TheKisho
- Aug 24, 2009
I'm listen LC with MBQuart 450 PRO. Don't know how the sound would be with AKG. But MBQuart has the best sound with the 2134 (stock OPAMP). The most comfort and slightly more dark sound with 627 class A mod. I also have tube amplifier Laconic HA-02, and I think LC with stock OPAMP sounds more naturally. But tubes is tubes, your favorite songs which gives you maximum pleasure with your tube amp will never sounds exactly the same way with transistor amp.
I hear they [OPA2134] are muddy, bloated and have limited sound stage, I rather avoid it [The OPA627 I hear kind has a muddled mid range at times as well]. The AKGs would make the flaws dead obvious as well.
It's a hybrid. Beside the tube doesn't add much to the sound (unlike the cheap chinese 6N11). While I cannot get the exact same sound I can achieve something similar with a good op-amp and a much better amp (the original indeed circuit isn't perfect).
Originally Posted by BlaBlaBla /img/forum/go_quote.gif
Maybe you need too much.
You should try OPA2107. If it is too bright and wide then you can put it into A class and get stronger mid range. OPA627 is too expensive.
Maybe. But I would like to get close to that on my first few attempts. Playing it picky usually helps to get the majority of the way there.
I'm fine if it's bright. Does it have good extension of highs and lows? Can you describe it any farther? Is it drop in able without pin rerouting or biasing to preventing being unstable oscillating? I don't like the OPA627 or most BB op-amps how they are described, they all seem to be described as sounding layed back, slow, bloated, and colored.
I might get a LT1364 and OPA2107 for starters. Can somebody tell me how to bias the LT1364 for class-A with bias that is just right for it (or my likes). Sorry, I'm new...
Any more suggestions before I start buying? [Post #490]
