RPGWiZaRD
- Jan 31, 2010
Yea the value is quite crazy if a strong bass presence is an important requirement. It's funny how I've went from like DT770 Pro - 145 EUR to M50 - 140 EUR, D1100 110 - EUR, XB700 - 55 EUR, XB500 - 43 EUR and now Panasonic for 35 EUR (with a couple of others in-between) and the cheaper I go the more satisfied I've become, so much for price being a good indicator for satisfaction eh... xD
I was trying to switch back and forth between the XB500 and HTF600 today and I used to love the sound of the EQ'd XB500 and thought it had a very "full", "thick" sounding midrange and now it almost sounds "thin" in comparision to the Panasonics. The XB500 does great around 1.5~2kHz especially but it's like around 1kHz it's quite recessed, this makes the midrange quite "nasal" sounding, the 2kHz or so area sticks out too much and you can't perfectly "balance" the whole midrange nicely on it. The Panasonics are more balanced in the entire midrange and is very forward around 1kHz where XB500 is the least forward in the midrange which becomes quite noticable when switching back and forth and even dragging 1kHz slider almost to the top on XB500 it's like the mids would still often sound more "full" on the Panasonics. There's also a very noticable difference in bass response between the two, especially after the simple mod to the HTF600. The HTF600 is so much more controlled; there's not that much reverb (it's on the border of too snappy but I wouldn't say to the point I would be looking for more reverb in it) and there's no midrange bleed despite boosting the bass further using ZO or EQ to get it to the levels I liked with XB500, the Panasonic does respond a lot worse to EQing and even if you drag the sliders like half way up in the lows, it's not such a drastic difference and the bass still stays VERY controlled despite the large boost (well a 6dB boost on the EQ sounds more like a percievable 2~3dB or so boost perhaps), if I'd do that with XB500 it'd become a earthquake-simulation for your head and has a lot greater added bass boost at same settings (that 6dB increase probably results in around 6dB percievable increase). In some tracks I could use a bit more "uncontrollable" bass with the Panasonics but for others it sounds just perfect, if you're looking for very strong bass but controlled bass response, I'd definitely check out the simple mod to the HTF600.
