mrgo
- Jan 7, 2015
Hi Davy,
I have just switched from using Neutron to UAPP for use with the Chord Hugo as UAPP can play nice with Redbook to DSD.
Thanks for creating a very good player that produces amazing sound and it stable
Since switching from Neutron, I am trying to setup Playlists with UAPP which is not going well
Currently I use a Sunsung Note 4 as the transport and have multiple microsd cards loaded with Redbook (FLAC), DSD (DSF) and 24/88 - 24/192 (FLAC).
The issue centres from UAPP's use of the PLA format for playlist management. If I create a playlist and remove and replace the MicroSD then all playlist data disappears. I have tried adding an MU3 to the Notes playlist folder, it gets read and the information is displayed in UAPP as it may have been re-read as PLA. Upon the removal of the MicroSD card and reinsertion of the same card with the same path details to the Microsd, no playlist data is shown?
It would be very useful if UAPP could deal with M3u or M3u8 playlists, is this possible?
In addition when using DSD (Dsf) file with id3v2 tags I have no Metadata being pulled through as I do with FLAC tags (Album, Artist, etc.)
The addition of 'Genre' alongside 'Album' and 'Artist' would be very useful and would provide a better sorting solution for larger catalogues
Thanks again for all your efforts from a very happy user of a solid solution
Regards
Mark
Regards
Mark
