wwyjoe
- Sep 19, 2005
Is there any way I can verify that the HiRes driver in UAPP is being used (instead of of Android driver) in Samsung S9+?
In other words, you can't actually hear the difference?The only true verification is capturing the audio output and doing frequency analysis. The next release of UAPP has support for the
Samsung S9+ (Qualcomm Snapdragon 845). If you have this variant and not the Exynos, all it should take is enabling the 'Direct' flag (and not any others) in the HiRes driver flags.
I know this isn't the place for this, and with all due respect, but if your hearing isn't enough proof, then what's the point?I didn't say that. It's just that I prefer proof.
I do use and love the app. I hopped on board in the days of USB audio recorder to enable external dacs to be used. I love the UI, and i love the fact that you've added cue sheet support, even though I remember I requested that a few years back and you said no .
@Davy Wentzler, on my Fiio X7 mark II, the play/pause and track control HW buttons do not work. The volume wheel works though. Any ideas?
Davy,The fix that was done a couple of releases ago for this problem (that never occurred on any of our devices including the Fiio X5iii, but seemed to happen for a lot of people using the exact same Android devices), was playing silence for half a second on the standard Android driver when starting the app. This would 'trick' Android into thinking that the app plays audio using the official audio path and made the buttons working. Why it is still not working for you, I don't know. I tried it a couple of days ago again in 4.2.5 on a Fiio X5iii and that still worked (but it always worked for me anyway). If you play using the Android driver, are the buttons working then?
Davy,
I switched to Android driver, then back to Hires. That fixed the issue. HW buttons are working again.
Not meaning to labour the point, but one may believe they hear benefits to sq with the HR driver, and measurements may confirm this, but re: blind testing, and well you know the rest.Hope I can try...
We need "scientific" data for testing/confirmation. Not all have sensitive ears. (And that is how products are made of right? Design/Testing) Hence "Capturing audio output and do frequency analysis".
You can hook up your smartphone to an audio interface/ADC unit and record its output. Analyze sound file thru a spectograph for example.
This is what I did a while back when UAPP did not have a Hires driver. To confirm that I was hearing more thru the built-in app of my LG V20 than UAPP, I made this little experiment more than a year ago.
LG built in music app:
Old UAPP (no Hires driver)
See the difference on the graphs? Why does the spectrograph of the built-in LG music app gave more? So was there something missing from UAPP that it fell short (tops only at 23k)? Therefore I/we were bugging Davy for it. Hence we have now the Hires Driver!
