Davy Wentzler
Member of Trade: eXtream Software Development / Audio Evolution
- Dec 18, 2012
I have the "Play Through Android" checkbox OFF, and "Use USB DAC" check box ON, but the app still plays music through my phone speakers even when no DAC is connected. How can I be sure that it is using my DAC when a DAC is connected?
Since the HiRes driver was introduced, there are lots of people using the app without a USB DAC, so we have reduced the warning messages regarding no presence of a USB DAC. When your DAC is connected, you can tell whether you are using the app's custom USB driver if it says 'USB audio initialized' on start-up and/or you are seeing 'USB DAC' in front of the actual sample rate display.
Otherwise, you'd see HiRes or Android.
