Will do, should be in sometime next week.
Got the NX7 this week. Initial impressions from my limited perspective is this is definitely value added to my Shanling M6 Pro 21 DAP as this amp has LOTS of gain!
Took some quick impression notes:
Sound--
AMPLIFIES! Note that all of my observations are on Hi-Gain (+14db) setting even though you could probably run the amp at Mid-Gain (+0db) and still enjoy it and get some more nuance and travel time out of the volume pot. Didn't test Low-Gain (-14db). Anyway, connected to the Shanling's line-out, it's like an X-ray into a musical production. Where the Shanling amp is fairly powerful and resolving, the 1.4W output of the NX7 leaves no prisoners. If a recording/production is well done (
Jacob Collier Djesse Vol. 1 -"Ocean Wide, Canyon Deep"--astounding dynamic range and impact, very low noise floor... or
A Winged Victory For The Sullen -"So That The City Can Begin To Exist"-powerful bass and moments of percussive high sound pressure level that the NX7 just eats up) you'll hear it
. These latter both sound wow-amazing relative to what I've been used to portably which was already very good just out of the M6's balanced 4.4mm on Turbo Gain. Conclusion--NX7's Hi-Gain is
STRONG amplification and is ideal in many situations but you can also go Mid-Gain and get a reasonably powerful output but a mellower experience.
Synergy--I have a limited array of cans/IEMs so here goes:
Drop/HiFiMan HE-X4: THIS is the answer I've been looking for for these cans. The Shanling was pretty good but the NX7 finally gives them what they need: Bass is now significantly more impactful and, for lack of a better word, these cans are now BALLZY with volume, like planars are supposed to be, and
not lacking in impact with higher energy music-- Steve Vai, Eric Johnson, Return to Forever and the like all had a new excitement. It reminded me of my earlier days listening to stuff just thrown on a turntable with a Pioneer receiver and cranked up into a set of JBLs, you know, the joy of music without regard for audiophile musings, etc. Yet even acoustic stuff is great and the bright light of higher current into these very current hungry cans makes everything better because they're getting what they need!
7Hz Timeless--Was surprised how much the power of the NX7 brought these fantastic IEMs out of their shell, so to speak. This combination of amp and IEM, for me, was the best of all the listening experiences in my limited array of headphones. All of the best aspects of the Timeless, the bass, soundstage, mids, highs, etc, just the wonderful sort of inexplicable goodness of the Timeless, is much more apparent. I just about could not take them out of my ears it was so great!
Senn HD-6XX w/Custom Cans mod-- Big improvement over the Shanling--you can tell the higher current into these 300 Ohm cans does them more justice. At this point though I have just not spent that much time with the Senns as with the HE-X4's and Timeless, but after I give them a good run through I'll probably edit this post with my findings.
SIVGA SV021--Although these headphones are very sensitive and don't technically need high current they really scale up with it and with the NX7 they do really well. Probably best suited to mid-gain but on hi-gain they sounded even better than ever. Due to their mid-bass bloom you have to cut the volume back but, again, they do the best on mid (+0db) gain with the Topping.
Charging Stuff--
1. From being totally discharged, the NX7 takes about 5 hours to fully charge (goes from blinking red to steady red light). The rating on the units charging input is 5V/1.2A and I was charging it with a standard 5V/2A brick. The consensus with charging portable stuff is that devices will only take as much charge as they need (in this case 1.2A) so there should not be an issue with any type of damage as long as your brick is 5V. This charging time is similar to my Topping NX4DSD (it takes a while) so maybe its charging circuit is also below 2A.
2. When fully charged and on the Hi-Gain setting my NX7 stayed on and charged for about 10-11 hours while playing music off and on intermittently. In a real world scenario for me, I usually have about a 1-2 hour session and shut off the music, so I'd probably get at least a few days of normal usage on it before needing to recharge. When it's within an hour of total discharge (on Hi-Gain setting) the green light blinks (this light looks more yellow to me) and you've got about an hour left. If you're on low or medium gain, the instructions say about 1-2 hours left.
Conclusion--For $200USD/+- this amp is a no brainer. I was looking for a relatively inexpensive way to enhance my DAP/portable experience, especially with planars and HD-6XX. If you're looking for a more high-energy, impactful and enjoyable listening session from your average DAP in line-out mode, I think it's a great choice. Overall the sound is clean, strong, uncolored,
excellent bass and excellent highs. Soundstage is good; it seems to resolve whatever the original production warrants, nothing extra added. This amp is not, how do you put it? Refined...? And I don't mean that in a negative way--it just amplifies whatever the source is giving it, nothing added or removed. One observation, and not really a criticism per se but, as I said earlier, on high gain you can hear any sort of tape hiss or production artifact, amp hum, etc., more than on lower gain. Not a big deal but the NX7's resolution, lack of distortion and flat frequency response just doesn't hide anything, including any shortcomings of your sources, from recording production to your own DAP/source. Note: Just about all of my observations have been on the Hi-Gain setting so Mid-Gain is going to be a little different story. Regarding the volume when on Hi-Gain, I almost never wanted to put the volume pot much past 12 o'clock as I value my remaining hearing!
Playlist:
1. Steve Vai: "Juice" from
Alien Love Secrets
2. Return To Forever "Majestic Dance" from
The Anthology
3
. Milton Nascimento "Don Quixote" from
Miltons
4. Eric Johnson "Shape I'm In (Live)" from
Eric Johnson & Alien Love Child, Live and Beyond
5. Mark Isham "And Miles To Go... Before He Sleeps" from
Pure
6. Michael Hedges "The First Cutting" from
Taproot
7. Keith Jarret Trio "You and the Night and the Music" from
Still Live
8. Ralph Towner "Mevlana Etude" from
Blue Sun
9. Chicago "Beginnings" from
Chicago Transit Authority (2002 Remaster)
10. Jacob Collier "Ocean Wide, Canyon Deep" from
Djesse Vol. 1
11. A Winged Victory For The Sullen
"So That The City Can Begin To Exist" from
Invisible Cities
