@dweaver
You're making sense, but my criteria tends to be more simple (or simplistic, depending on who you ask.)
I care about one thing: fidelity--can the phones accurately represent the recorded performance, or can they be made to accurately represent it.
The perfect phones are flawlessly accurate, without adjustment. The phones I call top-tier take minor adjustments. The more I need to fix, the more mediocre the phones are.
Hence, my problem with the Golds. To me, in-your-face
anything is an instant strike. If I want to push anything, I'll EQ; I don't like phones with built-in distortion.
As for midbass, I get a track with a plucked string bass. A midbass hump pushes the bass forward, and gives it that ghetto-car-stereo buzz. The Golds do it, and the IE8s do it bad.
@average_joe
Top-Tier: FX500, TF10
Near-Top: SE530 (treble rolloff, too-polite bass), IE8 (ginormous midbass, needs more instrument detail)
And when you mean the FX500 has a peerless and commanding presentation of all music, are you saying you think it should be alone in the top-tier category and everything else is a step down? |
No. In addition to the final sound quality, I'll also consider the amount time I spend squinting at my equalizer to get there. This is my beef with the Golds; great sounding phones, but it was such a slog bringing the sound out that when they started sounding good, I was physically startled.
