Hmmm...this Toucan is really tempting. Was pretty set on the P-51....now all the buzz around this little amp has me rethinking.
RIDE
RIDE
I think I've missed this so far....can the PB1 also take in SE and output balanced like the Protector?
Also, can the boomslang output SE? If not, would an adapter cable return the boomslang's output balanced signal to SE if needed for other SE equipment? I'm just wondering if it can act as a SE DAC and possibly replace the DAC function of the D10 for folks who have not jumped completely into balanced yet.
Â
Although the Boomslang DAC only has a balanced output, it can provide a SE output by simply making up an output cable using the Hirose balanced connector on the DAC end with a standard TRG plug that ties both grounds together with R+ going to ring and L- going to tip on the amp end of the pigtail.
Â
This will enable the Boomslang to serve as an "all-purpose" DAC for desktop as well as portable use and for both SE and balanced applications.
Â
I mean those are all DAC/amp combos? I can't really speculate too much now as the boomslang(the ibasso balanced DAC) is not yet released.
Wouldn't it be L+ (pin 5) to tip R+ (pin 2) to ring and L-,R-,Ground(s) all to shield for a TRS plug? Well Possibly just grounds to ground (pins 1 + 4) but I am not sure why I thought you bridged - and Ground ->unbalanced ground for balanced Mics -> SE plugs anyhow. Regardless I just want to be sure I am not confused about your L- to tip.
Also not really important but wouldn't your wallet not getting heavier imply your income is stagnant/you want to spend money you aren't making sooner. Also your wallet busting apart at the seams would seem to indicate to me you are rolling in the dough! Too much for your wallet. Just saying...
Â
Do you know which DAC chip it uses and how many?
A word of caution: Be gentle with the gain switches on the back of the Toucan. I would avoid using them at all, if possible. I switched them only a couple times before the two on the right broke off. iBasso told me that they have not seen this problem before and that I was probably using something too hard to switch them. The only thing I could fit in that tiny space, though, was a paper clip. I was a little worried to begin with because they looked fragile, but they felt solid enough the first time I moved them. Hopefully others won't have the same problem, but I feel this design could be improved. I don't see the need for four tiny switches over one larger, sturdier one. Who is going to change the gain on the + and - or left and right individually?
