The T50RP Paradox | reviews, discussion, & mini-tour impressions (index in second post)
May 12, 2013 at 9:27 PM Post #421 of 750
jus gonna buy myself a hotdog....
and pour thru the "bible", yes n pour myself a glass of shiraz.
meanwhile, get an alpha pad n stick it on one of my headfones..n zzz.
May 13, 2013 at 12:24 AM Post #423 of 750
Luis, care to spill more info on your new project?  It been some time now since you first mentioned about it a while ago.
+1 I need to spend some money on upgrades
UPD: Oh, I've got a question - does somebody know where to get "compatible" and cool-looking headband cushion for paradox vader - it's strange but it clamps much more on the top of my head than my basic paradox and I hate the way suspension looks - ruins the beautiful look of Vader.
May 13, 2013 at 11:10 AM Post #424 of 750
I'm still working on it. Don't want to let the cat out of the bag just yet...
I want to make sure that they are sounding the best they can with what I have in mind.
If any of you find one...let me know. Those suspension bands are getting harder to find for me. I feel I'm going to have to find a new solution soon as they really are getting difficult to source for a decent price.
May 13, 2013 at 12:23 PM Post #425 of 750
I use this:
http://www.amazon.com/Replacement-Leatherette-Universal-Sennheiser-Beyerdynamic/dp/B00862522A
http://www.ebay.com/itm/Headband-Cushion-Comfort-pad-fit-GRADO-SR60-i-SR80-i-SR125-i-SR225-i-Headphones-/190702643884
You have to stretch it really hard to fit over the headband but it does fit. I find it very comfortable.
May 13, 2013 at 12:40 PM Post #426 of 750
I use this:
Thanks! I've seen this headband - comfortable one, but those snap locks... :frowning2:( The one from Beyer Custom One Pro - https://www.storedj.com.au/products/BEY-C1HB-BLACK looks super sexy to my taste, but I'm not sure it will fit :frowning2:( And the price...
May 13, 2013 at 11:19 PM Post #428 of 750
this is the first time i am seeing the hanger head bands..:p
as hi end headfones gets heavier n heavier,
there should be a relook at how the cups are held up/down...
maybe supported from the shoulders,
with a screwclasp to adjust the clamp on the head..lol
May 14, 2013 at 12:20 AM Post #431 of 750
I don't know if it would provide enough cushioning but I'm certain that it would fit: http://www.ebay.com/itm/Headphone-protection-sleeve-For-Sennheiser-DENON-Beyerdynami-GRADO-Monster-/221224123289?pt=LH_DefaultDomain_0&var=&hash=item3381fc3b99
The snapping buttons are smaller and hidden. It's fairly extensible so it might be possible to add a layer of foam / cushioning beforehand and wrapping the wool headband around it.
I'm loving two on my Grados right now, no burning spots at all with the heavy HP 1000.
May 14, 2013 at 3:46 AM Post #432 of 750
This doesn't look good to me - it looks like my grandma sewed this for me ^_^
So far Sennheiser foam headband pad looks like the best option for me - http://www.custom-cable.co.uk/sennheiser-hd650-replacement-foam-headband-pad.html  or http://www.custom-cable.co.uk/sennheiser-foam-headband-pad-for-hd600-hd580.html - it looks OK and I suppose will do the job well.
May 14, 2013 at 9:43 AM Post #434 of 750
I never tried the Sennheiser strap, but I did make a snap-on headband cover using velour and soft upholstery foam.  It was more comfortable than the bare headband but not nearly as comfortable as the suspension strap, and significantly reduced the clamping force (since you had to extend the cups down further, and it effectively pushed out on the headphones).  The elastic of the suspension band helps to pull the cups against your head and slightly increases the clamping force from stock.  This can be tuned by increasing or decreasing the length of the elastic used, or by using a tighter or softer elastic.  The first strap that I made, I used elastic that was way too tight and it felt like the ear cups were smashing my head in, LOL.  After trying out a bunch of different elastics, I narrowed it down to what I have now
May 14, 2013 at 10:38 AM Post #435 of 750
Thanks for sharing your experience!
