetch 65536
2019-01-29 20:12:05.009: Fetch 65536
2019-01-29 20:12:05.026: Fetch 65536
2019-01-29 20:12:05.042: Fetch 65536
2019-01-29 20:12:05.057: Fetch 65536
2019-01-29 20:12:05.071: Fetch 65536
2019-01-29 20:12:05.083: Fetch 65536
2019-01-29 20:12:05.095: Fetch 65536
2019-01-29 20:12:05.109: Fetch 65536
2019-01-29 20:12:05.126: Fetch 65536
2019-01-29 20:12:05.152: Fetch 65536
2019-01-29 20:12:05.166: Fetch 65536
2019-01-29 20:12:05.188: Fetch 65536
2019-01-29 20:12:05.203: Fetch 65536
2019-01-29 20:12:14.747: Fetch 65536
2019-01-29 20:12:14.774: Fetch 65536
2019-01-29 20:12:14.785: Fetch 65536
2019-01-29 20:12:14.798: Fetch 65536
2019-01-29 20:12:14.815: Fetch 65536
2019-01-29 20:12:14.833: Fetch 65536
2019-01-29 20:12:14.849: Fetch 65536
2019-01-29 20:12:14.867: Fetch 65536
2019-01-29 20:12:14.883: Fetch 65536
2019-01-29 20:12:14.898: Fetch 65536
2019-01-29 20:12:14.915: Fetch 65536
2019-01-29 20:12:14.934: Fetch 65536
2019-01-29 20:12:14.950: Fetch 65536
2019-01-29 20:12:14.966: Fetch 65536
2019-01-29 20:12:14.982: Fetch 65536
2019-01-29 20:12:14.995: Fetch 65536
2019-01-29 20:12:15.006: Fetch 65536
2019-01-29 20:12:15.024: Fetch 65536
2019-01-29 20:12:15.039: Fetch 65536
2019-01-29 20:12:15.056: Fetch 65536
2019-01-29 20:12:15.075: Fetch 65536
2019-01-29 20:12:15.096: Fetch 65536
2019-01-29 20:12:15.112: Fetch 65536
2019-01-29 20:12:15.127: Fetch 65536
2019-01-29 20:12:15.139: Fetch 65536
2019-01-29 20:12:15.152: Fetch 65536
2019-01-29 20:12:15.167: Fetch 65536
2019-01-29 20:12:15.188: Fetch 65536
2019-01-29 20:12:15.213: Fetch 65536
2019-01-29 20:12:15.227: Fetch 65536
2019-01-29 20:12:15.247: Fetch 65536
2019-01-29 20:12:15.262: Fetch 65536
2019-01-29 20:12:15.283: Fetch 65536
2019-01-29 20:12:15.303: Fetch 65536
2019-01-29 20:12:15.326: Fetch 65536
2019-01-29 20:12:15.347: Fetch 65536
2019-01-29 20:12:15.359: Fetch 65536
2019-01-29 20:12:15.371: Fetch 65536
2019-01-29 20:12:15.388: Fetch 65536
2019-01-29 20:12:15.410: Fetch 65536
2019-01-29 20:12:15.425: Fetch 65536
2019-01-29 20:12:15.446: Fetch 65536
2019-01-29 20:12:15.466: Fetch 65536
2019-01-29 20:12:15.481: Fetch 65536
2019-01-29 20:12:15.496: Fetch 65536
2019-01-29 20:12:15.510: Fetch 65536
2019-01-29 20:12:15.524: Fetch 65536
2019-01-29 20:12:15.538: Fetch 65536
2019-01-29 20:12:15.558: Fetch 65536
2019-01-29 20:12:15.580: Fetch 65536
2019-01-29 20:12:15.597: Fetch 65536
2019-01-29 20:12:15.611: Fetch 65536
2019-01-29 20:12:15.625: Fetch 65536
2019-01-29 20:12:15.640: Fetch 65536
2019-01-29 20:12:28.119: Fetch 65536
2019-01-29 20:12:28.143: Fetch 65536
2019-01-29 20:12:28.157: Fetch 65536
2019-01-29 20:12:28.170: Fetch 65536
2019-01-29 20:12:28.184: Fetch 65536
2019-01-29 20:12:28.197: Fetch 65536
2019-01-29 20:12:28.211: Fetch 65536
2019-01-29 20:12:28.228: Fetch 65536
2019-01-29 20:12:28.244: Fetch 65536
2019-01-29 20:12:28.259: Fetch 65536
2019-01-29 20:12:28.277: Fetch 65536
2019-01-29 20:12:28.297: Fetch 65536
2019-01-29 20:12:28.314: Fetch 65536
2019-01-29 20:12:28.328: Fetch 65536
2019-01-29 20:12:28.345: Fetch 65536
2019-01-29 20:12:28.361: Fetch 65536
2019-01-29 20:12:28.376: Fetch 65536
2019-01-29 20:12:28.395: Fetch 65536
2019-01-29 20:12:28.409: Fetch 65536
2019-01-29 20:12:28.421: Fetch 65536
2019-01-29 20:12:28.441: Fetch 65536
2019-01-29 20:12:28.455: Fetch 65536
2019-01-29 20:12:28.477: Fetch 65536
2019-01-29 20:12:28.493: Fetch 65536
2019-01-29 20:12:28.504: Fetch 65536
2019-01-29 20:12:28.517: Fetch 65536
2019-01-29 20:12:28.530: Fetch 65536
2019-01-29 20:12:28.543: Fetch 65536
2019-01-29 20:12:28.561: Fetch 65536
2019-01-29 20:12:28.577: Fetch 65536
2019-01-29 20:12:28.595: Fetch 65536
2019-01-29 20:12:28.612: Fetch 65536
2019-01-29 20:12:28.628: Fetch 65536
2019-01-29 20:12:28.646: Fetch 65536
2019-01-29 20:12:28.665: Fetch 65536
2019-01-29 20:12:28.686: Fetch 65536
2019-01-29 20:12:28.700: Fetch 65536
2019-01-29 20:12:28.712: Fetch 65536
2019-01-29 20:12:28.726: Fetch 65536
2019-01-29 20:12:28.739: Fetch 65536
2019-01-29 20:12:28.756: Fetch 65536
2019-01-29 20:12:28.780: Fetch 65536
2019-01-29 20:12:28.800: Fetch 65536
2019-01-29 20:12:28.817: Fetch 65536
2019-01-29 20:12:28.828: Fetch 65536
2019-01-29 20:12:28.840: Fetch 65536
2019-01-29 20:12:28.854: Fetch 65536
2019-01-29 20:12:28.872: Fetch 65536
2019-01-29 20:12:28.890: Fetch 65536
2019-01-29 20:12:28.902: Fetch 65536
2019-01-29 20:12:28.919: Fetch 65536
2019-01-29 20:12:28.933: Fetch 65536
2019-01-29 20:12:28.949: Fetch 65536
2019-01-29 20:12:28.971: Fetch 65536
2019-01-29 20:12:38.514: Fetch 65536
2019-01-29 20:12:38.535: Fetch 65536
2019-01-29 20:12:38.546: Fetch 65536
2019-01-29 20:12:38.559: Fetch 65536
2019-01-29 20:12:38.575: Fetch 65536
2019-01-29 20:12:38.589: Fetch 65536
2019-01-29 20:12:38.606: Fetch 65536
2019-01-29 20:12:38.617: Fetch 65536
2019-01-29 20:12:38.628: Fetch 65536
2019-01-29 20:12:38.643: Fetch 65536
2019-01-29 20:12:38.660: Fetch 65536
2019-01-29 20:12:38.674: Fetch 65536
2019-01-29 20:12:38.687: Fetch 65536
2019-01-29 20:12:38.699: Fetch 65536
2019-01-29 20:12:38.713: Fetch 65536
2019-01-29 20:12:38.725: Fetch 65536
2019-01-29 20:12:38.741: Fetch 65536
2019-01-29 20:12:38.765: Fetch 65536
2019-01-29 20:12:38.786: Fetch 65536
2019-01-29 20:12:38.810: Fetch 65536
2019-01-29 20:12:38.830: Fetch 65536
2019-01-29 20:12:38.843: Fetch 65536
2019-01-29 20:12:38.859: Fetch 65536
2019-01-29 20:12:38.887: Fetch 65536
2019-01-29 20:12:38.907: Fetch 65536
2019-01-29 20:12:38.927: Fetch 65536
2019-01-29 20:12:38.949: Fetch 65536
2019-01-29 20:12:38.963: Fetch 65536
2019-01-29 20:12:38.977: Fetch 65536
2019-01-29 20:12:38.991: Fetch 65536
2019-01-29 20:12:39.002: Fetch 65536
2019-01-29 20:12:39.016: Fetch 65536
2019-01-29 20:12:39.029: Fetch 65536
2019-01-29 20:12:39.042: Fetch 65536
2019-01-29 20:12:39.066: Fetch 65536
2019-01-29 20:12:39.078: Fetch 65536
2019-01-29 20:12:39.093: Fetch 65536
2019-01-29 20:12:39.107: Fetch 65536
2019-01-29 20:12:39.122: Fetch 65536
2019-01-29 20:12:39.136: Fetch 65536
2019-01-29 20:12:39.152: Fetch 65536
2019-01-29 20:12:39.170: Fetch 65536
2019-01-29 20:12:39.188: Fetch 65536
2019-01-29 20:12:39.218: Fetch 65536
2019-01-29 20:12:39.237: Fetch 65536
2019-01-29 20:12:39.256: Fetch 65536
2019-01-29 20:12:39.275: Fetch 65536
2019-01-29 20:12:39.287: Fetch 65536
2019-01-29 20:12:39.300: Fetch 65536
2019-01-29 20:12:39.313: Fetch 65536
2019-01-29 20:12:39.329: Fetch 65536
2019-01-29 20:12:39.350: Fetch 65536
2019-01-29 20:12:39.382: Fetch 65536
2019-01-29 20:12:39.396: Fetch 65536
2019-01-29 20:12:39.410: Fetch 65536
2019-01-29 20:12:39.428: Fetch 65536
2019-01-29 20:12:51.872: Fetch 65536
2019-01-29 20:12:51.883: Fetch 65536
2019-01-29 20:12:51.897: Fetch 65536
2019-01-29 20:12:51.911: Fetch 65536
2019-01-29 20:12:51.931: Fetch 65536
2019-01-29 20:12:51.952: Fetch 65536
2019-01-29 20:12:51.973: Fetch 65536
2019-01-29 20:12:51.988: Fetch 65536
2019-01-29 20:12:52.004: Fetch 65536
2019-01-29 20:12:52.019: Fetch 65536
2019-01-29 20:12:52.033: Fetch 65536
2019-01-29 20:12:52.047: Fetch 65536
2019-01-29 20:12:52.071: Fetch 65536
2019-01-29 20:12:52.095: Fetch 65536
2019-01-29 20:12:52.113: Fetch 65536
2019-01-29 20:12:52.130: Fetch 65536
2019-01-29 20:12:52.148: Fetch 65536
2019-01-29 20:12:52.169: Fetch 65536
2019-01-29 20:12:52.183: Fetch 65536
2019-01-29 20:12:52.200: Fetch 65536
2019-01-29 20:12:52.213: Fetch 65536
2019-01-29 20:12:52.227: Fetch 65536
2019-01-29 20:12:52.246: Fetch 65536
2019-01-29 20:12:52.262: Fetch 65536
2019-01-29 20:12:52.280: Fetch 65536
2019-01-29 20:12:52.298: Fetch 65536
2019-01-29 20:12:52.316: Fetch 65536
2019-01-29 20:12:52.335: Fetch 65536
2019-01-29 20:12:52.351: Fetch 65536
2019-01-29 20:12:52.368: Fetch 65536
2019-01-29 20:12:52.386: Fetch 65536
2019-01-29 20:12:52.404: Fetch 65536
2019-01-29 20:12:52.417: Fetch 65536
2019-01-29 20:12:52.437: Fetch 65536
2019-01-29 20:12:52.455: Fetch 65536
2019-01-29 20:12:52.472: Fetch 65536
2019-01-29 20:12:52.493: Fetch 65536
2019-01-29 20:12:52.510: Fetch 65536
2019-01-29 20:12:52.525: Fetch 65536
2019-01-29 20:12:52.539: Fetch 65536
2019-01-29 20:12:52.556: Fetch 65536
2019-01-29 20:12:52.570: Fetch 65536
2019-01-29 20:12:52.586: Fetch 65536
2019-01-29 20:12:52.602: Fetch 65536
2019-01-29 20:12:52.622: Fetch 65536
2019-01-29 20:12:52.639: Fetch 65536
2019-01-29 20:12:52.658: Fetch 65536
2019-01-29 20:12:52.675: Fetch 65536
2019-01-29 20:12:52.689: Fetch 65536
2019-01-29 20:12:52.706: Fetch 65536
2019-01-29 20:12:52.723: Fetch 65536
2019-01-29 20:12:52.747: Fetch 65536
2019-01-29 20:12:52.761: Fetch 65536
2019-01-29 20:12:52.777: Fetch 65536
2019-01-29 20:12:52.793: Fetch 65536
2019-01-29 20:12:52.809: Fetch 65536
2019-01-29 20:12:52.823: Fetch 65536
2019-01-29 20:12:52.836: Fetch 65536
2019-01-29 20:12:52.855: Fetch 65536
2019-01-29 20:12:52.871: Fetch 65536
2019-01-29 20:12:52.891: Fetch 65536
2019-01-29 20:13:02.300: Fetch 65536
2019-01-29 20:13:02.355: Fetch 65536
2019-01-29 20:13:02.394: Fetch 65536
2019-01-29 20:13:02.407: Fetch 65536
2019-01-29 20:13:02.421: Fetch 65536
2019-01-29 20:13:02.434: Fetch 65536
2019-01-29 20:13:02.448: Fetch 65536
2019-01-29 20:13:02.461: Fetch 65536
2019-01-29 20:13:02.481: Fetch 65536
2019-01-29 20:13:02.497: Fetch 65536
2019-01-29 20:13:02.513: Fetch 65536
2019-01-29 20:13:02.529: Fetch 65536
2019-01-29 20:13:02.548: Fetch 65536
2019-01-29 20:13:02.565: Fetch 65536
2019-01-29 20:13:02.581: Fetch 65536
2019-01-29 20:13:02.594: Fetch 65536
2019-01-29 20:13:02.606: Fetch 65536
2019-01-29 20:13:02.617: Fetch 65536
2019-01-29 20:13:02.630: Fetch 65536
2019-01-29 20:13:02.644: Fetch 65536
2019-01-29 20:13:02.663: Fetch 65536
2019-01-29 20:13:02.691: Fetch 65536
2019-01-29 20:13:02.711: Fetch 65536
2019-01-29 20:13:02.723: Fetch 65536
2019-01-29 20:13:02.739: Fetch 65536
2019-01-29 20:13:02.753: Fetch 65536
2019-01-29 20:13:02.768: Fetch 65536
2019-01-29 20:13:02.778: Fetch 65536
2019-01-29 20:13:02.791: Fetch 65536
2019-01-29 20:13:02.802: Fetch 65536
2019-01-29 20:13:02.814: Fetch 65536
2019-01-29 20:13:02.828: Fetch 65536
2019-01-29 20:13:02.845: Fetch 65536
2019-01-29 20:13:02.862: Fetch 65536
2019-01-29 20:13:02.879: Fetch 65536
2019-01-29 20:13:02.897: Fetch 65536
2019-01-29 20:13:02.914: Fetch 65536
2019-01-29 20:13:02.929: Fetch 65536
2019-01-29 20:13:02.944: Fetch 65536
2019-01-29 20:13:02.957: Fetch 65536
2019-01-29 20:13:02.972: Fetch 65536
2019-01-29 20:13:02.991: Fetch 65536
2019-01-29 20:13:03.021: Fetch 65536
2019-01-29 20:13:03.041: Fetch 65536
2019-01-29 20:13:03.055: Fetch 65536
2019-01-29 20:13:03.073: Fetch 65536
2019-01-29 20:13:03.090: Fetch 65536
2019-01-29 20:13:03.103: Fetch 65536
2019-01-29 20:13:03.115: Fetch 65536
2019-01-29 20:13:03.129: Fetch 65536
2019-01-29 20:13:03.144: Fetch 65536
2019-01-29 20:13:03.157: Fetch 65536
2019-01-29 20:13:03.169: Fetch 65536
2019-01-29 20:13:03.185: Fetch 65536
2019-01-29 20:13:03.202: Fetch 65536
2019-01-29 20:13:03.222: Fetch 65536
2019-01-29 20:13:03.239: Fetch 65536
2019-01-29 20:13:03.257: Fetch 65536
2019-01-29 20:13:03.270: Fetch 65536
2019-01-29 20:13:03.283: Fetch 65536
2019-01-29 20:13:03.294: Fetch 65536
2019-01-29 20:13:03.306: Fetch 65536
2019-01-29 20:13:14.204: Fetch 65536
2019-01-29 20:13:14.223: Fetch 65536
2019-01-29 20:13:14.238: Fetch 65536
2019-01-29 20:13:14.252: Fetch 65536
2019-01-29 20:13:14.264: Fetch 65536
2019-01-29 20:13:14.281: Fetch 65536
2019-01-29 20:13:14.298: Fetch 65536
2019-01-29 20:13:14.324: Fetch 65536
2019-01-29 20:13:14.344: Fetch 65536
2019-01-29 20:13:14.361: Fetch 65536
2019-01-29 20:13:14.374: Fetch 65536
2019-01-29 20:13:14.393: Fetch 65536
2019-01-29 20:13:14.408: Fetch 65536
2019-01-29 20:13:14.419: Fetch 65536
2019-01-29 20:13:14.432: Fetch 65536
2019-01-29 20:13:14.444: Fetch 65536
2019-01-29 20:13:14.458: Fetch 65536
2019-01-29 20:13:14.473: Fetch 65536
2019-01-29 20:13:14.488: Fetch 65536
2019-01-29 20:13:14.510: Fetch 65536
2019-01-29 20:13:14.528: Fetch 65536
2019-01-29 20:13:14.544: Fetch 65536
2019-01-29 20:13:14.558: Fetch 65536
2019-01-29 20:13:14.573: Fetch 65536
2019-01-29 20:13:14.587: Fetch 65536
2019-01-29 20:13:14.601: Fetch 65536
2019-01-29 20:13:14.613: Fetch 65536
2019-01-29 20:13:14.626: Fetch 65536
2019-01-29 20:13:14.643: Fetch 65536
2019-01-29 20:13:14.673: Fetch 65536
2019-01-29 20:13:14.685: Fetch 65536
2019-01-29 20:13:14.701: Fetch 65536
2019-01-29 20:13:14.722: Fetch 65536
2019-01-29 20:13:14.738: Fetch 65536
2019-01-29 20:13:14.754: Fetch 65536
2019-01-29 20:13:14.766: Fetch 65536
2019-01-29 20:13:14.781: Fetch 65536
2019-01-29 20:13:14.795: Fetch 65536
2019-01-29 20:13:14.807: Fetch 65536
2019-01-29 20:13:14.823: Fetch 65536
2019-01-29 20:13:14.841: Fetch 65536
2019-01-29 20:13:14.857: Fetch 65536
2019-01-29 20:13:14.879: Fetch 65536
2019-01-29 20:13:14.898: Fetch 65536
2019-01-29 20:13:14.914: Fetch 65536
2019-01-29 20:13:14.935: Fetch 65536
2019-01-29 20:13:14.949: Fetch 65536
2019-01-29 20:13:14.966: Fetch 65536
2019-01-29 20:13:14.985: Fetch 65536
2019-01-29 20:13:15.004: Fetch 65536
2019-01-29 20:13:15.020: Fetch 65536
2019-01-29 20:13:15.033: Fetch 65536
2019-01-29 20:13:15.048: Fetch 65536
2019-01-29 20:13:15.063: Fetch 65536
2019-01-29 20:13:15.079: Fetch 65536
2019-01-29 20:13:15.094: Fetch 65536
2019-01-29 20:13:15.111: Fetch 65536
2019-01-29 20:13:15.129: Fetch 65536
2019-01-29 20:13:15.156: Fetch 65536
2019-01-29 20:13:15.184: Fetch 65536
2019-01-29 20:13:27.567: Fetch 65536
2019-01-29 20:13:27.583: Fetch 65536
2019-01-29 20:13:27.597: Fetch 65536
2019-01-29 20:13:27.611: Fetch 65536
2019-01-29 20:13:27.625: Fetch 65536
2019-01-29 20:13:27.648: Fetch 65536
2019-01-29 20:13:27.665: Fetch 65536
2019-01-29 20:13:27.683: Fetch 65536
2019-01-29 20:13:27.697: Fetch 65536
2019-01-29 20:13:27.712: Fetch 65536
2019-01-29 20:13:27.726: Fetch 65536
2019-01-29 20:13:27.737: Fetch 65536
2019-01-29 20:13:27.749: Fetch 65536
2019-01-29 20:13:27.766: Fetch 65536
2019-01-29 20:13:27.783: Fetch 65536
2019-01-29 20:13:27.798: Fetch 65536
2019-01-29 20:13:27.813: Fetch 65536
2019-01-29 20:13:27.834: Fetch 65536
2019-01-29 20:13:27.851: Fetch 65536
2019-01-29 20:13:27.868: Fetch 65536
2019-01-29 20:13:27.886: Fetch 65536
2019-01-29 20:13:27.907: Fetch 65536
2019-01-29 20:13:27.926: Fetch 65536
2019-01-29 20:13:27.939: Fetch 65536
2019-01-29 20:13:27.955: Fetch 65536
2019-01-29 20:13:27.975: Fetch 65536
2019-01-29 20:13:27.991: Fetch 65536
2019-01-29 20:13:28.006: Fetch 65536
2019-01-29 20:13:28.022: Fetch 65536
2019-01-29 20:13:28.044: Fetch 65536
2019-01-29 20:13:28.057: Fetch 65536
2019-01-29 20:13:28.068: Fetch 65536
2019-01-29 20:13:28.081: Fetch 65536
2019-01-29 20:13:28.098: Fetch 65536
2019-01-29 20:13:28.117: Fetch 65536
2019-01-29 20:13:28.131: Fetch 65536
2019-01-29 20:13:28.145: Fetch 65536
2019-01-29 20:13:28.164: Fetch 65536
2019-01-29 20:13:28.186: Fetch 65536
2019-01-29 20:13:28.200: Fetch 65536
2019-01-29 20:13:28.215: Fetch 65536
2019-01-29 20:13:28.230: Fetch 65536
2019-01-29 20:13:28.251: Fetch 65536
2019-01-29 20:13:28.266: Fetch 65536
2019-01-29 20:13:28.280: Fetch 65536
2019-01-29 20:13:28.293: Fetch 65536
2019-01-29 20:13:28.307: Fetch 65536
2019-01-29 20:13:28.321: Fetch 65536
2019-01-29 20:13:28.337: Fetch 65536
2019-01-29 20:13:28.351: Fetch 65536
2019-01-29 20:13:28.377: Fetch 65536
2019-01-29 20:13:28.407: Fetch 65536
2019-01-29 20:13:28.431: Fetch 65536
2019-01-29 20:13:28.443: Fetch 65536
2019-01-29 20:13:28.455: Fetch 65536
2019-01-29 20:13:28.468: Fetch 65536
2019-01-29 20:13:28.487: Fetch 65536
2019-01-29 20:13:28.510: Fetch 65536
2019-01-29 20:13:28.527: Fetch 65536
2019-01-29 20:13:28.542: Fetch 65536
2019-01-29 20:13:28.556: Fetch 65536
2019-01-29 20:13:28.570: Fetch 65536
2019-01-29 20:13:28.586: Fetch 65536
2019-01-29 20:13:28.605: Fetch 65536
2019-01-29 20:13:37.952: Fetch 65536
2019-01-29 20:13:37.976: Fetch 65536
2019-01-29 20:13:37.987: Fetch 65536
2019-01-29 20:13:38.000: Fetch 65536
2019-01-29 20:13:38.012: Fetch 65536
2019-01-29 20:13:38.030: Fetch 65536
2019-01-29 20:13:38.043: Fetch 65536
2019-01-29 20:13:38.063: Fetch 65536
2019-01-29 20:13:38.081: Fetch 65536
2019-01-29 20:13:38.095: Fetch 65536
2019-01-29 20:13:38.109: Fetch 65536
2019-01-29 20:13:38.124: Fetch 65536
2019-01-29 20:13:38.143: Fetch 65536
2019-01-29 20:13:38.160: Fetch 65536
2019-01-29 20:13:38.172: Fetch 65536
2019-01-29 20:13:38.185: Fetch 65536
2019-01-29 20:13:38.202: Fetch 65536
2019-01-29 20:13:38.221: Fetch 65536
2019-01-29 20:13:38.243: Fetch 65536
2019-01-29 20:13:38.263: Fetch 65536
2019-01-29 20:13:38.280: Fetch 65536
2019-01-29 20:13:38.296: Fetch 65536
2019-01-29 20:13:38.310: Fetch 65536
2019-01-29 20:13:38.323: Fetch 65536
2019-01-29 20:13:38.336: Fetch 65536
2019-01-29 20:13:38.349: Fetch 65536
2019-01-29 20:13:38.361: Fetch 65536
2019-01-29 20:13:38.373: Fetch 65536
2019-01-29 20:13:38.384: Fetch 65536
2019-01-29 20:13:38.399: Fetch 65536
2019-01-29 20:13:38.412: Fetch 65536
2019-01-29 20:13:38.430: Fetch 65536
2019-01-29 20:13:38.451: Fetch 65536
2019-01-29 20:13:38.468: Fetch 65536
2019-01-29 20:13:38.488: Fetch 65536
2019-01-29 20:13:38.500: Fetch 65536
2019-01-29 20:13:38.512: Fetch 65536
2019-01-29 20:13:38.526: Fetch 65536
2019-01-29 20:13:38.540: Fetch 65536
2019-01-29 20:13:38.556: Fetch 65536
2019-01-29 20:13:38.577: Fetch 65536
2019-01-29 20:13:38.600: Fetch 65536
2019-01-29 20:13:38.624: Fetch 65536
2019-01-29 20:13:38.639: Fetch 65536
2019-01-29 20:13:38.658: Fetch 65536
2019-01-29 20:13:38.672: Fetch 65536
2019-01-29 20:13:38.686: Fetch 65536
2019-01-29 20:13:38.697: Fetch 65536
2019-01-29 20:13:38.712: Fetch 65536
2019-01-29 20:13:38.725: Fetch 65536
2019-01-29 20:13:38.737: Fetch 65536
2019-01-29 20:13:38.750: Fetch 65536
2019-01-29 20:13:38.769: Fetch 65536
2019-01-29 20:13:38.786: Fetch 65536
2019-01-29 20:13:38.807: Fetch 65536
2019-01-29 20:13:38.823: Fetch 65536
2019-01-29 20:13:38.836: Fetch 65536
2019-01-29 20:13:38.847: Fetch 65536
2019-01-29 20:13:38.863: Fetch 65536
2019-01-29 20:13:38.878: Fetch 65536
2019-01-29 20:13:38.899: Fetch 65536
2019-01-29 20:13:38.917: Fetch 65536
2019-01-29 20:13:38.931: Fetch 65536
2019-01-29 20:13:51.320: Fetch 65536
2019-01-29 20:13:51.335: Fetch 65536
2019-01-29 20:13:51.350: Fetch 65536
2019-01-29 20:13:51.373: Fetch 65536
2019-01-29 20:13:51.393: Fetch 65536
2019-01-29 20:13:51.427: Fetch 65536
2019-01-29 20:13:51.453: Fetch 65536
2019-01-29 20:13:51.465: Fetch 65536
2019-01-29 20:13:51.480: Fetch 65536
2019-01-29 20:13:51.495: Fetch 65536
2019-01-29 20:13:51.508: Fetch 65536
2019-01-29 20:13:51.522: Fetch 65536
2019-01-29 20:13:51.537: Fetch 65536
2019-01-29 20:13:51.553: Fetch 65536
2019-01-29 20:13:51.572: Fetch 65536
2019-01-29 20:13:51.591: Fetch 65536
2019-01-29 20:13:51.616: Fetch 65536
2019-01-29 20:13:51.630: Fetch 65536
2019-01-29 20:13:51.651: Fetch 65536
2019-01-29 20:13:51.665: Fetch 65536
2019-01-29 20:13:51.680: Fetch 65536
2019-01-29 20:13:51.696: Fetch 65536
2019-01-29 20:13:51.709: Fetch 65536
2019-01-29 20:13:51.722: Fetch 65536
2019-01-29 20:13:51.736: Fetch 65536
2019-01-29 20:13:51.748: Fetch 65536
2019-01-29 20:13:51.760: Fetch 65536
2019-01-29 20:13:51.782: Fetch 65536
2019-01-29 20:13:51.798: Fetch 65536
2019-01-29 20:13:51.818: Fetch 65536
2019-01-29 20:13:51.832: Fetch 65536
2019-01-29 20:13:51.846: Fetch 65536
2019-01-29 20:13:51.860: Fetch 65536
2019-01-29 20:13:51.873: Fetch 65536
2019-01-29 20:13:51.888: Fetch 65536
2019-01-29 20:13:51.906: Fetch 65536
2019-01-29 20:13:51.929: Fetch 65536
2019-01-29 20:13:51.953: Fetch 65536
2019-01-29 20:13:51.982: Fetch 65536
2019-01-29 20:13:51.998: Fetch 65536
2019-01-29 20:13:52.010: Fetch 65536
2019-01-29 20:13:52.024: Fetch 65536
2019-01-29 20:13:52.037: Fetch 65536
2019-01-29 20:13:52.052: Fetch 65536
2019-01-29 20:13:52.065: Fetch 65536
2019-01-29 20:13:52.084: Fetch 65536
2019-01-29 20:13:52.104: Fetch 65536
2019-01-29 20:13:52.123: Fetch 65536
2019-01-29 20:13:52.139: Fetch 65536
2019-01-29 20:13:52.152: Fetch 65536
2019-01-29 20:13:52.167: Fetch 65536
2019-01-29 20:13:52.180: Fetch 65536
2019-01-29 20:13:52.195: Fetch 65536
2019-01-29 20:13:52.208: Fetch 65536
2019-01-29 20:13:52.227: Fetch 65536
2019-01-29 20:13:52.240: Fetch 65536
2019-01-29 20:13:52.254: Fetch 65536
2019-01-29 20:13:52.272: Fetch 65536
2019-01-29 20:13:52.289: Fetch 65536
2019-01-29 20:14:01.743: Fetch 65536
2019-01-29 20:14:01.759: Fetch 65536
2019-01-29 20:14:01.771: Fetch 65536
2019-01-29 20:14:01.783: Fetch 65536
2019-01-29 20:14:01.797: Fetch 65536
2019-01-29 20:14:01.812: Fetch 65536
2019-01-29 20:14:01.828: Fetch 65536
2019-01-29 20:14:01.849: Fetch 65536
2019-01-29 20:14:01.862: Fetch 65536
2019-01-29 20:14:01.877: Fetch 65536
2019-01-29 20:14:01.893: Fetch 65536
2019-01-29 20:14:01.905: Fetch 65536
2019-01-29 20:14:01.921: Fetch 65536
2019-01-29 20:14:01.938: Fetch 65536
2019-01-29 20:14:01.956: Fetch 65536
2019-01-29 20:14:01.970: Fetch 65536
2019-01-29 20:14:01.984: Fetch 65536
2019-01-29 20:14:01.998: Fetch 65536
2019-01-29 20:14:02.011: Fetch 65536
2019-01-29 20:14:02.023: Fetch 65536
2019-01-29 20:14:02.035: Fetch 65536
2019-01-29 20:14:02.051: Fetch 65536
2019-01-29 20:14:02.073: Fetch 65536
2019-01-29 20:14:02.091: Fetch 65536
2019-01-29 20:14:02.108: Fetch 65536
2019-01-29 20:14:02.123: Fetch 65536
2019-01-29 20:14:02.136: Fetch 65536
2019-01-29 20:14:02.148: Fetch 65536
2019-01-29 20:14:02.159: Fetch 65536
2019-01-29 20:14:02.171: Fetch 65536
2019-01-29 20:14:02.183: Fetch 65536
2019-01-29 20:14:02.195: Fetch 65536
2019-01-29 20:14:02.211: Fetch 65536
2019-01-29 20:14:02.228: Fetch 65536
2019-01-29 20:14:02.245: Fetch 65536
2019-01-29 20:14:02.260: Fetch 65536
2019-01-29 20:14:02.273: Fetch 65536
2019-01-29 20:14:02.287: Fetch 65536
2019-01-29 20:14:02.299: Fetch 65536
2019-01-29 20:14:02.314: Fetch 65536
2019-01-29 20:14:02.326: Fetch 65536
2019-01-29 20:14:02.337: Fetch 65536
2019-01-29 20:14:02.349: Fetch 65536
2019-01-29 20:14:02.362: Fetch 65536
2019-01-29 20:14:02.381: Fetch 65536
2019-01-29 20:14:02.396: Fetch 65536
2019-01-29 20:14:02.415: Fetch 65536
2019-01-29 20:14:02.433: Fetch 65536
2019-01-29 20:14:02.447: Fetch 65536
2019-01-29 20:14:02.463: Fetch 65536
2019-01-29 20:14:02.476: Fetch 65536
2019-01-29 20:14:02.488: Fetch 65536
2019-01-29 20:14:02.506: Fetch 65536
2019-01-29 20:14:02.523: Fetch 65536
2019-01-29 20:14:02.549: Fetch 65536
2019-01-29 20:14:02.567: Fetch 65536
2019-01-29 20:14:02.584: Fetch 65536
2019-01-29 20:14:15.098: Fetch 65536
2019-01-29 20:14:15.136: Fetch 65536
2019-01-29 20:14:15.172: Fetch 65536
2019-01-29 20:14:15.185: Fetch 65536
2019-01-29 20:14:15.200: Fetch 65536
2019-01-29 20:14:15.215: Fetch 65536
2019-01-29 20:14:15.230: Fetch 65536
2019-01-29 20:14:15.240: Fetch 65536
2019-01-29 20:14:15.253: Fetch 65536
2019-01-29 20:14:15.271: Fetch 65536
2019-01-29 20:14:15.285: Fetch 65536
2019-01-29 20:14:15.303: Fetch 65536
2019-01-29 20:14:15.323: Fetch 65536
2019-01-29 20:14:15.345: Fetch 65536
2019-01-29 20:14:15.365: Fetch 65536
2019-01-29 20:14:15.376: Fetch 65536
2019-01-29 20:14:15.387: Fetch 65536
2019-01-29 20:14:15.398: Fetch 65536
2019-01-29 20:14:15.413: Fetch 65536
2019-01-29 20:14:15.433: Fetch 65536
2019-01-29 20:14:15.450: Fetch 65536
2019-01-29 20:14:15.466: Fetch 65536
2019-01-29 20:14:15.482: Fetch 65536
2019-01-29 20:14:15.500: Fetch 65536
2019-01-29 20:14:15.513: Fetch 65536
2019-01-29 20:14:15.527: Fetch 65536
2019-01-29 20:14:15.539: Fetch 65536
2019-01-29 20:14:15.553: Fetch 65536
2019-01-29 20:14:15.565: Fetch 65536
2019-01-29 20:14:15.577: Fetch 65536
2019-01-29 20:14:15.590: Fetch 65536
2019-01-29 20:14:15.603: Fetch 65536
2019-01-29 20:14:15.617: Fetch 65536
2019-01-29 20:14:15.637: Fetch 65536
2019-01-29 20:14:15.668: Fetch 65536
2019-01-29 20:14:15.689: Fetch 65536
2019-01-29 20:14:15.701: Fetch 65536
2019-01-29 20:14:15.717: Fetch 65536
2019-01-29 20:14:15.733: Fetch 65536
2019-01-29 20:14:15.750: Fetch 65536
2019-01-29 20:14:15.761: Fetch 65536
2019-01-29 20:14:15.775: Fetch 65536
2019-01-29 20:14:15.790: Fetch 65536
2019-01-29 20:14:15.811: Fetch 65536
2019-01-29 20:14:15.835: Fetch 65536
2019-01-29 20:14:15.849: Fetch 65536
2019-01-29 20:14:15.864: Fetch 65536
2019-01-29 20:14:15.877: Fetch 65536
2019-01-29 20:14:15.891: Fetch 65536
2019-01-29 20:14:15.903: Fetch 65536
2019-01-29 20:14:15.917: Fetch 65536
2019-01-29 20:14:15.929: Fetch 65536
2019-01-29 20:14:15.943: Fetch 65536
2019-01-29 20:14:25.520: Fetch 65536
2019-01-29 20:14:25.558: Fetch 65536
2019-01-29 20:14:25.573: Fetch 65536
2019-01-29 20:14:25.593: Fetch 65536
2019-01-29 20:14:25.609: Fetch 65536
2019-01-29 20:14:25.622: Fetch 65536
2019-01-29 20:14:25.636: Fetch 65536
2019-01-29 20:14:25.665: Fetch 65536
2019-01-29 20:14:25.686: Fetch 65536
2019-01-29 20:14:25.704: Fetch 65536
2019-01-29 20:14:25.717: Fetch 65536
2019-01-29 20:14:25.730: Fetch 65536
2019-01-29 20:14:25.748: Fetch 65536
2019-01-29 20:14:25.763: Fetch 65536
2019-01-29 20:14:25.782: Fetch 65536
2019-01-29 20:14:25.800: Fetch 65536
2019-01-29 20:14:25.815: Fetch 65536
2019-01-29 20:14:25.832: Fetch 65536
2019-01-29 20:14:25.846: Fetch 65536
2019-01-29 20:14:25.859: Fetch 65536
2019-01-29 20:14:25.873: Fetch 65536
2019-01-29 20:14:25.887: Fetch 65536
2019-01-29 20:14:25.898: Fetch 65536
2019-01-29 20:14:25.913: Fetch 65536
2019-01-29 20:14:25.931: Fetch 65536
2019-01-29 20:14:25.951: Fetch 65536
2019-01-29 20:14:25.971: Fetch 65536
2019-01-29 20:14:25.991: Fetch 65536
2019-01-29 20:14:26.009: Fetch 65536
2019-01-29 20:14:26.028: Fetch 65536
2019-01-29 20:14:26.049: Fetch 65536
2019-01-29 20:14:26.062: Fetch 65536
2019-01-29 20:14:26.074: Fetch 65536
2019-01-29 20:14:26.087: Fetch 65536
2019-01-29 20:14:26.100: Fetch 65536
2019-01-29 20:14:26.123: Fetch 65536
2019-01-29 20:14:26.144: Fetch 65536
2019-01-29 20:14:26.160: Fetch 65536
2019-01-29 20:14:26.185: Fetch 65536
2019-01-29 20:14:26.204: Fetch 65536
2019-01-29 20:14:26.221: Fetch 65536
2019-01-29 20:14:26.236: Fetch 65536
2019-01-29 20:14:26.247: Fetch 65536
2019-01-29 20:14:26.260: Fetch 65536
2019-01-29 20:14:26.275: Fetch 65536
2019-01-29 20:14:26.289: Fetch 65536
2019-01-29 20:14:26.308: Fetch 65536
2019-01-29 20:14:26.326: Fetch 65536
2019-01-29 20:14:26.347: Fetch 65536
2019-01-29 20:14:26.367: Fetch 65536
2019-01-29 20:14:26.390: Fetch 65536
2019-01-29 20:14:37.424: Fetch 65536
2019-01-29 20:14:37.447: Fetch 65536
2019-01-29 20:14:37.462: Fetch 65536
2019-01-29 20:14:37.478: Fetch 65536
2019-01-29 20:14:37.496: Fetch 65536
2019-01-29 20:14:37.511: Fetch 65536
2019-01-29 20:14:37.525: Fetch 65536
2019-01-29 20:14:37.544: Fetch 65536
2019-01-29 20:14:37.560: Fetch 65536
2019-01-29 20:14:37.575: Fetch 65536
2019-01-29 20:14:37.587: Fetch 65536
2019-01-29 20:14:37.602: Fetch 65536
2019-01-29 20:14:37.621: Fetch 65536
2019-01-29 20:14:37.640: Fetch 65536
2019-01-29 20:14:37.660: Fetch 65536
2019-01-29 20:14:37.679: Fetch 65536
2019-01-29 20:14:37.696: Fetch 65536
2019-01-29 20:14:37.713: Fetch 65536
2019-01-29 20:14:37.734: Fetch 65536
2019-01-29 20:14:37.754: Fetch 65536
2019-01-29 20:14:37.772: Fetch 65536
2019-01-29 20:14:37.786: Fetch 65536
2019-01-29 20:14:37.802: Fetch 65536
2019-01-29 20:14:37.823: Fetch 65536
2019-01-29 20:14:37.842: Fetch 65536
2019-01-29 20:14:37.858: Fetch 65536
2019-01-29 20:14:37.875: Fetch 65536
2019-01-29 20:14:37.891: Fetch 65536
2019-01-29 20:14:37.905: Fetch 65536
2019-01-29 20:14:37.918: Fetch 65536
2019-01-29 20:14:37.933: Fetch 65536
2019-01-29 20:14:37.952: Fetch 65536
2019-01-29 20:14:37.968: Fetch 65536
2019-01-29 20:14:37.983: Fetch 65536
2019-01-29 20:14:37.997: Fetch 65536
2019-01-29 20:14:38.013: Fetch 65536
2019-01-29 20:14:38.028: Fetch 65536
2019-01-29 20:14:38.045: Fetch 65536
2019-01-29 20:14:38.061: Fetch 65536
2019-01-29 20:14:38.075: Fetch 65536
2019-01-29 20:14:38.087: Fetch 65536
2019-01-29 20:14:38.104: Fetch 65536
2019-01-29 20:14:38.118: Fetch 65536
2019-01-29 20:14:38.134: Fetch 65536
2019-01-29 20:14:38.150: Fetch 65536
2019-01-29 20:14:38.162: Fetch 65536
2019-01-29 20:14:50.775: Fetch 65536
2019-01-29 20:14:50.791: Fetch 65536
2019-01-29 20:14:50.804: Fetch 65536
2019-01-29 20:14:50.817: Fetch 65536
2019-01-29 20:14:50.830: Fetch 65536
2019-01-29 20:14:50.843: Fetch 65536
2019-01-29 20:14:50.860: Fetch 65536
2019-01-29 20:14:50.876: Fetch 65536
2019-01-29 20:14:50.894: Fetch 65536
2019-01-29 20:14:50.905: Fetch 65536
2019-01-29 20:14:50.918: Fetch 65536
2019-01-29 20:14:50.930: Fetch 65536
2019-01-29 20:14:50.944: Fetch 65536
2019-01-29 20:14:50.960: Fetch 65536
2019-01-29 20:14:50.978: Fetch 65536
2019-01-29 20:14:50.994: Fetch 65536
2019-01-29 20:14:51.003: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 46308345, m_contentLength = 46295618
2019-01-29 20:14:51.017: Fetch 65536
2019-01-29 20:14:51.031: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 46336578, m_contentLength = 46295618
2019-01-29 20:14:51.054: Fetch 65536
2019-01-29 20:14:51.079: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 46349305, m_contentLength = 46295618
2019-01-29 20:14:51.113: Fetch 65536
2019-01-29 20:14:51.153: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 46361154, m_contentLength = 46295618
2019-01-29 20:14:51.196: HttpURLConnection: Returning -1 (end of file)!2019-01-29 20:14:51:215  not enough data, calling setNextToCurrent, framesToRead = 286720
2019-01-29 20:14:51:215  after setNextToCurrent: current = 0xd1849200, m_next = 0x0
2019-01-29 20:14:51.228: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:14:51.664: HttpURLConnection: contentLength = 19188017 for Tidal
2019-01-29 20:14:51.695: Fetch 65536
2019-01-29 20:14:51.722: Fetch 335262
2019-01-29 20:14:51.748: Fetch 163840
2019-01-29 20:14:51.766: Fetch 89502
2019-01-29 20:14:51.782: Fetch 65536
2019-01-29 20:14:51.796: Fetch 40350
2019-01-29 20:14:51.848: Fetch 65536
2019-01-29 20:14:51.856: Fetch 65536
2019-01-29 20:14:51.863: Fetch 65536
2019-01-29 20:14:51.870: Fetch 65536
2019-01-29 20:14:51.882: Fetch 65536
2019-01-29 20:14:51.889: Fetch 65536
2019-01-29 20:14:51.896: Fetch 65536
2019-01-29 20:14:51.903: Fetch 65536
2019-01-29 20:14:51.911: Fetch 65536
2019-01-29 20:14:51.919: Fetch 65536
2019-01-29 20:14:51.928: Fetch 65536
2019-01-29 20:14:51.947: Fetch 65536
2019-01-29 20:14:51.962: Fetch 65536
2019-01-29 20:14:51.980: Fetch 65536
2019-01-29 20:14:51.994: Fetch 65536
2019-01-29 20:14:52.013: Fetch 65536
2019-01-29 20:14:52.034: Fetch 65536
2019-01-29 20:14:52.048: Fetch 65536
2019-01-29 20:14:52.065: Fetch 65536
2019-01-29 20:14:52.083: Fetch 65536
2019-01-29 20:14:52.103: Fetch 65536
2019-01-29 20:14:52.116: Fetch 65536
2019-01-29 20:14:52.126: Fetch 65536
2019-01-29 20:14:52.138: Fetch 65536
2019-01-29 20:14:52.158: Fetch 65536
2019-01-29 20:14:52.171: Fetch 65536
2019-01-29 20:14:52.187: Fetch 65536
2019-01-29 20:14:52.239: Fetch 65536
2019-01-29 20:14:52.268: Fetch 65536
2019-01-29 20:14:52.286: Fetch 65536
2019-01-29 20:14:52.312: Fetch 65536
2019-01-29 20:14:52.332: Fetch 65536
2019-01-29 20:14:52.343: Fetch 65536
2019-01-29 20:14:52.356: Fetch 65536
2019-01-29 20:15:01.182: Fetch 65536
2019-01-29 20:15:01.226: Fetch 65536
2019-01-29 20:15:01.275: Fetch 65536
2019-01-29 20:15:01.289: Fetch 65536
2019-01-29 20:15:01.303: Fetch 65536
2019-01-29 20:15:01.315: Fetch 65536
2019-01-29 20:15:01.340: Fetch 65536
2019-01-29 20:15:01.357: Fetch 65536
2019-01-29 20:15:01.377: Fetch 65536
2019-01-29 20:15:01.391: Fetch 65536
2019-01-29 20:15:01.405: Fetch 65536
2019-01-29 20:15:01.428: Fetch 65536
2019-01-29 20:15:01.442: Fetch 65536
2019-01-29 20:15:01.455: Fetch 65536
2019-01-29 20:15:01.466: Fetch 65536
2019-01-29 20:15:01.483: Fetch 65536
2019-01-29 20:15:01.496: Fetch 65536
2019-01-29 20:15:01.508: Fetch 65536
2019-01-29 20:15:01.523: Fetch 65536
2019-01-29 20:15:01.539: Fetch 65536
2019-01-29 20:15:01.555: Fetch 65536
2019-01-29 20:15:01.578: Fetch 65536
2019-01-29 20:15:01.601: Fetch 65536
2019-01-29 20:15:01.613: Fetch 65536
2019-01-29 20:15:01.635: Fetch 65536
2019-01-29 20:15:01.648: Fetch 65536
2019-01-29 20:15:01.663: Fetch 65536
2019-01-29 20:15:01.676: Fetch 65536
2019-01-29 20:15:01.690: Fetch 65536
2019-01-29 20:15:01.705: Fetch 65536
2019-01-29 20:15:01.721: Fetch 65536
2019-01-29 20:15:01.736: Fetch 65536
2019-01-29 20:15:01.752: Fetch 65536
2019-01-29 20:15:01.768: Fetch 65536
2019-01-29 20:15:01.788: Fetch 65536
2019-01-29 20:15:01.809: Fetch 65536
2019-01-29 20:15:01.832: Fetch 65536
2019-01-29 20:15:01.852: Fetch 65536
2019-01-29 20:15:01.863: Fetch 65536
2019-01-29 20:15:01.877: Fetch 65536
2019-01-29 20:15:01.892: Fetch 65536
2019-01-29 20:15:01.909: Fetch 65536
2019-01-29 20:15:01.924: Fetch 65536
2019-01-29 20:15:01.936: Fetch 65536
2019-01-29 20:15:01.950: Fetch 65536
2019-01-29 20:15:01.964: Fetch 65536
2019-01-29 20:15:01.987: Fetch 65536
2019-01-29 20:15:02.009: Fetch 65536
2019-01-29 20:15:02.022: Fetch 65536
2019-01-29 20:15:02.039: Fetch 65536
2019-01-29 20:15:02.056: Fetch 65536
2019-01-29 20:15:02.069: Fetch 65536
2019-01-29 20:15:02.080: Fetch 65536
2019-01-29 20:15:02.092: Fetch 65536
2019-01-29 20:15:02.112: Fetch 65536
2019-01-29 20:15:02.128: Fetch 65536
2019-01-29 20:15:02.153: Fetch 65536
2019-01-29 20:15:02.166: Fetch 65536
2019-01-29 20:15:02.179: Fetch 65536
2019-01-29 20:15:02.193: Fetch 65536
2019-01-29 20:15:02.211: Fetch 65536
2019-01-29 20:15:02.227: Fetch 655362019-01-29 20:15:07:84  FileQueue dump CB: switch required
2019-01-29 20:15:07:85  FileQueue dump: current = 0xd1849200, Tidal
2019-01-29 20:15:07:85  FileQueue dump: next    = 0x0,
2019-01-29 20:15:07:86  filldatacb: stopAndGo 0
2019-01-29 20:15:07.119: Open ASYNC: Slåttetrall: Springar Etter Gudmund Eide
2019-01-29 20:15:07.587: onPositiveResult, i_isNextPosition = true
2019-01-29 20:15:07.604: Message MESSAGE_TYPE_QUEUE_SONG
2019-01-29 20:15:07.614: HttpURLConnection: fetchDataForReal: m_HttpURLConnection == null, creating request, this = com.extreamsd.usbaudioplayershared.ESDHTTPClient@dd38ed6
2019-01-29 20:15:07.623: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:15:08.030: HttpURLConnection: contentLength = 15493606 for Tidal
2019-01-29 20:15:08.054: Fetch 65536
2019-01-29 20:15:08.068: Fetch 334684
2019-01-29 20:15:08.086: Fetch 233780
2019-01-29 20:15:08.100: Fetch 164276
2019-01-29 20:15:08.117: Fetch 81920
2019-01-29 20:15:08.133: Fetch 65536
2019-01-29 20:15:08.145: Fetch 65536
2019-01-29 20:15:08.208: Fetch 65536
2019-01-29 20:15:08.221: Fetch 65536
2019-01-29 20:15:08.237: Fetch 65536
2019-01-29 20:15:08.249: Fetch 65536
2019-01-29 20:15:08.259: Fetch 65536
2019-01-29 20:15:08.274: Fetch 65536
2019-01-29 20:15:08.286: Fetch 65536
2019-01-29 20:15:08.297: Fetch 65536
2019-01-29 20:15:08.307: Fetch 65536
2019-01-29 20:15:08.318: Fetch 65536
2019-01-29 20:15:08.330: Fetch 65536
2019-01-29 20:15:08.343: Fetch 65536
2019-01-29 20:15:08.361: Fetch 65536
2019-01-29 20:15:08.382: Fetch 65536
2019-01-29 20:15:08.396: Fetch 65536
2019-01-29 20:15:08.437: Fetch 65536
2019-01-29 20:15:08.446: Fetch 65536
2019-01-29 20:15:08.460: Fetch 65536
2019-01-29 20:15:08.474: Fetch 65536
2019-01-29 20:15:08.486: Fetch 65536
2019-01-29 20:15:08.499: Fetch 65536
2019-01-29 20:15:08.512: Fetch 65536
2019-01-29 20:15:08.524: Fetch 65536
2019-01-29 20:15:08.540: Fetch 65536
2019-01-29 20:15:08.554: Fetch 65536
2019-01-29 20:15:08.566: Fetch 65536
2019-01-29 20:15:08.584: Fetch 65536
2019-01-29 20:15:08.597: Fetch 65536
2019-01-29 20:15:08.612: Fetch 65536
2019-01-29 20:15:08.631: Fetch 65536
2019-01-29 20:15:08.641: Fetch 655362019-01-29 20:15:08:656  Current wasn't NULL, so setting next to Slåttetrall: Springar Etter Gudmund Eide = Tidal
2019-01-29 20:15:08:656  after setNextDataSource: current = 0xd1849200, m_next = 0xd1849e00
2019-01-29 20:15:08.665: Setting m_asyncInProgress to false in A
2019-01-29 20:15:14.553: Fetch 65536
2019-01-29 20:15:14.584: Fetch 65536
2019-01-29 20:15:14.599: Fetch 65536
2019-01-29 20:15:14.614: Fetch 65536
2019-01-29 20:15:14.631: Fetch 65536
2019-01-29 20:15:14.643: Fetch 65536
2019-01-29 20:15:14.665: Fetch 65536
2019-01-29 20:15:14.694: Fetch 65536
2019-01-29 20:15:14.705: Fetch 65536
2019-01-29 20:15:14.717: Fetch 65536
2019-01-29 20:15:14.735: Fetch 65536
2019-01-29 20:15:14.749: Fetch 65536
2019-01-29 20:15:14.763: Fetch 65536
2019-01-29 20:15:14.777: Fetch 65536
2019-01-29 20:15:14.793: Fetch 65536
2019-01-29 20:15:14.806: Fetch 65536
2019-01-29 20:15:14.818: Fetch 65536
2019-01-29 20:15:14.834: Fetch 65536
2019-01-29 20:15:14.854: Fetch 65536
2019-01-29 20:15:14.868: Fetch 65536
2019-01-29 20:15:14.899: Fetch 65536
2019-01-29 20:15:14.915: Fetch 65536
2019-01-29 20:15:14.934: Fetch 65536
2019-01-29 20:15:14.948: Fetch 65536
2019-01-29 20:15:14.960: Fetch 65536
2019-01-29 20:15:14.973: Fetch 65536
2019-01-29 20:15:14.985: Fetch 65536
2019-01-29 20:15:14.998: Fetch 65536
2019-01-29 20:15:15.012: Fetch 65536
2019-01-29 20:15:15.029: Fetch 65536
2019-01-29 20:15:15.040: Fetch 65536
2019-01-29 20:15:15.050: Fetch 65536
2019-01-29 20:15:15.061: Fetch 65536
2019-01-29 20:15:15.077: Fetch 65536
2019-01-29 20:15:15.096: Fetch 65536
2019-01-29 20:15:15.111: Fetch 65536
2019-01-29 20:15:15.128: Fetch 65536
2019-01-29 20:15:15.146: Fetch 65536
2019-01-29 20:15:15.173: Fetch 65536
2019-01-29 20:15:15.190: Fetch 65536
2019-01-29 20:15:15.206: Fetch 65536
2019-01-29 20:15:15.221: Fetch 65536
2019-01-29 20:15:15.236: Fetch 65536
2019-01-29 20:15:15.249: Fetch 65536
2019-01-29 20:15:15.259: Fetch 65536
2019-01-29 20:15:15.270: Fetch 65536
2019-01-29 20:15:15.287: Fetch 65536
2019-01-29 20:15:15.308: Fetch 65536
2019-01-29 20:15:15.322: Fetch 65536
2019-01-29 20:15:15.336: Fetch 65536
2019-01-29 20:15:15.355: Fetch 65536
2019-01-29 20:15:15.379: Fetch 65536
2019-01-29 20:15:15.392: Fetch 65536
2019-01-29 20:15:15.413: Fetch 65536
2019-01-29 20:15:15.437: Fetch 65536
2019-01-29 20:15:15.454: Fetch 65536
2019-01-29 20:15:15.471: Fetch 65536
2019-01-29 20:15:15.485: Fetch 65536
2019-01-29 20:15:15.500: Fetch 65536
2019-01-29 20:15:15.519: Fetch 65536
2019-01-29 20:15:15.533: Fetch 65536
2019-01-29 20:15:15.546: Fetch 65536
2019-01-29 20:15:15.564: Fetch 65536
2019-01-29 20:15:15.583: Fetch 65536
2019-01-29 20:15:15.597: Fetch 65536
2019-01-29 20:15:24.965: Fetch 65536
2019-01-29 20:15:25.010: Fetch 65536
2019-01-29 20:15:25.025: Fetch 65536
2019-01-29 20:15:25.038: Fetch 65536
2019-01-29 20:15:25.050: Fetch 65536
2019-01-29 20:15:25.092: Fetch 65536
2019-01-29 20:15:25.116: Fetch 65536
2019-01-29 20:15:25.128: Fetch 65536
2019-01-29 20:15:25.141: Fetch 65536
2019-01-29 20:15:25.156: Fetch 65536
2019-01-29 20:15:25.168: Fetch 65536
2019-01-29 20:15:25.181: Fetch 65536
2019-01-29 20:15:25.196: Fetch 65536
2019-01-29 20:15:25.214: Fetch 65536
2019-01-29 20:15:25.235: Fetch 65536
2019-01-29 20:15:25.260: Fetch 65536
2019-01-29 20:15:25.282: Fetch 65536
2019-01-29 20:15:25.296: Fetch 65536
2019-01-29 20:15:25.312: Fetch 65536
2019-01-29 20:15:25.330: Fetch 65536
2019-01-29 20:15:25.345: Fetch 65536
2019-01-29 20:15:25.362: Fetch 65536
2019-01-29 20:15:25.377: Fetch 65536
2019-01-29 20:15:25.392: Fetch 65536
2019-01-29 20:15:25.404: Fetch 65536
2019-01-29 20:15:25.417: Fetch 65536
2019-01-29 20:15:25.434: Fetch 65536
2019-01-29 20:15:25.451: Fetch 65536
2019-01-29 20:15:25.468: Fetch 65536
2019-01-29 20:15:25.479: Fetch 65536
2019-01-29 20:15:25.490: Fetch 65536
2019-01-29 20:15:25.503: Fetch 65536
2019-01-29 20:15:25.520: Fetch 65536
2019-01-29 20:15:25.534: Fetch 65536
2019-01-29 20:15:25.563: Fetch 65536
2019-01-29 20:15:25.577: Fetch 65536
2019-01-29 20:15:25.589: Fetch 65536
2019-01-29 20:15:25.609: Fetch 65536
2019-01-29 20:15:25.626: Fetch 65536
2019-01-29 20:15:25.642: Fetch 65536
2019-01-29 20:15:25.670: Fetch 65536
2019-01-29 20:15:25.691: Fetch 65536
2019-01-29 20:15:25.717: Fetch 65536
2019-01-29 20:15:25.749: Fetch 65536
2019-01-29 20:15:25.764: Fetch 65536
2019-01-29 20:15:25.780: Fetch 65536
2019-01-29 20:15:25.794: Fetch 65536
2019-01-29 20:15:25.809: Fetch 65536
2019-01-29 20:15:25.823: Fetch 65536
2019-01-29 20:15:25.836: Fetch 65536
2019-01-29 20:15:25.852: Fetch 65536
2019-01-29 20:15:25.873: Fetch 65536
2019-01-29 20:15:25.897: Fetch 65536
2019-01-29 20:15:25.926: Fetch 65536
2019-01-29 20:15:25.950: Fetch 65536
2019-01-29 20:15:25.971: Fetch 65536
2019-01-29 20:15:25.989: Fetch 65536
2019-01-29 20:15:26.001: Fetch 65536
2019-01-29 20:15:26.015: Fetch 65536
2019-01-29 20:15:26.028: Fetch 65536
2019-01-29 20:15:26.051: Fetch 65536
2019-01-29 20:15:26.064: Fetch 65536
2019-01-29 20:15:36.854: Fetch 65536
2019-01-29 20:15:36.866: Fetch 65536
2019-01-29 20:15:36.881: Fetch 65536
2019-01-29 20:15:36.897: Fetch 65536
2019-01-29 20:15:36.912: Fetch 65536
2019-01-29 20:15:36.924: Fetch 65536
2019-01-29 20:15:36.937: Fetch 65536
2019-01-29 20:15:36.949: Fetch 65536
2019-01-29 20:15:36.963: Fetch 65536
2019-01-29 20:15:36.993: Fetch 65536
2019-01-29 20:15:37.025: Fetch 65536
2019-01-29 20:15:37.040: Fetch 65536
2019-01-29 20:15:37.055: Fetch 65536
2019-01-29 20:15:37.069: Fetch 65536
2019-01-29 20:15:37.089: Fetch 65536
2019-01-29 20:15:37.100: Fetch 65536
2019-01-29 20:15:37.110: Fetch 65536
2019-01-29 20:15:37.124: Fetch 65536
2019-01-29 20:15:37.138: Fetch 65536
2019-01-29 20:15:37.158: Fetch 65536
2019-01-29 20:15:37.176: Fetch 65536
2019-01-29 20:15:37.195: Fetch 65536
2019-01-29 20:15:37.223: Fetch 65536
2019-01-29 20:15:37.236: Fetch 65536
2019-01-29 20:15:37.248: Fetch 65536
2019-01-29 20:15:37.261: Fetch 65536
2019-01-29 20:15:37.273: Fetch 65536
2019-01-29 20:15:37.285: Fetch 65536
2019-01-29 20:15:37.298: Fetch 65536
2019-01-29 20:15:37.317: Fetch 65536
2019-01-29 20:15:37.339: Fetch 65536
2019-01-29 20:15:37.356: Fetch 65536
2019-01-29 20:15:37.375: Fetch 65536
2019-01-29 20:15:37.397: Fetch 65536
2019-01-29 20:15:37.412: Fetch 65536
2019-01-29 20:15:37.430: Fetch 65536
2019-01-29 20:15:37.447: Fetch 65536
2019-01-29 20:15:37.461: Fetch 65536
2019-01-29 20:15:37.473: Fetch 65536
2019-01-29 20:15:37.486: Fetch 65536
2019-01-29 20:15:37.497: Fetch 65536
2019-01-29 20:15:37.509: Fetch 65536
2019-01-29 20:15:37.523: Fetch 65536
2019-01-29 20:15:37.536: Fetch 65536
2019-01-29 20:15:37.552: Fetch 65536
2019-01-29 20:15:37.570: Fetch 65536
2019-01-29 20:15:37.592: Fetch 65536
2019-01-29 20:15:37.603: Fetch 65536
2019-01-29 20:15:37.622: Fetch 65536
2019-01-29 20:15:37.641: Fetch 65536
2019-01-29 20:15:37.654: Fetch 65536
2019-01-29 20:15:37.670: Fetch 65536
2019-01-29 20:15:37.688: Fetch 65536
2019-01-29 20:15:37.700: Fetch 65536
2019-01-29 20:15:37.716: Fetch 65536
2019-01-29 20:15:37.729: Fetch 65536
2019-01-29 20:15:37.746: Fetch 65536
2019-01-29 20:15:37.762: Fetch 65536
2019-01-29 20:15:37.778: Fetch 65536
2019-01-29 20:15:37.795: Fetch 65536
2019-01-29 20:15:37.812: Fetch 65536
2019-01-29 20:15:37.833: Fetch 65536
2019-01-29 20:15:37.846: Fetch 65536
2019-01-29 20:15:37.859: Fetch 65536
2019-01-29 20:15:37.872: Fetch 65536
2019-01-29 20:15:48.724: Fetch 65536
2019-01-29 20:15:48.751: Fetch 65536
2019-01-29 20:15:48.765: Fetch 65536
2019-01-29 20:15:48.780: Fetch 65536
2019-01-29 20:15:48.796: Fetch 65536
2019-01-29 20:15:48.819: Fetch 65536
2019-01-29 20:15:48.831: Fetch 65536
2019-01-29 20:15:48.850: Fetch 65536
2019-01-29 20:15:48.863: Fetch 65536
2019-01-29 20:15:48.878: Fetch 65536
2019-01-29 20:15:48.892: Fetch 65536
2019-01-29 20:15:48.908: Fetch 65536
2019-01-29 20:15:48.935: Fetch 65536
2019-01-29 20:15:48.947: Fetch 65536
2019-01-29 20:15:48.966: Fetch 65536
2019-01-29 20:15:48.996: Fetch 65536
2019-01-29 20:15:49.013: Fetch 65536
2019-01-29 20:15:49.026: Fetch 65536
2019-01-29 20:15:49.040: Fetch 65536
2019-01-29 20:15:49.057: Fetch 65536
2019-01-29 20:15:49.068: Fetch 65536
2019-01-29 20:15:49.080: Fetch 65536
2019-01-29 20:15:49.102: Fetch 65536
2019-01-29 20:15:49.123: Fetch 65536
2019-01-29 20:15:49.138: Fetch 65536
2019-01-29 20:15:49.157: Fetch 65536
2019-01-29 20:15:49.186: Fetch 65536
2019-01-29 20:15:49.211: Fetch 65536
2019-01-29 20:15:49.229: Fetch 65536
2019-01-29 20:15:49.251: Fetch 65536
2019-01-29 20:15:49.264: Fetch 65536
2019-01-29 20:15:49.280: Fetch 65536
2019-01-29 20:15:49.295: Fetch 65536
2019-01-29 20:15:49.307: Fetch 65536
2019-01-29 20:15:49.319: Fetch 65536
2019-01-29 20:15:49.333: Fetch 65536
2019-01-29 20:15:49.347: Fetch 65536
2019-01-29 20:15:49.365: Fetch 65536
2019-01-29 20:15:49.379: Fetch 65536
2019-01-29 20:15:49.396: Fetch 65536
2019-01-29 20:15:49.416: Fetch 65536
2019-01-29 20:15:49.431: Fetch 65536
2019-01-29 20:15:49.444: Fetch 65536
2019-01-29 20:15:49.459: Fetch 65536
2019-01-29 20:15:49.473: Fetch 65536
2019-01-29 20:15:49.487: Fetch 65536
2019-01-29 20:15:49.505: Fetch 65536
2019-01-29 20:15:49.522: Fetch 65536
2019-01-29 20:15:49.543: Fetch 65536
2019-01-29 20:15:49.558: Fetch 65536
2019-01-29 20:15:49.574: Fetch 65536
2019-01-29 20:15:49.588: Fetch 65536
2019-01-29 20:15:49.600: Fetch 65536
2019-01-29 20:15:49.611: Fetch 65536
2019-01-29 20:15:49.629: Fetch 65536
2019-01-29 20:15:49.651: Fetch 65536
2019-01-29 20:15:49.665: Fetch 65536
2019-01-29 20:15:49.686: Fetch 65536
2019-01-29 20:15:49.711: Fetch 65536
2019-01-29 20:15:49.735: Fetch 65536
2019-01-29 20:15:49.746: Fetch 65536
2019-01-29 20:15:49.758: Fetch 65536
2019-01-29 20:15:49.779: Fetch 65536
2019-01-29 20:15:49.794: Fetch 65536
2019-01-29 20:15:49.807: Fetch 65536
2019-01-29 20:15:49.825: Fetch 65536
2019-01-29 20:16:00.645: Fetch 65536
2019-01-29 20:16:00.690: Fetch 65536
2019-01-29 20:16:00.707: Fetch 65536
2019-01-29 20:16:00.721: Fetch 65536
2019-01-29 20:16:00.734: Fetch 65536
2019-01-29 20:16:00.747: Fetch 65536
2019-01-29 20:16:00.760: Fetch 65536
2019-01-29 20:16:00.773: Fetch 65536
2019-01-29 20:16:00.787: Fetch 65536
2019-01-29 20:16:00.800: Fetch 65536
2019-01-29 20:16:00.814: Fetch 65536
2019-01-29 20:16:00.827: Fetch 65536
2019-01-29 20:16:00.840: Fetch 65536
2019-01-29 20:16:00.853: Fetch 65536
2019-01-29 20:16:00.868: Fetch 65536
2019-01-29 20:16:00.888: Fetch 65536
2019-01-29 20:16:00.900: Fetch 65536
2019-01-29 20:16:00.913: Fetch 65536
2019-01-29 20:16:00.929: Fetch 65536
2019-01-29 20:16:00.944: Fetch 65536
2019-01-29 20:16:00.963: Fetch 65536
2019-01-29 20:16:00.982: Fetch 65536
2019-01-29 20:16:01.004: Fetch 65536
2019-01-29 20:16:01.026: Fetch 65536
2019-01-29 20:16:01.038: Fetch 65536
2019-01-29 20:16:01.050: Fetch 65536
2019-01-29 20:16:01.065: Fetch 65536
2019-01-29 20:16:01.090: Fetch 65536
2019-01-29 20:16:01.106: Fetch 65536
2019-01-29 20:16:01.122: Fetch 65536
2019-01-29 20:16:01.135: Fetch 65536
2019-01-29 20:16:01.151: Fetch 65536
2019-01-29 20:16:01.168: Fetch 65536
2019-01-29 20:16:01.185: Fetch 65536
2019-01-29 20:16:01.203: Fetch 65536
2019-01-29 20:16:01.227: Fetch 65536
2019-01-29 20:16:01.251: Fetch 65536
2019-01-29 20:16:01.272: Fetch 65536
2019-01-29 20:16:01.285: Fetch 65536
2019-01-29 20:16:01.301: Fetch 65536
2019-01-29 20:16:01.314: Fetch 65536
2019-01-29 20:16:01.326: Fetch 65536
2019-01-29 20:16:01.339: Fetch 65536
2019-01-29 20:16:01.352: Fetch 65536
2019-01-29 20:16:01.364: Fetch 65536
2019-01-29 20:16:01.379: Fetch 65536
2019-01-29 20:16:01.399: Fetch 65536
2019-01-29 20:16:01.415: Fetch 65536
2019-01-29 20:16:01.428: Fetch 65536
2019-01-29 20:16:01.449: Fetch 65536
2019-01-29 20:16:01.465: Fetch 65536
2019-01-29 20:16:01.479: Fetch 65536
2019-01-29 20:16:01.490: Fetch 65536
2019-01-29 20:16:01.502: Fetch 65536
2019-01-29 20:16:01.514: Fetch 65536
2019-01-29 20:16:01.527: Fetch 65536
2019-01-29 20:16:01.541: Fetch 65536
2019-01-29 20:16:01.561: Fetch 65536
2019-01-29 20:16:01.574: Fetch 65536
2019-01-29 20:16:01.588: Fetch 65536
2019-01-29 20:16:01.604: Fetch 65536
2019-01-29 20:16:01.618: Fetch 65536
2019-01-29 20:16:01.637: Fetch 65536
2019-01-29 20:16:01.655: Fetch 65536
2019-01-29 20:16:01.667: Fetch 65536
2019-01-29 20:16:01.679: Fetch 65536
2019-01-29 20:16:13.996: Fetch 65536
2019-01-29 20:16:14.018: Fetch 65536
2019-01-29 20:16:14.029: Fetch 65536
2019-01-29 20:16:14.043: Fetch 65536
2019-01-29 20:16:14.064: Fetch 65536
2019-01-29 20:16:14.081: Fetch 65536
2019-01-29 20:16:14.099: Fetch 65536
2019-01-29 20:16:14.116: Fetch 65536
2019-01-29 20:16:14.128: Fetch 65536
2019-01-29 20:16:14.144: Fetch 65536
2019-01-29 20:16:14.159: Fetch 65536
2019-01-29 20:16:14.174: Fetch 65536
2019-01-29 20:16:14.192: Fetch 65536
2019-01-29 20:16:14.207: Fetch 65536
2019-01-29 20:16:14.234: Fetch 65536
2019-01-29 20:16:14.251: Fetch 65536
2019-01-29 20:16:14.262: Fetch 65536
2019-01-29 20:16:14.274: Fetch 65536
2019-01-29 20:16:14.288: Fetch 65536
2019-01-29 20:16:14.302: Fetch 65536
2019-01-29 20:16:14.315: Fetch 65536
2019-01-29 20:16:14.329: Fetch 65536
2019-01-29 20:16:14.349: Fetch 65536
2019-01-29 20:16:14.374: Fetch 65536
2019-01-29 20:16:14.390: Fetch 65536
2019-01-29 20:16:14.412: Fetch 65536
2019-01-29 20:16:14.428: Fetch 65536
2019-01-29 20:16:14.442: Fetch 65536
2019-01-29 20:16:14.456: Fetch 65536
2019-01-29 20:16:14.470: Fetch 65536
2019-01-29 20:16:14.487: Fetch 65536
2019-01-29 20:16:14.502: Fetch 65536
2019-01-29 20:16:14.519: Fetch 65536
2019-01-29 20:16:14.534: Fetch 65536
2019-01-29 20:16:14.547: Fetch 65536
2019-01-29 20:16:14.562: Fetch 65536
2019-01-29 20:16:14.582: Fetch 65536
2019-01-29 20:16:14.608: Fetch 65536
2019-01-29 20:16:14.632: Fetch 65536
2019-01-29 20:16:14.645: Fetch 65536
2019-01-29 20:16:14.661: Fetch 65536
2019-01-29 20:16:14.678: Fetch 65536
2019-01-29 20:16:14.695: Fetch 65536
2019-01-29 20:16:14.711: Fetch 65536
2019-01-29 20:16:14.727: Fetch 65536
2019-01-29 20:16:14.745: Fetch 65536
2019-01-29 20:16:14.758: Fetch 65536
2019-01-29 20:16:14.773: Fetch 65536
2019-01-29 20:16:14.785: Fetch 65536
2019-01-29 20:16:14.797: Fetch 65536
2019-01-29 20:16:14.815: Fetch 65536
2019-01-29 20:16:14.829: Fetch 65536
2019-01-29 20:16:14.850: Fetch 65536
2019-01-29 20:16:14.863: Fetch 65536
2019-01-29 20:16:14.878: Fetch 65536
2019-01-29 20:16:14.897: Fetch 65536
2019-01-29 20:16:14.918: Fetch 65536
2019-01-29 20:16:14.936: Fetch 65536
2019-01-29 20:16:14.948: Fetch 65536
2019-01-29 20:16:14.964: Fetch 65536
2019-01-29 20:16:14.984: Fetch 65536
2019-01-29 20:16:14.998: Fetch 65536
2019-01-29 20:16:15.015: Fetch 65536
2019-01-29 20:16:15.028: Fetch 65536
2019-01-29 20:16:15.042: Fetch 65536
2019-01-29 20:16:15.064: Fetch 65536
2019-01-29 20:16:15.082: Fetch 65536
2019-01-29 20:16:15.099: Fetch 65536
2019-01-29 20:16:24.402: Fetch 65536
2019-01-29 20:16:24.439: Fetch 65536
2019-01-29 20:16:24.452: Fetch 65536
2019-01-29 20:16:24.464: Fetch 65536
2019-01-29 20:16:24.477: Fetch 65536
2019-01-29 20:16:24.511: Fetch 65536
2019-01-29 20:16:24.529: Fetch 65536
2019-01-29 20:16:24.542: Fetch 65536
2019-01-29 20:16:24.556: Fetch 65536
2019-01-29 20:16:24.570: Fetch 65536
2019-01-29 20:16:24.582: Fetch 65536
2019-01-29 20:16:24.598: Fetch 65536
2019-01-29 20:16:24.621: Fetch 65536
2019-01-29 20:16:24.646: Fetch 65536
2019-01-29 20:16:24.668: Fetch 65536
2019-01-29 20:16:24.691: Fetch 65536
2019-01-29 20:16:24.703: Fetch 65536
2019-01-29 20:16:24.718: Fetch 65536
2019-01-29 20:16:24.733: Fetch 65536
2019-01-29 20:16:24.745: Fetch 65536
2019-01-29 20:16:24.766: Fetch 65536
2019-01-29 20:16:24.779: Fetch 65536
2019-01-29 20:16:24.796: Fetch 65536
2019-01-29 20:16:24.811: Fetch 65536
2019-01-29 20:16:24.824: Fetch 65536
2019-01-29 20:16:24.838: Fetch 65536
2019-01-29 20:16:24.852: Fetch 65536
2019-01-29 20:16:24.864: Fetch 65536
2019-01-29 20:16:24.881: Fetch 65536
2019-01-29 20:16:24.901: Fetch 65536
2019-01-29 20:16:24.915: Fetch 65536
2019-01-29 20:16:24.926: Fetch 65536
2019-01-29 20:16:24.945: Fetch 65536
2019-01-29 20:16:24.962: Fetch 65536
2019-01-29 20:16:24.975: Fetch 65536
2019-01-29 20:16:24.994: Fetch 65536
2019-01-29 20:16:25.020: Fetch 65536
2019-01-29 20:16:25.036: Fetch 65536
2019-01-29 20:16:25.052: Fetch 65536
2019-01-29 20:16:25.070: Fetch 65536
2019-01-29 20:16:25.086: Fetch 65536
2019-01-29 20:16:25.109: Fetch 65536
2019-01-29 20:16:25.123: Fetch 65536
2019-01-29 20:16:25.136: Fetch 65536
2019-01-29 20:16:25.149: Fetch 65536
2019-01-29 20:16:25.169: Fetch 65536
2019-01-29 20:16:25.183: Fetch 65536
2019-01-29 20:16:25.200: Fetch 65536
2019-01-29 20:16:25.227: Fetch 65536
2019-01-29 20:16:25.240: Fetch 65536
2019-01-29 20:16:25.253: Fetch 65536
2019-01-29 20:16:25.269: Fetch 65536
2019-01-29 20:16:25.281: Fetch 65536
2019-01-29 20:16:25.292: Fetch 65536
2019-01-29 20:16:25.303: Fetch 65536
2019-01-29 20:16:25.315: Fetch 65536
2019-01-29 20:16:25.327: Fetch 65536
2019-01-29 20:16:25.342: Fetch 65536
2019-01-29 20:16:25.358: Fetch 65536
2019-01-29 20:16:25.378: Fetch 65536
2019-01-29 20:16:25.398: Fetch 65536
2019-01-29 20:16:25.414: Fetch 65536
2019-01-29 20:16:25.426: Fetch 65536
2019-01-29 20:16:25.439: Fetch 65536
2019-01-29 20:16:25.450: Fetch 65536
2019-01-29 20:16:25.465: Fetch 65536
2019-01-29 20:16:25.479: Fetch 65536
2019-01-29 20:16:25.494: Fetch 65536
2019-01-29 20:16:25.510: Fetch 65536
2019-01-29 20:16:36.293: Fetch 65536
2019-01-29 20:16:36.308: Fetch 65536
2019-01-29 20:16:36.325: Fetch 65536
2019-01-29 20:16:36.339: Fetch 65536
2019-01-29 20:16:36.354: Fetch 65536
2019-01-29 20:16:36.368: Fetch 65536
2019-01-29 20:16:36.380: Fetch 65536
2019-01-29 20:16:36.392: Fetch 65536
2019-01-29 20:16:36.407: Fetch 65536
2019-01-29 20:16:36.423: Fetch 65536
2019-01-29 20:16:36.436: Fetch 65536
2019-01-29 20:16:36.447: Fetch 65536
2019-01-29 20:16:36.460: Fetch 65536
2019-01-29 20:16:36.474: Fetch 65536
2019-01-29 20:16:36.488: Fetch 65536
2019-01-29 20:16:36.502: Fetch 65536
2019-01-29 20:16:36.517: Fetch 65536
2019-01-29 20:16:36.528: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 19209721, m_contentLength = 19188017
2019-01-29 20:16:36.549: Fetch 65536
2019-01-29 20:16:36.563: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 19237169, m_contentLength = 19188017
2019-01-29 20:16:36.575: Fetch 65536
2019-01-29 20:16:36.584: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 19245361, m_contentLength = 19188017
2019-01-29 20:16:36.600: Fetch 65536
2019-01-29 20:16:36.618: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 19253553, m_contentLength = 19188017
2019-01-29 20:16:36.642: HttpURLConnection: Returning -1 (end of file)!2019-01-29 20:16:36:657  not enough data, calling setNextToCurrent, framesToRead = 319488
2019-01-29 20:16:36:658  after setNextToCurrent: current = 0xd1849e00, m_next = 0x0
2019-01-29 20:16:36.677: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:16:36.878: HttpURLConnection: contentLength = 15493606 for Tidal
2019-01-29 20:16:36.905: Fetch 65536
2019-01-29 20:16:36.917: Fetch 335211
2019-01-29 20:16:36.930: Fetch 163840
2019-01-29 20:16:36.947: Fetch 89451
2019-01-29 20:16:36.968: Fetch 65536
2019-01-29 20:16:36.978: Fetch 40299
2019-01-29 20:16:37.033: Fetch 65536
2019-01-29 20:16:37.042: Fetch 65536
2019-01-29 20:16:37.052: Fetch 65536
2019-01-29 20:16:37.065: Fetch 65536
2019-01-29 20:16:37.077: Fetch 65536
2019-01-29 20:16:37.086: Fetch 65536
2019-01-29 20:16:37.096: Fetch 65536
2019-01-29 20:16:37.121: Fetch 65536
2019-01-29 20:16:37.137: Fetch 65536
2019-01-29 20:16:37.155: Fetch 65536
2019-01-29 20:16:37.173: Fetch 65536
2019-01-29 20:16:37.184: Fetch 65536
2019-01-29 20:16:37.195: Fetch 65536
2019-01-29 20:16:37.206: Fetch 65536
2019-01-29 20:16:37.217: Fetch 65536
2019-01-29 20:16:37.226: Fetch 65536
2019-01-29 20:16:37.235: Fetch 65536
2019-01-29 20:16:37.244: Fetch 65536
2019-01-29 20:16:37.254: Fetch 65536
2019-01-29 20:16:37.266: Fetch 65536
2019-01-29 20:16:37.283: Fetch 65536
2019-01-29 20:16:37.298: Fetch 65536
2019-01-29 20:16:37.318: Fetch 65536
2019-01-29 20:16:37.337: Fetch 65536
2019-01-29 20:16:37.346: Fetch 65536
2019-01-29 20:16:37.358: Fetch 65536
2019-01-29 20:16:37.383: Fetch 65536
2019-01-29 20:16:37.400: Fetch 65536
2019-01-29 20:16:37.415: Fetch 65536
2019-01-29 20:16:37.428: Fetch 65536
2019-01-29 20:16:37.440: Fetch 65536
2019-01-29 20:16:37.450: Fetch 65536
2019-01-29 20:16:37.526: Fetch 65536
2019-01-29 20:16:37.552: Fetch 65536
2019-01-29 20:16:37.575: Fetch 65536
2019-01-29 20:16:37.594: Fetch 65536
2019-01-29 20:16:37.612: Fetch 65536
2019-01-29 20:16:37.629: Fetch 65536
2019-01-29 20:16:37.648: Fetch 65536
2019-01-29 20:16:37.665: Fetch 65536
2019-01-29 20:16:37.678: Fetch 65536
2019-01-29 20:16:37.690: Fetch 65536
2019-01-29 20:16:48.180: Fetch 65536
2019-01-29 20:16:48.199: Fetch 65536
2019-01-29 20:16:48.213: Fetch 65536
2019-01-29 20:16:48.226: Fetch 65536
2019-01-29 20:16:48.243: Fetch 65536
2019-01-29 20:16:48.262: Fetch 65536
2019-01-29 20:16:48.296: Fetch 65536
2019-01-29 20:16:48.310: Fetch 65536
2019-01-29 20:16:48.325: Fetch 65536
2019-01-29 20:16:48.342: Fetch 65536
2019-01-29 20:16:48.357: Fetch 65536
2019-01-29 20:16:48.376: Fetch 65536
2019-01-29 20:16:48.390: Fetch 65536
2019-01-29 20:16:48.412: Fetch 65536
2019-01-29 20:16:48.428: Fetch 65536
2019-01-29 20:16:48.444: Fetch 65536
2019-01-29 20:16:48.456: Fetch 65536
2019-01-29 20:16:48.466: Fetch 65536
2019-01-29 20:16:48.477: Fetch 65536
2019-01-29 20:16:48.494: Fetch 65536
2019-01-29 20:16:48.523: Fetch 65536
2019-01-29 20:16:48.546: Fetch 65536
2019-01-29 20:16:48.589: Fetch 65536
2019-01-29 20:16:48.602: Fetch 65536
2019-01-29 20:16:48.617: Fetch 65536
2019-01-29 20:16:48.630: Fetch 65536
2019-01-29 20:16:48.650: Fetch 65536
2019-01-29 20:16:48.664: Fetch 65536
2019-01-29 20:16:48.681: Fetch 65536
2019-01-29 20:16:48.695: Fetch 65536
2019-01-29 20:16:48.708: Fetch 65536
2019-01-29 20:16:48.721: Fetch 65536
2019-01-29 20:16:48.737: Fetch 65536
2019-01-29 20:16:48.750: Fetch 65536
2019-01-29 20:16:48.767: Fetch 65536
2019-01-29 20:16:48.782: Fetch 65536
2019-01-29 20:16:48.802: Fetch 65536
2019-01-29 20:16:48.823: Fetch 65536
2019-01-29 20:16:48.846: Fetch 65536
2019-01-29 20:16:48.868: Fetch 65536
2019-01-29 20:16:48.884: Fetch 65536
2019-01-29 20:16:48.905: Fetch 65536
2019-01-29 20:16:48.925: Fetch 65536
2019-01-29 20:16:48.939: Fetch 65536
2019-01-29 20:16:48.953: Fetch 65536
2019-01-29 20:16:48.968: Fetch 65536
2019-01-29 20:16:48.982: Fetch 65536
2019-01-29 20:16:49.003: Fetch 65536
2019-01-29 20:16:49.017: Fetch 65536
2019-01-29 20:16:49.041: Fetch 65536
2019-01-29 20:16:49.061: Fetch 65536
2019-01-29 20:16:49.079: Fetch 65536
2019-01-29 20:16:49.095: Fetch 65536
2019-01-29 20:16:49.107: Fetch 65536
2019-01-29 20:16:49.126: Fetch 65536
2019-01-29 20:16:49.146: Fetch 65536
2019-01-29 20:16:49.163: Fetch 65536
2019-01-29 20:16:49.178: Fetch 65536
2019-01-29 20:16:49.196: Fetch 655362019-01-29 20:16:54:92  FileQueue dump CB: switch required
2019-01-29 20:16:54:93  FileQueue dump: current = 0xd1849e00, Tidal
2019-01-29 20:16:54:94  FileQueue dump: next    = 0x0,
2019-01-29 20:16:54:94  filldatacb: stopAndGo 0
2019-01-29 20:16:54.131: Open ASYNC: Carter: Sonata For Violoncello And Piano - Moderato
2019-01-29 20:16:54.699: onPositiveResult, i_isNextPosition = true
2019-01-29 20:16:54.720: Message MESSAGE_TYPE_QUEUE_SONG
2019-01-29 20:16:54.729: HttpURLConnection: fetchDataForReal: m_HttpURLConnection == null, creating request, this = com.extreamsd.usbaudioplayershared.ESDHTTPClient@251c262
2019-01-29 20:16:54.736: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:16:54.908: HttpURLConnection: contentLength = 46687663 for Tidal
2019-01-29 20:16:54.935: Fetch 65536
2019-01-29 20:16:54.956: Fetch 335296
2019-01-29 20:16:54.971: Fetch 163840
2019-01-29 20:16:55.005: Fetch 92493
2019-01-29 20:16:55.023: Fetch 65536
2019-01-29 20:16:55.040: Fetch 65536
2019-01-29 20:16:55.094: Fetch 65536
2019-01-29 20:16:55.103: Fetch 65536
2019-01-29 20:16:55.116: Fetch 65536
2019-01-29 20:16:55.127: Fetch 65536
2019-01-29 20:16:55.135: Fetch 65536
2019-01-29 20:16:55.146: Fetch 65536
2019-01-29 20:16:55.156: Fetch 65536
2019-01-29 20:16:55.164: Fetch 65536
2019-01-29 20:16:55.172: Fetch 65536
2019-01-29 20:16:55.181: Fetch 65536
2019-01-29 20:16:55.188: Fetch 65536
2019-01-29 20:16:55.199: Fetch 65536
2019-01-29 20:16:55.211: Fetch 65536
2019-01-29 20:16:55.226: Fetch 65536
2019-01-29 20:16:55.244: Fetch 65536
2019-01-29 20:16:55.262: Fetch 65536
2019-01-29 20:16:55.276: Fetch 65536
2019-01-29 20:16:55.289: Fetch 65536
2019-01-29 20:16:55.306: Fetch 65536
2019-01-29 20:16:55.323: Fetch 65536
2019-01-29 20:16:55.334: Fetch 65536
2019-01-29 20:16:55.345: Fetch 65536
2019-01-29 20:16:55.360: Fetch 65536
2019-01-29 20:16:55.375: Fetch 65536
2019-01-29 20:16:55.395: Fetch 65536
2019-01-29 20:16:55.407: Fetch 655362019-01-29 20:16:55:422  Current wasn't NULL, so setting next to Carter: Sonata For Violoncello And Piano - Moderato = Tidal
2019-01-29 20:16:55:423  after setNextDataSource: current = 0xd1849e00, m_next = 0xd184f300
2019-01-29 20:16:55.430: Setting m_asyncInProgress to false in A
2019-01-29 20:17:00.076: Fetch 65536
2019-01-29 20:17:00.091: Fetch 65536
2019-01-29 20:17:00.104: Fetch 65536
2019-01-29 20:17:00.120: Fetch 65536
2019-01-29 20:17:00.136: Fetch 65536
2019-01-29 20:17:00.152: Fetch 65536
2019-01-29 20:17:00.174: Fetch 65536
2019-01-29 20:17:00.185: Fetch 65536
2019-01-29 20:17:00.200: Fetch 65536
2019-01-29 20:17:00.215: Fetch 65536
2019-01-29 20:17:00.227: Fetch 65536
2019-01-29 20:17:00.248: Fetch 65536
2019-01-29 20:17:00.272: Fetch 65536
2019-01-29 20:17:00.286: Fetch 65536
2019-01-29 20:17:00.313: Fetch 65536
2019-01-29 20:17:00.326: Fetch 65536
2019-01-29 20:17:00.337: Fetch 65536
2019-01-29 20:17:00.350: Fetch 65536
2019-01-29 20:17:00.361: Fetch 65536
2019-01-29 20:17:00.371: Fetch 65536
2019-01-29 20:17:00.382: Fetch 65536
2019-01-29 20:17:00.395: Fetch 65536
2019-01-29 20:17:00.410: Fetch 65536
2019-01-29 20:17:00.424: Fetch 65536
2019-01-29 20:17:00.440: Fetch 65536
2019-01-29 20:17:00.464: Fetch 65536
2019-01-29 20:17:00.485: Fetch 65536
2019-01-29 20:17:00.507: Fetch 65536
2019-01-29 20:17:00.525: Fetch 65536
2019-01-29 20:17:00.536: Fetch 65536
2019-01-29 20:17:00.547: Fetch 65536
2019-01-29 20:17:00.558: Fetch 65536
2019-01-29 20:17:00.569: Fetch 65536
2019-01-29 20:17:00.584: Fetch 65536
2019-01-29 20:17:00.602: Fetch 65536
2019-01-29 20:17:00.627: Fetch 65536
2019-01-29 20:17:00.650: Fetch 65536
2019-01-29 20:17:00.670: Fetch 65536
2019-01-29 20:17:00.700: Fetch 65536
2019-01-29 20:17:00.713: Fetch 65536
2019-01-29 20:17:00.731: Fetch 65536
2019-01-29 20:17:00.756: Fetch 65536
2019-01-29 20:17:00.776: Fetch 65536
2019-01-29 20:17:00.792: Fetch 65536
2019-01-29 20:17:00.807: Fetch 65536
2019-01-29 20:17:00.819: Fetch 65536
2019-01-29 20:17:00.831: Fetch 65536
2019-01-29 20:17:00.842: Fetch 65536
2019-01-29 20:17:00.855: Fetch 65536
2019-01-29 20:17:00.873: Fetch 65536
2019-01-29 20:17:00.892: Fetch 65536
2019-01-29 20:17:00.911: Fetch 65536
2019-01-29 20:17:00.923: Fetch 65536
2019-01-29 20:17:00.937: Fetch 65536
2019-01-29 20:17:00.950: Fetch 65536
2019-01-29 20:17:00.970: Fetch 65536
2019-01-29 20:17:00.985: Fetch 65536
2019-01-29 20:17:00.998: Fetch 65536
2019-01-29 20:17:01.012: Fetch 65536
2019-01-29 20:17:01.024: Fetch 65536
2019-01-29 20:17:11.954: Fetch 65536
2019-01-29 20:17:11.968: Fetch 65536
2019-01-29 20:17:11.982: Fetch 65536
2019-01-29 20:17:11.995: Fetch 65536
2019-01-29 20:17:12.010: Fetch 65536
2019-01-29 20:17:12.031: Fetch 65536
2019-01-29 20:17:12.063: Fetch 65536
2019-01-29 20:17:12.082: Fetch 65536
2019-01-29 20:17:12.097: Fetch 65536
2019-01-29 20:17:12.108: Fetch 65536
2019-01-29 20:17:12.126: Fetch 65536
2019-01-29 20:17:12.140: Fetch 65536
2019-01-29 20:17:12.152: Fetch 65536
2019-01-29 20:17:12.167: Fetch 65536
2019-01-29 20:17:12.190: Fetch 65536
2019-01-29 20:17:12.207: Fetch 65536
2019-01-29 20:17:12.221: Fetch 65536
2019-01-29 20:17:12.235: Fetch 65536
2019-01-29 20:17:12.245: Fetch 65536
2019-01-29 20:17:12.255: Fetch 65536
2019-01-29 20:17:12.267: Fetch 65536
2019-01-29 20:17:12.281: Fetch 65536
2019-01-29 20:17:12.302: Fetch 65536
2019-01-29 20:17:12.328: Fetch 65536
2019-01-29 20:17:12.342: Fetch 65536
2019-01-29 20:17:12.364: Fetch 65536
2019-01-29 20:17:12.375: Fetch 65536
2019-01-29 20:17:12.386: Fetch 65536
2019-01-29 20:17:12.406: Fetch 65536
2019-01-29 20:17:12.426: Fetch 65536
2019-01-29 20:17:12.440: Fetch 65536
2019-01-29 20:17:12.452: Fetch 65536
2019-01-29 20:17:12.464: Fetch 65536
2019-01-29 20:17:12.477: Fetch 65536
2019-01-29 20:17:12.491: Fetch 65536
2019-01-29 20:17:12.519: Fetch 65536
2019-01-29 20:17:12.530: Fetch 65536
2019-01-29 20:17:12.541: Fetch 65536
2019-01-29 20:17:12.555: Fetch 65536
2019-01-29 20:17:12.573: Fetch 65536
2019-01-29 20:17:12.588: Fetch 65536
2019-01-29 20:17:12.609: Fetch 65536
2019-01-29 20:17:12.645: Fetch 65536
2019-01-29 20:17:12.672: Fetch 65536
2019-01-29 20:17:12.685: Fetch 65536
2019-01-29 20:17:12.696: Fetch 65536
2019-01-29 20:17:12.706: Fetch 65536
2019-01-29 20:17:12.719: Fetch 65536
2019-01-29 20:17:12.731: Fetch 65536
2019-01-29 20:17:12.746: Fetch 65536
2019-01-29 20:17:12.760: Fetch 65536
2019-01-29 20:17:12.779: Fetch 65536
2019-01-29 20:17:12.795: Fetch 65536
2019-01-29 20:17:12.812: Fetch 65536
2019-01-29 20:17:12.824: Fetch 65536
2019-01-29 20:17:12.839: Fetch 65536
2019-01-29 20:17:12.855: Fetch 65536
2019-01-29 20:17:12.870: Fetch 65536
2019-01-29 20:17:12.888: Fetch 65536
2019-01-29 20:17:12.901: Fetch 65536
2019-01-29 20:17:12.934: Fetch 65536
2019-01-29 20:17:23.862: Fetch 65536
2019-01-29 20:17:23.899: Fetch 65536
2019-01-29 20:17:23.910: Fetch 65536
2019-01-29 20:17:23.925: Fetch 65536
2019-01-29 20:17:23.939: Fetch 65536
2019-01-29 20:17:23.954: Fetch 65536
2019-01-29 20:17:23.985: Fetch 65536
2019-01-29 20:17:23.997: Fetch 65536
2019-01-29 20:17:24.008: Fetch 65536
2019-01-29 20:17:24.021: Fetch 65536
2019-01-29 20:17:24.034: Fetch 65536
2019-01-29 20:17:24.056: Fetch 65536
2019-01-29 20:17:24.072: Fetch 65536
2019-01-29 20:17:24.084: Fetch 65536
2019-01-29 20:17:24.097: Fetch 65536
2019-01-29 20:17:24.110: Fetch 65536
2019-01-29 20:17:24.124: Fetch 65536
2019-01-29 20:17:24.146: Fetch 65536
2019-01-29 20:17:24.167: Fetch 65536
2019-01-29 20:17:24.186: Fetch 65536
2019-01-29 20:17:24.201: Fetch 65536
2019-01-29 20:17:24.217: Fetch 65536
2019-01-29 20:17:24.233: Fetch 65536
2019-01-29 20:17:24.252: Fetch 65536
2019-01-29 20:17:24.268: Fetch 65536
2019-01-29 20:17:24.280: Fetch 65536
2019-01-29 20:17:24.295: Fetch 65536
2019-01-29 20:17:24.309: Fetch 65536
2019-01-29 20:17:24.326: Fetch 65536
2019-01-29 20:17:24.345: Fetch 65536
2019-01-29 20:17:24.358: Fetch 65536
2019-01-29 20:17:24.373: Fetch 65536
2019-01-29 20:17:24.389: Fetch 65536
2019-01-29 20:17:24.406: Fetch 65536
2019-01-29 20:17:24.424: Fetch 65536
2019-01-29 20:17:24.449: Fetch 65536
2019-01-29 20:17:24.463: Fetch 65536
2019-01-29 20:17:24.478: Fetch 65536
2019-01-29 20:17:24.491: Fetch 65536
2019-01-29 20:17:24.506: Fetch 65536
2019-01-29 20:17:24.517: Fetch 65536
2019-01-29 20:17:24.532: Fetch 65536
2019-01-29 20:17:24.545: Fetch 65536
2019-01-29 20:17:24.557: Fetch 65536
2019-01-29 20:17:24.571: Fetch 65536
2019-01-29 20:17:24.593: Fetch 65536
2019-01-29 20:17:24.610: Fetch 65536
2019-01-29 20:17:24.625: Fetch 65536
2019-01-29 20:17:24.638: Fetch 65536
2019-01-29 20:17:24.649: Fetch 65536
2019-01-29 20:17:24.665: Fetch 65536
2019-01-29 20:17:24.679: Fetch 65536
2019-01-29 20:17:24.703: Fetch 65536
2019-01-29 20:17:24.722: Fetch 65536
2019-01-29 20:17:24.751: Fetch 65536
2019-01-29 20:17:24.773: Fetch 65536
2019-01-29 20:17:24.790: Fetch 65536
2019-01-29 20:17:24.802: Fetch 65536
2019-01-29 20:17:24.818: Fetch 65536
2019-01-29 20:17:24.840: Fetch 65536
2019-01-29 20:17:35.735: Fetch 65536
2019-01-29 20:17:35.747: Fetch 65536
2019-01-29 20:17:35.761: Fetch 65536
2019-01-29 20:17:35.775: Fetch 65536
2019-01-29 20:17:35.789: Fetch 65536
2019-01-29 20:17:35.841: Fetch 65536
2019-01-29 20:17:35.855: Fetch 65536
2019-01-29 20:17:35.869: Fetch 65536
2019-01-29 20:17:35.883: Fetch 65536
2019-01-29 20:17:35.896: Fetch 65536
2019-01-29 20:17:35.914: Fetch 65536
2019-01-29 20:17:35.932: Fetch 65536
2019-01-29 20:17:35.946: Fetch 65536
2019-01-29 20:17:35.961: Fetch 65536
2019-01-29 20:17:35.976: Fetch 65536
2019-01-29 20:17:35.988: Fetch 65536
2019-01-29 20:17:36.010: Fetch 65536
2019-01-29 20:17:36.027: Fetch 65536
2019-01-29 20:17:36.042: Fetch 65536
2019-01-29 20:17:36.058: Fetch 65536
2019-01-29 20:17:36.070: Fetch 65536
2019-01-29 20:17:36.082: Fetch 65536
2019-01-29 20:17:36.095: Fetch 65536
2019-01-29 20:17:36.106: Fetch 65536
2019-01-29 20:17:36.123: Fetch 65536
2019-01-29 20:17:36.138: Fetch 65536
2019-01-29 20:17:36.155: Fetch 65536
2019-01-29 20:17:36.168: Fetch 65536
2019-01-29 20:17:36.180: Fetch 65536
2019-01-29 20:17:36.207: Fetch 65536
2019-01-29 20:17:36.221: Fetch 65536
2019-01-29 20:17:36.235: Fetch 65536
2019-01-29 20:17:36.260: Fetch 65536
2019-01-29 20:17:36.280: Fetch 65536
2019-01-29 20:17:36.304: Fetch 65536
2019-01-29 20:17:36.323: Fetch 65536
2019-01-29 20:17:36.338: Fetch 65536
2019-01-29 20:17:36.352: Fetch 65536
2019-01-29 20:17:36.366: Fetch 65536
2019-01-29 20:17:36.378: Fetch 65536
2019-01-29 20:17:36.389: Fetch 65536
2019-01-29 20:17:36.401: Fetch 65536
2019-01-29 20:17:36.421: Fetch 65536
2019-01-29 20:17:36.441: Fetch 65536
2019-01-29 20:17:36.467: Fetch 65536
2019-01-29 20:17:36.494: Fetch 65536
2019-01-29 20:17:36.506: Fetch 65536
2019-01-29 20:17:36.526: Fetch 65536
2019-01-29 20:17:36.539: Fetch 65536
2019-01-29 20:17:36.553: Fetch 65536
2019-01-29 20:17:36.570: Fetch 65536
2019-01-29 20:17:36.586: Fetch 65536
2019-01-29 20:17:36.603: Fetch 65536
2019-01-29 20:17:36.615: Fetch 65536
2019-01-29 20:17:36.627: Fetch 65536
2019-01-29 20:17:36.640: Fetch 65536
2019-01-29 20:17:36.659: Fetch 65536
2019-01-29 20:17:36.687: Fetch 65536
2019-01-29 20:17:36.716: Fetch 65536
2019-01-29 20:17:36.744: Fetch 65536
2019-01-29 20:17:36.773: Fetch 65536
2019-01-29 20:17:36.795: Fetch 65536
2019-01-29 20:17:36.810: Fetch 65536
2019-01-29 20:17:36.828: Fetch 65536
2019-01-29 20:17:47.613: Fetch 65536
2019-01-29 20:17:47.626: Fetch 65536
2019-01-29 20:17:47.638: Fetch 65536
2019-01-29 20:17:47.651: Fetch 65536
2019-01-29 20:17:47.665: Fetch 65536
2019-01-29 20:17:47.681: Fetch 65536
2019-01-29 20:17:47.697: Fetch 65536
2019-01-29 20:17:47.714: Fetch 65536
2019-01-29 20:17:47.727: Fetch 65536
2019-01-29 20:17:47.739: Fetch 65536
2019-01-29 20:17:47.753: Fetch 65536
2019-01-29 20:17:47.765: Fetch 65536
2019-01-29 20:17:47.777: Fetch 65536
2019-01-29 20:17:47.790: Fetch 65536
2019-01-29 20:17:47.810: Fetch 65536
2019-01-29 20:17:47.827: Fetch 65536
2019-01-29 20:17:47.844: Fetch 65536
2019-01-29 20:17:47.859: Fetch 65536
2019-01-29 20:17:47.872: Fetch 65536
2019-01-29 20:17:47.886: Fetch 65536
2019-01-29 20:17:47.899: Fetch 65536
2019-01-29 20:17:47.917: Fetch 65536
2019-01-29 20:17:47.946: Fetch 65536
2019-01-29 20:17:47.966: Fetch 65536
2019-01-29 20:17:47.988: Fetch 65536
2019-01-29 20:17:48.007: Fetch 65536
2019-01-29 20:17:48.026: Fetch 65536
2019-01-29 20:17:48.062: Fetch 65536
2019-01-29 20:17:48.079: Fetch 65536
2019-01-29 20:17:48.092: Fetch 65536
2019-01-29 20:17:48.109: Fetch 65536
2019-01-29 20:17:48.126: Fetch 65536
2019-01-29 20:17:48.141: Fetch 65536
2019-01-29 20:17:48.156: Fetch 65536
2019-01-29 20:17:48.169: Fetch 65536
2019-01-29 20:17:48.184: Fetch 65536
2019-01-29 20:17:48.200: Fetch 65536
2019-01-29 20:17:48.228: Fetch 65536
2019-01-29 20:17:48.252: Fetch 65536
2019-01-29 20:17:48.265: Fetch 65536
2019-01-29 20:17:48.278: Fetch 65536
2019-01-29 20:17:48.294: Fetch 65536
2019-01-29 20:17:48.312: Fetch 65536
2019-01-29 20:17:48.325: Fetch 65536
2019-01-29 20:17:48.337: Fetch 65536
2019-01-29 20:17:48.354: Fetch 65536
2019-01-29 20:17:48.365: Fetch 65536
2019-01-29 20:17:48.383: Fetch 65536
2019-01-29 20:17:48.397: Fetch 65536
2019-01-29 20:17:48.412: Fetch 65536
2019-01-29 20:17:48.424: Fetch 65536
2019-01-29 20:17:48.436: Fetch 65536
2019-01-29 20:17:48.448: Fetch 65536
2019-01-29 20:17:48.467: Fetch 65536
2019-01-29 20:17:48.483: Fetch 65536
2019-01-29 20:17:48.502: Fetch 65536
2019-01-29 20:17:48.515: Fetch 65536
2019-01-29 20:18:00.991: Fetch 65536
2019-01-29 20:18:01.006: Fetch 65536
2019-01-29 20:18:01.022: Fetch 65536
2019-01-29 20:18:01.038: Fetch 65536
2019-01-29 20:18:01.052: Fetch 65536
2019-01-29 20:18:01.064: Fetch 65536
2019-01-29 20:18:01.079: Fetch 65536
2019-01-29 20:18:01.097: Fetch 65536
2019-01-29 20:18:01.121: Fetch 65536
2019-01-29 20:18:01.135: Fetch 65536
2019-01-29 20:18:01.162: Fetch 65536
2019-01-29 20:18:01.189: Fetch 65536
2019-01-29 20:18:01.216: Fetch 65536
2019-01-29 20:18:01.228: Fetch 65536
2019-01-29 20:18:01.240: Fetch 65536
2019-01-29 20:18:01.253: Fetch 65536
2019-01-29 20:18:01.269: Fetch 65536
2019-01-29 20:18:01.281: Fetch 65536
2019-01-29 20:18:01.299: Fetch 65536
2019-01-29 20:18:01.319: Fetch 65536
2019-01-29 20:18:01.336: Fetch 65536
2019-01-29 20:18:01.354: Fetch 65536
2019-01-29 20:18:01.371: Fetch 65536
2019-01-29 20:18:01.386: Fetch 65536
2019-01-29 20:18:01.400: Fetch 65536
2019-01-29 20:18:01.416: Fetch 65536
2019-01-29 20:18:01.433: Fetch 65536
2019-01-29 20:18:01.446: Fetch 65536
2019-01-29 20:18:01.460: Fetch 65536
2019-01-29 20:18:01.472: Fetch 65536
2019-01-29 20:18:01.485: Fetch 65536
2019-01-29 20:18:01.499: Fetch 65536
2019-01-29 20:18:01.516: Fetch 65536
2019-01-29 20:18:01.535: Fetch 65536
2019-01-29 20:18:01.551: Fetch 65536
2019-01-29 20:18:01.563: Fetch 65536
2019-01-29 20:18:01.576: Fetch 65536
2019-01-29 20:18:01.588: Fetch 65536
2019-01-29 20:18:01.605: Fetch 65536
2019-01-29 20:18:01.622: Fetch 65536
2019-01-29 20:18:01.636: Fetch 65536
2019-01-29 20:18:01.647: Fetch 65536
2019-01-29 20:18:01.659: Fetch 65536
2019-01-29 20:18:01.670: Fetch 65536
2019-01-29 20:18:01.685: Fetch 65536
2019-01-29 20:18:01.698: Fetch 65536
2019-01-29 20:18:01.713: Fetch 65536
2019-01-29 20:18:01.727: Fetch 65536
2019-01-29 20:18:01.741: Fetch 65536
2019-01-29 20:18:01.754: Fetch 65536
2019-01-29 20:18:01.766: Fetch 65536
2019-01-29 20:18:01.784: Fetch 65536
2019-01-29 20:18:01.799: Fetch 65536
2019-01-29 20:18:01.815: Fetch 65536
2019-01-29 20:18:01.825: Fetch 65536
2019-01-29 20:18:01.839: Fetch 65536
2019-01-29 20:18:11.399: Fetch 65536
2019-01-29 20:18:11.414: Fetch 65536
2019-01-29 20:18:11.426: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 15506929, m_contentLength = 15493606
2019-01-29 20:18:11.440: Fetch 65536
2019-01-29 20:18:11.451: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 15534566, m_contentLength = 15493606
2019-01-29 20:18:11.463: Fetch 65536
2019-01-29 20:18:11.482: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 15547889, m_contentLength = 15493606
2019-01-29 20:18:11.500: Fetch 65536
2019-01-29 20:18:11.518: HttpURLConnection: Request more bytes than available! i_size = 65536, m_totalBytesRead + i_size = 15559142, m_contentLength = 15493606
2019-01-29 20:18:11.536: HttpURLConnection: Returning -1 (end of file)!2019-01-29 20:18:11:548  not enough data, calling setNextToCurrent, framesToRead = 458752
2019-01-29 20:18:11:549  after setNextToCurrent: current = 0xd184f300, m_next = 0x0
2019-01-29 20:18:11.571: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:18:12.030: HttpURLConnection: contentLength = 46687663 for Tidal
2019-01-29 20:18:12.042: Fetch 65536
2019-01-29 20:18:12.055: Fetch 335296
2019-01-29 20:18:12.115: Fetch 252358
2019-01-29 20:18:12.137: Fetch 159686
2019-01-29 20:18:12.148: Fetch 81494
2019-01-29 20:18:12.156: Fetch 65536
2019-01-29 20:18:12.166: Fetch 42784
2019-01-29 20:18:12.225: Fetch 65536
2019-01-29 20:18:12.234: Fetch 65536
2019-01-29 20:18:12.244: Fetch 65536
2019-01-29 20:18:12.254: Fetch 65536
2019-01-29 20:18:12.272: Fetch 65536
2019-01-29 20:18:12.298: Fetch 65536
2019-01-29 20:18:12.311: Fetch 65536
2019-01-29 20:18:12.324: Fetch 65536
2019-01-29 20:18:12.335: Fetch 65536
2019-01-29 20:18:12.344: Fetch 65536
2019-01-29 20:18:12.353: Fetch 65536
2019-01-29 20:18:12.362: Fetch 65536
2019-01-29 20:18:12.371: Fetch 65536
2019-01-29 20:18:12.385: Fetch 65536
2019-01-29 20:18:12.397: Fetch 65536
2019-01-29 20:18:12.412: Fetch 65536
2019-01-29 20:18:12.431: Fetch 65536
2019-01-29 20:18:12.463: Fetch 65536
2019-01-29 20:18:12.475: Fetch 65536
2019-01-29 20:18:12.484: Fetch 65536
2019-01-29 20:18:12.494: Fetch 65536
2019-01-29 20:18:12.505: Fetch 65536
2019-01-29 20:18:12.517: Fetch 65536
2019-01-29 20:18:12.527: Fetch 65536
2019-01-29 20:18:12.541: Fetch 65536
2019-01-29 20:18:12.552: Fetch 65536
2019-01-29 20:18:12.564: Fetch 65536
2019-01-29 20:18:12.637: Fetch 65536
2019-01-29 20:18:12.659: Fetch 65536
2019-01-29 20:18:12.674: Fetch 65536
2019-01-29 20:18:12.693: Fetch 65536
2019-01-29 20:18:12.706: Fetch 65536
2019-01-29 20:18:12.720: Fetch 65536
2019-01-29 20:18:12.735: Fetch 65536
2019-01-29 20:18:12.745: Fetch 65536
2019-01-29 20:18:12.757: Fetch 65536
2019-01-29 20:18:12.774: Fetch 65536
2019-01-29 20:18:12.786: Fetch 65536
2019-01-29 20:18:12.800: Fetch 65536
2019-01-29 20:18:12.816: Fetch 65536
2019-01-29 20:18:12.827: Fetch 65536
2019-01-29 20:18:12.840: Fetch 65536
2019-01-29 20:18:12.856: Fetch 65536
2019-01-29 20:18:12.875: Fetch 65536
2019-01-29 20:18:12.890: Fetch 65536
2019-01-29 20:18:12.914: Fetch 65536
2019-01-29 20:18:12.926: Fetch 65536
2019-01-29 20:18:23.304: Fetch 65536
2019-01-29 20:18:23.340: Fetch 65536
2019-01-29 20:18:23.358: Fetch 65536
2019-01-29 20:18:23.372: Fetch 65536
2019-01-29 20:18:23.389: Fetch 65536
2019-01-29 20:18:23.407: Fetch 65536
2019-01-29 20:18:23.420: Fetch 65536
2019-01-29 20:18:23.437: Fetch 65536
2019-01-29 20:18:23.452: Fetch 65536
2019-01-29 20:18:23.465: Fetch 65536
2019-01-29 20:18:23.484: Fetch 65536
2019-01-29 20:18:23.494: Fetch 65536
2019-01-29 20:18:23.501: Fetch 65536
2019-01-29 20:18:23.506: Fetch 65536
2019-01-29 20:18:23.516: Fetch 65536
2019-01-29 20:18:23.524: Fetch 65536
2019-01-29 20:18:23.533: Fetch 65536
2019-01-29 20:18:23.566: Fetch 65536
2019-01-29 20:18:23.599: Fetch 65536
2019-01-29 20:18:23.622: Fetch 65536
2019-01-29 20:18:23.637: Fetch 65536
2019-01-29 20:18:23.654: Fetch 65536
2019-01-29 20:18:23.664: Fetch 65536
2019-01-29 20:18:23.678: Fetch 65536
2019-01-29 20:18:23.690: Fetch 65536
2019-01-29 20:18:23.707: Fetch 65536
2019-01-29 20:18:23.718: Fetch 65536
2019-01-29 20:18:23.729: Fetch 65536
2019-01-29 20:18:23.744: Fetch 65536
2019-01-29 20:18:23.755: Fetch 65536
2019-01-29 20:18:23.766: Fetch 65536
2019-01-29 20:18:23.776: Fetch 65536
2019-01-29 20:18:23.783: Fetch 65536
2019-01-29 20:18:23.790: Fetch 65536
2019-01-29 20:18:23.797: Fetch 65536
2019-01-29 20:18:23.802: Fetch 65536
2019-01-29 20:18:23.809: Fetch 65536
2019-01-29 20:18:23.816: Fetch 65536
2019-01-29 20:18:23.823: Fetch 65536
2019-01-29 20:18:23.829: Fetch 65536
2019-01-29 20:18:23.835: Fetch 65536
2019-01-29 20:18:23.843: Fetch 65536
2019-01-29 20:18:23.849: Fetch 65536
2019-01-29 20:18:23.856: Fetch 65536
2019-01-29 20:18:23.861: Fetch 65536
2019-01-29 20:18:23.867: Fetch 65536
2019-01-29 20:18:23.873: Fetch 65536
2019-01-29 20:18:23.879: Fetch 65536
2019-01-29 20:18:23.884: Fetch 65536
2019-01-29 20:18:23.890: Fetch 65536
2019-01-29 20:18:23.895: Fetch 65536
2019-01-29 20:18:23.901: Fetch 65536
2019-01-29 20:18:23.906: Fetch 65536
2019-01-29 20:18:23.912: Fetch 655362019-01-29 20:18:24:736  FileQueue dump CB: switch required
2019-01-29 20:18:24:737  FileQueue dump: current = 0xd184f300, Tidal
2019-01-29 20:18:24:738  FileQueue dump: next    = 0x0,
2019-01-29 20:18:24:738  filldatacb: stopAndGo 0
2019-01-29 20:18:24.763: Open ASYNC: Bartók: Sonata For Solo Violin - Fuga
2019-01-29 20:18:25.225: onPositiveResult, i_isNextPosition = true
2019-01-29 20:18:25.245: Message MESSAGE_TYPE_QUEUE_SONG
2019-01-29 20:18:25.261: HttpURLConnection: fetchDataForReal: m_HttpURLConnection == null, creating request, this = com.extreamsd.usbaudioplayershared.ESDHTTPClient@23863a3
2019-01-29 20:18:25.285: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:18:25.472: HttpURLConnection: contentLength = 45056509 for Tidal
2019-01-29 20:18:25.507: Fetch 65536
2019-01-29 20:18:25.534: Fetch 334689
2019-01-29 20:18:25.559: Fetch 219761
2019-01-29 20:18:25.603: Fetch 161841
2019-01-29 20:18:25.636: Fetch 79921
2019-01-29 20:18:25.656: Fetch 65536
2019-01-29 20:18:25.665: Fetch 65536
2019-01-29 20:18:25.752: Fetch 65536
2019-01-29 20:18:25.774: Fetch 65536
2019-01-29 20:18:25.786: Fetch 65536
2019-01-29 20:18:25.803: Fetch 65536
2019-01-29 20:18:25.812: Fetch 65536
2019-01-29 20:18:25.820: Fetch 65536
2019-01-29 20:18:25.829: Fetch 65536
2019-01-29 20:18:25.837: Fetch 65536
2019-01-29 20:18:25.847: Fetch 65536
2019-01-29 20:18:25.862: Fetch 65536
2019-01-29 20:18:25.874: Fetch 65536
2019-01-29 20:18:25.886: Fetch 65536
2019-01-29 20:18:25.911: Fetch 65536
2019-01-29 20:18:25.926: Fetch 65536
2019-01-29 20:18:25.941: Fetch 65536
2019-01-29 20:18:25.953: Fetch 65536
2019-01-29 20:18:25.967: Fetch 65536
2019-01-29 20:18:25.977: Fetch 65536
2019-01-29 20:18:25.986: Fetch 65536
2019-01-29 20:18:25.995: Fetch 65536
2019-01-29 20:18:26.007: Fetch 65536
2019-01-29 20:18:26.022: Fetch 65536
2019-01-29 20:18:26.031: Fetch 65536
2019-01-29 20:18:26.048: Fetch 65536
2019-01-29 20:18:26.067: Fetch 65536
2019-01-29 20:18:26.077: Fetch 65536
2019-01-29 20:18:26.088: Fetch 65536
2019-01-29 20:18:26.107: Fetch 655362019-01-29 20:18:26:126  Current wasn't NULL, so setting next to Bartók: Sonata For Solo Violin - Fuga = Tidal
2019-01-29 20:18:26:126  after setNextDataSource: current = 0xd184f300, m_next = 0xd184f100
2019-01-29 20:18:26.142: Setting m_asyncInProgress to false in A
2019-01-29 20:18:35.129: Fetch 65536
2019-01-29 20:18:35.137: Fetch 65536
2019-01-29 20:18:35.145: Fetch 65536
2019-01-29 20:18:35.152: Fetch 65536
2019-01-29 20:18:35.160: Fetch 65536
2019-01-29 20:18:35.168: Fetch 65536
2019-01-29 20:18:35.176: Fetch 65536
2019-01-29 20:18:35.181: Fetch 65536
2019-01-29 20:18:35.188: Fetch 65536
2019-01-29 20:18:35.194: Fetch 65536
2019-01-29 20:18:35.199: Fetch 65536
2019-01-29 20:18:35.212: Fetch 65536
2019-01-29 20:18:35.221: Fetch 65536
2019-01-29 20:18:35.228: Fetch 65536
2019-01-29 20:18:35.235: Fetch 65536
2019-01-29 20:18:35.243: Fetch 65536
2019-01-29 20:18:35.251: Fetch 65536
2019-01-29 20:18:35.259: Fetch 65536
2019-01-29 20:18:35.268: Fetch 65536
2019-01-29 20:18:35.275: Fetch 65536
2019-01-29 20:18:35.283: Fetch 65536
2019-01-29 20:18:35.290: Fetch 65536
2019-01-29 20:18:35.296: Fetch 65536
2019-01-29 20:18:35.307: Fetch 65536
2019-01-29 20:18:35.314: Fetch 65536
2019-01-29 20:18:35.321: Fetch 65536
2019-01-29 20:18:35.327: Fetch 65536
2019-01-29 20:18:35.334: Fetch 65536
2019-01-29 20:18:35.340: Fetch 65536
2019-01-29 20:18:35.346: Fetch 65536
2019-01-29 20:18:35.353: Fetch 65536
2019-01-29 20:18:35.359: Fetch 65536
2019-01-29 20:18:35.366: Fetch 65536
2019-01-29 20:18:35.373: Fetch 65536
2019-01-29 20:18:35.379: Fetch 65536
2019-01-29 20:18:35.386: Fetch 65536
2019-01-29 20:18:35.393: Fetch 65536
2019-01-29 20:18:35.400: Fetch 65536
2019-01-29 20:18:35.407: Fetch 65536
2019-01-29 20:18:35.414: Fetch 65536
2019-01-29 20:18:35.422: Fetch 65536
2019-01-29 20:18:35.428: Fetch 65536
2019-01-29 20:18:35.435: Fetch 65536
2019-01-29 20:18:35.445: Fetch 65536
2019-01-29 20:18:35.453: Fetch 65536
2019-01-29 20:18:35.464: Fetch 65536
2019-01-29 20:18:35.472: Fetch 65536
2019-01-29 20:18:35.479: Fetch 65536
2019-01-29 20:18:35.487: Fetch 65536
2019-01-29 20:18:35.495: Fetch 65536
2019-01-29 20:18:35.505: Fetch 65536
2019-01-29 20:18:35.512: Fetch 65536
2019-01-29 20:18:35.520: Fetch 65536
2019-01-29 20:18:35.529: Fetch 65536
2019-01-29 20:18:35.539: Fetch 65536
2019-01-29 20:18:35.549: Fetch 65536
2019-01-29 20:18:35.556: Fetch 65536
2019-01-29 20:18:36.706: Message MESSAGE_TYPE_STOP
2019-01-29 20:18:36.718: Stop2019-01-29 20:18:36:719   ===================> STOP <====================
2019-01-29 20:18:36.754: MediaService: onDestroy
2019-01-29 20:18:36.759: MediaService: onDestroy, player stop
2019-01-29 20:18:36.770: Remove media session
2019-01-29 20:18:36.779: MediaService: onDestroy, send exit
2019-01-29 20:18:36.794: Closing DB
2019-01-29 20:18:36.801: MediaService: END onDestroy
2019-01-29 20:18:36.928: onDestroy SSPA2019-01-29 20:18:37:316  ATN stopped
2019-01-29 20:18:37.324: Message MESSAGE_TYPE_STOP
2019-01-29 20:18:37.330: Message MESSAGE_TYPE_EXIT
2019-01-29 20:18:37.335: T: delete AS2019:01:29 20:18:37.336 DTOR AS
2019-01-29 20:18:37:336  libusb_exit!
2019:01:29 20:18:37.341 Deleting old device
2019:01:29 20:18:37.341 Deleted old device
2019-01-29 20:18:37:341  Deleting device in thread
2019-01-29 20:18:37.345: T: AS deleted2019:01:29 20:18:37.412 DTOR OD 0xe83cf540
2019:01:29 20:18:37.412 Send exit message to decode thread
2019-01-29 20:18:37:413  Deleting device done
2019-01-29 20:19:21.627: App: loading 3rd party libs
2019-01-29 20:19:21.660: Loaded
2019-01-29 20:19:21.675: SSPA oncreate
2019-01-29 20:19:21.722: MediaService onCreate com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:19:21.726: Start LG-H932
lge
joan
26
com.extreamsd.usbaudioplayerpro 5.0.7
2019-01-29 20:19:21.740: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c2019:01:29 20:19:21.755 CTOR AS
2019-01-29 20:19:21.819: Android driver = 12019:01:29 20:19:21.821 setOutputType 2
2019:01:29 20:19:21.821 new ATN
2019:01:29 20:19:21.822 CTOR ATN 0xe83cf400
2019-01-29 20:19:21.833: Logmethod = 1
2019-01-29 20:19:21.944: logFileName = /storage/emulated/0/UAPP/UAPP.txt, log to file = true
2019-01-29 20:19:21.950: Calling getUSBAudioDevices()getUSBAudioDevices
getDevices
No USB devices found
2019-01-29 20:19:21:953  USBAudioManager: Finding audio device for rooted devices: 0 USB devices
Devices to query = 0, hasClass2Vendor5401 = false
2019-01-29 20:19:21.984: loadPlayQueueInfo
2019-01-29 20:19:21.996: loadPlayQueueInfo done, diff = 8, counter = 19, i_queue.size = 19
2019-01-29 20:19:22.002: After reloadQueue
2019-01-29 20:19:22.013: #devices 4
2019-01-29 20:19:22.016: Output 0
2019-01-29 20:19:22.021:     ID = 1
2019-01-29 20:19:22.026:     Type = 1
2019-01-29 20:19:22.030:     Name = LG-H932
2019-01-29 20:19:22.034: #rates = 1
2019-01-29 20:19:22.038:     Rate = 48000
2019-01-29 20:19:22.042: Output 1
2019-01-29 20:19:22.046:     ID = 2
2019-01-29 20:19:22.050:     Type = 2
2019-01-29 20:19:22.054:     Name = LG-H932
2019-01-29 20:19:22.058: #rates = 1
2019-01-29 20:19:22.062:     Rate = 48000
2019-01-29 20:19:22.066: Output 2
2019-01-29 20:19:22.070:     ID = 22
2019-01-29 20:19:22.074:     Type = 4
2019-01-29 20:19:22.078:     Name = LG-H932
2019-01-29 20:19:22.082: #rates = 1
2019-01-29 20:19:22.086:     Rate = 48000
2019-01-29 20:19:22.090: Output 3
2019-01-29 20:19:22.094:     ID = 5
2019-01-29 20:19:22.097:     Type = 18
2019-01-29 20:19:22.101:     Name = LG-H932
2019-01-29 20:19:22.105: #rates = 2
2019-01-29 20:19:22.109:     Rate = 8000
2019-01-29 20:19:22.113:     Rate = 16000
2019-01-29 20:19:22.121: Service created
2019-01-29 20:19:22.125: onStartCommand
2019-01-29 20:19:22.134: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:19:22.197: Connectivity change, state = CONNECTED, type = VPN
2019-01-29 20:19:22.235: CT 772195341009, 949194403724, 2679720
2019-01-29 20:19:22.238: DT
2019-01-29 20:19:22.401: onStartCommand
2019-01-29 20:19:22.410: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:19:22.422: onStartCommand
2019-01-29 20:19:22.432: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:19:22.475: postReloadQueue, i_currentPos = 13374
2019-01-29 20:19:22.479: setting async in prog because setting two songs
2019-01-29 20:19:22.485: Open ASYNC: Carter: Sonata For Violoncello And Piano - Moderato
2019-01-29 20:19:22.765: onPositiveResult, i_isNextPosition = false
2019-01-29 20:19:22.773: Message MESSAGE_TYPE_QUEUE_SONG2019-01-29 20:19:22:774  Current was NULL, so current becomes Carter: Sonata For Violoncello And Piano - Moderato = Tidal
2019-01-29 20:19:22:774  after setNextDataSource: current = 0xd04e8400, m_next = 0x0
2019-01-29 20:19:22.778: Open ASYNC: Bartók: Sonata For Solo Violin - Fuga
2019-01-29 20:19:22.863: onPositiveResult, i_isNextPosition = true
2019-01-29 20:19:22.871: Message MESSAGE_TYPE_QUEUE_SONG2019-01-29 20:19:22:871  Current wasn't NULL, so setting next to Bartók: Sonata For Solo Violin - Fuga = Tidal
2019-01-29 20:19:22:871  after setNextDataSource: current = 0xd04e8400, m_next = 0xd04e8500
2019-01-29 20:19:22.875: Setting m_asyncInProgress to false in A
2019-01-29 20:19:24.308: onStartCommand
2019-01-29 20:19:24.338: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:19:25.782: onStartCommand
2019-01-29 20:19:25.806: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:19:25.834: onStartCommand
2019-01-29 20:19:25.858: startForeground com.extreamsd.usbaudioplayershared.MediaPlaybackService@d06646c
2019-01-29 20:19:27.266: setting async in prog because setting two songs
2019-01-29 20:19:27.266: Message MESSAGE_TYPE_STOP
2019-01-29 20:19:27.277: Message MESSAGE_TYPE_STOP
2019-01-29 20:19:27.277: Open ASYNC: Carter: Sonata For Violoncello And Piano - Moderato
2019-01-29 20:19:27.504: onPositiveResult, i_isNextPosition = false
2019-01-29 20:19:27.543: Message MESSAGE_TYPE_QUEUE_SONG2019-01-29 20:19:27:544  Current was NULL, so current becomes Carter: Sonata For Violoncello And Piano - Moderato = Tidal
2019-01-29 20:19:27:544  after setNextDataSource: current = 0xcfaaaf00, m_next = 0x0
2019-01-29 20:19:27.568: Open ASYNC: Bartók: Sonata For Solo Violin - Fuga
2019-01-29 20:19:27.569: Message MESSAGE_TYPE_START
2019-01-29 20:19:27.583: linkSpeed = 866 Mbps
2019-01-29 20:19:27.592: Restrict bg status = 32019:01:29 20:19:27.597 setOutputType 2
2019-01-29 20:19:27.606: HttpURLConnection: fetchDataForReal: m_HttpURLConnection == null, creating request, this = com.extreamsd.usbaudioplayershared.ESDHTTPClient@cb340be
2019-01-29 20:19:27.616: HttpURLConnection: Opening connection for Tidal, i_offset = 0
2019-01-29 20:19:27.650: onPositiveResult, i_isNextPosition = true
2019-01-29 20:19:27.838: HttpURLConnection: contentLength = 46687663 for Tidal
2019-01-29 20:19:27.847: Fetch 65536
2019-01-29 20:19:27.872: Fetch 335296
2019-01-29 20:19:27.914: Fetch 239192
2019-01-29 20:19:27.927: Fetch 116312
2019-01-29 20:19:27.942: Fetch 103080
2019-01-29 20:19:27.955: Fetch 65536
2019-01-29 20:19:27.964: Fetch 65536
2019-01-29 20:19:28.020: Fetch 65536
2019-01-29 20:19:28.044: Fetch 65536
2019-01-29 20:19:28.065: Fetch 65536
2019-01-29 20:19:28.077: Fetch 65536
2019-01-29 20:19:28.088: Fetch 65536
2019-01-29 20:19:28.100: Fetch 65536
2019-01-29 20:19:28.114: Fetch 65536
2019-01-29 20:19:28.134: Fetch 65536
2019-01-29 20:19:28.144: Fetch 65536
2019-01-29 20:19:28.155: Fetch 65536
2019-01-29 20:19:28.166: Fetch 65536
2019-01-29 20:19:28.183: Fetch 65536
2019-01-29 20:19:28.195: Fetch 65536
2019-01-29 20:19:28.206: Fetch 65536
2019-01-29 20:19:28.218: Fetch 65536
2019-01-29 20:19:28.230: Fetch 65536
2019-01-29 20:19:28.243: Fetch 65536
2019-01-29 20:19:28.260: Fetch 65536
2019-01-29 20:19:28.272: Fetch 65536
2019-01-29 20:19:28.287: Fetch 65536
2019-01-29 20:19:28.302: Fetch 65536
2019-01-29 20:19:28.313: Fetch 65536
2019-01-29 20:19:28.325: Fetch 65536
2019-01-29 20:19:28.337: Fetch 65536
2019-01-29 20:19:28.360: Fetch 65536
2019-01-29 20:19:28.373: Fetch 655362019-01-29 20:19:28:394  OutputDevice::preparePlayback, i_singleBufferSize = 131072, i_offsetMilliSeconds = 0, i_isWiredHeadsetOn = 1, i_upsampleMethod = 0
2019-01-29 20:19:28:395  setActualDeviceSampleRate: decoder rate = 44100
2019-01-29 20:19:28:395  setActualDeviceSampleRate: getNearestDeviceSampleRate = 44100
2019-01-29 20:19:28:395  Device rate becomes 44100
2019-01-29 20:19:28:395  m_diskBufferSizeFrames = 524288
2019-01-29 20:19:28.448: Fetch 65536
2019-01-29 20:19:28.456: Fetch 65536
2019-01-29 20:19:28.466: Fetch 65536
2019-01-29 20:19:28.478: Fetch 65536
2019-01-29 20:19:28.489: Fetch 65536
2019-01-29 20:19:28.501: Fetch 65536
2019-01-29 20:19:28.512: Fetch 65536
2019-01-29 20:19:28.523: Fetch 65536
2019-01-29 20:19:28.535: Fetch 65536
2019-01-29 20:19:28.555: Fetch 65536
2019-01-29 20:19:28.569: Fetch 65536
2019-01-29 20:19:28.585: Fetch 65536
2019-01-29 20:19:28.601: Fetch 65536
2019-01-29 20:19:28.613: Fetch 65536
2019-01-29 20:19:28.627: Fetch 65536
2019-01-29 20:19:28.649: Fetch 65536
2019-01-29 20:19:28.665: Fetch 65536
2019-01-29 20:19:28.679: Fetch 65536
2019-01-29 20:19:28.691: Fetch 65536
2019-01-29 20:19:28.706: Fetch 65536
2019-01-29 20:19:28.718: Fetch 65536
2019-01-29 20:19:28.733: Fetch 65536
2019-01-29 20:19:28.748: Fetch 65536
2019-01-29 20:19:28.760: Fetch 65536
2019-01-29 20:19:28.774: Fetch 65536
2019-01-29 20:19:28.789: Fetch 65536
2019-01-29 20:19:28.813: Fetch 65536
2019-01-29 20:19:28.834: Fetch 65536
2019-01-29 20:19:28.853: Fetch 65536
2019-01-29 20:19:28.865: Fetch 65536
2019-01-29 20:19:28.879: Fetch 65536
2019-01-29 20:19:28.894: Fetch 65536
2019-01-29 20:19:28.907: Fetch 65536
2019-01-29 20:19:28.920: Fetch 65536
2019-01-29 20:19:28.935: Fetch 65536
2019-01-29 20:19:28.947: Fetch 65536
2019-01-29 20:19:28.959: Fetch 65536
2019-01-29 20:19:28.972: Fetch 65536
2019-01-29 20:19:28.985: Fetch 65536
2019-01-29 20:19:29.000: Fetch 65536
2019-01-29 20:19:29.014: Fetch 65536
2019-01-29 20:19:29.028: Fetch 65536
2019-01-29 20:19:29.041: Fetch 65536
2019-01-29 20:19:29.054: Fetch 65536
2019-01-29 20:19:29.069: Fetch 65536
2019-01-29 20:19:29.082: Fetch 65536
2019-01-29 20:19:29.094: Fetch 65536
2019-01-29 20:19:29.109: Fetch 65536
2019-01-29 20:19:29.121: Fetch 65536
2019-01-29 20:19:29.134: Fetch 65536
2019-01-29 20:19:29.150: Fetch 65536
2019-01-29 20:19:29.164: Fetch 65536
2019-01-29 20:19:29.175: Fetch 65536
2019-01-29 20:19:29.191: Fetch 65536
2019-01-29 20:19:29.203: Fetch 65536
2019-01-29 20:19:29.218: Fetch 65536
2019-01-29 20:19:29.235: Fetch 65536
2019-01-29 20:19:29.249: Fetch 65536
2019-01-29 20:19:29.265: Fetch 65536
2019-01-29 20:19:29.277: Fetch 65536
2019-01-29 20:19:29.290: Fetch 65536
2019-01-29 20:19:29.306: Fetch 65536
2019-01-29 20:19:29.320: Fetch 65536
2019-01-29 20:19:29.341: Fetch 65536
2019-01-29 20:19:29.360: Fetch 65536
2019-01-29 20:19:29.382: Fetch 65536
2019-01-29 20:19:29.402: Fetch 65536
2019-01-29 20:19:29.420: Fetch 65536
2019-01-29 20:19:29.442: Fetch 65536
2019-01-29 20:19:29.480: Fetch 65536
2019-01-29 20:19:29.517: Fetch 65536
2019-01-29 20:19:29.538: Fetch 65536
2019-01-29 20:19:29.548: Fetch 65536
2019-01-29 20:19:29.562: Fetch 65536
2019-01-29 20:19:29.575: Fetch 65536
2019-01-29 20:19:29.587: Fetch 65536
2019-01-29 20:19:29.610: Fetch 65536
2019-01-29 20:19:29.622: Fetch 65536
2019-01-29 20:19:29.643: Fetch 65536
2019-01-29 20:19:29.657: Fetch 65536
2019-01-29 20:19:29.667: Fetch 655362019-01-29 20:19:29:671  createNewAudioTrack! m_sampleRate = 44100
2019-01-29 20:19:29:671  AudioTrackNative::init
2019-01-29 20:19:29:673  Creating AudioTrack
2019:01:29 20:19:29.673 prep ATN i_sampleRate = 44100, i_flags = 400000, i_format = 0, bufferSize = 131072
2019-01-29 20:19:29:674  V8, flags = 400001, format = 6
2019-01-29 20:19:29:705  bufferFrames = 131072 for sr 44100
2019-01-29 20:19:29.723: Play Android, HiRes = true2019-01-29 20:19:29:724  ATN start
2019-01-29 20:19:29.791: Message MESSAGE_TYPE_QUEUE_SONG2019-01-29 20:19:29:793  Current wasn't NULL, so setting next to Bartók: Sonata For Solo Violin - Fuga = Tidal
2019-01-29 20:19:29:793  after setNextDataSource: current = 0xcfaaaf00, m_next = 0xe2176900
2019-01-29 20:19:29.810: Setting m_asyncInProgress to false in A
2019-01-29 20:19:35.790: Message MESSAGE_TYPE_PAUSE2019-01-29 20:19:35:791   ===================> STOP <====================
2019-01-29 20:19:36:404  ATN stopped
2019-01-29 20:20:13.567: Focus change -2
2019-01-29 20:20:13.582: Pause due to focus loss transient
2019-01-29 20:20:33.700: Focus change 1
2019-01-29 20:21:58.635: onDestroy SSPA
2019-01-29 20:22:12.126: onStartCommand
2019-01-29 20:22:12.136: Message MESSAGE_TYPE_STOP
2019-01-29 20:22:12.141: MediaService: onDestroy
2019-01-29 20:22:12.149: MediaService: onDestroy, player stop
2019-01-29 20:22:12.159: Message MESSAGE_TYPE_STOP
2019-01-29 20:22:12.165: Remove media session
2019-01-29 20:22:12.173: MediaService: onDestroy, send exit
2019-01-29 20:22:12.180: Message MESSAGE_TYPE_EXIT
2019-01-29 20:22:12.186: T: delete AS
2019-01-29 20:22:12.186: Closing DB2019:01:29 20:22:12.187 DTOR AS
2019-01-29 20:22:12:187  libusb_exit!
2019:01:29 20:22:12.187 Deleting old device
2019:01:29 20:22:12.188 Deleted old device
2019-01-29 20:22:12:187  Deleting device in thread
2019:01:29 20:22:12.192 DTOR OD 0xe83cf400
2019:01:29 20:22:12.192 Send exit message to decode thread
2019-01-29 20:22:12.192: MediaService: END onDestroy
2019-01-29 20:22:12.192: T: AS deleted2019-01-29 20:22:12:194  Deleting device done
Thanks! Could you please use OkHttp to see if there is a difference? HTTPUrlConnection is known to glitch between tracks.
Jan 30, 2019 at 8:32 AM Post #2,392 of 6,408
I already tried that, as I am aware of your recommendation. As reported in my original post on this, OkHttp seems to be worse in this regard -- or at least not better. That's why I went back to HTTPUrlConnection.
Jan 30, 2019 at 10:06 AM Post #2,393 of 6,408
Ok, and what happens when you switch off the MQA flag in HiRes driver flags (such that all flags are cleared)? This would stream the same data, but the LG's MQA decoder wouldn't be active.
Jan 30, 2019 at 10:12 AM Post #2,394 of 6,408
I get the same glitches weather the flag is set or not.
Gary
Jan 30, 2019 at 10:18 AM Post #2,395 of 6,408
Interesting thought: Obviously LG's driver does some additional processing when the MQA flag is set, regardless of whether actual MQA data is streamed. I won't have time to do more testing myself until tomorrow, but I see that @Brava210 already reported his findings on this.
Edit: I should have added that all the testing I did yesterday (in that log) was on MQA tracks, because I've seen how higher bandwidth triggers more glitches. But they happen on 16/44 too. I'll focus on that in my next round of tests. Again, tomorrow.
Jan 30, 2019 at 10:21 AM Post #2,396 of 6,408
Thanks for all your findings. The more information, the better. Usually, I play low frequency sine waves to proof/find glitches, but I don't think Tidal serves any. :)
Jan 30, 2019 at 11:08 AM Post #2,397 of 6,408
LOL :grin:
You might be surprised: Try googling site:tidal.com "sine wave"
I'd recommend The Banner Saga from Reference Recordings to anybody who wants to test sub-base.
Jan 30, 2019 at 11:19 AM Post #2,398 of 6,408
My guess is it would require a firmware update, but that's not likely to happen. Android One phones are intended to be less expensive, and avoiding the costs of MQA licensing and approvals is one way to keep the retail price down.
Just to clarify, this issue is specific to the G7 One... The G7 thinQ should has full MQA support, right?
Jan 30, 2019 at 11:31 AM Post #2,399 of 6,408
Jan 30, 2019 at 11:45 AM Post #2,400 of 6,408
Just to note if anyone else was having the same issue...
Was having some problems with gapless playback streaming both Tidal and Qobuz via UAPP (wifi, LG G7 ThinQ, no external DAC). There were often slight clicks and timing offsets during track transitions.
Switching the HTTP client to OkHTTP appears to have solved the problem entirely.
