USB Audio Player PRO (UAPP): 24- and 32-bit playback, ubiquitous USB audio support for Android
post-11270109
Post #256 of 4,031
Davy Wentzler
Member of Trade: eXtream Software Development / Audio Evolution
Still hoping that UAPP will be able to ignore non-music files and be able to party shuffle a large directory and all subdirectories.
Just tell me which file extensions you would like to see ignored.
post-11270592
Post #257 of 4,031
Norway
Norway
We have a Geek Out here that just doesn't get recognized by Linux (the underlying operating system), which is a requirement before the app can even start opening the USB device. What model do you have? It's best to contact us by email at info AT audio-evolution.com.
DLNA might come, but first the main screen is being redesigned.
Thanks, I've got the 720 (and external power). I'll send an email instead.
post-11272984
Post #259 of 4,031
Davy Wentzler
  jpg, bmp, png, doc, txt, rtf,  pdf, nfo, ini, db, sfv, log, md5, ffp, m3u, m3u8, cue, accurip
Thanks. We added most of them in the version that has just been uploaded. Should be there in the next hours.
Reactions: Theogenes
post-11273046
Post #260 of 4,031
reddington
Hey Davy,
Are you guys considering changing the UI?
You wrote in an earlier post that you guys were doing something with the home screen.
post-11273139
Post #261 of 4,031
Davy Wentzler
Hey Davy,
Yes, it's being worked on. But unfortunately, if people talk about the UI, it's never clear if they mean just the looks or something else. So, if you can elaborate on what you want changed, this is your chance.
post-11273201
Post #262 of 4,031
reddington
Cosmetic changes will be good enough for me. Would prefer a minimalistic and clean UI possibly with customizable color schemes.
Feature wise would love to see album art lookup and auto id3 tagging implemented somewhere down the line. But can live without these just fine.
Functionalitywise the player performs brilliantly as it is
post-11273299
Post #263 of 4,031
Davy Wentzler
Thanks! I hope you will be pleased.
Reactions: reddington
post-11273866
Post #265 of 4,031
cat6man
  @Davy Wentzler
As a long time user of UAPP I'm very happy, thank you for a great product!
Only two things are missing for me to make this my one and only player:
1. Support for the Geek Out
2. DLNA support
Are there any plans to implement one or both of these in the near future?
My GeekOut works fine with UAPP on a Nexus 7 running lollipop (android 5.0)..........not sure why it didn't work with kitkat, but as soon as lollipop came out, the geek out was fine.
therefore, i don't know if this is a uapp issue or something in kitkat
post-11279529
Post #266 of 4,031
DanBa
  Is there a way to update UAPP so that could be remotely controlled from Sony SmartWatch like this?
"Moto 360 Champagne smartwatch using the built-in AndroidWare music control app" & UAPP
http://www.head-fi.org/t/633511/pictures-of-your-portable-rig-part-xvi/15435#post_11279432
post-11279582
Post #267 of 4,031
seeteeyou
Living encyclopedia of product accessories.
Oh no, Moto 360 can't support anything below Android 4.3 and that means no love for Sony Walkman F880 series, ZX1, and ZX2 in the near future. And then most likely we won't see Walkman running Android 4.3 with OMAP 4430 officially, hopefully someone could do a custom ROM with these files instead
http://oss.sony.net/Products/Linux/Audio/NW-F880.html
post-11285914
Post #268 of 4,031
Davy Wentzler
  Any possibility player could read CUE files so I dont have to split them up? I know this works no probs with audirvana on my macbook. cheers!
I am looking into it, but all information I find on the subject suggests that cue is just a small text file pointing to audio files somewhere else on disk. So I tried ImgBurn on Windows and indeed, it just creates a tiny text file with references to existing audio files. Do you really want this (which is kinda pointless since you can just select the folder with the audio files) or are there other types of cue files and if so, how can I make them for testing?
post-11286202
Post #269 of 4,031
Norway
Norway
Thanks for sharing this information, I'll try to upgrade to Lollipop when I get the time :wink:
post-11286815
Post #270 of 4,031
cat6man
don't forget to get a Y cable and power the geek out separately if your source device can't supply all the current the geek out needs.
Users Who Are Viewing This Thread (Users: 2, Guests: 8)
