How do you like your paradox? A huge change from stock I imagine?
My memory of the stock sound is very vague. I didn't listen to it for very long since the sole purpose of buying stock T50RPs is to get them modded into a Paradox. What I did remember is that it had a mid-centric sound with no peaks. However it lacked extension in the treble and bass.
I love my Paradox. I've owned them for 5 months so far (received them on December 2012). They are my favorite headphones of all time. LFF, if you're reading this I want to thank you for delivering me audiophile nirvana!
When I received the Paradox I initially thought they had too little bass and the mids sounded dry. However after about 2 weeks I stopped going back to my Fostex TH900s and listened to the Paradox exclusively. I just needed to get used to the neutral sound after only owning colored headphones in the past. 5 months later and the Paradox never fails to satisfy.
The sound is neutral from top to bottom with only a slight increase in the lower midrange which isn't unpleasant (makes vocals feel a bit closer). The midrange sounds incredibly detailed and realistic, very similar to the LCD2's mids. The bass extension is fantastic, it only starts to roll off after 30hz. Bass impact is good, the drivers can push air and deliver rumbling sub-bass when the recording calls for it. The treble is perfect. It extends effortlessly and has the perfect level of emphasis, very smooth with no peaks. The soundstage is the best I've heard out of any closed headphone. Not quite as good has most open headphones but still VERY good. There were many times where I had to check if the sound was coming out of my speakers, no joke. The Paradox sounds amazing with any kind of music I throw at it. It presents music the way it was meant to be heard without introducing any coloration or distortions (given that you use a transparent amp, I recommend the O2/ODAC). The Paradox is good for evaluating source equipment as they are transparent.
I've owned a few other TOTL headphones in the past (Fostex TH900 and LCD2) and the Paradox beats them both. TH900 had too much treble and the bass was bloated. LCD2 had far too little treble but was otherwise pretty good. The Paradox is also more durable and portable. I don't mind occasionally packing my Paradox headphones in my backpack and use them on the go. Same can't be said for the TH900 and LCD2. The sound isolation is ok. Not enough for trains and buses but ok for places with small amounts of background noise like a restaurant and park. Sound leakage is similar to something like the Audio-Technica M50s. It does leak a bit. If you're in a quiet room and listening at moderate volume levels, a person sitting next to you can hear what you're listening to fairly well.
I purchased a third party headband pad to improve comfort. It is a good alternative to the suspension headband if you don't want the headband shaking around when you are walking. You will need to stretch the headband pad significantly to fit it on the Paradox/T50RP. Don't worry about breaking the headband pad from stretching, it won't break.
Amazon link: http://www.amazon.com/Replacement-Leatherette-Universal-Sennheiser-Beyerdynamic/dp/B00862522A
eBay link: http://www.ebay.com/itm/Headband-Cushion-Comfort-pad-fit-GRADO-SR60-i-SR80-i-SR125-i-SR225-i-Headphones-/190702643884
Comfort is very good with the headband pad above or the suspension headband. Comfort is not as good as the Fostex TH900s and Denon D5000s but good enough for me to wear all day without complaints. Using the stock headband without padding or suspension headband causes discomfort after about an hour, too much pressure on the top of my head.
Feel free to criticize my review, I'm open to any feedback.
My Paradox portable rig (photo taken before I started using the headband pad):
