BlaBlaBla
- Aug 4, 2010
Hmm, I think I learning what all this DC offset is all about, now. Thanks bla.
But what confuses me is one channel is 14.3 mV and the other is 4.2mV. Is something wrong? I tried every gain setting but it's always about ~10mV apart.
P.s. I use 2107.
Nothing is wrong. Because of transistor mismatch, you have DC offset. In a circuit of regulators (LM317 and LM337), instead 1.1k resistor, you can put 1k resistor, and in series with that new 1k resistor - 200R trimpot. Then you should lower the Vout voltage of both regulators for about 0.5 volts and tune it to the lowest possible offset. "Sweet spot" in my setup is +14.2V and -14.25V. But I have BC109C and 179C regulators. You have to find "sweet spot" in your setup. It really does not matter if supply voltage is 15V or 14.5V or 14.2V.
But do not go under 14V because regulators could start dissipate too much wasted power (21V-14V = 7V, lets say 7Vx0.3A = 2.1W, 2.1W*27C°/W = 57C° above room temp)
Usually, for high demanding loads (headphones are not that kind of load) Vin - Vout is around 3V. In Lovely Cube Vin-Vout is 6V (21V-15V = 6V) that means better stability on Vout, but also bigger heat dissipation. Bigger Vin-Vout difference menans better stability but needs bigger heatsink. Smaller difference means lower stability but also smaller heatsink.
