BlaBlaBla
- Aug 4, 2010
Awesome job fitting those trim pots in! How did the yellow tantalums you have in there affect the sound?
Usually, capacitors in supply region also affects the sound. Polystyrene has more air and mild presentation, very fast and has precision. MKC has strong mids and "in your face" presentation but tends to mild things. Good MKP posses precision and bigger and (very clean) power than polystyrene but it is not so wide. MKT has power like MKP but harsh and sterile presentation (MKP is better). Tantalum capacitors? It is pure power cap, with direct presentation and it demands something in parallel....
It is good to put 10uF or even 22uF in Vadj circuit of regulator. It gives better noise rejection and stability. In regulator output (Vout) circuit it is good to put the smallest cap (that you can without putting circuit into oscillation).
BUT HERE we have 470uF electrolytic capacitors after regulator and close before transistors. So capacitors mentioned before (story about MKP, MKT, MKC etc...) do not affect sound too much in this case...
Electrolytic 470uF capacitors represent main power reservoir for output. They collect (suck) power directly from regulators much faster that headphones can spend. They collect already "cleaned" power (small voltage jumps are cleaned with Vout caps). Bypassing 470uF capacitor will mean that you "clean" power once again. Too much voltage "cleaning" leads to artificial and "boring" sound.
If you remove Vout capacitors and put them in parallel with 470uF capacitors then you can have bigger influence on sound. But also might put circuit into oscillation. Without oscilloscope this is not worth doing. It is not safe.
Removing 470uF capacitors will give you (according to some people) the best sound, in a way of sound stage, dynamic and speed. I tried that, and it is true (for driving ATH).
But this involves weak bass and total absence of "punch and grunt" for "more demanding" headphones like AKG...
