wolfetan44
- Mar 27, 2012
So does anyone know what Logitech/UE's support is like? Because it seems that my right earbud is producing more than the left. And I am using a Westone Cable if that matters.
Or are there things I can do to maybe fix it?
With all those armatures it wouldn't be hard for a driver to die on you if you've seen how those things are wired internally.
Theres nothing you can do to fix it, there isn't a way to take it apart and put it together again. I've only successfully broken one apart to mail the armatures to Fisher before.
A cable problem would only give you spotty sound, usually when there is a 30% decrease in volume, one of your armatures went out sadly =(
The alternative is to replace said pair of armatures in some custom reshells, or to get new ones entirely from UE/Logitech.
Yea its definatley a 30% decrease or 60% =( Im going to call them tomorrow see what I can find out. Have any of you dealt with their costumer support?
Uh yeah, basically they gave me 50% off their online catalog, which actually really sucks if you bought them for 99. They're listed at 399 on the website. They used to be 449 at debut.
Are you still within warranty? I was outside of warranty and the Super Fi 5 Pro that died was well out of production by the time they died.
Logitech customer service is sort of an upgrade to the old UE service in my opinion.
For what it's worth, I ordered this 3.5mm metal TRRS plug from ShowMeCables:
The metal casing and strain relief were the winners. Now to resuscitate my soldering skills...
I bought them for $99. Yea its still well within its warranty. It ends in November.
Thanks for the feedback. Sorry that they're a little more microphonic. We're getting new stranded silver plated copper soon, contact me when those land maybe I can swap for you if the microphonics are worse than you'd wish to deal with.
The harshness and slight tinny sound is a characteristic of fresh cables. Once they get "vine-ripened" on your IEM's for a week or so you'll notice a difference.
As of half a year ago, I didn't believe in cables or burn-in. It's becoming evident that I'm more wrong than right these days about audio.
Again, thanks for the support, it's what keeps us going.
I forgot if you had to mail in your old units but you can more or less get it done in like a week's time. It's a quick phone call to India and then you'll have your replacements buddy.
Someone just called me trying to upgrade his cable but I had to tell him the sad news that his IEM volume was low just like yours, problem is that he was outside warranty because his were reshelled. =/
It's ok I sent him over to Sound Earphones to buy some Earsonics SM3v2's.
Thanks for the info, Chris. I'll definitely be interested in the silver plated copper if I don't get used to the microphonics. And I haven't quite burnt in the cables yet, so hopefully the harshness will go away a bit. Don't really believe in burn-in either, but I've clearly been wrong before.
so its really easy to get a new pair?I forgot if you had to mail in your old units but you can more or less get it done in like a week's time. It's a quick phone call to India and then you'll have your replacements buddy.
I posted earlier that the outer molding of my 3-year old TF-10s had come unglued and then lost while traveling. I contacted Logitech customer support (they now own the universal fit part of UE and the custom fit portion is a different company) and they told me that they could not send me a replacement part or repair my IEMs. I pointed out that this was a $400 product and that their lack of support was very disturbing for what I consider to be a "high end" product. After a bunch of wrangling, they said they'd give me a 50% discount. I didn't think that was great, but I was willing to do it, but then the 50% discount EXCLUDED UE products!!! What good would that do me? I don't want a 50% discount on some crappy keyboard or computer mouse.
Anyway, they wouldn't budge. I'd recommend against buying the high end, universal fit IEMs from Logitech. They provide a two-year warranty, but have no clue about how to support their customers longer term.
