After replacing the pads and removing the thick felt disc covering the driver, I ended up with a headphone that has no bass and treble so piercing, it can cut right through my ear drums. So the tinkerer I am, I decided to take this mod a couple of steps forward.
Knowing that velour pads are mostly used on open back headphones, I tried to listen to it without the cups, just by putting the pads on the baffles and pressing them against my ears with my hands. The headphone sounded a lot better, so I came to the conclusion that this headphone should be made open.
The tuning of the driver is a bit weird too. It looks like it was engineered for an open pair of headphones, but then was used in the closed HD2000. I guess it's a way of keeping the production cost down. Instead of engineering two different drivers - one for closed, and one for open pair, just make one, and tune it according to the configuration it will be used in.
The weird thing about the tuning of the driver is the thick felt disc in front of it, and the dual layer of rice paper filter in the back, with no openings. That was probably meant to tame the treble. In addition to removing the felt disc, I cut out all of the cavities on the outer layer of the rice paper filter on the back of the driver. The outer layer was probably meant for fine tuning, but I didn't find it to have an audible affect on the sound. I cut three holes in the inner layer. One hole makes it sound a bit flat and analytical. Two additional holes elevate the mid bass and make it a bit warmer. Don't be afraid to experiment, cause you can always tape those holes back with a
3M surgical tape.
I drilled four 4mm holes in the baffle, taping them over with a surgical tape.
Drilling six 7.1mm holes in the cups, inserting metal ferrules, I harvested from a 6mm air tubing connectors and gluing the with an epoxy from the inside of the cup.
I took small pieces of speaker grill cloth, and pushed them through the ferrules using a 6mm Teflon tubing cut into pieces the length of the ferrules.
And this is the result...
This process leaves you with six 3.5mm holes in each cup, which is enough to call this headphone at least semi-open. Now it sounds like it was supposed to sound after the mod
@1clearhead suggested. And looks pretty striking in my opinion.
