The T50RP Paradox | reviews, discussion, & mini-tour impressions (index in second post)
May 19, 2013 at 9:21 PM Post #436 of 750
By any chance, has anyone been able to compare these to the Sony MDR-7250 or MDR-Z1000 headphones? They are both closed and have a strong studio background, so I'm just curious about how they might compare and contrast. Thanks in advance to anyone with comments!!
May 22, 2013 at 8:31 AM Post #437 of 750
subbed and interested and to theogenes, i have the z1000, just dont have the paradox, m13 should have both z1000 and 7520 if i remember right, and if hes indeed buying the paradox then you can ask him for comparison
May 22, 2013 at 5:48 PM Post #439 of 750
no problem, even im interested to see his comparison, it will be easier for me to imagine how the paradox sounds if he compares to the z1000 because i already have the z1000
May 22, 2013 at 8:10 PM Post #440 of 750
i find the soundstage of the z1000 kinda funneled when i had it...how do u find yours?
May 23, 2013 at 1:24 AM Post #441 of 750
i havent used it for a while and just use crappy internal laptop speakers since my dx100 had to be sent back but now i just got it back. what i remember was it sounds more closed in than my dt990 though im not really a soundstage guy
May 23, 2013 at 11:29 AM Post #442 of 750
I already mentioned how wonderful the Paradox sounds driven by the 30 watt/channel TBI Millenia amplifier, via the interface resistor box that Jan at TBI came up with. I am now using an external 12 volt battery supply which Jan recommended. This lowers the overall output of the amp somewhat, but that is not an issue for the Paradox. This takes the Paradox up at least another notch in terms of effortless transparency.
May 24, 2013 at 2:52 AM Post #446 of 750
Thanks for the information. I am still trying to get clean sound out of the Millenia to my headphones with no luck. Using the resistor adapter that Jan recommended I get constant clear noise out of my Fostex T20.
About the 12V battery supply that Jan recommended you, what would be the difference with the internal battery supply which should be around those 12V? I thought that it would only make sense to go for an external battery supply if it had 24V to get all the power that the Millenia can get.
May 24, 2013 at 8:23 AM Post #447 of 750
In all honesty, I have not gone back and forth between the internal batteries and the 12 volt external battery supply with critical A/Bing. Once I realized I preferred the amp driven by battery power over ac, I decided to go the external battery route. In the longer run, I don't need to be concerned about the batteries losing power over time, nor the cost of replacement ($14 at least per replacement). The external 12 volt battery is easy to recharge. But apart from that, the internal batteries (as long as they are the better, albeit costlier lithium batteries) should work fine.
Sorry you are not having such good luck with your headphones via the Millenia. Maybe, as with other situations, it's somewhat headphone dependent. The resistor network Jan came up with for me was with my particular headphones in mind (Paradox). I assume you have contacted Jan. He has always been very helpful to me.
May 24, 2013 at 10:17 AM Post #448 of 750
Fair enough.
[size=small] It is Ok, I still have high hopes. I should get a pair of Paradox and HE-6 soon enough and these are the headphones that I want to make really work with the Millenia. Still I thought that the Fostex T20 would behave similar to the Paradox.... [/size]
[size=small]  [/size]
[size=small] Anyway, like you said, Jan has always been really nice and helpful at all times and I just did not want to bother him more until I get my new headphones.[/size]
[size=small] Cheers[/size]
May 24, 2013 at 11:36 AM Post #449 of 750
[size=small]I should get a pair of Paradox and HE-6 soon enough and these are the headphones that I want to make really work with the Millenia.[/size]
Don't forget to compare HE-6 and Paradox and write about the sound
 Personally I preferred Paradox to HE-6's little brother - HE-500
