RPGWiZaRD
- Jan 31, 2010
Can you please tell if the modding impacts overall clarity ?
It impacts it in a GOOD way, you get more forward midrange, especially I thought female vocals sounded just tiny bit too distant/recessed for my liking without the mod (I prefer very forward/"in-your-face" midrange) so the mids get clearer. The bass gets tiny bit more impact/strength but at the same time more controlled, less midrange bleed and slightly less reverb to it (so it sounds a little snappier/punchier). The highs remain about the same as without mod. It's all about how much you leave the openings uncovered after having removed the inside foam, leave all holes uncovered actually results in worse clarity than stock due to very veiled highs and way too much reverb while completely covering all holes will result in a more "lifeless"/analytical sound, brighter than stock and less bass as well as smaller soundstage. I got the best result like this when leaving bottom hole + 1.5 ~ 2 mm of one of those sideholes open like in the pic below. Electrical tape on the inside would probably work/look best. I just used blutak on the outside so I could easily test whether how much I should leave uncovered for best result.
(click pic to see fullsize)
