I have had my HT600s for nearly a week now. I have been burning them in with pink-noise for at least 3-4 hours a day. The burn-in has definitely made a difference to my ears. Out of the box they were quite boomy and vocals seemed to be veiled for lack of a better term. After burn-in the bass tightened up a bit and it didn't bleed as much as before.
However, I still felt that the vocals could use some work. They still sounded a bit veiled to me.
Upon reading this thread, I noticed RPGWizard's mod and decided to give it shot. I just happened to have some Dynamat Extreme lying around, so why not?
Now, my mod is inspired by but is a bit different than RPGWizard's. I started by removing the fabric vent cover as RPGWizard did. I then laid down some dynamat on the inside of the cups with the foil still on. I left the vent hole completely uncovered.
When I put them back together, I quickly determined that this was just not right. Vocals had almost a hollow sound to them. Most likely due to the vent being uncovered.
So, I went back in. This time, I removed the foil from the dynamat in the cups and basically just completely lined the inside of the cups with just the dynamat material, no foil. I covered almost all of the vent holes except for the bottom one like RPGWizard suggested.
Now, I know what some are thinking. "How could you do that? You'll ruin the bass!". Yes, the bass presence is definitely reduced but ruined? No, not to my ears. Actually, to me, this mod has made these headphones much more balanced. The bass is still there, but it has much more detail now. Also vocals really stand out now, they are pushed forward and the highs are quite crisp and detailed.
It sounds quite nice now, much more balanced across the spectrum while still maintaining a bass presence that goes quite deep.
As of right now, I am going to listen to these some more to see if this will be the final mod. I definitely feel that this is an improvement over stock.
Do note though, as stated, this mod does reduce the bass a bit. So, if you like the HTF600s for their mass quantities of bass, I would suggest you don't do this. This mod is more for balancing.
I took some pics and will upload them later today.
Thanks to RPGWizard for all of the info in this thread. It really helped me while I was doing the work.
