DJScope
- Mar 24, 2014
I just removed the foam pads on my pro 80s. The sound stage improved a lot and treble was increased. This might go well with the HM5 pad mod.
OK just did it and ran SineWave before and after and once in between with the foam still there on one and not on the other. What I noticed is that you lose controlled bass from 20-30Hz but you regain a little bit of the 4kHz region and the treble now extends up to 15.5Khz, before it peaked at around 14.5kHz.
