mochill
Audio 123 need to try the Venture Electronics duke ☺
i tried alr very disappointing lolAudio 123 need to try the Venture Electronics duke ☺
Why?
Important notice: Output impedance of M3 is 0.14 ohm
Previously we marked the headphone output impedance of M3 a high value, which is inaccurate-we use our regular testing standard from the full-size units, which is with a different load. But we recently found out other brands are using a total different standard of testing-a common standard for DAPs. This is why we are now with a new value and need to revise our specification.
Thanks.
Under the new standard(the common one for DAP), M5 is 0.18 Ohm and M2 is 4.7 Ohm. There is a 4.7 Ohm resistance in the M2 circuit.
I just uploaded my full review of the LEAR NS-U1: http://www.head-fi.org/products/lear-ns-u1/reviews/15804
It's a single dynamic driver in-ear with second integrated crossfeed (called NatroSound™) driver that can be activated and deactivated. It does a good job for a dynamic driver in-ear around US$200 (I'd say on-par w/ Finder X1 but with a different approach; not as good as the LHF-AE1d though) and I have discovered some interesting things with enabled NS. However, the real fun just starts with the additional NSC-03 cable that lets one tweak the amount of bass and NS depending on preference - then the mids can also be tweaked to sound neutral with NS on (with the standard cable, the mids are on the thick and warm side when NS is engaged).
Great review as usual, Chris! What I'm curious about is the cable connector. Does it just snaps in, and if so - does it stay securely connected? It kind of reminds of JH cables, but I don't see a threaded collar on the cable. Also, wondering if there is some kind of a guide/key notch, so you don't attach the cable 90deg off.
Yep, I was very surprised that the FLC8s is even very slightly more detailed in the mids than my UERM - it's the first time for me a cheaper IEM has surpassed the UE's midrange resolution. Treble and bass refinement definitely go to the UE though.
