JiggaD369
- Apr 18, 2005
Sounds interesting but pushing the transistors into oscillation doesn't sound like a good idea.
Nice![]()
And you replaced the 4700µF and 470µF caps with what kind of caps?
Can you hear an improvement?
When replacing the BD13916/14016 and LM317/337, does there need to be any matching done (as in the case of BC550C/560C)?
I'm just about to order the kit for this amp. I want an op-amp better than the one that comes with the amp and better then the class-A mod dual OPA627. I'm new to op-amps. Currently I'm using a Indeed headphone amp (same as bravo hybrid) with a clear, flat, uncolored and transparent Siemens ECC88 A-frame tube (with IRF 630 output MOSFET). [I'm sure nobody here has ever mess with that sort of stuff. (That tube should probably sound similar in another device)]. I love to keep this sound, but I want something that is solid state that I can through in my bag and take with me without worrying about damaging tubes. I'm thinking about the LT1364 and I want to know if it fit the bill for what I'm looking for, and how do I make it class-A biased?
The ideal sound I want from an op-amp:
-A nice big soundstage that matches my headphones nicely
-A nice flat balanced frequency response that has good extension on both the high end and on the low end
-Very detailed and analytical
-A tad bit weighty
-Transparent and clear
-Good amount of low level detail (sensitive)
-Good Imaging
-Sibilance is alright only if it's in the source file and it's being true to the source
-Keep music feeling natural & musical while being accurate to source
-Fast, but not too fast to seem unnatural or too slow to be muddy
-NOT boomy, bloated, bassy, colored, congested, gentle, grungy, honky, mellow, layed back, muddy, muffled, smeared, warm, veiled, or tubby.
If this op-amp doesn't match ^, do you know any one that will work better for the task.
P.S. I'm into AKG headphones, so I'd really enjoy the input from fellow AKG people (all opinion welcome, but don't be shy AKG people (and if you are one, please say so in your post)).
P.P.S. What is the common basic mods and upgrades that most people here do to their amp these days.
-A tad bit weighty
-Good Imaging
Thanks![]()
The big caps is Epcos LongLife 4700uF 50V 105C. It is good caps I think. I didn't try Nichicon Gold Tune 5600uF 50V, because I doubt that it's real Nichicon (maybe I'm paranoid).![]()
The 470uF caps is Epcos 35V 105C. I've change them because of heating. I think that 85C is not enough. It is not the best choice, but I didn't find any better in local stores. I didn't notice difference in sound compared to Elna.
Also I've used another BD transistors.
